2000-2011 Chevrolet Malibu
Is your car running bad or something? I'll take it to someone else before I shell out that kind of cash.
That's just my opinion though.
Cedric
I bought it in August 2005. In November 2007, I changed rear pads because one of a pair completely worn out while others looked like new. Chevy dealer didn’t explain what was wrong. I strongly suspected that something was wrong. Today, they told me that it needs change again because they are almost worn out. For safety reason I changed them. But they still did not give me a satisfying explanation. They just told me it is normal.
Thank you very much for your advice on this matter.
There is definitely something wrong and it sounds like you have a sticking caliper. One pad of a pair would indicate such and it will likely be the one opposite the piston. Post back if you know otherwise.
That constant drag will hurt MPG and likely damage the rotor, depending upon how severe it is dragging and generating heat. If it is quite bad, at night you should be able to detect a reddish glow on the rotor. If it is that bad, you could be damaging other parts in that area such as a wheel bearing.
L Krotzer
p.s im not 100% sure i did the bypass correctly im a little foggy on adding the values of the resistors up.
With pump relay removed there should be at least one 12 volt feed to one of the 4 relay contacts with key on run. If not check fuel pump fuse for 12 volts in and out.
I like to use a 12 volt test light for this, cheap to buy.
Please email pr@edmunds.com Friday, April 29, 2011 to share your story.
Jeannine
MODERATOR /ADMINISTRATOR
Review your vehicle
Welcome to the GM family. If you have any questions comments or concerns please feel free to contact me directly! Have a great weekend!!
Christina
GM Customer Service
I have a LTZ 4 cylinder with a "surging problem" that is presently at the dealer for this problem. (See my postings on the "2008-2009 Chevrolet Malibu board!) ----- Take it back to the dealer ASAP! -------- Best regards. ------ Dwayne :lemon: :shades:
Please keep us posted on any information from the dealership.
Thank you and have a great weekend!
Caron, GM Customer Service
Now onto my current issues. Last month I started the car on only to have it beep at me and on the message read it said "power steering" So I shut off the car and turned it back on. It went away. This month did the same thing to my husband only he lost power steering going down the highway. Not fun. He shut the car off and turned it back on. It worked again. So it did it to him 2 days ago so I filed a complaint......again....with GM. They said it would be covered under warranty to have it repaired. But until we can get it serviced we have to drive the car seeming as it's our only one and my husband is military so he can't just "call off" So this morning on the way to another base, its pouring down rain and our windshield wipers quit working. I can hear the motor for them running but the wipers are not going.
But I would like to know what the problem could be with the windshield wipers and if I could fix it before taking it to the dealership and having to pay for labor?
I have always driven GM vehicles and am really disappointed with this car and the service that I have been getting!
I apologize for your experience. Can you please email me your complete contact information including a good number to reach you, VIN, current mileage, and involved dealer? I look forward to your response.
Christina
GM Customer Service
It would seem to me that if the battery gets low that the alternator would increase the amount it is charging my battery, but got no real answer on the question. I spoke with the manager and he offered to do some checking by keeping the car for a couple of days and he could check something. I do not have two cars and he would/could not provide a loaner. I asked him to ask his GM contact which he said he will do.
In any case, I'm not optimistic they will find anything if I leave it with the dealer for a couple of days. Do any of you have any advice as to what I can/should do now? Thanks in advance.
Uncle Dewey
Also, the tow truck driver used a power pack to start the car, but it too did not start the car. We had to hook up the jumpers to the truck battery which did work. Yesterday I also put a volt meter on the battery and watched what occurred when starting the car and when/if it fails again I can put the meter on again just to be sure it really is a low voltage. The voltage dropped from 12+ volts to 10+ volts and then back up to at least 15 volts--my meter only goes to 15 volts. Wonder if I should try to leave the meter connected all the time and leave it visible on my dashboard?
Alas, Uncle Dewey
Uncle Dewey
1.) How does the engine act when it does not start?
2.) Does it "turn over slowly?"
3.) Does it "turn over at the normal cranking speed, --- but fail to fire?"
4.) Does the starter "just click" when you turn the key?
5.) Does the starter fail to engage into the flywheel?
It is VERY possible that there is a "dead spot" in the starter that causes a no crank condition. When you jump the car, there is enough voltage to move the starter armature slightly and the starter spins.
A loose connection of the battery cables at the starter and ground could also cause this type of condition.
Have the dealer remove the starter and check the starter drive and the armature / commutator.
When the engine fails to start next time, DO NOT JUMP THE CAR! ---- Have it towed to the dealer, so they see the problem. (If this is a new car there should be no charge for the tow. The same is true if you belong the AAA.)
Best regards. ----- Dwayne
The car magazines have panned the Impala since 06 when the current model came out. It is supposed to be totally redesigned in 2014. I wouldn't even consider the 2011 or 2012. As for the Malibu I bought a 2011 knowing that the 2013 was going to be changed. I don't want a Regal suspension and I don't like the much shorter wheelbase. The present model rides nicely. I'm not gambling with the 2013.
After sitting in several Impalas on the lot, and then hopping into a Malibu, I knew what I wanted. I bought one on the spot, leaving Bonnie right there and driving out in my first Bu. Two more Bu's since then :-)
I am now beginning to think about replacing one of my Bu's with something else, and have had a mental struggle between the current Malibu and Impala. Both are discounted well enough now (a plus) and both seem to have uncomfortably too many problems (a minus). I dread buying a PITA, and from various owners' posts see that both cars (and Cruze) can compete with any other in that sad regard.
Well, at least Malibu has comfortable seats... I will eliminate Impala from the candidate list -- thank you very much!
The LaCrosse also has a good ride but visibility leaves something to be desired.
Review your vehicle
Review your vehicle
Thanks for any advice you can give me. Dewey
Any hints on how to prevent and how to repair. My other GM cars had a black synthetic material in that area.
Thanks, Dewey
Tx, Dewey
Thanks, Uncle Dewey
