Nissan Sentra 2006 and earlier
1505153555667
  • sandman46sandman46 Posts: 1,798
    I don't think our Sentra's have the NVIS system. We also have a '01 Altima with the security alarm and it does have it, according to the dealer, and the key is different than mine. We only have keyless entry on our cars. I could be wrong about this, so if anyone else can shed some light on this issue, feel free to clarify this.
    I've never taken the antenna off before going thru the car wash and nothing has ever happened to it. It's one of those whip antennas, so I'd just leave it alone.
    Hope this helps.
    The Sandman :-)
  • inuseinuse Posts: 1
    it's been since the second time i dive my new Sentra 1.8S, after I turn of the engine, i hear the leaking sound (same as my old VW Jetta), i bought the car in March, only dive it for 900 miles.
    My question is: 1.Is the leaking sound after turning of the engine normal?
    2. If not normal, would that be antifreaze problem?
    Thank you in advance for any input!
  • lngtonge18lngtonge18 Posts: 2,228
    I wouldn't trust the fate of your antenna to a carwash. It can be bent or broken if caught by a rotating brush. Unscrewing the antenna doesn't leave a hole. It unscrews from a stud that sticks up out of the fender, so there is nothing you have to worry about covering up.
  • ed2004ed2004 Posts: 8
    I have a 2004 2.5S. I bought it a few months ago.
    After the engine is shut off, I still hear these
    cracking noise (like metal is expanding and contracting) for a few minutes. I figured that it was winter and it was caused by contact of cold air and hot engine. But winter has passed and it is still making these noise. The guy at the dealer said is just the engine cooling down and is normal. My old car does not make this noise. Is this normal? Thanks for your help
  • alpha01alpha01 Posts: 4,747
    I have an 03 Sentra with the same engine, and it is the loudest post turnoff car I have EVER heard. Be assured, I was told by 3 separate Nissan dealerships (I have my car serviced whenever/where its most convenient) that this was normal, not to worry, and it did not indicate any issue. If its the same noise, its like a loud cool-down popping/ticking noise, correct?
    No stress. Love the car. It flies and I still get 26 MPG.
    ~alpha
  • nss167nss167 Posts: 8
    Noise you are hearing is not the engine cooling but the emissions equipment ( i.e catalytic converter etc. ) cooling down.
    I hear it also in my 1.8 S and it is a normal phenomenon which happens in most cars.
    Can't say however how long it will keep occuring , but I assume that it will occur less frequently as time goes on.
    My 1.8 S is just over a month old and I still hear ir every once in a while.
    Thank you alpha01 and nss167 for the quick response and the help. It is the same noise. By the way, I am getting around 28mpg (it has about 3900 miles on it.) I wish the tank is a bit bigger so that I don't have to go to the gas station too often.
    Ed.
  • ottomaticottomatic Posts: 12
    * The only key hole on the 2004 Nissan Sentra 1.8 S sedan is on the driver's side; is this a recent development on newer makes and models of today's cars?
    (I find it inconvenient at times to have to unlock the driver's door to reach the glove box from the outside, unless I use the remote control key fob and unlock all the doors with it.)
    * Is there an economical way to change the color of the instrument gauges like the speedometer, tachometer, fuel gauge, etc.
    (I prefer some other color than the yellow-and-red color scheme and was wondering if there was a way to change it, perhaps with a different colored light bulb or overlay.)
    Yes, the missing passenger keyhole is a recent development, but only on a few cars. It's a way of saving money (one less lock cylinder to put on the car).
    Changing the instrument lighting is not an easy job. I'm not sure if the Sentra uses colored bulbs but if it does (high chance it does), you would have to take the dash apart and pull out the gauges to get at the bulbs. If it uses LED bulbs, that could complicate replacement depending on how they are attached (they could be soldered in place). You could buy an aftermarket gauge cluster but that can get a little expensive and if it involves extra wiring, you are messing with your car's warranty. But yes, it is possible.
    Our car also has no keyhole on the passenger door. When we first got the car, I thought they made a mistake, but after returning to the dealership and looking at the other Altimas on the lot, I figured that the cars with the factory security alarms all had no keyholes on the passengers door.
    Interesting thing in my opinion!
    The Sandman :-)
    Just went out and saw that my '03 Sentra GXE also has no keyhole there...it must have to do with the keyless entry and not the factory alarm as I first suspected!
    I contacted my local Nissan dealership's automotive service department, about whether the 2004 Nissan Sentra 1.8 S sedan had the "Nissan Vehicle Immobilization System," or NVIS, that some of their car models supposedly do.
    I was told by the service advisor that the 2004 Nissan Sentra 1.8 S does not have NVIS. I also asked about the protruding stereo antenna, whether it should be removed from the hood with a wrench before taking it through an automated car wash.
    Two of the car salesmen I asked told me they thought the antenna did not need to be removed prior and could withstand going through the car wash without being damaged or being bent out of shape.
    However the same dealership's automobile service advisor, who takes care of oil changes, etc., advised me differently; this is what he had to say:
    "Yes, the antenna should be removed before going through automatic car washes. The small area that it leaves uncovered is not effected be the wash process, and any water that gets into the small recess gets pushed out when the antenna is screwed back in. However it is recommended that the end of the antenna remain lubricated with a small amount of grease, anti-seize, or equivalent. In the event the antenna, or any other component, is damaged during an automatic wash, it is not covered by warranty. This is because it is not a manufacture defect or premature wear that caused the damage, but the abnormal environment of an automatic wash."
  • lgoldinlgoldin Posts: 90
    I have my Sentra SE for more than 3 years and never removed antenna before going through car wash. Antenna is indeed strong enough to withstand it. However area surrounding antenna remains washed only by water.
    Also I am not sure about newer products, but 3 years ago only SE version of Sentra had NVIS. XE and GXE which are equivalent to 1.8 and 1.8s - did not.
  • I saw in the newspaper some dealers are advertising a really low price as $10495 for a brand new 2004 1.8S AT. But I know many people paid much more than that. Is there any trick in the dealer's advertisement? Just curious.
  • Hey y'all - I will be in the market for an economy sedan soon, and was wondering when the next redesign for the Sentra will be? Thanks!
    Welcome! The Sentra is the last of Nissans cars to be redesigned under direction of his majesty, Carlos Ghosn. It is expected to be related to the European Renault Megane, a well regarded small/compact car thats seeems to sell well over there. I think we'll see the next Sentra next Spring, possibly February or March. I dont think it will be here this Fall, although anythings possible.
    ~alpha
  • skylerskyler Posts: 6
    Yeah, it's fine. Same thing here. In fact, I get the exact same three clicks without fail at the same time each time I turn it off. It's kind of comforting now...
    Thats strange. I have keyholes on both sides. I don't see why you would only have one on one side. I'd compare it to other Sentra's.
    I'm not sure. I doubt it. The 2004's are about to end because the 2005's (if they come out with one) would be starting by August. I was the first person in Northern Illinois to buy my Sentra, a mere few days after the 2004's were delivered, and I paid $15,000 (full price). I bet he/she's trying to get rid of his/her cars before the new ones come in.
    If your Sentra does not have keyless entry, it will have two keyholes. Or, it might be a model year thing. All Sentras now produced with keyless do NOT have two keyholes. Its normal.
    ~alpha
    You're right. I checked again, and I only have one keyhole. Funny, I thought I had two, but I don't. Oh well, I use the keyless entry whenever i need to get in. I don't think I've actually ever used the key...
  • carcar Posts: 4
    I have a quote from a dealer for $11000.00 Check if the dealer is talking about a trade in or cash advance on the car. Also let me know where this dealer is located. I may also be interested in checking this out. You may also need to check that he is giving you the car you desire with all options
  • Just a comment to add to the mix: I have been buying my own cars for almost 20 years and have never been more disappointed in a car than my most recent purchase of a 2003 Sentra. I dislike the handling, the shifting, the noise, the locks, the CD player, the gas cap - even the driver's seat is no longer satisfactory. I've owned Nissans before and expected to like this one just as much. Live and learn, I guess. :(
    And I'm sorry you dislike your Sentra. But did you not try before you bought? Handling characteristics, shifting, noise, and drivers seat comfort should have been observable on a 10 min. test drive. What was your prior car? For my money, I couldnt be happier with my 2.5LE.
    ~alpha
    To be fair, you can't tell whether you like a car completely simply with a short test drive; for example, I discovered I'm not fond of the yellow-red color scheme of the instrument cluster-gauges but not until much later and having driven the car at night.
    (I read tons of reviews on this website and others, looked at many photographs of the interior and exterior of cars, before even thinking about test driving the car at a dealership.
    None of them mentioned the color scheme of the instrument cluster of the Sentra or even suggested test driving after dark, to see how easy it is to remember or reach the cabin controls in the dark, while driving for example.)
    And other things, like the driver's side-only keyhole you may never even think of if you've been driving the same car for years, until you take a very close look and realize after talking to others it's a recent development or trend in newer models, cars.
    Yes, I understand that. Thats why I picked out specific items that were on the list of pans that are easily observable from a test drive. Take a car out for 10 to 15 mins, and you can pretty much tell if it accelerates, shifts, and sounds to your standards. I'll concede drivers seat comfort- as a short stint is very different from a long haul in the saddle... but the other issues... are difficult to mask in a test drive of any substance.
    ~alpha
  • Yes, I test drove it - twice, but I should have taken it overnight or in adverse weather (there's the biggest lesson I learned). My previous car was a 1999 Altima and I was very satisfied with it and when I felt the need to get a newer car I automatically went back to the same dealer. I had expected some of the same qualities in the updated, brand new Sentra, but it just hasn't lived up to my expectations. I took it back three times in the first six weeks and get getting told that I just needed to "get used to it" because it was a brand new car. I should like it, but the litany of little things that annoy me have added up to a rather persistent pain in the neck. I know that Nissan can make a good car - I've driven several. I glad to know there are lots of happy drivers out there. By the way, on a recent browse through Comsumer reports, the Sentra was listed on the 'least satisfied' list. :( Lesson learned: take a prospective purchase home overnight and/or test drive in less than perfect weather conditions.
  • Your quote sounds attractive. I called that dealer and they said that price $10495 has expired since the $2500 rebate has been changed to $2000 in this month. They gave me a new quote as $11995, much higher than your quote. BTW, where are you and which dealer is it?
  • patpat Posts: 10,421
    I moved your inquiry about the SE-R Spec V to our Nissan Sentra SE-R/SE-R Spec V discussion. It had been inactive for a few months, but I reopened it.
    You might also want to look up the Tiburon discussions - welcome, and good luck!
  • Well, I had posted a previous message a few weeks ago discribing my small problems I had been having with my Sentra. It is a 5speed with 1.8 4 cylinder. My service engine soon light kept coming on. Good news. Took it to the dealer and they did some recall work on it and it took care of the problem. They also fixed 2 other problems that fell into the warranty. Thankgoodness I didnt have to pay anything. The customer service was great. I was out of the dealership 45 minutes later. My gas pedal still sticks for some reason every now and then so I will address that another time. I dont feel so bad now. I was worried that my new purchase was a mistake. I think this will be a good car. Glad its still under warranty for 5 more months. I have been getting a lot of compliments on it lately. Everyone at work cant believe how nice it is inside and out. I love the fog lights. I'm interested in how other owners 2002 sentras are holding up.
  • cargeekishcargeekish Posts: 5
    Hey, I walked into the Nissan Dealership yesterday and was looking for a cheap car with basic safety features. The salesman showed me the 1.8 S version of the Sentra. It DOES NOT have ABS, Side Airbags or anything like that. It does have keyless entry, cd, air, etc. The MSRP of that was about 15,200 or so but with a 2500 rebate they were asking for about 12,700. On top of that I get a IBM discount and a College Grad. discount which brought it down to about 11,900. The salesman told me that he cant go lower then that but after haggling with the guy for 2 hours or so i got him down to about 11,700. My goal was to buy for 11,500 without checking this site but after I did, i saw people buying for like 10750 or so. So I am wondering if I am getting ripped off or is it a good deal for a Nissan Sentra to be about 11,700?
Nissan Sentra 2006 and earlier - Page 53 — Car Forums at Edmunds.com
