Chevrolet Tracker Maintenance and Repair
crosscutter
Member Posts: 1
I just purchased the above mentioned vehicle and did a oil change. I added the correct amount of oil, 4 litres with filter and checked the dipstick and it only shows a little over half way to the full mark. I checked with Edmonston' Lemon-Aid book and it indicated this was a problem. Does anyone know if GM has a fix or will I just put a file mark on the dipstick where full should be??
Thanks in advance for your responces......Crosscutter
chris
Suppsedly it's a solenoid or wire.
I found this advise on another website
http://www.asashop.org/autoinc/feb2005/techtips.cfm
does this sound like a good place to start?
wondering if any one else had a similar problem.
Any help would be greatly appreciated.
Bud
thanks,
kathy
Jesse
Jesse
That should help yours to do this maintence. It helped mine. I did not realize how soft the shifts were until I changed all of this. Now its like new again. Hope it works for you also. Happy Trails
Jesse
I have good news. Discovered that the nut associated with the transmission cable was loose and just needed adjusting. After a tranny flush, oil change and nut adjustment - my Tracker is running like new!!! Quick fix, easy on the wallet.
Chevy Trev
Again,Thanks Trev..May God Bless You..Kim
I went to a AAA car care quick fix type place and they knew exactly what the problem was. Located under shifter console I believe. Quick fix, tranny flush and oil change cost $149 with labor & tax. Worth every cent.
Happy Thanksgiving!
Trev
Gerrard ">:sick: <img src="
chris
Tire size p205/70r15
Replaced the alternator, belt and battery. I start the tracker and after maybe 5 min ther check battery light comes on and then thre battery will dischrge and then die. When I strted the tracker I put a volt meter on it and it was just over 13 volts then from there once the light strts to flicker the voltage drops off.
I had the alternator retested and it checks ok.
lost at this time
2001 tracker 2.0L auto 4wd
thanks keith
chris
chris
Try going to http://www.gmparts-direct.com/. I know the have the cross rails, I just ordered and have received the front rail for my 2004 Tracker.
Roger.
Larry S.
