2015 Mazda 3 Skyactive 6spd. auto 2008 Mazda Tribute S 4spd auto.
Check some other places, but also check to see if it might still be under warranty. I know it sounds odd, but exhaust systems are starting to get special warranties, outside of everything, that are only dependent on the car, and not the owner.
Or it may just be a California thing.
It could be the Hyundai dealer was including a major tuneup along with the converter, but still that should be $800 max.
I am going to change the oil today (before the heat sets in!) and I also want to change the spark plugs. I have an 04 GT with about 62K miles on it, original plugs!! I thought they were a 60K interval, but I've come to find they're a 30K item :-( Anyhow, I'm pretty certain I know where they are on the engine (just to the right of the valve cover? They appear to be alligned length-wise with the car) Is this correct? Also,I'm pretty sure Hyundai didn't take the liberty to put anything too special in a car the retailed for $10,000, so I'm going to upgrade to some Bosch Platinums, +2's maybe. Anything I should know? And yes, I know I'm going to need a gapping tool. Any help is appreciated!
Some of the biggest gas mileage killers are low radiator fluid or a failed thermostat. Check coolant reservoir to be sure the fluid is at the correct level. Low coolant can result in wrong temperature sensor readings which causes too much gas to be sent to the engine. A failed open thermostat will have the same effect.
Other possible fuel economy vampires low tire pressure, worn bearings, and worn out sensors.
Thank You.
You're looking for bolts, these sensors are held in place by bolts. I've not taken them out on my car, however i would assume their will be one either end of the gear box. Have a drip tray ready for oil spilling out, up to 2-3 litres may pour out upon removal of these bolts holding the sensors in.
I dont know how much these sensors are, however im sure you could find out on the net. Could also read up about them a bit more on the net if you're not totally sure of what you're doing.
In reply to your message, my flex pipe went about 2 years ago, and Midas replaced the joint for $70. It's much cheaper than to go to the dealer.
Hope the info is useful, and good luck.
apart from tires a new battery at 185000 and a clutch at 130000 everything is all original its using oil now valve guide seals i think as for the exhaust i am in email discussion with a rep from bosal as to the suitability of their system for my accent (I have just emailed the details from the emissions label).i think it is ok for the older versions pre 2000 and am waiting for an email to see if ok for my model its about $60 and is an easy self fit. I know of one other that is two years old and has over 120000 miles on it with no problems. I will let you know as to the reply from bosal when i get it.
I was driving down the highway yesterday and it blew out. The entire frame had rusted from the moisture. Fortunately, no one was hurt.
Body shop sent me to sunroof specialist who sent me back to dealer. No luck. They "might" be able to put another in buit also suggested that I take it to a body shop and have a real roof put on. Approximate cost for any of their suggestions...$1000.
Make sure it is fixed properly.
you could try checking the engine mounts if they are loose the whole engine transmission could be jumping how many miles do you have on the car what is the warranty status you may want to email or contact Hyundai directly if the dealer is not being responsive
when you get an answer post it so the other owners can watch out for the same thing
I have had a problem with the transmission cutting out in slow and stop and go traffic, It seems to lose overdrive and 1st gear. If I turn the engine off and back on I get them back for a little while. If I get on the freeway and keep my speed up to about 60 or so I am fine, once I begin to slow down I risk losing the OD gear again. Engine light does not come on when this happens. At slower speeds it seems to kick out of gear and when accelerating the rpms go up but there is no response from the transmission or very little response, I have to take OD off and drive in 3d gear. I have replaced the Speed Sensors (Pulse Generators) and it still seems to have this problem. Do I need to clear any codes in the computer? Maybe I got the wrong sensor from the dealer or it was defective? anyone have any ideas? Thank You.
If it is an actual issue in the ECU I can't help but think that I would be best served by just getting rid of the Accent but past that I am lost.
Next, make sure it has other features you want/need. Do you want anti-lock brakes, for safety? (I highly recommend them.) If so, you are limited to the Accent SE hatchback, which is higher priced than the GS. Do you need A/C? It's optional on the GS. Is reliability really important to you? If so, the Accent is a pretty reliable car, and it has that long warranty, but there are small cars with better reliability histories. Engine reliability shouldn't be a concern--the Accent's engine design has been around many years, and engines rarely fail these days with proper maintenance.
Also think about crash protection. The Accent has OK frontal crash test scores but a Poor side crash test score from the IIHS. There are other small cars, like the Yaris, Versa, Rabbit, and Fit, with much better crash test scores.
Be sure to check out the Accent's competitors before plopping down your money. For example, the Yaris and Versa are both pretty inexpensive in base form. The Fit and Rabbit (3-door) cost a bit more but are fine little cars. Some people think the Yaris 3-door is really cute--have you seen it?
Your dad probably doesn't trust Hyundais because he remembers the low-quality Excels that Hyundai brought to the U.S. starting in the mid-'80s. That was a long time ago, and Hyundai makes solid cars now. But good luck trying to convince your dad of that.
Sometimes the car rpm's increase at low speed and the car does not accelerate. After the hesitation the car then oeprates properly. The engine seems to run well.
Any thoughts??
Can anyone give me some real world stories with this?
Take care and good luck.
I purchased my 2007 Hyundai Accent on July 3,2006 and on my way home the check engine light came on. First I was told it was the gas cap even though there is a seperate light for cap. Then I had to wait until December for dealership to receive software from Hyundai to do diagnostic. During this time my car really began to experience problems - decreasing fuel milage (currently down to 19mpg - hmmm why did I trade in my Dodge Caravan?), rough riding, trouble starting. In January Hyundai sent over Engineers from KOREA to study problem. :mad: I waited 3 months (and in the meantime filed with Consumer Protection which refered me to Better Business Bureau which handles Hyundai in my area) and the last day that they could reply to my Lemon Law complaint they sent in something called a Reflash for my car's computer. This was their Final Repair Attempt on my car - which was performed on April 19, 2007. Guess what - the engine light came back on this week and yesterday the same codes came out when dealership ran diagnostic.
The mechanics at my dealership then told me that they have five other Accents with same problem and showed me one Hyundai with 4,000miles - it's spark plugs were burnt up!!! They also told me that Hyundai cannot fix this problem.
Needless to say I have reopened my complaint and am now waiting for a buy back offer.
I really hope you do not have the same experience I have had but protect yourself and get that diagnostic run. :sick:
Did you guys realize this too, I mean it is no brainer, it has a much cheaper price and a life time warranty. The online store is www.rockauto.com. Any idea how this is possible? Why the huge price difference, am I missing something?
How did you make out with the buy back?? I'm anticipating that I'm going to have the same problem because my gas milage dropped from 28 mpg to 20 mpg (I check every tankfull).. Hopefully I caught it early enough.. Any help would be greatly appreciated.. (I really love this little car)
