Toyota Tundra Prices Paid
1568101117
    rappcovarappcova Member Posts: 24
    There is a very narrow grid right where the wipers park on the windshield. My salesman says he knows because they had to replace a windshield and were sent the wrong one--it didn't have the grid--and they had to reorder. Start the truck, then push the button that defrosts the side mirrors. After a few minutes, feel under the wiper blades. It's warm. Nice touch, I think.
    rappcova
    bugchuckerbugchucker Member Posts: 118
    You got a great deal and your TDA fee was about $300 less than mine.
    istundraistundra Member Posts: 23
    Hello all,
    time for me to upgrade to the new Tundra's.
    My main requirements are Tundra Crew Cab w/ Navigation & Reverse Camera.
    According to some salesman, Navigation and Reverse Camera are ONLY available in the Limited. Is this true?
    Also, anyone have experience in buying a Crew Cab w/ Navigation in Northern California?
    Please kindly share your experience and exact options of your Tundra.
    Thank you all! Your help is much appreciated!
    budgoobudgoo Member Posts: 7
    DVD navigation and backup camera are not available in the REGULAR at all, optional in DOUBLE CAB and CREWMAX per Toyota brochure. Any salesman should be able to provide you with a hard copy of the Tundra brochure. All trim lines and options are there. You can also find it all @ www.toyota.com. From memory I would say that you can request a hard copy brochure online also. :)
    The above should have read, "optional in DOUBLE CAB and CREWMAX models, regardless of trim line, per Toyota brochure.
    Yeah. Apparently in northern california, when i go to Toyota.com and build a Tundra Crew Cab, I am forced to select the Limited trim for the Nav and Reverse camera. Total BS!
    Can some1 please help me confirm? My zip code is 95110. Thank you all!
    gary_williamgary_william Member Posts: 52
    Here is the info of a white tundra in stock. This seems like a very rasonable deal to me:
    Model Number: 8242A SERIAL # :7X018628
    Model Description: DCAB SR5 5.7L V8 Category ..........: G
    Year ............: 2007
    Interior Color ..: FB13 FB13
    Wholesale Dealer ..: 27021
    Exterior Color ..: 0040 WHITE
    Body ............: DCAB SR5 5.7L V8
    Number of Cyl ...: 8
    VIN .............: 5TFRV541X7X018628
    Factory Installed Accessories: FE CK DZ BU HM MG RL WR
    Port Installed Accessories ..: LU Z1
    MECHANICAL & PERFORMANCE
    GVWR = 6900 lbs. Payload = 1680 lbs.
    381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8
    w/Dual Independent VVT-i
    6-Spd Automatic Trans w/Sequential Shift
    Engine Immobilizer, Cruise Control
    Tow Equip/Capacity (Except when equipped
    w/Sport Appr Pkg): Tow Cap = 10,600 lbs.
    Hitch Receiver, Supplemental A/T
    Cooler, 4.30 Rear Diff w/10.5" Ring
    Gear, 150A Alternator, A/T Temp Gauge,
    7 Pin Connector, Trailer Brake Prewire
    Automatic Limited Slip Diff (Auto LSD)
    TripleTech Frame: Fully-boxed Fr Section
    Reinforced C Under Cab, Open C Under Bed
    Coil Over Shock Double A-Arm Front
    Suspension w/Stabilizer Bar
    Multi-Leaf Trapezoidal Rear Suspension
    w/Staggered Outboard Mounted Shocks
    18" Styled Steel Wheels P255/70R18 Tires
    EXTERIOR
    6.5'' Double-Walled Bed w/Tailgate Assist
    Black Handles and Outside Mirrors
    Chrome Grille Surround, Fr & Rr Bumpers
    INTERIOR
    40/20/40 Front Bench Seat w/8-way Dr &
    4-Way Fr Pass Adj, Center 3pt Seatbelts
    Dual Zone Climate Control w/Sync Mode
    AM/FM/CD w/6 Speakers & Aux Audio Jack
    Tilt Steering Wheel
    Power Windows/Door Locks/Mirrors
    Remote Keyless Entry System
    SAFETY
    STAR Safety: Pwr Assist 4 Wheel Disc ABS
    w/Electronic Brakeforce Distrib (EBD),
    Brake Assist, Vehicle Stability Control
    with Traction Control (VSC+TRAC)
    Dr & Fr Pass Advanced Airbag System
    Dr & Fr Pass Seat Side Airbags
    Roll-Sensing Curtain Airbags (RSCA)
    Dr & Fr Pass 3pt Seatbelts
    w/Pretensioners & Force Limiters
    Tire Pressure Monitoring System
    Retail Total
    Vehicle Base Model ..........................:$ 28110.00 $ 28110.00
    50 State Emissions .........................
    Cold Kit: Heavy Duty Battery, Heavy Duty ... 100.00
    Starter, Heavy Duty Anti-Corrosion .........
    Protection, Windshield Wiper De-icer .......
    w/Timer ....................................
    AM/FM Audio w/6-Disc Changer, 6 Speakers ... 200.00
    and Auxiliary Audio Jack ...................
    Cloth Bucket Seats w/8-Way Power ........... 605.00
    Adjustable Driver''s Side / 4-way ...........
    Adjustable Passenger''s Side, Adjustable ....
    Headrests, Tilt/Telescoping Steering .......
    Wheel, Floor Shift Lever, Center Console ...
    Box with Laptop and File Storage, Trip .....
    Computer (Curr MPG/Avg MPG/Range/Temp ......
    Gauge) .....................................
    Power Heated Outside Mirrors ............... 30.00
    Front and Rear Mudguards ................... 60.00
    Daytime Running Lamps ...................... 40.00
    Sliding Rear Window w/Privacy Glass ........ 345.00
    Bedliner w/out Rails ....................... 325.00
    Preferred Accessory Package ................ 220.00
    Total Accessories ...........................: $ 1925.00 $ 1925.00
    Destination Charge ..........................: $ 645.00
    Total .......................................: $ 30680.00
    Internet price is 28,718 plus tax,title,fee's
    You can choose 0% or 3000 customer cash
    offer expires monday July 9th.
    "According to some salesman, Navigation and Reverse Camera are ONLY available in the Limited. Is this true?"
    ANSWER: NO.
    Finding one close to you may be an issue, but they're out there.
    Series: Tundra Double Cab
    Model: 4x2 Double Cab SR5 (6 Speed Automatic)- 8242
    Model Year: 2007
    Transmission: 6 Speed Automatic
    VIN: 5TFRV54147X021069
    Color: Radiant Red
    Interior: Black
    Available: 07/19/07
    Dealer Name: Jim Barkley Toyota Of Ash.
    Dealer Phone: 828-667-8888
    MSRP
    Base $28,110
    Options $5,747
    Manuf. Delv, Proc & Hndlg $695
    Total $34,552
    Selling Price $27,660
    Options Installed - View Image Gallery
    Fuel Surcharge $23
    Front and Rear Mudguards-MGAT $60
    Front and Rear Clearance Sonar-SOAT $500
    Cloth Bucket Seats w/8-way Power-BUAT $605
    4-way Adjustable Passenger's Side
    Adjustable Driver's Side
    Adjustable Headrests
    Center Console Box with Laptop and File Storage
    Floor Shift Lever
    Tilt/Telescoping Steering Wheel
    Trip Computer (Curr MPG/Avg MPG/Range/Temp Gauge)
    Deck Rail System w/4 Adjustable Tie-down-DSAT $135
    Cleats
    Daytime Running Lamps-RLAT $40
    All Weather Mats (4 pcs)-PW40 $129
    18 in Alloy Wheels w/P275/65R18 Tires-AAAT $910
    ***DVD Navigation System w/Backup Monitor,-NVAT $2,810
    10 Speakers including Subwoofer***
    8 Ch 440W Amplifier
    Bluetooth Capability
    JBL AM/FM w/4-disc Changer
    Steering Wheel Audio Controls and Auxiliary Audio Jack
    Tow Mirrors: Manually Extendable, Power-TMAT $90
    Adjustable, Heated, with Turn Signals
    Cold Kit: Heavy Duty Battery - Heavy Duty-CKAT $100
    Heavy Duty Anti-Corrosion Protection
    Starter
    Windshield Wiper De-Icer w/Timer
    Southeast Toyota Distributor Plus-FP50 $0
    Certified Technician 46 Point
    Final Quality Inspection
    Picture Asset Program
    Sliding Rear Window w/Privacy Glass-WRAT $345
    50 State Emissions-FEAT $0
    Fuel Economy Information
    20
    MPG Hwy 16
    MPG City
    Standard Features Of this Vehicle
    Mechanical
    18" Styled Steel Wheels P255/70R18 Tires - 381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8 w/Dual Independent VVT-i - 6-Spd Automatic Trans w/Sequential Shift - Automatic Limited Slip Diff (Auto LSD) - Coil Over Shock Double A-Arm Front Suspension w/Stabilizer Bar - Engine Immobilizer, Cruise Control - GVWR = 6900 lbs. Payload = 1680 lbs. - Multi-Leaf Trapezoidal Rear Suspension w/Staggered Outboard Mounted Shocks - Tow Equip/Capacity (Except when equipped w/Sport Appr Pkg): Tow Cap = 10,600 lbs. Hitch Receiver, Supplemental A/T Cooler, 4.30 Rear Diff w/10.5" Ring Gear, 150A Alternator, A/T Temp Gauge, 7 Pin Connector, Trailer Brake Prewire - TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed
    Safety
    Dr & Fr Pass 3pt Seatbelts w/Pretensioners & Force Limiters - Dr & Fr Pass Advanced Airbag System - Dr & Fr Pass Seat Side Airbags - Roll-Sensing Curtain Airbags (RSCA) - STAR Safety: Pwr Assist 4 Wheel Disc ABS w/Electronic Brakeforce Distrib (EBD), Brake Assist, Vehicle Stability Control with Traction Control (VSC+TRAC) - Tire Pressure monitoring System
    Exterior
    6.5' Double-Walled Bed w/Tailgate Assist - Black Handles and Outside Mirrors - Chrome Grille Surround, Fr & Rr Bumpers
    Comfort and Convenience
    40/20/40 Front Bench Seat w/8-way Dr & 4-Way Fr Pass Adj, Center 3pt Seatbelts - AM/FM/CD w/6 Speakers & Aux Audio Jack - Dual Zone Climate Control w/Sync Mode - Power Windows/Door Locks/Mirrors - Remote keyless entry system - Tilt steering wheel
    maciek102maciek102 Member Posts: 5
    Hi everyone, I'm looking into CrewMax in NJ. Anyone getting it bellow invoice? Another words what are the best deals out there. Thanks :)
    tickinspectortickinspector Member Posts: 21
    Check with Jim Barkley Toyota in Asheville NC. I have checked several Toyota regions and they seem to have the rock bottom best prices. Their prices are posted on their website. I have ordered a crewmax 4x2. I am told they sell about 100 Tundra's a month. They probable have about 75+ on their lot right now. Rebate on the crewmax is $3,500.00.
    Thanks for the Jim Barkley info. I have ordered one from them. Will have to drive 350 miles to get it but it is worth the savings. Everything was pretty cut and dry with the sales person. I only hope it goes that smooth when I go to pick up my new Tundra.
    Thanks for the info. I just have one more "stupid" question. How do those rebates exactly work? Is the rebate on M.S.R.P.,sticker price or what. Thanks again
    A "rebate", more commonly referred to as "Cash to Customer" or other monikers, is money paid directly to the customer, or applied to the price of a vehicle after all fees, and taxes have been applied. In the case of Jim Barkley of Asheville, which is part of the Southeast Region of Toyota, the selling price online includes the rebate. Currently the rebates there are $3,500 on all Tundras. Their selling price is really close to the invoice price with this rebate applied.
    One should always know the invoice price. That should be the starting point of dealing. Invoice, and up or down from there. MSRP should literally be taken as the "Manufacturers SUGGESTED Retail Price."
    raul76051raul76051 Member Posts: 19
    I'm looking into buying a Tundra Crewmax in the next few weeks, are dealers willing and dealing or are they being tight with the price?..
    Check out Jim Barkley Toyota.com. Their prices are posted on their web site. They have a $3500.00 rebate on the Crewmax plus additional discounts. You can get a Crewmax limited with a MSRP of $40,000.00 for about $34,000.00 after discounts and rebates.
    vinnynyvinnyny Member Posts: 764
    0% for 60 months is in effect until 31 July...
    flinchlockflinchlock Member Posts: 13
    The Tundra "Special Offers" for my zip code in Michigan (49001) are back! :):)
    New 2007 Tundra All Models Customer Choice
    0% APR for 36 Months
    0% APR for 48 Months
    1.9% APR for 60 Months
    OR $2500 Customer Cash
    Offer Ends 9/4/2007
    Mike
    flypigsflypigs Member Posts: 4
    Hi All,
    It's been a while since I've posted at Edmunds, and I didn't expect to, but... It looks like I'm selling my Dodge diesel to replace with some Toyota truck. I had been thinking 02-03 Tacomas or Tundras, but in the D.C area, they just don't depreciate, and buying new might (yes, this is a rationalization) make more sense. That's particularly true if I could come in at $500 over invoice, plus the $3000 back.
    Anythoughts?
    I got invoice +$500 in May. I had 6 dealers agreeable to this. Problem is finding what you want. If you are not picky, you should do fine.
    Thanks for the reply. I am flying down to Jim Barkley Toyota tomorrow to pick up my doublecab 4x4 shortbed 5.7. They came in just under invoice + $3000 back. It has been super easy so far, and my confidence is really high that this is going to be an easy purchase. On the down side, I'm spending $250 in airfare and an 8 hour drive home.
    Most of all I liked their internet listing of the final price and full disclosure. I'll let you know how it goes.
    Pete
    flypigs - Keep me posted on how things go with the final sale. I drive 6 hours on Saturday to pick up my Crewmax at Jim Barkley as well. Who's your sales rep. at JB?
    tickinspector,
    You asked me to post my experience with Jim Barkley, have you had a chance to read my post?
    "2007 Toyota Tundra New Owner Reports" flinchlock, "2007 Toyota Tundra New Owner Reports" #1546, 15 Aug 2007 6:10 pm
    My sales person was, "Allen, New Car Sales Manager"
    Mike
    Thanks Mike,
    Hope my experience on Saturday goes as well as yours. What are your pro's & con's on the truck so far. I am switching from chevy to toyota.
    My main reason for a '07 Tundra Reg Cab Long Bed 4x4 is for a truck pop-up camper (https://www.allterraincampers.com/, the Cougar model). I also wanted the 0% for 48 months, and I was not sure what deals the '08 would have.
    We do an annual trip to the northwest corner of Montana every year, and we HATE sleeping in motels. So, next June, I will drive to Sacramento (from Michigan) to pickup that camper on our trip to Montana.
    I only have about 750 miles on it, and no problems/dislikes/surprises, because I researched 1/2T pickup trucks to death, and Tundra was exactly what I wanted. I pretty much knew what all the good/bad things are.
    I am 100% sure you and Jim Barley will have a very good experience. (Do not forget to ask about free oil filters!)
    Mike
    That was an easy purchase. I'll post a longer reply when I get a few more minutes. We're not supposed to mention names, but email me if you want the sales guy. Another employee picked me up at Asheville's airport, and 1 hour later I was driving out of town. Price was exactly as posted on their website, which was about $100 under invoice, and then $3000 back. It was easy, but a tiny bit rushed in the dealership. They are definitely experts at this kind of a sale.
    It took a $250 flight, and an 8 hour drive home, but it was worth it, and I like dealing with a straight up dealership.
    Pete
    billmanwehbillmanweh Member Posts: 6
    '07 Tundra Double Cab SR5 5.7L Silver Sky Metallic
    Alloy Wheels
    Sliding Rear Window
    Rear Underseat Storage
    Dealer Added:
    Paint Sealant
    Floor Mats
    Window Tint
    MSRP: $30,813
    Without the dealer added stuff, the Edmunds TMV was $25,612
    I paid $24,725, $26,518 OTD
    This was at Toyota of Fort Worth. Very happy with the price and the salesperson.
    beltboybeltboy Member Posts: 9
    Bill,
    Now make sure you contact Toyota Customer service and get them to send you a check for loyalty, if you are a repeat customer, that is.
    I am paying 33,299 for CrewMax SR5
    JBL
    bucket seats
    bed liner
    TRD
    extra mile package B
    Window Tint
    Anyone have thoughts?
    beltboy - Is you Crewmax 2wd or 4wd?
    jb_turnerjb_turner Member Posts: 702
    If that is OTD 4wd that is an OK deal (although you could get it for a few bills less)
    Bought an 07 Limited Crewmax 2wd 5.7L on Saturday.
    MSRP $40,854.00
    Paid $33,513.00
    Had a great experience at Jim Barkley. I was in and out in about an hour.(They even fed me lunch) The truck was cleaned up with a full tank of gas and ready to go. Best experience I have ever had in buyng a vehicle. No hidden or added on fees. I paid exactly what was on their website. Everyone was super nice. Well worth the trip. (I to got the 6 free oil filters). The Tunda Crewmax is a beast of a truck and fun to drive.
    starwatcherstarwatcher Member Posts: 1
    Is the price outdoor price? Do you take the 0% APR for this purchase?
    The price on the internet is the out the door price plus tax & tag. The price on the internet also reflects the current rebate. If you want the 0% APR, add the rebate back to the internet price.
    watawata Member Posts: 2
    Any word on what the latest incentives(rebates/financing) are for the 2007 Tundra? The latest ones just ended on Sep 4th.
    fenderbender1fenderbender1 Member Posts: 6
    I am not sure whether I am going to pull the trigger or not, but these prices seem too good to last through next year's model...Any thoughts on that?
    Also, if I do buy, I am driving up to Barkley as they are only 75 miles from me...MANY kudos to those who posted about them.
    Rebates for the period of 9/5/07 thru 10/1/07 in the Southeast Toyota region are the same as they were in August.
    $3,000 rebate or 0% for 48 months, 1.9% for 60 months.
    Thanks for the reply. Sorry I forgot it was regional. Would you have the same information for Southern Cal?
    Southern CA specials are not posted on the Toyota website. the ones for Northern CA are and the Sept. specials are $2,500 rebate or 0% for 60 months.
    Well, Jim Barkley Toyo did not have the color I wanted, but a neighboring dealer did and they were willing to match his price. I get the truck tomorrow...Can't wait! If my calcs are correct, I am getting it for 400 below invoice before you tack on the additional 3000 Cash back...
    Now, I just have to get the old F-150 sold.
    Got the new Tundra - DC 4 X 4 Limited Radiant Red. Very nice and am blown away with all of the options. The only issue, which I hope is not an issue, is someone folded up the rear seat with the cleats for the rail system stuck in between. They left a couple of dimples. The dealer saw them and indicated he would make them right if they did not work themselves out.
    Anyway, Got a fantastic deal and will provide the name of the salesman if requested. I thought I read somewhere we could not post names...not sure.
    eric102eric102 Member Posts: 122
    Just put a deposit down on a very hard to find (in the NW) 5.7 4x4 DC Limited with Nav. The nav option in a 5.7 DC was what made this a fairly rare bird at this late stage of the game. The 08's are starting to show up on the dealers computers, wish I had been looking for trucks a couple of months ago.
    The best I could do was a $1,000 over dealer invoice (about $3,000 under MSRP) plus tax and tags, no other fees. I'm taking the 0% financing so no rebate in those figures.
    The truck is also coming with 20" wheels, TRD exhaust, sonar, tow mirrors, and the other usual stuff they option this things out with.
    You could have done better! That is pretty much the exact vehicle I got for $500 over invoice in mid-may after a 3 month search. I had 6 dealers at that price. Months later, I'm sure you could do better. You will love the Tundra even if you didn't get the best deal.
    mikefm58mikefm58 Member Posts: 2,882
    And how do you know that? Are you from the same area as he is? Prices vary widely by geographic area. I don't know why you make such a post and burst the guy's bubble.
    Its also timing, no more 07 Limited's with nav heading into my region. Didn't want to chance missing out on the 0% interest rate, no one knows if there will be any incentives on the 08's.
    jfritschjfritsch Member Posts: 958
    3000 off with another 3000-4000 in financing is pretty good if there was only one left within driving distance.
    All the chevs, tundras, fords, dodges etc wholesale 10000-14000 off msrp 1st year so there will be incentives. Starting off smaller and getting progressively larger as the year wears on. Just like in 06,05,04.
    All you folks negotiating remind the dealer that a 34000-$35000 dodge ram 1500 is discounted 12k and available for 22000+ all day long with the lifetime powertrain warranty and is awfully competitive with tundra, chev, etc. As a matter of fact check it out.
    Good luck
    --jjf
    nd93nd93 Member Posts: 12
    What neighboring dealer did you buy from? I have spoken to Jim Barkley and it seems those trucks are spoken for. I can drive anywhere in the southeast. I am looking for crewmax 4x4 limited in green and cannot find one. Thanks
    Is the Green one Jim Barkley has coming in on 9/26/07 spoken for?
    Yes
    trek_ridertrek_rider Member Posts: 1
    Anyone know of best place in or near Houston to get a good deal on a Crew Max 5.7? I received an email from Fred Haas in Spring saying he would sell at cost. Is this a good deal?
