-September 2024 Special Lease Deals-
The rock crawlers love the automatics (the old three speed autos, that is), but maybe they are installing a Tera Low Kit or an Atlas II transfer case to get the slow crawl speed.
I would research carefully before buying the four speed auto. I know I have seen posts about these trannies slipping when the Jeep is at extreme angles. There is a design problem of some kind that has to do with the sump, and the pump can't pick up fluid when the Jeep is pointed up at an extreme angle.
Tom
Have you hugged your Jeep today?
I'm not sure what is meant by the crawl ratio being better with the manual. In the real world, at low speed in low range against a load such as a steep hill or a rock, the auto is much more controllable. It's also of benefit at higher speeds over rough terrain. The effect of your right foot being bounced up and down on the throttle is 'softened' by the torque converter.
The manual has it's place off road too. It's main advantage is when maximum power is needed, such as when blasting through deep mud, either to overcome suction or to spin the wheels to clean the treads.
For mild trails, fireroads etc., etc., either transmission will be fine.
Tom
Congrats on getting a Jeep that you are happy with! I think it all worked out for the best, right? You are much happier with the power of the 4.0L I-6 than you would have been with the four cylinder.
rolinski:
Welcome! Stick with us.
Tom
Still think ya oughta let that poor Jeep have some fun off road!
Tom
As for your glove box, they all fall off, but they are removable. Just start the hinge back in place and shut it and it should be fine unless something has broken. Once you get used to it, you will just take the strap off and then open it wide and remove it. It's quite simple, but you have to get used to it.
The inline 4 cylinder gets a 3.73 to overcome the power difference from the 4.0.
I believe the Rubicon has a 4.10 to overcome the taller tires.
Since manual trannies have the fifth gear, with .78:1 overdrive ratio, they can afford to have lower gearing (higher ratio) in the rear ends without causing the engine RPMs to be too high at highway speeds. The old three speed autos have a 1:1 third gear (same as fourth gear in the manual five speed), so they need a higher rear end gear for lower engine RPMs at highway speeds.
The four bangers have had 4.11 rear ends for a long time. The little four cylinder engines need to run at higher RPMs to develop their power, so they put the 4.11 gearing in them.
The Rubicons have the 4.10 (or 4.11, whichever) to compensate for the 31" tires that are standard on them. Theoretically, I should have regeared from 3.73 to 4.11 in order to have the same final drive ratio when I put 31s on Thelma Jane. No one would probably regear for such a small difference, though. Now, if I go up to 33s, I will have to see what I think about the power, and maybe then I would want to regear. Lots of people have told me that the power reduction isn't all that bad with 33s, but I would have to see for myself.
Tom
I stand corrected on 3.73 on the 4 cyl. It is 4.11.
With 33's I regeared to 4.56 since I originally had 3.07s. This is a little more gear than I need but it helps with towing and I could go to 35's and be back to stock RPM's. In the meantime I am enjoying the low end kick of the 4.56/33 combo.
Just remember to go to a speedo calibration shop once you get it set. Mine was way off with the stock speedo gear and the 4.56/33. Was actually reading 10 to 15 under actual speed (not good).
As heavy as those doors are, they aren't going anywhere, once the studs are back in the hinges.
Just be VERY careful each time you take the doors off or put them back on! Those exposed threads are bad news for your paint, if you allow them to come in contact with the Jeep.
Tom
Since I dont have a garage and with the kind of weather we have here I dont have much choice but to put the door back almost every night. I'll try to be careful with the threads!
This will be my first grand child! (No offense, Ross Allen... I'm talking two legged grand child here.) It's gonna be a little Jeep Chick.
Don't know if it will work out or not, but I told my daughter that I want the baby's first ride in a vehicle to be in Thelma Jane, even if it's just around the parking lot at the hospital. We live about 40 miles from the hospital where the baby will be born, so I guess a topless/doorless Jeep ride that long is out of the question. BUMMER!
Tom
Have you hugged a little Jeep Chick today?
Have you considered getting a full Jeep cover? I bought one from Quadratec that works very well, and maybe you could just put the cover on at night and leave the doors off??? The cover is made specifically for the Wrangler, and it fits exactly over the Jeep. There is an elastic strip around the bottom front and back, and you just slip the elastic under the bumper corners to hold the cover on. The type I bought is called Duravent, and it sheds water very well. It is made so that it can "breathe," and they do not claim that it is waterproof; just water resistant, but it keeps the rain out pretty well. The cover was right at $100 U.S. a couple years ago, when I got mine.
Oh yeah, they make some nice door bags too, and they really protect the doors while they are in storage. They are Bestop brand, and I also got them from Qtec. They list now for $115.95 for the pair (for the full steel doors). They are padded inside, so the doors don't get scratched.
Tom
Dont hold your breath about me taking TAZZ off-road NEVER happen. It might get dirty!
Past few days no doors with bikini top on. ( the jeep not me), its been GREAT!
KEEP JEEPIN
BAMA
www.geocities.com/bamatazz2001/jeep.html
To cover my doors I use an old BBQ cover that was lying around and it fits just right. As for a whole truck cover that's a pretty good idea. I might buy just that! I want to go door less as often as possible! Thanks!
If you thought Thelma Jane was the best thing to come along, just wait 'til that jeep chick gets here. Girls come out of the womb knowing how to manipulate grandpa. They are good at it too. You will love it.
Terry
Yeah, I know that little Jeep Chick will get lots of my attention. But, I DO plan on making her a wheelin' buddy. I will introduce her to the wonderful world of Jeeps and off roading. Who knows, maybe her first vehicle will be a Jeep! (and Bama, she WILL wheel that Jeep!)
Tom
I'm sitting here waiting for a call from the wife. She's at the hospital with my daughter.
This will probably be a long process, since it is going to be my daughter's first baby. Her doctor told her most likey 12 to 24 hours after they start the medication to induce her labor, and that wasn't started until after midnight last night.
I'm babysitting Ross Allen, my "grand dog," until time to go to the hospital.
Thanks for the well-wishes.
Tom
Heck, it could still be several hours. I called about 7 AM CDST, and not much had been going on so far. I'll bet it will be late this afternoon or even this evening before she arrives.
Thanks for asking!
Tom
Tell them to call you on the cell phone and go for a drive. That would be better than pacing.
Hopefully, Mopar makes a Jeep Baby seat for the back seat.
Gotta find the Jeep baby clothes. Convert her stroller and put a Wawa 44 axle on it and go with oversize tires. Nothing like a Jeep in the mall when she goes shoppin'
Congratulations!
-Paul
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2330592328- &category=20679
Congrats again.. grandpa
Bama
Hey Bama....that stroller is pretty cool, but there can't be a Liberty around Tom's house. He needs the Wrangler version!!!
http://a1235.g.akamai.net/f/1235/5580/6h/www.quadratec.com/photos- /p16162.JPG
Mother and baby are doing fine, but the baby was delivered by C-section, since my daughter just wasn't progressing very well on her own ( would not dialate past 6 CM ).
Thanks to all of you guys for your words of encouragement!
If that doesn't work, I guess you could lobby for "Dana."
I was thinking "Leigh" might go well with Payton. How does "Payton Leigh" sound to all of you?
Tom
Have you hugged your Jeep and Little Jeep Chick today? ( I sure have! )
She is adorable! Any guesses as to when you will be able to take her on her first jeep ride?
Once I moved the pic, the link was no good any more, so I am reposting it.
Tom
I am still working on getting her mom and dad's permission to at least take her on a Jeep ride around the parking lot at the hospital. I think it would be so cool if her first ride in a vehicle in her life was in a Jeep.
Tom
NEVER MIND... it is NOT showing up in the original post now. Guess it was just stored on my puter until I logged off and came back. It's not showing now that I have logged off and come back.
Congratulations to you and your family!!!
dewars
Thanks again to all of you who have posted congratulatory messages.
I'm busy this morning printing out pics of that little gal and emailing pics of her to friends and relatives.
If any of you would like to see some more pics of Payton, just go to Gill's photo gallery. Aw heck, I'll post a link to the album (not that I am proud of that baby or anything)
http://itsajeep.org/PhotoPost/showgallery.php?cat=3035&ppuser- - =3
You guys are great friends! I am thankful for all of you.
Tom
Rich
-Pete
And, you can pass along to your bosses that I appreciate Edmunds giving us this great place to exchange messages and post pics. Where else on the Net is there a commercial site that has this kind of atmosphere?
If I posted about my granddaughter in any other Jeep message board (commercial site, I mean), I would be flamed to no end by the members, and my post would probably be deleted by the moderators or moved to "off topic," where no one would ever see it.
Tom
Proud Grandpa.
I hope Mom is doing well..
Remember..my little boy is 6.. hmmmmm about 17 years..
Bama (terry)
After you drive her around he parking lot in Thelma, you gotta let Ross Allen lick her face too before she will be truly in the family!
Thanks again to everyone for your congratulatory messages... I'm eating them up like candy!
Yeeeeeeeeeehawwwwwwww!!!!!!!!!
Tom
Have you explained things to Ross Allen yet, so he won't get jealous when she comes to visit the first time?
