Have you managed to have it fixed?
My Mazda dealer first said it was the ABS, replaced at $1,451., vibration was still there. Then they said it was the rear drive shaft, replaced at $450, vibration was still there. Told them they don't have a clue, that they are just guessing and got all my money back.
I'm going to a local independent garage on Monday.
Any info you can provide will be greatly appreciated.
Thx
Jack
2010 fwd CX9 with 30,000. Had the exact same symptoms when accellerating lightly at about 40 mph. Took it to the dealer (still under warranty) and they changed the transmission fluid. Has been a week now, and I haven't noticed any more shuddering.
Tom
Ruth
I just started having something similar happening. Have you found out what the problem is?
Just to be clear here's what has been happening with my car: about a month ago, the car was dead and we replaced the battery. While it was in the shop, I had them do the routine service that was due and rotate the tires. As I was driving away from the service dealer, I noticed that there was a slight vibration between 30-40 mph as I drove and a scraping sound in the front right wheel area. I took it back the next day and he said the drive shaft was going bad. Nothing I needed to fix right now but that it was out of warranty (I'm at 80k). I leave without fixing and as the weeks have progressed, the noise gets louder and begins to sound like a screw that's not oiled but very loud. After several days, I call a new dealer service provider and get the bad news that it's like a major transmission issue and the car is unsafe to drive the 10 minutes to the dealer. (Note I've been driving the car with my three small children daily for weeks now.)
Ugh..
I've already taken the car to the dealer once, but they couldn't replicate both issues... it was cool out and raining. Plan to take the car back soon for a second look.
1) Driver side A/C: We've only had the car 6 months and it just started getting warmer here. As a result, didn't need the A/C until now. Long story short, driver side air blows warm to slightly cool air while both passenger side and rear are getting cold air. The situation seems to improve after about thirty minutes driving.
2) The car produces what I can only describe as a rubbing noise at slow speeds when turning right. This doesn't happen all the time and I haven't been able to figure out how to reproduce the sound.
One more problem while I'm at it: I feel like there is significant resistance around 35mph when I take my foot off the gas pedal. The car doesn't coast, it slows down significantly. This normal behavior?
Thanks in advance.
Findings: drive shaft replaced for a "known drive shaft failure issue" by Mazda; transfer case issues, bearings in a wheel broken (told they've never seen this happen before) and now the brake booster has to be replaced (also a known issue by Mazda as near as I can read). The local dealer who has the car is handling it but I'm clearly going to be out of pocket a couple of thousand dollars for "known issues" by Mazda. One remaining issue is that my tires have worn unevenly so they need to be replaced too or I'll cause my "back end" to go out.
Look, I'm not a car nut. I expect it to run properly and I expect the maker to appropriately warranty their work. That's not what's happening and I'm very disappointed in Mazda USA customer service as they say this is just normal wear and tear and they won't even take the complaint any further. Keep in mind, I've been driving around in an unsafe car for months now (as the original dealer service people said it was fine to drive) and putting my kids and me at risk. Not cool Mazda. I know 8 people who drive this car (same year and model) in my immediate vicinity. I'll be passing on my knowledge and learnings. Most of what everyone seems to describe above seems to fit into the drive shaft, transfer case and brake booster issues I've seen occur in my car.
We have a CX9 2012 with 15,000 miles, 9 months old. First owners. Full and extended warranty. Could not ask for better right? Surprise!!!!
Everything OK until last week. Out of the blue the a pungent fresh gasoline smell made it to the inside of the cabin while driving on highway. It lasted several minutes and we stopped in panic after realizing it was not coming from the old Econoline in front of us. Husband went under the car, checked nothing was leaking. I opened the hood and it was like opening a can of rotten eggs! Now the raw gasoline smell is mostly gone but the rotten egg smell happens sporadically and its intensity varies too. The dealer checked the car yesterday and concluded nothing was wrong, and that the smell is normal (WHAT? a 2012 model at almost $40,000 ???). He used a document issued by Mazda document recommending the following :
- Refill the car with good quality gasoline and drive 100 miles. We did that and nothing has changed.
- Do not drive short distances. We were driving on highway for 8 hours stretches when this started. So, I guess.... Moreover, what do regular people want their car for when they live in the suburbs? 2-5 mile drives to stores and soccer fields. Right? Therefore, I asked Mazda USA (in California) to clarify what short distance means since it is their document. They refused to clarify and passed on the responsibility to do so to the dealer. I have not asked him yet but I imagine what his answer will be.
- Avoid quick acceleration
After reading the recommendations I told the dealer what I wrote above: basically I fulfill the recommendations before taking it to the dealer's: filled-it with Shell, drove after that over 150 miles, all on highway, mostly using the cruise control so no sudden acceleration happened, and yet ROTTEN EGG SMELL!!!!!! The dealer said take it, observe it, bring it back so that we check it again and maybe we will contact Mazda directly. That is what my extended warranty bought me? Additional trips to convince the dealer to take action?
For now I am keeping the name of the dealer to myself. Will be public tomorrow if they give the same story again after a second check-up. I do not get why when the car is under full and extended warranty the dealer is covering Mazda's a... And Mazda, what kind of explanation is that? Please stand for your product! Mazda tends to make excellent cars so a few flukes here and there should be taken care of and not denied. Or, is it because Mazda is aware that this is just the tip of the iceberg? By the way, there a number of Mazda models included in that list of recommendations. Not only the CX9. So yeah, it looks like Mazda is trying to convince the stupid user that rotten egg smell in a very new vehicle is normal. How trendy, how sexy! Maybe the objective is to force us roll-down the windows rain or shine to make sure the other cars can hear the sound system that commes with the car. Yes, and that is normal!
Is it a code issue and does anyone know the codes if they think it is related to this.
Finally went to independent garage who agreed it is a transmission problem, and asked if I have had my transmission serviced recently. Told I had a few months ago "at Mazda", he asked how much I paid, told him it was $180., he said that was pretty cheap and suspected they put in the wrong transmission fluid. Couldn't prove it, but he said Mazda CX9 auto transmissions are "high end units" (like BMW. Mercedes etc) and require high end fluid. Cost should be in the $250. range. He recommended putting the correct fluid in, I agreed. The vibration has disappeared and it shifts gears perfectly. Told Mazda, haven't had a reply yet!
I have a 2010 CX-9 and experienced a vibration this weekend while driving at about 40 miles/hr. It seemed like the car was struggling tto get to speed 6 from 5. When I shifted to manual the problem was not as apparent. The check engine light flashed on/off. Car has 60K on it. Just had it serviced last week!! Took it to the dealer and waiting for the phone call. Luckily I purchased extended warranty on this car (valid upto 100K miles) since this is my first Mazda. Wondering about the quality now if this is the situation at 60K.
Urge folks not to purchase CX-9. Purchased 2008 and has had many problems, some of them well known to mazda but not covered! For example, recently our air conditioner blower filled with water -- which was coming in thru air-vents. This problem is well known to Mazda and published by mechanic web-sites (I have copies of the bulletins published before I even purchased the car! -- it's a simple design flaw -- but mazda pretends it doesn't exist -- you are on your own with mazda!! DO NOT PURCHASE MAZDA CX-9!
Just got our 2011 CX 9 GT back from the dealer. The transfer case failed at 41k miles. It's a well known problem. Our dealership is new, and they've already replaced 15-20 transfer cases. The mechanic told me there's not enough room in the case for proper synthetic fluid, and it overheats. It's more prevalent in city driving, but can and will happen eventually. Mazda paid the dealership $890 for the replacement and labor, but out of pocket, I was told it would have been $1200 or more. They've extended the warranties on transfer cases on CX 9's to 7 years and 90,000 miles, so keep that in mind if you are having issues with clunking or shifting issues. I asked the tech what other issues to look out for, and he said the moon roof has a drain that goes down through the front A pillar. If we hear sloshing, it's a clogged drain, and to take it in.
Jess
Jess
1. The car starts and accelerates.
2. I release the gas pedal and then press back while still being in 1st or 2nd gear (e.g., if I need to slow down while going uphill or taking a turn just after starting) .
This seems to happen exactly when the power re-engages to the rear wheels (after dis-engaging when I released the gas pedal). This doesn't happen always but when it does, this is the symptom. The dealer is unable to diagnose the problem. Has somebody seen this problem? Any help would be much appreciated.
I have had the same problem as Rick with my wife's 2009 CX9 (has 99+K miles on it, but the issue started several thousand miles back when my wife first reported the issue, and has steadily worsened over time), and our vehicle has spent the last 2 months in the shop with the dealership (who have provided us with a loaner) attempting to determine the cause/subsequent resolution for it.
I can recreate the problem at will when I'm driving; anywhere between 35-45 mph, 4th-6th gear (and on occasion going up a steep hill under 35mph, but in 4th gear), with a light throttle application (like giving it a little gas to maintain speed up a hill, or to keep up with the flow of traffic) the car behaves as Rick described, sounding like traveling over rumble strips, but feeling like its having a problem grabbing the next gear. When I get a good one, it feels like someone has hit or kicked the back of the vehicle.
I've had the Master Tech, Service Advisor and Service Mgr all ride with me at various times, and all have experienced and acknowledged the problem. My SA, a former mechanic himself with 11yrs experience, who happened to be riding behind me at the time, indicated he could feel the 'clunking' and 'jerking' (which feels to me like transmission slippage from driver's seat) right underneath his feet (i.e. behind the driver's seat). That's why I originally took the car in for service when I noticed the problem (my wife, the DD of the car, had noticed waaaay before me, but it was a here-there thing; once the problem exacerbated, she had me drive it, and that's when I noticed it as well), because I thought it was a transmission issue.
At this point, I'm not even sure its the transmission, and I can tell you, it ain't something a fluid change can fix, as the following attempts have been made to fix the problem:
*replaced transmission (three new (i.e. rebuilt) 3rd party trans and 1 new Mazda-sourced Aisin trans failed to
resolve)
*all transmission fluids were drained, flushed and refilled
*replacement of TCM/PCM; these were also updated before replacement was attempted.
*removal of driveshaft (its AWD Touring model) during which issue still occurs.
*there was one other thing they fixed that was broken on the back end of the vehicle, which they noticed during a thorough examination, but I can't remember what it was they fixed.
As for the transfer case, that was replaced about six months before I took the car in for this issue, as my dealership went ahead and replaced it via TSB (or recall, not sure which) since they knew there was a problem for existing TFCs, and I already had it in the shop for an oil change (didn't cost me anything since I had the superlative Ford Extended Warranty which has been a gift from God!).
After each attempt to resolve the problem using the methods indicated above, I've test driven the vehicle and each time I drive it, the problem is still there. I've even gotten to the point that I now have a route mapped out for me to test drive it that includes flat surfaces, hill and curves (this problem is easiest to replicate for me going up hills, or up hills with curves in them).
I wish replacing the transmission was the solution as we'd already have our car back and be in good shape (the transmission replacement comes with a 2-year extended warranty from FEW company), but that hasn't proven to be the case. We are still looking for a solution, which is how I found this thread when searching for a way to contact Mazda TE myself (dealership has engaged them, but they keep telling the dealership to replace the transmission...). If we ever get it figured out, I'll follow up with a post on the solution so others can be armed with the knowledge if required!
When I first purchased the vehicle, I was very pleased with the fit and finish and performance of the vehicle, but I can't believe that less than 100,000 miles that this engine failed.
The electric motor in the door (actuator) has been anemic in performance for a few months and just seems like its finally died.
I had the car in the dealer today for regular service. The tech said he would need an hour to diagnose, perhaps its something cheaper than the actuator. Rather than pay a tech an hour to play around - should I just pony up and pay $339 I was quoted to replace the actuator ? I was wondering if anyone else had this issue and any insights.
I just got a new CX-9 with Mazda’s rear-seat Entertainment System. Biggest problem I have with the system is an audio delay while playing DVDs. It’s more than a second which is more annoying than one would think when you watch a movie.
Here’s how the system works: DVD plays on monitor B which is mirrored to monitor A which has the audio connection to AUX. When playing media on the two screens individually things are ok, still a bit of a delay but not too bad. What I realized is that when a DVD is played the audio on monitor B is louder. I assume that means there is a separate amplifier involved when the DVD player is involved. That’s probably cause number one for the delay. Secondly I assume that mirroring content from monitor B to A causes another delay. Lastly, I assume the car’s amplifier adds another delay since the audio is fed from monitor A into AUX. It just seems to me that this is a cheap system, not well tested it maybe it wasn’t installed correctly? Does anyone have any thoughts?
This basically renders watching DVDs impossible, which was the main reason why we got the entertainment system in the first place. Since it is a factory-installed system and a new package offered by Mazda I believe that Mazda should be held accountable to correct this issue. Thoughts?
Cheers. Andreas
