Nissan Pickups Maintenance and Repair
Check out the new Edmunds.com Maintenance Guide! Link is provided in the Additional Resource Box.
KarenS
Owner's Clubs
KarenS
Owner's Clubs
I got the same notice in 1996 but the dealer said it was ok.
Anyone else?
Has anyone done this? Your advice is appreciated.
JOn
Do you know of a model that can fit on a Titan that has the Utili-track system?
I replaced the clamps at the back with screws from the tracks for the cover into the lip of the box. The reason I had to do this is the clamps for the utlitrac fit into the trac. If you don't want to keep removing them when you put the bed extender in, you have to replace them. The tracks for the cover sit on top of the utilitrac and they are a bit wider. Because of this, The sliding bed extender can't flip because it hits the cover tracks. You need to slide the extender all the way out and flip it and slide it back in. Doesn't take long.
"I have a bed extender also. Is the utilitrac system fully functional when the bed cover is rolled back?"
You can place it anywhere you like, but in order to flip it you have to follow the procedure above.
I also have the LE and the radio issue is only common to the RF package and the mid grade radio. the base radio does not have the issue.
As an aside, did you know there is no RF part in the RF radio? It is a clarion amp with Clarion speakers with a panasonic head unit. Rockford Fosgate says they had input in the design - another good one!! A little bit of misleading/false advertising.
Other than that I am extremely happy with the truck so far.
I now have 65k+ miles in 4.5 years & couldn't be happier with the truck. Mileage is a very constant 19mpg, city or highway driving doesn't seem to affect my mileage. I have only had to replace the shocks, tires, front brake pads, the afore-mentioned battery & fluids. I'm now on my 3rd rear bumper due to being rear-ended twice, but the truck has held up like a trooper. I plan on keeping this truck another 5 years & am confident that it will last at least that long with minimal hassle.
My barber bought a 2000 SE-V6 Crew Cab the same night I bought my truck, and we compare notes. He has a little less mileage than I, and is similarly impressed with the vehicle's reliability. Now that I have a child, I wish I would have bought the 4-door, but oh-well.
I wouldn't have any reservations in recommending this truck to anyone looking for a reliable vehicle. Just make sure that it has been properly maintained & it should serve you well.
The four wheel drive system works flawlessly and I never had any problem with it. The truck never failed to start and never left me stranded. The engine check light has not come on to date. The A/C system after 9 years is as good as on the day I bought the truck. Never touched it in nine years. My rear brake shoes are originals and they look almost new. I installed one set of front brake pads in nine years. The original teal color paint looks showroom new, even though the truck spent nine years under hot Florida sun (garaged at night). But I take care of it and handwash it with Zip car wash every week.
Somebody I know has almost 300K miles on a truck just like mine, except it is an 86 model. He still has not rebuilt the original engine or transmission to this date. I saw another truck like his with over 300K miles. This should say something about the engine longevity on these trucks. The key is to do scheduled maintenance, replace the timing belt periodically, and change the oil often.
You are going to love this truck! I have a 2002 Frontier Crew Cab XE. 50k, no problmes at all. Only complaint is a rough ride, but some new tires and shocks will solve that.
Should i play or pass?
I just bought a 2000 Nissan frontier and when I came out for work this morning, after some heavy overnight rains, there was a small puddle of water on the passenger side floor... apparently running down the door seam. Anyone have experience with this... experience with fixing this? Thanks.
Daniel.
it. I have replaced spark plug wires and distributor cap. Truck has 150,000 miles, but otherwise runs well. Any suggestions?
Could be the neutral safety switch. If it is and automatic, make sure it is all the way in park. Also try starting while it is in neutral. Might be the cause. Also check you battery cables for corrosion. Hope this helps!
The shop manager said they won't take responsibility if something should go wrong with the engine. It runs fine, but I worry there will be problems ahead, and Nissan will find some way not to cover it. Can any harm have been done to it? I checked and found no leaks or oil anywhere. What would you do if something like this happened to you.
-mike
Anyways, I eventually took the truck to a Monroe to have them look at it. The 20 year old fellow told me that the stabilizer bar on the rear needed to be put back together, he did the work and didn't charge me a dime. I gave the kid $20 to buy himself a couple of lunches. A few months later the clunk returned. I'm going to try to tighten it up myself. My question: Anyone else seen this problem?
-Jay
When I first bought the truck one month ago,(at my local Nissan/Cadillac dealer) the body guy said just to paint the fender mouldings would be in the $700 range. That did not include the front bumper. I plan to get an estimate at an actual body shop...thought the $700 seemed a little high. I just like the monochrome look better, so will let you know what I find out.
So far the truck runs real good. Has just over 39,000 miles. Seems a little bumpy compared to my car, but it seems to have a real solid feel to it. (and no rattles!) I hate rattles.
thanks for your info.
mitsurob (formerly pontiacrick).
mitsurob.
This truck has the Rockford system and sounds great with CD's. When I listen to the radio it's almost like the subwoofer is completely non-functional. Even cranking the bass only results in a little life from the sub, and then a LOT of rumble when I play a CD.
Anyone know of any tricks to get the sub working with FM radio?
