You said in part:
Right now, I'd guess that the last guy that did an oil change is the one going to pay. My theory would be he pushed it into the engine while either inserting the oil gun or while inserting a funnel. Man, that's a poor design, IMHO.
Yeah, they aren't called grease monkeys for nothing. I have lost two oil pans to overtightening of oil drain bolts. I asked what lb-ft of torque they were using, and they told me they tighten by feel. Yeah, right. I can well imagine an oil change person jamming the oil gun nozzle in there so it won't splash on the top of the valve cover or tip out. This may have happened all at once, or taken several oil changes to bend down and break off.
I think the prior oil changes are all partially liable. Sue them all!
But, the ROTFLMAO part is that if this were written about a Dodge Neon, we'd all be selling our Neons, but since it is Toyota, we are just thinking "that's poor design" not a catastrophe waiting to happen.
I WOULD push this with Toyota; they should have distributed decals or placards or new oil filler caps with warnings on them. If they are going to put a baffle in that location, it should be strong enough to withstand normal use and foreseeable misuse.
Imagine a gas tank filler neck that had an obstruction so you couldn't push the gas nozzle in far enough to stay put and had to stay there and hold it instead of washinig your windshield.
Human nature is to push the thing in harder so it will stay.
Hence the problem, with baffles broken by mechanics doing simple oil changes.
I think this was a design flaw on the part of Toyota, and they should be giving away new oil caps with warning notes on them. You have to take into account "foreseeable misuse." Same thing with drain plugs and stripped oil pans; it's about time the manufacturers come up with a better system. Oil change mechanics are supposed to check the manual for the torque on the drain plug, then torque it on with a torque wrench, but instead they do it by feel. Plus, they forget or refuse to change washers at every oil change (as required by Honda) or use the same force with a washer system (Honda, Toyota) as with the clever GM and Ford "rubber gasket ring on the bolt" designs (which don't give the same level of resistance back when you install them, since the rubber gaskets are designed to compress to form a tight seal).
I have given up on anybody but dealers to do my work. I just shop for the cheapest, most competent dealer around and take them donuts.
I can see you are not a mechanic, I have never seen a oil drain plug tightened with a torque wrench. Of the millions tightened every year very few are stripped.
That's why I only go to dealers now, and try to use the same dealer consistently. They still make mistakes, but they will replace the oil pan if the thing gets stripped.
- the filter was easily accessible from above (didn't have to get under the car)... had to use a cap-type filter wrench to get the old filter off.
- switched over to synthetic (cost a bit more, but I'll be using 1/2 as much of the stuff over time due to less frequent changes)
I actually saw a Toyota where the filter had be put on so tight that the canister twisted in half when I tried to remove it. Took about an hour, but finally got the thing off without losing the threads or damaging the gasket seat. Would like to have spoken to the gorilla that put that one on!
It's time consuming i know, but i rather change my own oil than letting anybody else do it. Plus, it's much cheaper doing it yourself yes?
For my Elantra, I use a floor jack to raise the whole front end, lifting on the crossmember. Then I lower the car onto jackstands on each side rail of the engine cradle. This gives very solid support and balance when working underneath.
Jacks and stands are fine too and are better in some ways as already noted above. This combo will also serve you better if you get into brake work and tire rotations as part of your maintenance routine.
JR
Dirty job, taking a risk of getting under my car, have to dispose of the old oil etc..
And, for what? Save 20.00...maybe?
No thanks!
I had a bumper jack on a Cutlass long ago that dropped one time while I was jacking up the car. The dealer never asked a question when I showed up and asked how to handle it... He had that thing out of my hand quick and had a new one from the parts department and said thanks for bringing it in right away.
Jacks scare me; the screw jacks do it less, but they could break too.
Results: One large dent in the side of the car, several cracked ribs, and one kid that learned to never, ever trust a jack no matter how "commercial grade" it may be.
After spending my life in and around shops, I've seen some scary things.
Like s truck split rim blowing apart...
I contact the place that changed the oil, they actually come out to see it, and I have the truck towed to my home. I call the manager back and he says it not their fault because he isn't getting the whole story. Something about how its impossible for a filter to just fall off. (I checked where I usually park at home and at work and there is no oil drips, the filter wasn't leaking slowly.)
Later, I went back and found the oil filter. The filter has the ?bolt? that it would normally screw onto the engine, in it.
My questions are...Should I refill the truck with oil and see what it sounds like? I drove 3 or 4 miles, could have I messed up the engine? (already has 240,000 miles on it). Could refilling with oil and restarting cause even more severe damage?
Sorry 'bout the long post. I just can't believe this happened and the oil change place is not taking blame.
Unless an oil filter is welded on, chances are it can come off as easy as it goes on.
Your truck might be okay but really I don't think I'd touch it just yet, as you might destroy evidence that you'll need.
It's too late now, but stopping when I heard a bang would have been my immediate response. Sometimes road debris can kick up and hit. Still I stop and take a look! I'm assuming the filter was found about where the bang occurred along the travel route?
I keep thinking of the magic additive tests where they show the motors running for a long time with just the oil left on the bearings and no new oil being pumped to the motor. Remember where they drained out all the oil to show the additive they were selling on TV would let your motor run forever it was so good?...
Best guess? Filter was over-tightened cracking the threaded port that retains the filter and provides oil flow path. When you accelerated around the other car, your engine speed kicked up the oil pressure and "bang" no more filter. I don't know how many miles are on your engine, but assuming it has seen many oil changes this could have occured at an earlier time. But considering the time lapse between the last oil change and the failure you might need to get a lawyer. Your engine is probably toast.
I didn't know those mounts were that fragile.
It could have been cracked before and the final over tightening pushed it past it's limits.
With those extreme miles on that truck, this is going to be very hard to prove.
If you let someone else work on the truck, this does dilute your case but if you are a witness while the lube place replaces your oil and filter and starts your truck up, and if it sounds okay and has good oil pressure---well then you might have a hard time proving that you suffered damages. I'm no attorney but I do know that if you want to be the aggrieved party you need some tangible grievance.
So really, without obvious damage I don't think you have a case here in my amateurish opinion.
Yes an engine can indeed run without oil but not at road speeds---that's nonsense. At idling or putt-putting around the block, yep, you can do that and probably get away with it.
