my 90 suburban is cutting out and dying, sometimes i can start it right up other times it wont start. i have recently just changed the entire wire harness behind the distributor as the wire were brittle and it was shorting my ecm fuse. i have changed coolant temp sensor, fuel filter, egr valve, cap, rotor any ideas? i am losing my mind.
You might want to try to figure out what the problem is when it's happening by carrying a spare spark plug with a ground wire. Can you hook one up? If you have a coil for each plug then you could have a 12v test light check for power at the primary connection on one of those. You could spray ether into the air intake and see if it fires on that. It's possible that you have bad fuel or a clogged intake in the tank. My own "burb" has an intermittent check valve that releases the pressure in the fuel lines. It doesn't happen often so I just bang on the tank bottom. That either re pressurizes the lines or jars the check valve but it starts anyhow. That usually happens when my tank is below half full. You could have debris clogging the tank screen. When you say cutting out and dying do you mean it stumbles before it shuts off? If so that could mean the spark is weak or the engine is starved for fuel. An immediate shut off might mean that a switch or bad connection turned the engine off. Can you think of anything in common with it's shut offs? Any driving condition, engine temperature, weather, fuel level, etc.? How long did you have to wait to get it restarted and did it start normally then?
Do you have any other car problems that are easier to fix? No, really sometimes odd things are related.
thanks, i regularly run under half a tank i have changed fuel filter but not screen in tank. also fuel pump relay like i said just prior to this i kept blowing ecm fuses had to change wire harness now fuses do not blow. but this new problem has occurred. i always get a big blast of pressure when i open gas cap could this somehow effect? yes it stumbles at one point i was on freeway and just put my foot in it and i made the 40 mile round trip but when i slowed down in town it started to stumble again. service engine light comes on when it stumbles and goes off when it goes again. it does not always die right away but now it wont start. one other question, when i turn engine to crank should i hear fuel pump running? i know after i turn off key it still runs for a few seconds. thank you for your help
I have a 1998 Suburban 5.7 gas . The fuel pump has been replaced 2 times in 2 years and gone out again . I did replace the relay but stll no pump noise when the ignition is turned on . Any ideas , both were name brand pumps , is there anything else that could be causing this repeated problem ?
I'm going to be buying a used Suburban in the near future. Looks like I can afford the '01 -'04 models. Are there any years to stay away from? Basically, what years had the least amount of problems? After searching this forum it seems like they have electrical problems,tranny issues and fuel pump issues...anything else?? I wish I could afford a newer one but this economy is killing me and the family is getting bigger. Thanks for your time.....
Haven't owned those model years, but that sounds about right. Dashboard cluster stepper motors, which can easily be sent away to be rebuilt, transmissions, and fuel pumps. You'll also read about vibrations.
I'd make sure you figure out which seating arrangement works best for your family, and buy a vehicle with the correct seats. Too difficult to find someone to swap after the fact. For my family and our 2 suburbans over about 15 years, it's been the bench seats worked best.
In order for the injectors to work, they need to have a certain amount of pressure on the incoming line. As well for the fuel pump to work, it also needs to be pushing against a certain pressure. This is why the fuel lines need to be pressurized after a fuel pump is replaced. I believe that the fuel pump will actually make more noticeable noise when the fuel level is low and the pump can't establish this pressure. I don't know for sure but I believe that this pressure is maintained by a pressure regulator that allows excess fuel to return to the tank. If too much fuel is allowed to return then the fuel injectors won't have enough. If the system is shocked by banging on the tank then the regulator may resume proper functioning.
The engine light is probably coming on because the engine is going so slow that the alternator is not charging very much. That's to be expected.
I turned it off, 15 minutes later tried to re-start and engine turns over fine but it dosnt even try to run....re-placed fuel pump relay.....checked pressure at fuel filter input and no initial pressure from the pump with key in on position....is the pump bad?
i believe that you need to pressurize the fuel lines before the pump will pump on it's own. You may be able to do this by banging on the bottom of the fuel tank with the fuel cap on.
have 06 sub dropped tank and put new pump in last year since then can't fill with fuel without pump constantly clicking off takes half hour to fill tank dealer just replaced fuel canister and fuel vent saying they were plugged this did not cure the issues thinking is has to do with tank where fuel drops in taken any ideas be greatly appreciated
This truck has a history of inadvertent starting probs. When it starts it runs perfectly; no hesitation, no backfires, no stalls. Once in awhile though, it would start then immediately stall. At those times it would take many tries and sometimes some wait time until it started finally.
Last week it stopped starting altogether. No cranking at all and very little electricity to the truck. Replaced the battery and cleaned the VERY corrode cables. Removed and checked the starter. It passed.
Now I have good power to the truck. Dash lights work. Headlights work. Wipers work. Brake lights work. But no ignition, no sound from fuel pump, no turn signals, no reverse lights.
I checked all the fuses in both boxes and all look good. Don't know how to check the module thingies in the under-hood fuse box.
I thought maybe a bad ignition switch so I replaced that and I think I put everything back the way I found it.
It is the factory alarm, my '01 has the same problem and there is no chip in my key either. The dealer seems to think that I have a bad wire harness. Typically if you wait about 10-15 minutes the truck would start. Sometimes I would have to do a full reset by disconnecting the battery overnight.
First of all you have to remember why people post on a forum such as this in the first place, because they're having a problem. Not everyone is going to post that everything is just rosy with their Suburban.
Take me for instance, I bought my 1990 2500 suburban with over 300k on the odometer in February and have have no problems with it.
Also, the late 90's and early 2000's didn't have a very refined interior going on in concerns to Chevy trucks, but you bought to carry people and haul things which it should do admirably.
Hey everybody, I was wondering if anyone knew how to tell what type of brakes my suburban has short of removing them and measuring them. Its my family's only vehicle at the moment so I can't take them off then go to the parts store. Its a 1990 3/4ton 2wd with a 5.7L engine and turbo 400 trans. Autozone is calling for either a JB5 or JB7 front caliper. Thanks for the help
i need help replacing the control on the column. i have a 97 Ls 1,500 with air bag. is there someone out there who can tell me how to accomplish this? the air bag is what scares me.
I picked up an 89 Suburban a year ago with TBI 350. It occasionally gave me an error light when going up reasonably steep hills. Here a few weeks ago it took a complete dump and would barely run. I happen to have an 89 Caprice TBI 350 and an 89 Astrovan TBI. I just went through the most obvious likely things it might be.
I replaced, O2 sensor, TPS sensor, Map sensor, brand new cap, brand new fuel filter, and then noticed I had antifreeze dripping from my exhaust pipe. I went ahead and replaced my intake gasketts and was pretty good except when it warms up.
It drives reasonably well cold except sometimes a bit gutless when taking off, when it is fully on the other hand the idle keeps switching from low to high and is constantly dying. Very wierd is that when I try to restart the engine the timing is way advanced. I know the computer controls timing and that the only way it can do that is by varying the spark along the width of the terminals in cap, not much advance ( is this accurate?) I figured if I placed the distributor in just a little off from where it originally was and that was the computers method of advance it could try to advance to the point that the spark might miss the terminal (am I even on the right track here). I have gone back and checked my marks on the manifold and distributor and it lines up perfectly, I cannot imagine that I could have put it back in more than 1/32 inch from it's original placement, I am beginning to think it may have been having timing trouble before I took out the diributor and is just a continuing of that problem, does the computer have a dead mechanical set timeing or is it a passive sytem for determining the timing?
I have read that there is a timing bypass wire that you may unplug to set the timing, I guess this resets the computer back to its starting point anyone know ehere to find thid wire and exactly what they say to do?
Okay guys, Computers, I can understand... Vehicle Repair/Maintenance... not so much. So, be easy on me, I'm tryin'.
We have a 2003 Chevy Suburban. We bought it in 2005, so I don't have service records all the way back. I probably don't do as good a job of maintaining this thing because a.) I don't know how to do it; b.) I can't always afford it when it should be done (not a great money manager either). At this point, I'd rather try to learn how to fix it than ignore it and risk something happening to my family. It may be nothing, but I can't afford to pay someone to tell me if it is nor not, so here I am.
Over the past week or so, my wife has been noticing a rattling sound coming from what she says is under the car, below the drivers seat. I just heard it for myself today and it really doesn't sound good. I have NO clue what I'm looking at under the car... just recently learned how to change oil and brakes - yes, I'm new to vehicle repair. Therefore, ANY advice (even if it's, "Dude, this is too much for you right now, take it to the dealership and figure out how to pay for it," is greatly appreciated.
Sorry, I guess that would have been helpful. It happens both when the car is moving and when it's just idling. I have noticed that it tends to become louder if the tach drops and revs back up to prevent stalling or when I'm applying gas (also causing the tach to rise). However, you can still hear it when idling.
I know its been years since you posted this but I am Having the exact same problem I have a 2002 Chevy Tahoe w/ 60,000. miles . I've had the fuel pump changed the battery and alternator changed and the throttle cleaned. If you could please let me know what you did with yours. I'm to the point of deciding to either keep trying to fix it or just trade it in. Advice please, thank you :confuse:
I apologize for the problems you are experiencing with your vehicle. Were you planning on taking the vehicle in to be diagnosed? Please keep me posted on any updates.
I have an 03 Suburban 4 wheel drive. I've had it for almost a year now. Love the truck. Having weird sounds and looking for advice on what it might be. 1. Started with a clanking noise when I was turning (think 3 point turn). I don't know if it did it at higher speeds cause I never heard it. 2. Starting hearing this rattling sound when I accelerate. Goes away when I take my foot off the gas. 3. Now when I take my foot off the gas (highway speed) I notice a slight vibration, not in the wheel, but the truck in general. 4. This is probably unrelated but the AC blows cold when the truck is in motion, but when idling it is warm. Thanks for any guidance you can offer. My husband is out of the country currently so he can't look at any of this. It seems to be getting worse so I don't want to end up stranded with our 3 kids. Thanks!!
The dome lights in my 2002 Tahoe will not come on intermittently. They will not work if I try manually turning them on, or when you open a door, or when you turn off the ignition. When they are not working, the other problem i noticed is that the Horn will not sound, when you lock the doors with the remote - It is supposed to sound when you hit the lock button 2 times.
When I am driving I will hear a clicking sound coming from the fuse box area. The lights will work after I hear the click sound.
Not sure if it is related, but another problem that recently started, is when I turn the ignition off, the radio is supposed to stay on for 10 minutes, or until you open a door. It turns off as soon as the ignition is turned off - This is not intermittent, it does it all the time.
My 95 suburban stalls while sitting at a stop light . You can feel the rpm's surge and then drop to where the truck stalls . It does start up every time. Also , if I put the truck in gear , step on the brake and turn the wheel , it stalls . The first 5 minutes the truck runs it seems to be ok , after that it stalls. The dealer says they have no idea why and can't fix it . That cost me $200 . They say they can start replacing parts at my cost and no gaurentee that it will fix the problem . I also called GM with not much help from some woman on the phone who keeps calling the dealer for updates . I was told some "specialist" would call the dealer but that never happened . Any help would be much appreciated .
I would suspect a vaccum hose leak. This would affect the mixture with the greatest affect at idle. Sorry I can't be more specific as to where the leak is. Just go over all your vaccum hoses ad replace if you suspect they are cracked or leaking. If you do this it would be cheaper that the dealer doing the work. After that the failure would be somewhere in the intake manifold which starts to get more expensive.
My 2002 Suburban had a loud buzzing relay for the dome lights. I changed out the relay and about 2 weeks later the new relay failed by buzzing continously. Very loud. Any thoughts?
I was hoping someone could help me out. I have a 2008 Tahoe. For the last several months I have been having issues with the instrument panel. Every now and then when I turn the ignition on, my digital display on the instrument panel does not work. When this happens my other gauges like fuel, batt, oil pressure do not work properly. Everything else seems to be working just fine. Car starts and speedometer and tach work just fine. Sometimes it stays that way for a couple of days sometimes it fixes itself within few minutes. I have check the fuses and tried to see if there were any loose wires underneath the steering wheel area, but I have yet to find anything. There is no obvious thing that make the problem turn up, as well as when it fixes itself. Has anyone seen this before or does anyone have any suggestions? Any help would be great.
I am hopeful you'll receive some great insights from members of the Edmunds community. If you would like for us to check into anything (warranty/recall information), don't hesitate to send us the last 8 digits of your VIN via email at socialmedia@gm.com Best- Sarah, GM Customer Service
I have a 1988 Suburban I just replaced the driveshaft and u-joints, drove it short distances for the last week, yesterday I drove it about 40 miles and it started to make a stuttering shudder. It would go for a few miles then shudder for about a three beat then go fine for a few more miles then do it again. Could it be something with the driveshaft or something else?
I had a similar problem on a 2000 Jeep Grand Cherokee. Only shuddered intermittently at about 72 mph (typical interstate cruising speed), but when it did shudder, it shuddered hard. Turned out to be a bad tire. I put 4 new Michelins on, and the problem was gone.
Up to now have bought Expedition because of its fold down rear seats. Having to remove seats for luggage makes no sense, when you get to your destination and unload, you are without seats which in our case is a problem since our cottage is over 400 miles away. GM rep at auto show a few years ago had no ready reply to that statement!
But now things are changing. Finally Chevrolet realizes the practical value of folding seats and will have them on the 2015 model which supposedly is coming out Spring of 14.
Am I the only one experiencing the total failure of the metal on my 2008 suburban? I have owned three and this is the first (and last) time I have ever had an issue. At the hinge my metal has completely torn. Both the dealer body manager and independent shop agree that this is a defect, however GM says too bad over 100,000 miles. I say, this truck is not supposed to have the drivers door fall off even at 200,000 miles. What does the mileage have to do with the door metal failure. I have taken up as far as they will send me. HELP. Anyone else out there. GM did offer to give me a letter for $2000 off a new Chevy.... Right that helps. I cannot locate a used door for a 2008. Any help appreciated.
and type in your year/make/model and your zipcode and it will search the salvage yards in your area for the part. I did a quick search and it looks like 2006 - 2009 might fit your burb.
New to the Suburban family here. Just purchased an '06 nine passenger LS. Some of the dash/steering wheel/radio-ac control lights are not working. Are there replaceable bulbs or would this be a fuse issue? Thanks
There are 3 fuses that control the dash board gauges and lights. All three are located in the underhood fuse block:
IGN E 10 AMP IPC/DIC 10 AMP RADIO 15 AMP
If your gauges and radio are working then it's probably not a fuse. Your lights are not actually bulbs but LEDs built into the different gauges and dash displays. I don't think they are serviceable but you can pull the instrument cluster and see if they are removeable. An easier solution might be to just call your dealer and ask the service/parts folks there if they can be replaced.
Let's keep the discussion here so everyone will benefit. Thanks!
SUVs and Smart Shopper
Sean
Any ideas?
B
They're old!
lol
It has security but I think that's only for the radio.
Besides, why would that effect the reverse lights and/or turn signals.
Thanks though.
B
Thanks for the help
Thanks guys,
David.
Car not moving, engine idling?
Car not moving, rev engine and rattling frequency change?
Car moving, rattling in frequency with tire rotation?
I guess without hearing it, I might suspect a fuel pump, muffler baffle came loose, airshock pump (if you have that option).
Thank you,
Caron, GM Customer Service
Any thoughts?
Best-
Can't wait.
Anyway - if you need to find a used door go to
http://www.car-part.com/index.htm
Good luck in your search.
IGN E 10 AMP
IPC/DIC 10 AMP
RADIO 15 AMP
