My car is a Canadian car. The Premium (according to a print out & brochure) was suppose to have everything on the GLS V6 ++++. The CD & Station changer on the steering wheel, telescopic steering wheel & rear vent for air flow where suppose to be included as well.
I'm going in to see Sales Mgr. next week b/c even he's not too sure what's going on as well.
For a 2007 limited Sonata, searched the B pillar over and over, but only see the VIN label and a sticker with tire pressure info. Could someone please tell me in detail where you found the date of manufacture for your car? Thanks!
Any comments!? I don’t recall reading anywhere about “Hydraulic Valve Lifters" in Sonata V6. Does it worth to open the valve cover and have the taps adjusted for such a new engine?
Before, I believe when I set it to "Trip B", it stayed on "B" regardless of whether the car was running or whether the key was in or out. I could swear that was the case.
Maybe I was wrong. Can anyone confirm it?
YIKES!! Only if you want to void your warranty! Are you crazy????
I meant having it been adjusted by dealer! But even then, my hesitation is that I wouldn't have a virgin car any longer!
That gives you 24 more good reasons to change your oil frequently.
However, since my first oil change at 2,000km, i hear an annoying noise from engine, especially when it's cold. I cannot explain it in writing though, but as it reduces considerably after engine is warm, I guess it is from timimg chain, or..... Any similar experience?
van
(must be having a senior bunch of moments)
Oh yea. It's called a timing chain tensioner, and it makes a rattling sound for a few seconds until the oil pressure comes up. There's a technical service bulletin (TSB) to fix it under warranty. They gave me a loaner, and fixed mine in about 6 hours.
http://www.caranddriver.com/longroadtests/13633/2006-hyundai-sonata-lx.html
Senior moment is when age takes the memory away at times. Usually, happens to some of us senior citizens, from time to time. Or maybe even more often than that. Otherwise, everything seems OK.. for me it is trying to remember something like the name of something such as this "tensioner", which I knew, just couldn't recall. :confuse:
oh well, I knew that someone here would know what it was.
Again, thanks,
van
Any chance you may have a copy or reference something of that (TSB) regarding timing chain tensioner!? It may just help saving some time in convincing dealer about the problem, and who has to pay for it ;-)
I am a little disillisioned with the power of the 4 cyl engine. Presumably it makes 162 hp.
I live in Pennsylvania and as such have a number of hills to climb. Quite often I must be in 3rd when going up a hill and sometimes even in 2nd. The engine seems to labor in these situations.
Accelerations seems fine when on a level, but as soon there is a load the power seems limited. Anyone else have this type of problem or what are your experiences.
Additionally, I also have a problem with the transmission.
When I reach a speed of between 45 and 50 mph in 4th gear, in automatic mode, I get a slight vibration. This will continue as long as I maintain that speed. If I tap the accelerator the vibration stops. When driving in the "Shift it yourself" mode in 4th gear, this does not occur.
I think it may have something to do with the torque convertor, but do not know for sure. Does anyone know, is there any form of overdrive built into 4th gear or anything like that?
Have had it to the dealership one time for this problem but they could not duplicate it on a test drive. It is somewhat transient.
Does anyone else have this type of problem or know anything about it
Any insight is appreciated. Thanks
gandb777@wmconnect.com
From what you are saying about your transmesion I would have it checked out by the dealer. IUt sounds like the software in the computer is not right or possably the transmission it self is need of repair.
Good luck with your problem.
eagle2
I go in tomorrow to fix a rear door lock and I'll ask if they have heard any complaints about this.
The first dealer I showed my car said everything is fine.
Whereas 2nd dealer was able to diagnose the problem. They say that the sending unit is bad. They are going to replace it soon. I will keep everyone posted.
Anyhow, I wanted to defend the power of the 2.4 liter 4.. it really is a quick car. One only needs to rent some other brands with a 4 cylinder and drive them or better yet drive them back to back as I did (Kia Optima verses Ford Fusion) to see the difference.
While I am discussing the Sonata/Kia 4's I am also impressed with their smoothness and silence at idle and lack of excessive engine noise while accelerating. This is an area where the Fusion was especially poor.
Oh yes, buy them all the time for folks. Bought one 3 weeks ago, in the light blue color. They are smooth, not quite as smooth as the Camry or Accord, but they're close. As I said, they're a smooth as the Ford or the Chevy equivalent engines, and they're not bad. I'm just saying the Japanese engines are 'generally' more refined yet. NOt always, as in the case of the Toyota 4.7L truck engine, which idles pretty rough and is fairly noisy at high revs.
This whole refinement thing reminds me of a "blind" soft drink, or better yet, beer taste test. Can one tell between Coors light and another beer? Maybe but I'll bet not 10 out of 100. My opinion of course..
Personally, I can still feel a difference between the Hyundai, Toyota and Honda. But much much less difference than I did in say, the last gen Sonata....
That's the exact speed that the torque converter locks and unlocks. I believe it's something that could be fixed with a firmware update. I hope there will be a TSB to fix it. Meanwhile, it's not harmful, and can largely be avoided.
Believe it or not, there was a time when some engines were refined and others weren't.
My wife was embarrassed when she tried to start our already-running V6 Sonata. That's the first time she ever did that, and we've owned some pretty nice cars. She's very cautious now. She checks the gages to see whether it's running.
What a wonderful car, but I guess everything that had to be said - has been said.
Endure it for the benefit of the new forum members, who haven't heard the questions or replies yet. Take one for the team.
Getting off topics here, but, do you know all the toy/food stuff is actually made for and imported by American companies like Mattel? Sure the Chinese is partly responsible, but more responsibility rests with our very own american companies.
I test drove a 2006 Sonata GLS V6 recently and was pretty impressed overall. The car was extremely quiet (especially compared with my Neon), had a smooth, powerful engine, and the exterior and interior looked very nice. My only gripes were that the steering was vague and that I heard the suspension noise I read so much about. In the end, I decided to wait a year or two to purchase another vehicle, but I'll definitely keep the Sonata in mind. It deserves to have done as well as it has.
1. I recall reading that the maximum passenger & luggage weight is 860 lbs, is this correct?
2. Is it true that manufacturers set this at a certain percentage below the real tolerance limit for maximum passenger & luggage weight?
3. Has anybody here tried loading their sonata up to, let's say 1,000 lbs? for how far did you travel & how much time did it take you to do this?
4. Are you suppose to keep the tire pressure the same regardless of the total load/weight put into the car? and is it recommended to travel at less speed or it doesn't matter?
