There was no comparison. The 6.0L was far superior to the 7.4L in towing ability. My primary point of comparison is a very steep hill just off the Fort Littleton exit of the PA turnpike on the way to Raystown Resort. There is a 3+ mile grade that in the 3/4ton SUBs with the pedal floored my maximum speed was about 30mph (performed this task consistently over the past 10-12 years).
This year with one more passenger (6) and a similarly loaded boat trailer, I climbed this same grade, floored at 40-42mph. Overall the 6.0L felt much stronger, accelerated better and maintained cruise much more easily that my previous SUB.
I can't make any comparison to the 8.1L but I can assure you I was very satisfied with the 6.0L in the DXL and its towing ability.
http://www.bnsf.com/
then click on tracing tools and go from there.
Campo57
Never got below 50mph and didn't even have to floor it. Downshifted to 3rd with about 3/4 throttle.
What's important is if you're happy with your vehicle. If the 6.0 in your Denali is doing the job for you, then who cares what the next guy says.
I'm extremely happy with the performance my 3/4 ton 8.1 Suburban gives me.
"As of 8/1/01 you have a choice of $1,000.00 factory rebate or subvented rates through GMAC of: 12-36 months 1.9%, 37-48 months 4.9%, 49-60 month contract 5.9%."
What's interesting is that after posting my first message, I called Chevy 800# (got it on the chevy.com site) and was told that there was no $1,000 rebate on the West Coast, only special financing.
I believe the engines are the same in both applications however in the Denali XL you have a slightly lighter vehicle than the 2500 (Denali XL 5690 vs 3/4 ton 4wd w/ 6.0L 5840lbs).
The lack of leaf springs and lighter chassis in the DXL provides an 8400LB tow capacity while the 6.0L in the 3/4 ton 4wd Sub has a 10000lb tow capacity.
The comfort in the two suspensions is significantly in favor of the Denali however the towing capabilities are the trade-off.
buster27: that area of the Turnpike is some beautiful country. The grade I was referring to in the earlier post was not on the turnpike but up in the Blue Mountains and is quite the "bear" to climb with a full load. The DXL handled the entire turnpike trip from NJ almost entirely in cruise and tow/haul mode without breaking a sweat.
The following would be my assessment (not factoring in $).
If you're towing more than 7000lbs regularly get the 3/4 ton with the 8.1L. I'm not sure what application would justify the 3/4 ton with a 6.0L. If you're going to step up in chassis, you might as well get the additional power.
Almost all other towing applications can be comfortably handled with a 1500 and very comfortably handled with a DXL. It really comes down to your tow package and frequency. Having owned two previous 3/4 ton's, I preferred the heavier duty chassis, transmission, rear and 8 lug wheels when towing when particularly when they were new. However after 50,000 miles be prepared for the ride to get progressively bouncier when not towing as the leaf spring rear hardens. I owned both previos 3/4 ton's to about 130K miles.
Ultimately thats what motivated me to move to the 1500 with coil/air rear suspension (maybe I'm getting softer as I age). My tow package (6500lbs) and frequency (12-15 times a year) didn't demand the 3/4 ton.
It's worth noting the new 3/4 tons are measurably more comfortable than the previous 3/4 tons (I drove several prior to deciding on the DXL), however the 1500's have significantly improved as well, with the DXL, IMO, having the best handling and best overall ride of the line.
I think it would be a safer bet to just listen to the noise
As long as its not effecting performance why change it? There are alot of 5.3's and other motors out there with this noise and they have alot of miles on em
Personally i think its alot of widepread panic
Ryan
http://www.copartfinder.com
Probably get a good deal on a skid plate
NHTSA CAMPAIGN ID Number: 01V159000
Component: INTERIOR SYSTEMS:ACTIVE RESTRAINTS:BELT RETRACTORS
Manufacturer: GENERAL MOTORS CORP.
Mfg. Campaign #: 01043
Year: 2001
Make: CHEVROLET TRUCK
Model: SUBURBAN
Potential Number of Units Affected: 9196
Manufactured From: SEP 2000 To: OCT 2000
Year of Recall: '01
Type of Report: Vehicle
Summary:
Vehicle Description: Pickup and utility trucks. Some of these vehicles have an internal component in the outboard
seat belt retractors for the 2nd and 3rd row of seats that could be cracked. With repeated actuation of the locking
mechanism, the crack could spread to the point such that the seat belt would no longer lock.
In a crash, increased occupant injury could result from the no-lock condition.
I would like to find a good exhaust and/or performance shop in Eastern MA that I can go to for some educated installations. Does anybody have anyone around here that they have worked with and can recommend?
Subliminal
http://suv.s5.com/
Campo57
Brian
Buy the skid plate pkg and get some good shocks and then add some stickers and you will be set
"3.5 qts of oil in 6000 mi. Dealer says that it may be within normal limits"
within normal limits? What kinda math is your dealership doing
6K miles = 3 qts
you said its using 3.5 so that means it 0.5 qts over
Better tell them to go back to freshman math
" tires cut the ratio to about 3.93, and I feel did effect the performance. After the first tank of Gas in Georgia, I stopped using the cruise control. I tried to keep my speed in the 55 to 65 MPH, speeding up, down hill to make the next hill, some times hitting 75 down hill and throttle floored, first gear and 48 MPH on long 4 to 5% grades. Having not towed through the mountains before, I did not know what to expect. Taking speedometer 4% error in effect, at times I was disappointed and at other times I felt we were doing real well. On lesser hills and with a good down hill start, I might make the next hill in OD. On the other hand the truck seemed to perform better if I kept the RPM above 2000 RPM and best at 2500 to 3500 RPM. Only a couple of times did my transmission get over the mid mark and most of the time was just below that mark. Engine temperature stayed very close to normal most of the time. Gas mileage went 7.9 worst to 8.8 MPG best, with an adverage of 8.5 MPG I was in First gear three or four times, 2nd quite a bit and overdrive downhill and later on lesser hills. The trip back was through Eastern Kentucky, Eastern Tenn., Knoxville and Chattanooga mountains. With about 4800 miles, oil is still on the full mark. Surprising, since I used a quart in the first 2500 miles. Must have broke it in right? Most hills, I would gain speed in 2nd, hold or gain some in 3rd. Over flatter terrain, I could hold overdrive on over passes and smaller hills. How would you rate this performance through the mountains, compared to say the 8.1 engine, or the Ford diesel, I'm thinking of getting to pull a 5th wheel. Chevy is still too proud of their Diesel to get competitive. Thanks for any input, (if you got this far). Skipjack2
285's iffy
I have 285's on my 1500 silverado with no clearance problems
Ryan
You can also use the supplier deal for vehicles you order
