I got the steering retrofit (4/2 build). In short, no big difference. It feels a tad heavier, that's all. There is no improvement in the already great road feel - I have always claimed that the issue with post-January cars is not road feel but purely assist. I took out a June build 330ci out for a back-to-back comparison. The June build felt the same as my 325i before the retrofit. The retrofitted steering felt a bit heavier off-center, giving you a better sense for how much you're turning without looking at the wheel (slightly better on-center feel). However, the feel right in the center (within a 1-2 inch wheel turn) still feels a little vague and it seems to me that it should be more responsive than that. The biggest difference due to the retrofit is felt at high speed (>80 mph). At that speed, the steering tightens up considerably and responds to smaller steering inputs. There is, however, more wander at high speed than I'd like to see. The steering weight of my retrofitted 325i is much closer to the June build 330ci than the '99 323 with the original heavy steering that I drove a few months back. I'm not sure what to recommend to those of you considering the retrofit. If you have a 3-series with the really light steering (pre-January build), you will notice a significant positive difference, just like Kominsky described it a month ago. If you have a post-January build, you will only notice a minor positive difference. I thought that it would have been easy for me to go through the steering retrofit mentally but I have to admit that I was anxiously comparing the steering after the retrofit and I spent too much time overanalyzing the results. If you are happy with your car's steering, don't touch it or be prepared to endure some painful doubts. BMWNA made a mess out of this issue and although they managed to turn it around into good PR, the retrofitted steering is NOT the same as the original 3-series' heavy steering, such as that found on the '99 and '00 323 and 328 models.
I had to fight with the dealership to take another 3-series out for a back-to-back comparison. Was I asking too much you think? Maybe I have unrealistic expectations for what's reasonable but it seems to me that there is lots of room for improvement in BMW Peabody's service. It has been my experience so far that being very polite with them takes you only so far. Insisting and holding your own works much better. It should not have to be that way.
After sensing that a BMW owner was going to make a scene right in the middle of the showroom on a busy Saturday morning, they put me in a 330ci step and although I did not ask for it, they told me I could take it out by myself for as long as I needed to. I only drove it for 5-10 min - the step is exceptionally smooth but no fun ( The car had plenty of power on tap and I was able to get a good feel for its performance capabilities. At any RPM level, it's like punch the gas and you take off immediately. The 325 typically hesitates if you depress the accelerator all the way when the RPM's are below 2K. There is a huge difference between the 325 and 330 below 3K. However, past 3K RPM's, the 330 felt just marginally faster than the 325 and they both pull with relentless determination.
I finally started using the V1 radar detector that I bought a month ago. I have not installed it the way I want it (no time) but at least I am using a thin phone cord instead of the coiled cord. It is almost invisible against the black interior background and especially if you don't know it's there. So far, all I can say is "Buy it". In and around densely populated and especially commercial areas, it is totally useless. However, out on a rural highway, it is tremendous help. The detection range is probably longer than what most people need and it has great rear detection as well. I never thought the directional arrows would be so helpful. It is enormous help knowing where the signal is coming from. It is very comforting seeing the arrows indicate that you are passing by the cause of alarm, which you most often do not see. The bogey counter is also great and very helpful in determining the likely cause for alarm. Mounting the V1 (or any other detector) on the visor is a big no-no for the 3-series. It renders the visor obsolete but most important, you cannot easily see the warning lights and info up there. Mounting it way up on the windshield is excellent - the suction cups are behind the blue tint line and the V1 unit itself is right underneath the tinted line. You cannot see it at speed and it is barely visible from outside when the car is motionless. Once I run the cord behind the panels and hook up the concealed unit, it will be totally invisible from outside. Do buy the concealed unit ($40) if you are thinking of buying the V1. In addition to being visible only to you, it will be on the dashboard in front of you, which is by far the best place to be looking for detection info. You don't have to take your eyes off the road/dash to find out what the beeps are telling you. In my limited experience with the V1 so far, I think it is unsafe to drive while looking up there for detection info and trying to interpret it at the same time. The concealed unit is more convenient, discreet, compact, and much safer. Unlike the built-in K40 radar detector, which is more than twice the price, you get the bogey count, the directional arrows, and the flexibility to use it with different cars. Even so, the V1 is no substitute whatsoever for you natural radar detection abilities (common sense). It is just a supplement that has to be used wisely and should not distract you from the road.
As a final note, I drove from Boston to Albany (170 miles) for work this morning. I've been doing it for 5 weeks now. I get reimbursed for the miles and the way I look at it, my company is paying me to drive my BMW. It is the type of work that I would have gladly paid for ) Call me crazy but I am actually looking forward to my 2 1/2 commute. I am not at all a morning person but when I wake up at 5:45 AM, I am excited about the drive I have ahead of me. I get out of the car 2 1/2 hours later energized and with a smile on my face... I'd turn at least a couple of times to look at the Shtroumpf before I enter the office building. I guess it's some sort of a mysterious "BMW Thing" because I've never felt that way about any other car, except for that 911 that I once drove for a day.
Thanks for the analysis.
Best Regards,
Shipo
Shipo, as I mentioned in my previous post, the retrofitted steering is heavier than the June build 330ci that I took out for a drive. I think the '02 models will be just like that car and if you like you 328's steering just the way it is, you will likely be very disappointed with the '02 models' steering. Again, my 325's retrofitted steering is closer to the June build models that it is to the original 323/328's steering.
shipo - iwould would go test drive the 02, since i think bmw probably took car of the problem since there are so many complaints. Although the new front end is ugly in my taste.....
How much at BMW dealer vs authorized service center??
Kominsky -- u da man, thanks for your help! (haven't decided on the wheels yet...tire rack has yet to come back to me with a set of options).
genie1 -- where'd you go?
This car is absolutely amazing....wouldn't trade it in for the world (maybe an M3, though).
I haven't exposed it to the elements yet...will have to wait and see how it wears.
But it looks great so far.
Good luck with the snows. Let me know how they work out for you.
If you haven't been to Nashville, IN, check it out one weekend. Its a tacky tourist trap (no offense if you like that sort of thing) but the drive from Bloomington, IN is fantastic in a car that likes the curves.
Besides, the leaves should be turning soon.
Shifty?
Anyone?
I hope the retro will cure the mystery left-right imbalance. If it doesn't I'll be real frustrated.
What I still don't get is if the 328, retro and 6-01 cars all have the same rack, why do they all feel different?
Take Care
Mothers:
The Mothers system was labor intensive. My brother and I took an afternoon to complete. It lasted all of one month (more like three weeks). I had the worst time with water spots (not just from Toronto's polluted rainfall but also from just the weekly wash.
I didn't WANT to wash my car every week, but HAD to. This is because the car was soon covered in sticky dust even when it sat in my garage. I dreaded washing the car because I seemed to redistribute the dirt and add a splatter of water.
I'm not a neat freak but it really bothered me to see my beautiful car covered in dust and water spots.
All I wanted was to reduce the water spots that I got when rain fell on the dust on the car. And a good coat of protection for winter. I don't mind the elbow grease initially as long as the followup is maintenance free.
Zaino:
Spent a couple of hours Saturday and an hour Sunday Dawn/Z5/Z6/Z5 by myself. It took less effort but some planning around my weekend.
If you pick up one tip from this: Buy the white 100% cotton towels. (even the finest natural chamois only re-distributes the water on the car). I was extremely impressed with the absorbency of the Fieldcrest towels (two are plenty - one to soak up the water, the second to wipe completely dry).
After going through half the process, (I still need two more coats of Z5 on here before I switch to Z2) the car doesn't seem to be a dust magnet.
The paint is slick to the touch, the towel just slides off after Z6 and the lint from the towels doesn't stick.
Overall -
I will have to see how it does this week, but initial results have been as promised. It was worth the effort so far.
I will keep you posted as to how much dirt it picks up tomorrow when I drive it to work.
PS. It looks glossy in a nice different way to the wax too.
PPS. I'll admit, we may have been over enthusiastic with the wax and have applied too much (which could account for the stickiness). But I will have a hard time going back to a wax-based product from now on.
peace!
The Toyota dealer that services my mother-in-law's Corolla took it in for an alignment, and the mechanic involved managed to fail to set the brake when loading it on the rack, and if fell off the alignment rack, damaging both bumpers and doing other minor nicks to various parts of the undercarriage. To their credit, they quickly notified her of the incident, and immediately ordered parts to repair the car, and got her into a loaner while awaiting repairs. She was beside herself, but in the end the car was properly repaired and drove just fine right up to the time she sold it - bought a new one from the same dealer.
Certainly, wheel runout would easily explain your symptoms; equally certainly, this did not happen by magic...how you are going to get the dealership management to step up to the plate on this, when they seem to already have adopted a stonewall as the default approach, is a question I cannot answer.
genie1 - I just picked up some Mother's wax from the dealer and was planning on waxing in a week or so. I've used Turtle carnauba wax maybe 1-2 times a year on my old car (the VR6) and I was happy with the results. It took me about 30-40 min applying and wiping it off by myself. I would have thought that Mother's is very similar, only better quality. I am definitely staying with wax vs. polymers, just wondering if there's a big difference between Meguiar's (?), Mother's, and other brands.
brake dust - If anyone saw the CART race yesterday, you would have seen the cloud of dust that comes out of the cars' brakes when they replace the tires in the pits. Softer pads improve braking but also result in more brake dust. Function over form in my book. I brush the dust off my car's wheels once a week if even that - it just does not bother me at all. Then again, I do not use the brakes much (downshift instead), so the dust takes a while to accumulate.
Well, I was so excited over picking up the Shtroumpf on Saturday that I got carried away and I revved it into the rev limiter in second gear. It all happened very fast but the limiter kicked in definitely above 6,500 RPM's - it was somewhere between 6,600 and 6,700 in second gear. The DSC light came up and power was reduced for a split second. Overall, it felt just as if you had let off the gas - that's how good they programmed it. I remember it felt pretty frightening doing that in the '97 Porsche 911 once but then again, the 911 has a lot more torque and I felt a much stronger lurch forward. The power in the 911 did not come back for about 2-3 seconds, though, and I felt a lot safer in the 3-series when the rev limiter kicked in. I have read that the rev limiter kicks in at different engine speed in different gears. I'm guessing the higher the gear, the closer the limiter will be to the 6,500 level indicated on the dash. So down goes another question that we could not answered in the past.
Now I have the wagon, which has a slightly higher rear end then the 325i sedan or coupe.
Regardless...the engine is quieter at 4000 rpm and 80mph than my wife's Accord is at 2000 and 60mph. The constant comment that people forget to shift into 5th gear on the highway is testament to the smoothness and quietness of the BMW Inline 6.
About the ratio. The rear end in conjunction with the gear ratio in the transmission dictate engine rpm at a given speed. I believe that the step has an overdrive 5th gear, making up for the higher rear end.
Enjoy your future purchase!
How have you Compact owners liked your cars?
I too, hit the rev limiter the other day in second gear. I wasn't staring at the tach but I know I was at or above 6,500. At almost the exact time the engine cut out I was shifting, but it did startle me for a split second. I wish BMW would do what my 86 RX-7 did. About 500 RPM before redline it made an audible tone so I didn't have to look at the tach to know when to shift. Do any cars do that today? By the way, that Rotary engine was wonderful in it's time - only 80 cubic inches of displacement, 146 HP, 7,000 RPM redline, 2,600 pounds. 0-60 in 8.0 seconds, which was fast in 1986. And it handled as well as my BMW (or close, at least).
My 5 speed manual runs about 2700-2800 RPM at 60MPH.
waxing: deep rich shine is indeed what I'd like to see. I think that polymers tend to reflect more light with their mirror-like finish, while wax tends to make true colors (typically the metallic shades) come out better resulting in deeper, richer shine. That's exactly what Orient Blue needs. There is no question in mind that polymers take longer to apply but also last longer. However, I only wash my car about once a month and waxing is good enough for me.
rev limiter: CART cars have flashing lights with different colors indicating how close you are to the rev limiter. I guess when you're going 230 mph, you don't have the time to get an exact RPM read. Now that would be really cool in a BMW. I'll give it another couple of years before it shows up in the M3 GTR.
I'm impressed.
Brave: the Mothers beaded very well and had a deep rich glossy shine. BUT it was a dust magnet. It took me a while to apply because I did the whole "system". The basic wash/wax shouldn't take too long. I just didn't appreciate having to wash the car every weekend and needing to wax every month. Too much work.
I think for me the Zaino thing is like the BMW thing. I gave Mothers a try because I didn't want to go through the hassle of waiting for the Zaino to arrive. I consider it (Mothers) a waste of 50 bucks and a beautiful summer afternoon. But thats just my opinion based on my experience with my car.
According to Meguiar's website, the Mirror Glaze products are for "professionals", while its Gold Class products are for "consumers"... Don't know what the big difference is.
1) I found that the sports suspension must be breaking in as well, because my previous assessment of it as almost too smooth has now become what I really expected, that is, it takes in all the unevennous of the road quite a bit. However, it handles very well on all the meattier curvy roads I've taken here...very very nimble and hardly any roll at all. The Continentals are great and I absolutely love the rims and lowered ride. My girlfriend, however, has complained on occasion recently...the passenger seat is HER territory and should be unmistakably smooth....at least so she says!
2) The clutch in certain lower gears (maybe 2nd or 3rd) seems to give an almost pulsating resistance when I push it in on occasion (only lately), that is, as opposed to no resistance at all. I'm unsure if this is part of "breaking" it in. I'm no gearhead.
3) The brake dust is not really a problem. It seems to wash off without much effort. Is there some kind of clear protectant for the rims to keep them nice, however? Otherwise, I've been trying to stay in the habit of downshifting correctly. Once in awhile, I've had to stomp on the brakes because of some @#$% in front of me.
4) If there is anything I disliked, it would be the over-boosted steering (feels too aloof when you want to take out those snazzy Ss, especially when some streets here are TIGHT), the very limited storage in the center console (I would like to drop down something besides some spare change and my girlfriend's hairclip!), and not being able to get it in reverse when the car is angled down a bit (then again, lately, I have not had too much of problem with this...I'm so afraid of fighting the resistance, but sometimes, you just have to give a little muscle, I guess!).
Otherwise, the car is simply a joy to own and unmistakable to drive. I don't regret one penny I paid for it, and I would do it again in a heartbeat! Co-workers are eager to sit in it, strangers will come out of nowhere to compliment it, and it just feels really good to know that the money I worked so hard for is paying off with this car, this machine that keeps me looking over my shoulder when I walk away from it, wanting me to take it out for another drive....just one more for the day, I promise, it says....
Not as lucky as it seems on the surface. her "system" is usually on the order of... "someone's coming over and we cannot allow them to think people actually live here. everything must go. I'll just throw this piece of paper in the kitchen utensil drawer". On top of that, after driving the 323i loaner I had, when I asked what she thought her answer was "it's not bad, but I'd rather drive my Odyssey". Nope... definetly not gonna meet anyone like her on any BMW bulletin boards.
Retailing 101: Treat the customer right and they'll be back with another cash transfusion for your business.
When I was shopping for a BMW I recall saying to the salesman I eventually bought from-"The trick is not to sell me one car,but to sell me 5 over the next 15 years". I think that was already part of his mindset as he is a professional,a career salesman.
Recently, during a phone conversation regarding an upcoming Ultimate Drive I'm taking part in, he told me that anytime I want to come in and drive an E46 M3 he would have the keys ready,even though he knows it is financially out of my league at present. He is building a relationship with no guarantee I will ever get another car from him.
How was that Saturn loaner by the way? (ouch!)
question: Will this feature be standard for the Sport Package on both the 325 and 330 or will they only offer it and the 18" wheel options for the 330i?
