Will
Mike
http://www.honda-tech.com/zerothread?id=962851&uid=999378256&dir=1&postid=111228- 54
What do you think? Did I get ripped? I'm suspicious that the speedometer problem may have been the reason the transmission wouldn't shift. The car only has 93k miles.
Thanks for your replies.
Sammy
They replaced the whole instrument panel for me, had nothing to do with transmission.
Sammy
you didn't say you tried that - what do you mean by tried that? did you remove the switch and check that the switch closed the circuit to enable the motor to drive the window to the up position? did you purchase another switch or perhaps swap the switches from the doors (if they are identical)? did you see if you had a loose wiring harness to the switch?
i'm trying to help you - i bet noone else can read your mind.
is there any mechanical binding that you can see between the window and the rubber seal going around the window frame? i had a '94 which bound on the seal and would slow the motor way way down.
barring all that, i suppose if i felt confident enough doing so, i'd remove the door panel and verify that when I operated the switch, power was getting to the motor. if it was, but the window motor (regulator) wasn't working, i'd probably see if i could purchase one used (perhaps at a pull-it place), or perhaps swap it with a regulator from another door used infrequently.
if i didn't feel confortable doing that, i'd bring it to someone that does (independant perhaps).
Anyways, I know for those of you who are "car" friendly some of our questions can seem stupid, but I appreciate the help very much!
Before taking anything apart, check the fuse in the underhood fuse box. When my switch went bad I was finally able to at least get the window to go up by pushing hard forward on the switch with some downward pressure to momentarily get the contacts to work.
The front torque rod and left front mount are easy to inspect and replace if needed if you're going to do it yourself. Support the engine with your jack and a block of wood under the oil pan. The torque rod is just a matter of removing the two bolts. For the left mount you will need move the cruise control to get the cable out of the way and adjust the engine height with your jack as necessary to slip the mount out. When I replaced mine they cost roughly $20 for the front and $50 for the left at Autozone.
The rear mount, however, is a different story.
The automatic transmission models (I'm paraphrasing my maintenance manual here) are equipped with fluid filled dual chamber, electronically controlled rear engine mounts. These mounts smooth out any low frequency vibrations created under high load, low engine speed conditions such as idling in gear with the air conditioning running. When the engine increases rpm's the computer makes the mount firmer.
I haven't tackled this mount (yet), but it appears to be quite labor intensive. If you're going to have a service department changing your mounts, I would highly recommend getting a cost quote first.
Sammy
I am fairly sure the problem is with fuel delivery. I know the engine is getting ignition spark at times when the problem is present. I have replaced the fuel filter, fuel pump, and fuel pressure regulator and the problem persists.
PLEASE HELP. I am out of ideas, anyone had similar probs or another idea of a fix?????
Thanks for any info Catam.
see
http://techauto.tripod.com/s.htm
While the front mount's main purpose is to support torque changes, mine had deteriorated to the point that the rubber had completely broken away from the mount and the left mount was beginning to crack and felt pretty spongy also. Keep in mind that I'm not suggesting you spend money replacing them unless an inspection of their condition warrants it.
That said, I still have a little vibration when idling in gear (I'm pretty sure it's my rear mount) but it's not so severe that it's worth the hassle and expense of the rear mount at this point.
I believe the warning system will beep and flash as you described when an unsafe condition exists in the restraint system, such as when a belt doesn't fully retract or lock in.
Even if they appear to be working, try giving your shoulder belts some manual assistance reaching full rearward travel in the rail, then ensure they can't be moved out of that position with force once retracted. While your at it, buckle both lap belts and with the doors closed, jerk the living hell out of all the belts to make sure nothing lets loose. If anything gives, the warning system is doing exactly what it is supposed to do.
My transmission is an automatic n it revs up when the car in drive..den i have to let mah foot go frm the gas..it was said that it would slips on second gear..it sounds like a manual..n i need a new axle on right if im correct..when i make a wide turn i can hear clickin frm the front..
thank you all guys.
Best I can tell, you have tranny problems. Is the "D4" light blinking at all when you are driving? If it is, you need a mechanic, pronto. The blinking D4 is the sure sign that you have transmission trouble.
Try another shop that is noted for high quality. If the estimate is like 3X as much, you know the first guy is doing a quick patch job for you.
That is what I thought. I took the offer anyway. It looks great after! It runs fine and looks nice. I wont get rid of my car any time soon.
rust was not too much shiftright.. only around the tires (chasis) and a bump on the hood, minor rust. They guy told me though , I might have to replace the rear windshear.
I also get to replace the upper control arm on the other side-I should've done it when I replaced the one on the other side (again, not a bad job).
I just had to change out mine as well as it was intermittently acting up. Something to use to check over and repair the old one would be appreciated.
-K
Alternatively, another manual says to just start wailing on the back of the rotor (once those 4 bolts on the back are out) but I was afraid to do that to make the car undriveable.
I was doing a lot of suspension work at the same time so I had the uprights out all together and that made things easier. I was afraid of doing the unscrew/block/hammer thing because I didn't want to hurt the threads.
Good luck and be thankful you don't have to change the front rotors very often.
I’m new to the list, searched the archives (best as I could) and found nothing that gives me a clue as to an answer to my questions.
Scenario – 1991 Accord, automatic, bone stock. Had a mechanic install a new timing belt, water pump, camshaft seal, seals, related gaskets and such. 180K on the odometer, all but 40K of it put on by yours truly.
Problem – After the above items done, drove care about 200 miles. Then got lot$ of serious metal making sound$, so stopped immediately (city street at under 30 mph). Friendly AAA guy hooked it and took it back to the scene of the original surgery. Mechanic claims the Front Timing Balancer Pulley committed suicide—an item he said he did not touch or in anyway effect. He also claims it is an anomaly.
Questions – Is he blowing smoke or is it truly coincidental? Is this a rare, or common occurrence with this engine/mileage? Should I be going back to the shop with a baseball bat (for the car or the mechanic)?
Thanks in advance for your thoughts,
Randy
I have a 1993 honda accord lx I just bought the other day. I was driving it and found out that i need to replace the brakes. I am planning on changing the pads and rotors. I heard that the rotors are sort of hard to get off. Are there any tips you can give me or anything I should know before diving in?
btw, when the timer is changed, the engine bay makes a constant ticking noise that won't go away. The good news is, it gets good gas mileage from sitting so long in between repairs!
In the upper left of the page is a Icon that says: Main relay repair.
This will show you how to inspect and resolder the main relay. Good luck.
FWIW, my son's car has been running fine since the repair, (knock on wood).
