any help would be appreciated....
If in the brake system, it sounds like a bad master cylinder, possible power brake booster leak (is the hose from it to the intake manifold good, rubber gromet good, and the connection not leaking - also the intake connection is a housing that can rotate and disconnect). This needs to be seen to determine the cause. ABS module defects should show codes with the ABS light on and using an ABS reader. As a last thought, look at the flex hoses on all wheels and see if when the brakes are pushed any have a bulge or bubble - you stated no leaks in any lines so the reservior should be full and not dropping.
I have an update. I will be sending the vehicle to the shop on friday. In addition to your thoughts above, I did notice that when the brakes act up, you can also hear on the left front side a ticking sound that is in sync with the pulsation feeling I'm getting on the brakes.
From- Motor:The nuts & bolts of Kelsey-Hayes 4WAL, Jun98
By- Black, Ludlow
(partial test only from a longer article)
Used on millions of GM trucks through the years, this antilock system can be a handful to diagnose and service for the uninformed. Here's how to avoid the pitfalls.
The Kelsey-Hayes 4WAL ABS system has been used on many GM light trucks through the years. So chances are pretty good you'll tangle with one real soon. Like all ABS, the 4WAL system is designed to keep the vehicle under control during heavy braking. To meet this challenge, however, there may be some sacrifice in pedal feel and even increased stopping distances under certain conditions. Make sure your customers know this and understand what to expect from the system to prevent you from wasting hours trying to diagnose something that may be perfectly normal.
The 4WAL system is nonintegral, meaning it uses a conventional booster rather than a separate pump to provide power assist. As a result, there is no external accumulator to worry about, and the pressures you are exposed to during service and repair are the same as with conventional brakes.
The Electronic Control Unit (ECU) of the 4WAL system is attached directly to the business part of the system-the Brake Pressure Modulator Valve (BPMV). This assembly can be found under the hood on the right side on pickups, Blazers and Suburbans; beneath the brake booster bolted to the firewall on Astro/Safari vans; and under the vehicle about a third of the way back on the passenger side on G-series vans.
System Operation
The 4WAL system has three channels of control-right front, left front and rear axle. Although some applications have four wheel speed sensors, if one rear wheel locks, hydraulic pressure to both rear wheels will be reduced. This method of control is not as inefficient as it may seem, since the front wheels do as much as 80% of the work during heavy brake application.
The 4WAL system is an active system, meaning it's able to provide energy to reapply the brakes after pressure is released. The vented fluid is stored in accumulators within the BPMV and pushed back to the wheels by an electric pump. Be aware that the solenoids and pump motor can consume up to 45 amps during use, so don't forget to check out the battery and charging system as part of your diagnosis.
Self-Tests
Two different self-tests are performed whenever the vehicle is started. The first happens as soon as the key is turned on. During this period, the red BRAKE and yellow ANTILOCK lights will come on for 2 seconds. The ECU then tests for continuity in the wheel speed sensor circuits and for proper voltage in the pump circuit. The ANTILOCK light should turn off if no electrical faults are detected; the BRAKE lamp will stay on if either the parking brake is applied or there's a hydraulic problem in the brake circuits.
Once the vehicle is moving and the brake pedal is released, the BPMV is tested hydraulically by the ECU. This testing includes the pump and the control valves. The wheel speed sensor inputs are also dynamically tested at this time. If no faults are found, the 4WAL system is operational for the rest of the trip or until a fault is detected.
So me being an electrician, I jammed a piece of 6-4 range cable into the spout down to the flap and loosed it.
Now it doesn't take 10 minutes to pump $20 worth of gas...
The hub assemblies were $115.00 each through AutoZone and they warranty them for one year.
thanks,
PS it has a new motor 67k miles. Also it has 31" tires on it. Can that be the problem?
Help
It doesnt have thatplastic thing thats connects it to the front of the grille(from the air cleaner)
Ill check for vac leaks and fuel filter(where is that?)
thanks jamie oops its a 95 jimmy 4wd
Check the oil level first, then see if they forgot to connect something when they were under the hood. Look at the area behind the air intake assembly at the big air breather tube, then the PCV on the drivers side, and all the same vac hoses running along. Check to see if the air filter housing is all closed up again too.
(2001 Blazer LS)
A :confuse:
after market replacment cost is about 50.00 and takes 30 minutes to change.
