Nissan Quest/Mercury Villager problems
Cheers!
Paul
The fix is either to repalace the resistor pack or the switch. If you can locate a reputable independent mechanic they should be able to fix it pretty easily. I don't know how much it would cost though. If you call your dealer's service department, they sould be able to tell you what the parts and labor cost for the fix.
Hope this helps.
Dave
Any suggestions?
mgr4: I'm letting mine run til the next scheduled service stop, or something different happens (my wife nagging me about it may qualify)!
Cheers!
Paul
Changer with a FM Modulator, well I hooked everything up and when the time came to test everything, my radio/tape didn't turn on. I checked all the wires, and all the fuses. Then when I took out all the wires and put them back, the clock turned on for about less than 1 second then turned off again. I checked everything again and the same thing happened
I would very much appreciate if someone can help me with my problem..
At first, we had some minor fit and finish issues and thought nothing of it. But now, we have some mileage on the vehicle and it seems to be aging pre-maturely. My '93 Villager had one issue(manifold bolts) in the 6 years that I owned it. I expected the next generation to be an improvment, not a step back. We'll see...
I do think I need to clean the throttle body....
These updates are nice to see, warts and all - anyone else have anything to report?
Steve
These are problems I've experienced so far with my 99 SE Quest:
-Noisy brake booster replaced twice: 12k, 25k. Noticed the creaking earlier on. Dealer claims noise is normal, but replaced it with my persuasion. Noise improved on second repair. Despite noise, brakes have always worked fine.
-Vibration/rattles under the dash fixed at 29k. Was there for quite a while, but waited till it was more obvious.
-Middle row window latch replaced because of clicking noise. There is a tsb out on this.
-Noisy Blower Motor replaced at 33k. Dealer said they could not hear noise, but went ahead and replaced it.
-Power door switch replaced at 33k. Door was periodically locking itself. There is also a tsb on this.
-Knock sensor replaced at 33k. Btw, this malfunction will only be noticed via the computer consult. It will not trigger the check engine light. Not a bad idea to check this out before the 36k/36m warranty expires.
Persisting problems at 33.6k: occasional vibration heard from right dash or door. Occasional rough idle. Hope this is helpful. I'll keep you posted on anything else that occurs.
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Cheers!
Paul
You might want to take a look through the archives of the VillagerQuest mailing list. I have seen similar problems addressed there.
http://groups.yahoo.com/group/villagerquest/
As Paul mentions, it's not a bad idea to have your transmission fluid & filter changed anyway, as preventative mainenance.
Dave
After replacing the TCU, it ran another few weeks before the same wire burnt in the replacement unit. Clearly, there's something awry in the Electrical system, but I don't know what.
So I am about to have a "factory" mechanic dismantle a normally functioning tranny just to change the filter. And with just a fluid change, I'm doing that myself.
Otherwise it just says "i" inspect... all the way through.... I asked a mechanic I know, and he suggested I have this done at 60k since I don't tow anything. I've seen other suggestions online to have this changed as high as 100k. Seem a little high to me.
Now my own Nissan service advisor suggests every 30k, but then they are in the businesss of earning your hard earned dollars. Not to mention he does state that a 30k tranny change is NOT required for fulfilling any lease requirements. If I decide to purchase my lease, I'll probably changed the tranny fluid shortly there after... or no later than 45k just to be safe. ;-)
Anyway, my 2 cents.
Revka
Correction: I am NOT about to... (above).
It still is a mechanical tranny and fluid is cheap at 30k intervals, so I will be doing that maint (especially since I own the van - cheap insurance).
I change the transmission fluid/filter every 30k, manual or automatic transmission (and I don't do trailer towing). Just noticed a few months ago, after paying for it all these years, that the transmission pan has a drain plug on the bottom. Never had a car with a drain plug before; always paid to have it changed because I didn't want to be cleaning tranny oil off my driveway...
We recently purchased a 96 Quest GXE with 54,000 miles on it. We've been pretty happy with it so far (just over a month) though we've had some relatively minor electrical bugs. The rear audio controls work sporadicly at best and I was considering pulling them out and replacing them with the cupholder that sits in the same cut out. (don't really need the kids messing with the volume anyway!) I'm wondering if I can just disconnect the controls or if there may need to be some additional re-wiring would be required to take those controls out of the loop. Thanks to all who keep the posts coming. Very helpful to a new owner like myself. Tim
I thought maybe someone out there has had some experience with this one: Is it normal to get some tap-tap-tap-tap (kind of like lifter noise) for a few seconds during extremely cold mornings. Our 96 has 54,000 miles on it and I use 10-30 oil. I get the same sound on my Pathfinder but it has 187,000 miles so it doesn't surprise me there. Any input would be appreciated. Thanks! Tim
Mjeong, the Synthetic motor oil discussion may have some answers for you.
Steve
I still have my dealer put it in. I purchase an Nissan Oil filter from him for around 9 bucks then pay him and additional 5 dollars to change the oil/filter for me. So with oil included, my total costs come to around $33.
Btw, if you're going to use an aftermarket oil filter, I've been told to make sure it's not a cheap one. I was told that the Nissan oil filters have this special valve in them to prevents all the oil from draining out of the engine overnight. (I'm sure this is also available in other brands as well.) This supposedly helps prevent a cold start up in the morning... therefore reducing engine wear.
My 99 SE Quest has only 34k miles on it, so I honestly can't account for the difference. However, it does give me a little peace of mind. Also, some people feel more comfortable extending the oil changes to 7.5k, as opposed to 3.7k, when using synthetic. Hope this is helpful. ;-)
Revka
Steve
I'm taking it in tomorrow for its scheduled servicing and will have the mechanic take a look at the passenger side sliding door. As was mentioned by our host, I think the rear window latches are loose.
I think you are correct. Here is my theory. The sound you are hearing is coming from the front doors and is a result of minor body flex. A more modern design would likely not suffer from these somewhat annoying squeaks and rattles. But who are we to complain - these vans are durable and offer the most bang-for-the-buck in the minivan market (will, they did until the Sedona came along).
Steve
I have been using the Napa gold and silver filters, I have heard they are pretty good.
I own a 1995 Nissan Quest XE and love it. I have 102000 miles on it. It still drives like it did when I first purchased it. I haven't experienced any major mechanical problems since day one. This week, I will be putting it in the shop to have some deserved maintenance completed: CV Boot replacement, new fan belts, timing belt, tranny flush, and possible water pump if necessary. All of this is to be completed by a trusted Nissan Dealership who has completed all the maintenance on the Quest. I have been quoted a price of $850 for parts and labor.
If you decide to purchase one, have it inspected. You will be pleased with your decision.
I'm with sopman. Change by time, every 6 months with bosch filter. Just got a case over xmas of valvoline dino. With rebate = .49cents per quart (big diff over full-syn cost).
Have anyone encountered radiator problem for your Quest?
I have a 96 Quest. Recently it has gone through several major repairs, fuel pump, etc.. Now the dealer has suggested me to replace the radiator!
Every item costs > $500! I am wondering if Nissan makes good and reliable vehicles.
Your experience is appreciated.
Great price on the oil. I caught Castrol on sale and with rebate for .69 cents about three years ago. Bought 8 cases. Getting low now. Been looking for some more sales. Don't care what brand.
$500 seems a bit high; think I paid less using for it installed.
Also, any problems with the door locks? It appears both front door locks are worn out in my 93 Quest (95k miles). Passenger door started binding up (can't unlock if from outside with the key) at about 50k miles; now the driver's door sticks (can't unlock with the key or from inside). I've lubed everything in sight to no avail; dealer quoted me $120 for the new lock (should say latch) mechanism plus labor. (Checked -- it's not hte power door lock motors binding, The plastic pieces of the lock it self appear worn out).
So a few months and 3k miles and I finally get them replaced. My soft pedal is gone!! I cannot believe how nice and firm the pedal is. If anyone has what they believe is too soft a pedal, have the rear wheel cylinders checked.
I have had a 60K service for the Quest.
Right after the service, the coolant level was at MAX. Five days later, the coolant level is now in between MAX and MIN.
Should I be concerned there is a major leak? Or the coolant is now in the radiator? I was told by the dealer that my radiator has (minor) leak.
Thanks for your advice.
KK
