The car was stopped at a Stop sign. Applied the gas pedal gently, but no movement for a few seconds. I could feel the wheels spinning.
The V6 has the TCS, and the TCS light didn't come on during
that time.
I noticed when that happened, the front wheel wells were filled
with slushy snow on a slushy snow road.
If the wheels are spinning, the brakes are not locked up.
I read about removing intake hoses, etc., but all I did was loosen the four screws holding down the air cleaner housing cover. I did have to pull on it toward the engine to get it up and out from under the frame but it wasn't that tough.
This was on the I-4, the V6 might be harder.
I also changed the cabin filter... that puppy sure gets dirty.
1) Use a wrench instead of a screwdriver. The screw is made for either tool. I found that the screws needed a decent amount of force when cracking them loose for the first filter change. I tried using a screwdriver the first time and ended up almost stripping the tops of the screwdriver indentation off. A socket wrench made the job a lot easier.
2) Use an extension from the wrench that will reach one or two screws that are deeper down in the bay. This is at least the case for V6 models... not sure about I4s.
But next time I am in there I will try and see if there is an angle I am not seeing.
Not to plug a product but if anyone has not ever used K&N, (or similar cleanable filter), they are worth it. Well, they are worth it if you plan on keeping the car until it dies. Just a little food for thought.
I agree. I saw the potential for disaster so I used a socket right away. They are on very tight so it takes some muscle to loosen them. It is good that they don't come out of the housing though. I hate trying to retrieve dropped screws/bolts.
The I4 has screws that are deep as well so I agree that you need an extension.
And yes, it is a tight fit but if you really force it, you can get the housing out of the way.
http://townhall-talk.edmunds.com/direct/view/.efdf924/4330
I'm sure it's nothing, but I'm curious.
I've already taken the mats inside and placed them by my heating vents for the night. That did a good job of getting rid of all or at least most of the water.
Mrbill
This is my first post here, so please bare with me.
The ploblem is with my 2005 2.2 i-cdti accord. Every now and then, when I get to about 3,000rpm, the engine looses power. It does not stop the engine, but the glow plug light comes on and starts flashing. When this happens the engine is limited to about 2100rpm, in all gears, and does not want to go any higher.
The only way I can get it to run normally again, is to pull over, turn off the engine for a few minutes and restart. Once I do this, it runs ok, as long as I keep the RPM low.
The thing is, it does not happen every day, so I am stumped for a cause.
Has anyone had this problem, or related problem, and if so, what was the fix?
Mrbill
I did this time. HandA is a great place. The last time, I had a 15% off parts coupon from a Honda dealer so I bought stuff there. That was the one and only time I've seen that sort of coupon.
Second question is, today I noticed that my heated seats are not working and my power seat is not working.....is it just a coincidence that everything is screwing up all at once? What could cause this to happen? I installed HID lights, and some people told me that it could be that, but most tell me it has nothing to do with it. I remember I replaced my battery right after I installed the lights, and my mechanic told me that if I wasnt boosting the car properly it could of screwed the electrical wiring....someone hellllllpp
Good luck!
Don't know what year your Accord is but my 06 has over 60K and I'm still on the original brakes. Lots of freeway driving though. Others have posted here that they seem to wear out early.
The front license plate bracket of my 2005 accord broke and I need to buy a new one. I called up a dealer in Houston and they quoted $58 + tax. Can't believe $60 for a piece of plastic :mad:
Any place I can get it cheaper. Can't seem to find it any where on the internet either!
Kris
...+1 (I have an '05 6M with 62k)
best, ez....
Corkscrew
I have 07 I4 Manual. Around 56K. My shims just started making warning squeal on the drivers rear. I looked at the pad depth and they seem fine still. My front have not yet made any noise.
I believe driving style and habit are the primary factor in brake wear differences.
"Recommendation" make sure whenever replacing pads that you have brand new shims put on. This way you know that you are not being taken advantage of at a brake place/dealership. Also, I don't remember if the owners manual lists the depth for change on brake pads but you should find that out for your car and measure yourself periodically. If you can't find it I am sure someone in hear may have access to that info.
But if you are not inclined to do any of your own mechanic work at the very least make sure new shims are put on so you can hear the warning sound. Especially if you were told "0" was left on the pad. That means pretty soon you would have started grinding the rotors which could triple the cost of your brake job since you would have to probably get new ones (depending on how long they were ground for of course).
Good Luck!
PS ~ Not sure if their is a "Brake" thread but you may want to find one to get more advice.
Honda Accord Brake Questions
There ya go!
My 2003 Accord LX V6 only has around 47K miles. Now when I press the brake pedal, only the left stop light comes up. But all bulbs appear OK, because if I use remote key to close or open the door, all lights flash correctly.
Anyone can give some advice? Thanks.
I have always been advised to replace bulbs simultaneously, so if you do have to replace the bulb replace both of them. I would guess they are cheap at any auto parts store.
Good luck!
Thanks for the advice.
What do you mean 'running lights'? When I checked the manual, it says we have the following lights on the back:
tail light/stop light
backup light
high-mount brake light
turn signal light
I probably will swap the bulbs during the weekend to see if it is the bulb or not.
The wear indicators are attached to each inner pad, for each caliper. The shims are thin plates that go between the pad backing and the caliper. The wear indicators are part of the inner pad, and not a separate part. The shims, in most cases, do not come with the pads, when you purchase them. If the shims have rust on them, they should be replaced. When you buy brake pads, they should come with a packet of grey anti-squeal paste (looks like never-seize to me). This is to be applied between the pads and shims.
Further research on my part indicates that the Honda pumps are failing at an unusually high rate. This item costs around $500.00 to replace.
Please post up if you have had this issue with your 03 and newer Honda, and the amount you paid to have it corrected.
http://www.driveaccord.net/forums/attachment.php?attachmentid=10581&d=1200936994-
I will be taking in the Accord for certain 120k and below services (it's now at 126k+ miles - I've discussed these services recently on this thread and will give an update on where I am with everything soon to help others who are in the same boat as me). I'll show them this and see what they say, but I guess it's exclusive to the 6 cylinder? maybe there's something for the 4 cylinder too?
Are these TSB's available online to the public?
My two cents! Good luck!
You are basically going to be paying for a warranty that will last you until you hit 100K on the odemeter. Most people drive more miles before the yearly deadline.
Personally, I wouldn't pay for an extended warranty on a Honda or Toyota for that matter. If you can wait, you should wait until the end of the factory warranty to get an extension if that is what you desire.
I have just under 60K on my 07 EX I4 Sedan Manual. It still runs and operates like the day I got it with 7 miles on it. Maybe the carpets a little worn and have a few scratches around the ignition from my keys, but that's it.
Good luck on your decision. I also have confidence in the high level of maintenance I perform to keep my car operating smoothly. If you want the piece of mind up until 100K that you have to decide what that piece of mind is worth to you. Obviously, anything could happen, hence the ability for warranties.
I used to work for a luxury used cxar dealer. We had the abil;ity to sell warranties. If I remeber correctly Honda warranties only cost us around $500 dollars. So if I could sell one for $1,300 I would be making $800 pure profit on you. I would offer them $600. If they say they can't tell them you are not willing to pay that much for a warranty that will probably never get used, it is a Honda after all. ( I am sure one of their selling points to you on it was reliability anyway.)
Good luck whatever you. Just remember if you know you could pay cash for the warranty then you should use that to your advantage by not feeling pressured to buy it now. Then try and talk them down, and if they keep trying to get you to pay more tell them what I mentioned. If the sales person knows they can make an extra $100 they will at least do that. just don't let them bully you or try and hard close you. You can always buy the extension later.
I'll do some shoping around but unless a great deal presents itself I will probably not get it.
