Chrysler's New Lifetime Drivetrain Warranty
That means a DGC, T&C, or Commander would possibly work for us. With a lifetime powertrain warranty, we would be able to think about one of these vehicles. I know some of the rebates are smaller than they were but newspaper ads on these vehicles are still looking good. In the meantime, I would worry about two things.
One, a new van or Commander is somewhat above our budget. We could finance it out six years and get the payment where we need it, and the warranty would still be in effect long after the payment book is an empty spine. Right now we're looking at used 02-05 Suburbans in the $10-$15K range and one of these new vehicles are more like $20-$25K.
Two, if we were to spend this extra money and get the new van and have the transmission conk out 4 years in at what would be around 80K, is the dealer going to come back and say, "you have 5 kids plus soccer and softball equipment and bring home meat for your freezer 375lbs at a time, you abused the van and we're not covering it!"
There are plenty of loopholes available.
Now how can one REALLY prove that they provided proper maintenance? I read here that saving receipts for oil purchases will be accepted as proof of oil changes. If that is true, then it proves that only a game is being played with the buyer. Then, again, I'll say, buy a moderately priced vehicle and take your chances. Do not buy a vehicle you think may require considerable repairs, warranty repairs included. Caveat Emptor. :lemon:
I have a 2007 Pacifica and it came with free oil changes until 100k. I take it in every 3500 miles and let the dealer do it. That way, if there are any warranty issues down the road, there is no argument. I also follow the book for everything else....not what the dealer says. Those jokers recomend changing all fluids every 15k.....the book says more like 45k.
The free oil changes are probably like the lifetime light bulb warranty at the hardware stores. When you're in the store to exchange the defective bulb they figure you will purchase other things that will more than offset the cost of a 50-cent light.
I have lifetime free oil changes and tire rotation from the dealer I bought my car through. All I pay is $8 for the oil filter. So far they haven't tried to hit me up with any additional services but it only has 6,000 miles.
I like to do the majority of my own maintenance anyway. I keep any receipts on things I did on my own for warranty reasons.
O.k, he just emailed me the specifics. The Jeep was MSRP $20,150....minus dealership discount of around $800... minus $3,175 rebate ... which is a total price paid of $16,163. That's around 20% under MSRP
He paid $320 in lisence and fees....$970 in taxes. The lifetime bumper to bumper warranty was $1,960
Now considering some people pay $1,960 for 4 years of extended warranty... the price for a lifetime of total coverage seems pretty darn good. By the way, my friends brother-in- law is the GM of this Chrysler dealership.
Also, will they cover an engine failure if I follow all the provisions in the warranty and I happen to put 250K+ miles and the transmission or engine fails, will they honor the warranty and fix it? Or will they come back and say it's normal wear and tear? LIfetime is lifetime, but are they saying that they expect their powertrains to last a lifetime? I'd almost be tempted if I had the resources to go buy a Chrysler vehicle and try and get several hundred thousand miles out of the vehicle and see what happens when a major drivetrain component fails...
"Q3: What powertrain parts and components are covered?
A3: Gasoline engine, transmission and drive systems (FWD, AWD, RWD or 4WD). "
It's pretty simple. Also read Q4 as well as it explains what maintenance the consumer must perform.
" If Chryslers Power train Warranty is the same as Fords here is what it cover. "
Very similar, possibly identical. It took some digging but here's what the Chrysler powertrain warranty covers;
Covered parts include:
(Gas engine) cylinder block and all internal parts; cylinder head assemblies; timing case, timing chain, timing belt, gears and sprockets; vibration damper; oil pump; water pump and housing; intake and exhaust manifolds; flywheel with starter ring gear; core plugs; valve covers; oil pan; turbocharger housing and internal parts; turbocharger wastegate actuator; supercharger; serpentine belt tensioner; seals and gaskets for listed components only.
Transmission: transmission case and all internal parts; torque converter; drive/flex plate; transmission range switch; transmission control module; bell housing; oil pan; seals and gaskets for listed components only. Manual transmission clutch parts are NEVER covered.
Front Wheel Drive: transaxle case and all internal parts; axle shaft assemblies; constant velocity joints and boots; differential cover; oil pan; transaxle speed sensors; transaxle solenoid assembly; PRNDL position switch; transaxle electronic controller; torque converter; seals and gaskets for listed components only. Again, manual transmission clutch parts are NOT covered.
All Wheel Drive (AWD): power transfer unit and all internal parts; viscous coupler; axle housing and all internal parts; constant velocity joints and boots; driveshaft and axle shaft assemblies; differential carrier assembly and all internal parts; output ball bearing; output flange; end cover; overrunning clutch; vacuum motor; torque tube; pinion spacer and shim, seals and gaskets for listed components only.
Rear Wheel Drive: rear axle housing and all internal parts; axle shafts; axle shaft bearings; drive shaft assemblies; drive shaft center bearings; universal joints and yokes; seals and gaskets for listed components only.
Four-Wheel Drive (4X4): transfer case and all internal parts; transfer case control module and shift mode motor assembly; axle housing and all internal parts; axle shafts; axle shaft bearings; drive shafts assemblies (front and rear); drive shaft center bearings; universal joints and yokes; disconnect housing assembly; seals and gaskets for the listed components only.
This forum was in defib, but now there's a rhythm. Faint though.
As pointed out, you can save a ton if you purchase online at Chrysler Extended Warranty.
