Hyundai Santa Fe Maintenance and Repair (2007+)
Since the 2007 Hyundai Santa Fe represents a brand new vehicle, with problems unique and different than past Santa Fe's, I feel it deserves its own discussion thread so we don't have to sort through problems with prior model years, which are not likely applicable to the 2007.
When we picked up our new Limited from the dealer, the outside temp was reading 140 (actual temperature was in the 60's). The dealer looked at it prior to our taking delivery and said it needed a new temperature sensor. We will hopefully have the new sensor installed tomorrow. Hopefully it will fix the problem. While driving it the last few days I've noticed that it will often register 68 degrees (regardless of actual outside temp). This is a significant problem since the climate control system is partially controlled by the outside temp reading it senses, as was mentioned by ginop.
[EDIT] - Looking at the work order, the language is as follows:
"Tech confirmed fault with engine compartment fuse box. Tech performed following repair per Hyundai Tech Line. Jumped connecter B-39 to D-12 and D-6 to B-45. Outside temperature reading normally at this time."
Whether this is the best fix is unclear. My guess is there will be a TSB or even a recall notice in the near future. Limiteds are the only SF's with the problem since only they have the outside temp display.
1) Inside door panels: the material below the door handle began to seperate from the frame. It took a few weeks but Hyundai installed new panels and all is well.
2) I have the "kerlunk" under the car first thing in the morning after driving 50' or so. Seems to be a common ailment based on other postings. Does anyone have any answers for this ?
3) Most annoying is that the body "creaks" when I make a sharp right turn. I don't know if this is just extreme body flex or what.
4) Other than these minor issues I have 5000 miles trouble free.
On a sadder note, we've only had our Santa Fe for two weeks (Platinum Sage Limited AWD w/ Premium & Touring Pkg) and my wife got hit by another driver this past Saturday (it was raining and he lost control as he passed her in the left hand lane on an interstate highway and hydroplaned into her . There's a fair amount of damage to the driver's side front fender and door. We took it for some estimates on Monday and are scheduled to have it in for the repairs in two weeks. Not surprisingly, none of the auto body shops we visited could bring up any prices on 2007 replacement parts from Hyundai (the one we went with ended up having to base the estimate on 2006 parts).
- Frank.
I am sorry to hear of your accident. I hope no one was seriously injured. Metal can be replaced.
Is there any Hyundai documentation about this known issue that I could share with the manager?
This is my first Hyuandai and I am not disappointed yet. My previous car was a Mitsu Eclipse and the service doesn't even compare to Hyundai's. When Hyundai looked into this issue for me, they gave me a loaner. Mitsu would always try to charge me for a loaner or wouldn't give me one at all.
I apologize if this is old news.
From the 2007 Santa Fe Shop Manual
USER OPTION MODE
The BCM (Body Control Module) offers 3 items user option mode for a user convenience (AUTO DOOR LOCK, ARMIDISARM BY KEY, HORN ANSWER BACK)
It is able to set up the enable or disable of AUTO DOOR LOCK function or AUTO DOOR LOCK operation vehicle speed when using it.
It is able to set up the enable or disable of enter the burglar alarm mode when using door lock by the key.
It is able to set up the enable or disable of horn inform function when using door lock by the key or RKE.
Select option "SNATAFF(CM)" and press ENTER.
Select option "BODY CONTROL MODULE" and press ENTER.
Select option "USER OPTION" and press ENTER.
Select option "AUTO DOOR LOCK STATUS by using the direction button(& IT).
Select the parameter by using the direction button( . I ) and press ENTER to save it. (Disable I 5km1h II Okmlh IISkmIh I 20kmlh I 2Skmlh 130kmlh 13SkmIh I 40kmlh)
- Frank.
I can now read the outside temperature (Too bad it's getting so cold out. Sometimes I don't want to know how cold it's getting ).
I usually keep the third row seats folded down so I have more storage in back. If I then fold down the second row seat on the drivers side, I cannot easily fold the seat back up because the bottom rear of the seat back gets caught on the headrest of the third row seat. If I reach in with my hand and press the bottom/back of the 2nd row seat in and carefully guide it past the headrest, I can get it to fold up, but it's a pain.
Upon looking the situation over, I see that when I fold flat the third row seat, the compression of the seat back with the seat bottom pushes the headrest of the 3rd row seat up by about 1/2 inch. Just enough so the 2nd row seat back does not have enough clearance to easily fold up and down. This only occurs on the drivers side. The passenger side is a tight fit, but is able to open without my pressing it. If I take the 3rd row headrest off, I have no problem.
My question is, does anyone else have this problem, or is mine just an isolated case of things not being aligned correctly that I can get fixed by the dealer? Please let me know if you do or do not have this problem. Thanks.
2007 Santa Fe AWD Limited with Touring and Premium packages
Also glad to know they are using the same fix. I was worried that this may not be Hyundai's standard fix long term. I figure it's worth while asking at the first oil change if they have changed the fix to something else in case this proves not to be the standard way to go. Also I figure to hold on to the repair slip in case I have to bring the vehicle to another dealer and they question who did the rewiring.
When I read through the user manual, there is a mention of rain sensor option on some models. I think it means it can be set to AUTO mode when wiper is ON and speed is ON.
I have a 2007 GL Premium AWD, I do not think it has it. I have tried it, there is no difference in wiping speed when it rains lightly / heavily.
Does anyone have their rain sensor turned on. Which models?
On another note, the dealer gave me a 2007 Sonata to drive while my Santa Fe SE was being looked at. Not a bad car but the center cluster is ugly/cheap looking.
I really liked the 07' Santa Fe until trying to install our baby seat. Wondering if anyone has any suggestions. We are expecting our 2nd this spring. We took our infant seat and tried to install it, but found we had to have the passenger seat very close to the dash in order to be able to get the baby in/out of the vehicle. Our seat is made by EvenFlo and has a jagged handle like the one in this picture that is causing us to move the passenger forward. I think there is a better designed seat/handle or even a smaller seat out there. Wondering if anyone has any suggestions.
PS - Our local dealer said if we can find a seat that fits he will buy it for us
http://www.sears.ca/gp/product/B000FO2ZZ4/sr=1-2/qid=1164304765/ref=sr_1_2/104-2- 360570-6915104?ie=UTF8&searsBrand=core&mqnodeid=15858271
We have had our 07 SF since August and we put our standard rear facing Graco model in the middle. We added a child rearview mirror to the center headrest and it works very well.
Yes, you have to reach a little farther but it's not a big deal and on inclimate days it gets you out of the weather a little better.
Also, we had a Dodge Grand Caravan prior to the SF and always had to push the passenger seat forward to accomodate the rear facing child seat. I think this is a problem common on most vehicles. Same problem on my Ford Taurus. On the rare occasions that we do use a different vehicle, we put the child seat in the middle. It also has the benefits of placing the child further away from side impacts and accommodating other passengers better in our opinion.
JCS
The range will vary from tank to tank depending on what your previous/current MPG was/is.
-thanks
aaron
Hiss isn't overwhelming but it's definately noticeable.
Am planning on taking it into the dealer but was curious if anyone else has experienced it.
Cheers,
Sol
My Santa Fe makes this slight but definitely noticible
grinding noise when it's being shifted from 2nd gear to
3rd. It's as if when you are driving manual, you let go of
clutch a little too soon, and your transmission makes
a sound, just like that.
But it happens every once in a while.
I talked to the local dealer, they said they can't fix
what they don't know. When a mechanic took it for spin,
he couldn't feel anything. And told me they can't start
fixing without something concrete dignose to begin with.
I thought my full description of what's happening is
good enuf to start..
Any way, this is bothering me big time.
Anybody else having this issue ?
Or Did I pick 1 out of 1000000000 santa fe which has
Also, does anyone feel its slow to respond? Better than half the time it allowed the interior to get a good dose of fumes before switching to recirculate...
Called this one in and the dealer has asked me to bring it in for inspection after Christmas. Will update this post on the outcome.
Link To MP3 Trim
Link To MP3 Gain
Link To ID3-TagIT
With the ID3 TagIt program you can setup your MP3s to show title and artist, etc., when they play.
Try burning with the free version of DeepBurner. Make sure that you burn as "Data" and No "Nulti-Session". See the following link.
Link To DeepBurner
Don't use paper labels and try burning at a lower speed.
Use folders for your music.
Hope this helps!
There are several areas you can check for water intrusion. Most are electrical. I highly recommend having a professional look at it. This issue will get worse and may disable the truck. Look for water getting to the fuse block under the hood. Also look for water some how getting into the fresh air intake. Locate and inspect the O2 sensor wiring harness and inspect for damage and exposure to the water. I am looking in the electrical manuals for more detail for you. What size motor do you have? While I wait for an answer I will guess it is a 2.7. Correct?
SERVICE MANUAL
Applies to: Santa Fe 2001-2004 and Sonata 2001-2004
GROUP
Fuel System MFI Control System
INSPECTING THE MFI SYSTEM
If the MFI system components (sensors, PCM, injector, etc.) fail, the interruption or failure to supply the proper amount of fuel for various engine operating conditions will result. The following situations may be encountered:
Engine is hard to start or does not start at all
Unstable idle
Poor driveability
If any of the above conditions is noted, first check for trouble codes and make basic engine checks (ignition system malfunction, incorrect engine adjustment, etc.). Then, inspect the MFI system components.
ON-BOARD DIAGNOSTICS
Diagnostic trouble codes are set as follows:After the PCM first detects a malfunction, a diagnostic trouble code is recorded when the engine is restarted and the same malfunction is re-detected. (The malfunction is detected in driving cycle). However, for fuel system rich/lean misfiring, a diagnostic trouble code is recorded on the first detection of the malfunction.
Erasing diagnostic trouble codes:After recording the diagnostic trouble code, if the PCM does not re-detect the malfunction for 40 driving cycles, the diagnostic trouble code will be erased from the PCM memory. However, for fuel system rich/lean or misfiring, the diagnostic trouble code will be erased if both of the following conditions are met:
When driving conditions (engine speed, engine coolant temperature, etc.) are identical to those when the malfunction was first recorded.
When the PCM does not re-detect the malfunction for 80 driving cycles.
NOTE
A "driving cycle" is completed as soon as the vehicle goes into closed-loop operation.
Malfunction Indicator Light (MIL)
The MIL lights up to notify the driver that there is a problem with the vehicle.
However the MIL will go off automatically after 3 subsequent sequential driving cycles that do not redetected the same malfunctions.
Immediately after the ignition switch is turned on, the MIL is lit for 5 seconds to indicate that the light operates normally.
The following Items can be indicated by the MIL:
Catalyst
Fuel system
Air flow sensor (MAF sensor)
Intake Air Temperature Sensor (IAT sensor)
Engine Coolant Temperature Sensor (ECT sensor)
Throttle Position Sensor (TPS)
Front Oxygen Sensor
Rear Oxygen Sensor Heater
Rear Oxygen Sensor
Front Oxygen Sensor Heater
Injector
Misfire
Crankshaft Position Sensor (CKP sensor)
Camshaft Position Sensor (CMP sensor)
Evaporative Emission Control System
Vehicle Speed Sensor (VSS)
Idle Speed Control
PCM
Manifold Absolute Pressure (MAP) Sensor (Except 2.7L V6 engine)
Idle Switch
EGR System (Except 2.7L V6 engine).
Inspecting the malfunction indicator lamp (MIL)
After turning the ignition key on, check that the light illuminates for 5 seconds without the engine running.
If the light does not illuminate, check for an open circuit in the harness, blown fuse and blown bulb.
SELF-DIAGNOSIS
The PCM monitors the input/output signals (some signals at all times and others under specified conditions). When the PCM detects an irregularity, it memorizes the diagnostic trouble code, and outputs the signal to the self-diagnosis output terminal. The diagnosis results can be read by a Generic Scan Tool (GST) or Hi-Scan Pro. A diagnostic trouble code (DTC) will remain in the PCM as long as battery power is maintained. The diagnostic trouble code will however be erased when the battery terminal or the powertrain control module (PCM) connector is disconnected or erased using the Generic Scan Tool.
CHECKING PROCEDURE (SELF-DIAGNOSIS)
NOTE
When battery voltage is excessively low, diagnostic trouble codes can not be read. Be sure to check the battery for voltage and the charging system before starting the test.
Codes are erased if the battery or the PCM connector is disconnected. Do not disconnect the battery before the diagnostic trouble codes are completely read and recorded.
Inspection Procedure (Using Generic Scan Tool)
Turn OFF the ignition switch.
Connect the scan tool to the data link connector on the lower crash pad.
Turn ON the ignition switch.
Use the scan tool to check the diagnostic trouble code.
Repair the faulty part from the diagnosis chart.
Erase the diagnostic trouble code.
Disconnect the scan tool.
