Honda Pilot 2006
Anyone seen any news on the 2006 Honda Pilot? This is the only thing I've found:
"The Pilot is set for a mid model change in 2006. From what we've been hearing the styling upgrade should be fairly extensive. You can also expect to see VCM (Variable Cylinder Management), Curtain Airbags and 2WD trim levels. XM you ask? We don't have a confirmation but we believe it will be standard on select models. The first 2006 arrivals will be in September."
I'm in the market for a Pilot, but I'd like to know what the 2006 model will bring before I decide on the 2005.
You can wait until August for the screaming deals on the outgoing Pilot...
And check out the 06 Pilots too...
Side airbag curtains
Standard XM radio
New taillights
Perhaps a Special Edition Model - more bells for fewer $$
Not too much new anticipated
It will need to compete with the new Hyundai Santa Fe which will be released later this year or early next. This company clearly has its eyes set on Honda and may be a formidable competitor.
1. VCM (as in the Ody)
2. Stability Control (even the 05 CR-V LX has it standard now)
How radical could a 'fairly extensive' styling upgrade be for Honda ?
As far as the style is concerned, I really like the 2005 Pilot. The 2 things I would have changed would be the addition of side curtain airbags and a better color selection.
The '05 blue is pretty dull - I would much rather have had the blue that is available on the '05 Odyssey. The '05 red looks nice, but only comes with the ivory interior, which my wife did not like.
1) VCM
2) Side curtain air bags
3) Standard stability control across whole line (not just EX-L)
4) Some exterior trim updates(?)
I purchased my '05 EX-L knowing these potential changes. It would be nice to have the additional features, particularly the side curtain air bags. But the '05 is a fine vehicle in of itself. There's always new features/content each year given the annual incremental updates that Honda and most other makes are now adapting during each model design cycle.
http://auto.consumerguide.com/auto/new/reviews/full/index.cfm/id/38135/
For the front treatment (headlights, grill, that would not be a bad thing.
It would be nice if they added some of the interior updates found in the Ridgeline too but that might be too much to expect from a mid model refresh.
As for 2WD versions - as long as it has VSA with it, it is probably a good bet for states that do not see a lot of snow. And it would save $ on initial purchase and gas. But you would essentially have a cramped minivan in Ute clothes. Probably not great for resale.
Frankly, I wouldn't have a vehicle with a PAX on it until they are more widely used. BTW remember that the Odys with PAX have no spare so when you hit the mileage limit of the PAX after it is flat, you are stuck.
Hybrid
DVD + Navigation System in same Pilot
XM Satellite radio
Wireless connectivity..
When will this happen ?
I am hoping it looks a bit more like the Ridgeline in the grill and headlights and interior.
At latest we will know in September '05 when the '06 models come out.
If you think about the current iteration of the Civic, you can see the pattern pretty clearly.
Since this is year 4 of 5 for the Pilot, a change of some sort is expected.
I am guessing that the 2WD variant of a Pilot, if made, will be like the 2WD variants of the CR-V and Element - FWD. But that is just a guess.
In my opinion, 2WD combined with VSA might not be too bad a combo outside heavy snow country or trail duty.
I am hoping it looks a bit more like the Ridgeline in the grill and headlights and interior."
According to a few sources I've read (all from Canada, actually), you'll get your wish. :shades: Here's what one had to say:
"Here are some notes from ******* ***** that was up at the Honda Of Canada
Production plant last week and he got to look and the new Civic and
revisions to Pilot (all new Pilot comes next year)
Pilot details: New items - Back lit dash i.e. Accord - Rear entertainment
system i.e. Odyssey - No front/rear filler panels above bumper - more
vertical front end i.e. Ridgeline - smaller high intensity headlight bulbs
in different designed housing - clear rear tail light lenses - grill
similar to Ridgeline but solid horizontal bars - all new front/rear bumpers
- very nice looking new alloy wheel" (from CarSpyShots.net).
Just to confirm what others here have written, standard rollover-sensing side curtain airbags, Variable Cylinder Management (VCM), XM Satellite Radio, and 2WD models will most definitely be available. The standard Vehicle Stability Assist (VSA) rumor has yet to be confirmed (to my knowledge, anyway), but is very possible.
Take care,
Mike
ummm... as opposed to what? using a flashlight to see it? Is it NOT backlit now? I could have sworn it is.
Rear entertainment system i.e. Odyssey
Now I'm POSITIVE a RES is already available on the Pilot. Is it a different version?
I too did not understand what was meant by the RES option beyond what is currently available.
Since the info is a re-post from elsewhere its hard to know what exactly the original author meant.
But like many other Honda fans, I always hope they will make some little change that is important to me when the new models come out!
No, if the '06 length changes at all it will only be because of the bumper modifications.
An all-new Pilot will supposedly be out next year. Honda might then take the oppurtunity to switch the Pilot to the "global truck platform" (on which the Ridgeline is built), possibly increasing the size a bit.
Mike
Yep, it's different. The Odyssey's has a 2" larger screen and some unique features (such as a faceplate that can be released separately and used as a remote control). I have to assume that's what the original author meant.
Mike
Maybe so. It was so hard to get information on the 2006, I think everyone's just guessing now....
Have a great evening, Joe!
Mike
I haven't the foggiest idea as to what the seats will look like - but you're right: the current ones look really weird! I personally would like to see some active head restraints for better whiplash protection. The '07 Hyundai Santa Fe will have them, so, who knows...?
I'll reply back to you once I find out, 'k?
Mike
Kristie, it appears that the front-seat head restraints do have a "peep-hole" in them. But from what I can see, the design seems to have changed. Kinda hard to tell, though....
Enjoy!
Mike
The Honda website lists the Curb Weight as 4414 for the LX and 4431 for the EX.
5954 lbs. is a lot!! Only full size trucks approach that kind of weight. A Navigator is 6000 lbs, an H2 is 6400, and an Escalade is around 5600 lbs. No way the new Pilot will even approach 6000 lbs, it'll need a V8 for power. 255 horses won't cut it.
No, nothing yet. 'Course, 46 lbs really isn't all that much, so I figure it's possible. Even a slight (favorable) revision in the payload capacity rating or some other, relatively minor alteration could do it.
Have you noticed that all V8 4WD Toyota 4Runners qualify... by 5 lbs!
Mike
