2. Engine compression ratio
Krzys
The turbo engines have the potential to deliver exceptional highway gas mileage, they're just limited by the gearing.
FWIW - the six-speed trans in the current GTO has somewhere around a .7 overdrive ratio in 6th gear, which helps the LT1 attain the EPA highway rating of 29!
Ken- my friend's WRX with a boost gauge is all over the place (no boost, some boost, lots of boost)- the turbo appears to be active all the time (just not overly active unless asked)
Juice- wouldn't that take away from GT/XT sales? I think the base engine should have a little more hp anyway.
Rob- I was thinking since the car is rev-limited to 130 anyway, they should change the gearing so that it would accelerate faster (a la FXT) but give it a tall 5th gear (or preferably 6th) for highway cruising/fuel economy.
Krzys- But is the compression ratio off boost different in the NA engine?
I forgot, the 17" wheels on the GT probably have more rotational inertia than the 16" on the 2.5i, decreasing fuel economy.
tom
however, I will say that the STi's six gear is just about perfect. it's tall enough that you don't want to use it below 65-70, and if you're going really fast --just imagine you're on the autobahn -- it keeps the RPM range reasonable. I think that type of gearbox ratio would work great in a 250 HP Legacy GT or 3.0R.
~c
My 2 cents (Canadian)
Owen
I would love to either see an additional engine option or somehow bump up the performance of the base engine. I am not certain I want to pay for the performance of the turbo or H6 motor since I am fortunate enough to own another vehicle that satisfies my performance craving. I own a 98 Outback that I will be looking to replace sometime in the future, depending on whether it starts to nickel and dime me or not. I just can't seem to pull the trigger on another NA 2.5L engine with a 4 speed auto. It can just be too anemic at times. If Subaru could give me a bump in performance either through AVCS or maybe even the 5 speed auto, all while keeping the prices near the current 2.5L prices, I would be sold. I don't care if it is an option or standard across the board as long as it doesn't add more than say $500-$800 to the price.
Karl
Some would argue my 2 cents is worthless! ;-)
tom
What the other guys noted about compression ratio, etc... makes my point about the engine. When an engine is designed for 250HP, there are off-design penalties when you are only using a small fraction of the engine's capability, such as highway cruise.
Craig
if the factory fuel map was done well, it should get very comparable if not superior highway cruising MPG. it is tuned pretty rich in the upper RPM range under load, but hopefully they leaned it out as much as possible under vacuum / very low boost in the midrange.
~Colin
Any plans for Subaru Direct Injection ?
Did you know that the STS comes with THREE different final drive ratios. The AWD model only comes with the middle one.
There is certainly enough power for a 6th gear, me thinks.
Maybe 3 engines is too much. But 168 to 250 is a *huge* jump. I don't think a 180hp base engine would steal turbo sales. It's a totally different level of power.
While we complain, a while back the Lancer made you choose between a 120hp base model or a full-blown EVO!
Talk about a big gap!
Now they have a 160hp model.
-juice
Listen up, Subaru, lots of folks want something in between!
-juice
Then everyone would be happy!
tom
Three engines 168,208,257hp.
Make that four engines, the 300hp S60R.
Listen up Subaru, some folks want something above and beyond (and are willing to pay for it).
I blew away a 911 on the freeway yesterday.. He might not have known we were racing, though..
But yeah, 168 sounds familiar, no? 208 is about what the light pressure turbo in the Baja makes. 257 is close to the GT. 300 is in the same ballpark as the STi would be (maybe).
So to match Volvo Subaru needs two new options, the light pressure turbo plus the STi.
-juice
I don't even like the spoiler on my GT, so I'm having it removed next week. I might put on a small tasteful lip spoiler to replace it though.
Juice- I don't think it would take much to push the GT to 300hp (some other sites have dyno'd the engine at 270) which means the STi should be 350?
(Turbo 3.3L H6 please?)
tom
That must've been the case. The R series Volvos has a different front bumper and some minor aero stuff but it sounds like you saw one that someone might have uh "enhanced".
Go here: http://new.volvocars.com/r/us_index.asp and check out the gallery under "Styling".
Remember - good taste isn't required for vehicle ownership.
You're right, the dealership I saw it outside of must have 'spiced' it up! It certainly makes for a different look though!
tom
So basically there is an enormous 100 horsepower gap between the two.
Look at the Honda "FP" kits or the Nismo body kits, a lot of them are a bit over-the-top.
There's money in that stuff, though, so don't be surprised to see SPT offer more of that stuff soon. Some people really want a custom look, and the Legacy GT is pretty stealthy.
-juice
You bring up an excellent point, and one that I am currently struggling with (looking at buying a new car/suv in the near future). I really want the XT or LL Bean Outback, but really struggle with paying 30K for one.. Yet, the base 2.5i is just a little lacking.. So, I am thinking about a completely loaded (leather, cd changer, sunroof, seat heater, etc) 2005 V6 4x4 Mazda Tribute. I can get one for about 23.5K which is about the same as the base 2.5i and a TON cheaper than the XT/Bean. Granted it is not as fast as the Bean/XT but it has 200HP (drove well and was pretty quick), the MPG are similar to an XT, but it does take regular fuel. If the base 2.5 made closer to 180-190HP, I would not think twice about purchasing the 2.5i limited... It would be a little more than the Mazda, but significantly cheaper than the XT/Bean... I was seriously considering a Forester, but this car will primarily be for my wife, and she is not as keen on the styling as me.. But you make a great point... Subaru, please give us a little more HP on the base (and if you dont compromsise MPG and regular fuel, you will have a winner!)
My OBXT 5EAT is going 80 at 3000 rpm. What's up?
After the last few winters here, I would really like AWD, so that rules out the 6 sport wagon for now. I would really prefer the XT or Bean, but for the price of a completly loaded Tribute (23K), it makes it very tempting. My wife insists that the car have an automatic, and I was not impressed with the base 2.5's engine and auto tranny. I thought the Tribute was a good balance between the base Outback and XT. I thought the Tribute handled well, and really liked the interior. I dove the Tribute on some wet and slippery roads and it handled them quite well. The other plus was that the Tribute has the option to upgrade to a Sirius satellite radio. We will definitely need to drive both the Outback and Tribute back to back before purchasing. I drove an 03 CRV awhile back and was not that impressed. To be honest, I have had some bad Honda dealer experiences, and have a hard time giving my money to them...
Now the further good news: at only 1300 miles I'm getting 29 mpg on the highway. I can hardly wait to see what kind of mileage I will get when it gets fully broken in.
Now for a couple of glitches:
1. Last week both my ACC and CD shut down. No power, no display, no nothing. I got into the fuse box and started pulling all the relevant fuses but they were all OK. After replacing them I started the car up and both came back on. Neither has failed again so far. The blade fuses were plenty tight so I hope I don't have some loose wires somewhere. Anyway it has not repeated so far. Has this happened to anyone else?
2. The cruise control does strange things on hills. When you are descending the car is constantly on and off throttle. Not the tranny but the engine. It cuts in and out. Is this a design flaw are do I have a problem?
TWRX
Cruise sounds like a problem, but I honestly can't remember the last time I went down an appreciable hill with cruise on in the last 5-6 years, so I am not even a reliable person to comment. I did use cruise on a trip a couple weeks ago, but didn't have it on when we got into the mountains. On fairly flat highways or those with mild inclines, it has been fine so far.
Craig
tom
Test drove an OXT AT yesterday, and noticed a couple of things. The first time i did, it was at a different dealership and the salesman rode with me. Basically just drove up the road to check the storage lot for a color combo. Pretty boring ride, although i was somewhat impressed that it was almost as quick as my WRX.
Anyway, was at my regular dealer yesterday and took another one out, this time without the salesman! First thing i noticed was the loud whooshing when the turbo kicked in! Is that normal? Car only had 70 miles on it, so not sure if that had anything to do with it. It ran fine, i just didn't recall it being so loud the last time i drove one, and my WRX certainly isn't as loud. Other thing i noticed was that, after playing with the sportshift buttons, i pulled away from a light a bit aggressively, and it got to the redline before it shifted, and even then it was confused, jumping back and forth between 1st & 2nd, until i backed off and upshifted. Now, i know one is not supposed to go over 4k RPM before it's broken in, but i figured it was a test drive vehicle and knew i wasn't going to be mine (wrong color combo!) My apologies in advance to it's future owner!! Also didn't notice the ACC doing anything too bizarre, but then again, i was a bit more concerned with the driving aspect.
Still love the car and am seriously contemplating getting one, if things fall into place. However, the tranny behavior and the turbo whoosh was a bit of a concern. Is that normal, or did i get a funky car? I asked the salesman, but he said it was because the car hadn't been prepped yet, which doesn't necessarily make me feel any more comfortable...
Thanks, all!
Oliver
Momo knob and ST shifter are separate options, though you could certainly order both together.
Craig
Yes, the 05 models are about a zillion times better for NVH (even the "base" 05 2.5i models are better than my 02 "high end" LL Bean was).
If you get an XT, it's insanely fast (0-60 in the low 6 sec range with 5MT and high 6 sec range with 5EAT). The H6 models are pretty fast too.
No issues with any of the 05 engines thus far.
Craig
Not sure about the tranny behavior. If you had it in manual mode and were using the +/- buttons, then it will not shift until you shift. So if you were bouncing off the rev limiter, it probably was flashing you a message, but it would have been totally up to you to do the upshift. I am guessing you ran into odd behavior because you probably didn't know how the 5EAT works. It actually has 4 modes of operation, and takes some studying to undertsand them. The modes are:
1) lever to the right, don't touch any buttons, this is the normal "auto" mode
2) lever to the right, and you touch the +/- buttons on the wheel. This will give you temporary manual control but will revert back to auto.
3) lever to the left, don't touch any buttons or push the lever up/down, this is "sport mode". Transmission shifts for you, but does so more agressively (I use this most of the time).
4) lever to the left, use the +/- buttons or push the lever up/down. This is full manual mode, where you are in total control. The car will let you bounce off the rev limiter all day if you want.
Ah, i see said the grasshopper! I had been shifting, but had assumed the tranny would take over near the redline. So you have to flip the lever to the right to get out of manual mode, eh?? Lesson learned, and my sincere apologies to whoever buys the White OXT from Colonial in Danbury, CT!!! Didn't mean to abuse it like that!!
Guess i'll just have to go suffer through another test drive, to see if the sound was just that car or in my brain!! :-))
Thanks again!
Oliver
I own a 05 GT wagon and it's hard to hear the turbo spool in my vehicle as well. Only if I have the stereo off and I'm accelerating up a hill can I faintly hear the turbo.
Other than you having above average hearing, it could be that the vehicle you test drove had something out of whack. Try test driving others and see if you still hear the same.
Ken
Also, is the standarad tire on the new GT a Potenza RE92, a tire dealer said it's a Potenza RE92A.I'm shopping for a full size spare.
I'd appreciate any feedback anyone can offer.
For the replacement wheel, try any one of the online parts vendors, like Liberty Subaru in NJ, which would be close to you to minimize shipping costs. Liberty knocks about 20% off the retail price, and I normally get all my parts and accessories from them.
As I recall, the wheels are $275 at full retail.
Craig
Worst thing you can do on a green engine is to drive it at a constant rpm range for extended periods of time. As long as you can vary the engine speed from 2000-4000rpm on your trip, you should be OK. If, however, you will be driving on the highway for hours at a time, that would probably be bad.
Basically, follow the break-in guidelines in the manual, they are pretty clear on the recommended procedure.
Craig
for the 05 outback, this to me may just be the cabin air filter like in other cars but 85 bucks
for it? has anyone ordered this option.
-B
PS Picking up the GT tomorrow.
Anyone have this issue and has it been fixed?
