Visitor Agreement.
Although it's a matter of choice, if the Goodyears don't bother you too much, keep them until you're ready for a change. For myself, if I bought another Intrigue, I would almost immediately put another set of Pilots on. Bumps large and small do seem to be less pronounced. I also have over 7,000 miles with the new tires. Perhaps that may account for my feelings.
If you want less body roll and are willing to pay, you could always check into fitting the Impala police package rear sway bar on your Intrigue. For sharper steering response, you could install front and rear strut tower braces. I intend to install those braces in the spring.
http://www.holden.com.au/sc02_vehicle_showroom/sc02_7_vxcommodore/sc02_7_4_ss/popup_360_exterior.asp
No brainer right ? Apparently not for GM, if anybody could miss the obvious its GM.
http://coming.to/holden/vt_coupe/interior.htm
A few thoughts on the Regal and why the only mid-size GM car I'd get is the Intrigue:
1. Dashboard: besides looking like a mini sand dune, the guages seemed like they were an afterthought. Especially the guages on the right. It looked like they forgot to add the fuel guage so they dropped it below the tach.
2. Shifter: To shift you have to push the button on the top of the shifter. The problem is it feels like a lump of unmolded clay. There's a button on the left side. Place your hand like most shifters and it feels natural (and you can push the little button on the side). The problem is you can't shift out of gear like that.
3. Headlight switch: After being in the Intrigue it feels awfully awkward to stretch forward just to turn on the lights.
4. Wiper/cruise control/turn signal stalk: Come on. Back when the gear shifter was mounted behind the steering wheel it made sense. Is GM trying to empty out its stock?
On the positive side, the seats felt very comfortable as they should in a Buick.
Not that I think the Buick is a bad car, but I do think that the Intrigue interior was thought out much better than the Regal. The guages are symetrical, the dash seems better laid out and the shifter feels natural. Some folks don't think the shifter feels right because of the way it looks (Ann Job seems to think so). If you let your arm fall naturally, you'll notice the Intrigue shifter fits perfectly into you hand.
Considering that Olds will probably not even be selling leftovers by the time Epsilon-cars are released ('cause they probably won't be around), I wanted to be sure that getting another Intrigue wouldn't lead to buyer's remorse.
I know this will spark some comments from Regal owners. But hey, maybe it will put us back in the number one spot on TownHall.
Accustomed to them in the very first day I received the car, and since never had any trouble with reading them.
2. The Regal vents are inconvenient somewhat. Tend to blow the cold air on the hands. Good for hand heating, bad when used with cool air.
My wife does not use the auto mode of the Regal climate control for this reason, while I aim the vents above my shoulders.
Additionally, the vents or fan rattle a bit at higher speed (in the auto mode it happens suddenly, without driver control).
The same two problems as with Malibu vents. The Ford Taurus ones are a bit better, but not so much. The best vents I had experience with belong to the Pontiac GrandAM. They look as rough industrial design and are made of plastic, but are very functional, easy to aim and quiet.
3. The Regal stalk is inconvenient, especially if you switch back and forth to other car. Overloaded by functions as a Christmas tree. After 3.5 month I am still have to recall how to use washer, and am engaging the cruise control instead sometimes. The same with high beam toggle.
I believe, the stalk is still used with Regal, Impala LS, and even Monte-Carlo because the other cars produced on the same plant have bench seats and column shift. Century, the base Impala, LeSabre...
4. The headlight switch on the dash is a consequence of the single stalk. Otherwise it would have even more functions. Any case, it does not matter at all: with the automatic headlights, I used the control only once in 3.5 months - and only to test if it does work.
5. I found the cassette controls and the air condition controls to be somewhat inconvenient. A lot of buttons, most of them of about the same size. Cannot distinguish the buttons (and the settings) by touch. Have to remove my eyes from the road to read the temperature etc. on the under-dash panel. Switched the air flow direction often instead of increasing / decreasing air flow and / or the temperature.
Fortunately, the cassette controls are duplicated on the steering wheel.
As you can see, some real car's deficiencies became clear only after using it for time being, while some perceived deficiencies turned to be not-existing.
She's cold the GM mark having owned at one time a Vega, and her father a diesel impala -both terrible mistakes by GM. Anyway, out of the cars, I prefer the olds comfort features and nice 3.5 motor and trans, the good looks and size. The maxima is a great car but ugly and very japaneese in design, costs a ton to get a equipped one. Anyway, I may go rent a intrigue to show her what a good car it is for 24 hours, they have them nearby.
RE: regal - I think the outside is very sleeper, but inside could use some work, very 80's or even 70's.
Slope
Best wishes
Ken
However, the W-body sedans still give much bang for the buck and you can get the same powertrains and equipment as in the larger H-platform sedans for less $$$. Still the Bonnie SE is one of my favorites.
I once owned a VW Golf, it was great until about 80k miles and then it got real expensive to repair, and plus a bunch of little things kept breaking. German cars in general can be very expensive to keep on the road JMHO.
in the Middle East as well as a Lumina SS for chris' sakes. Hello, GM, anyone home, bring it here. I always liked the Aussie's, how they combined European chassis tuning with American V* muscle, the best of both worlds.
Saw yesterday while printing Intrigue articles and data, that the recent SEMA show had the 2nd gen. OSV Alero with the 3.5 this time (!) and a new OSV Intrigue stuffed full of caddy Northstar 4.6 v8! And they decide to kill them all off of course.
Ron Zarrella needs some time off, permanently, as he obviosly doesn't have a clue.
http://www.caprice2000.com
So in the end, extend your gratitude to some of our elected official that if left up to them, bycicles and horse carriages should be good enough methods of transportation. Thank God Al Gore did not make it to the White House...He is the #1 enemy of the automobile as we know it.
And yes, Ronald Zarella could take an extended vacation in the process.
Check them out at:
www.gm.com
Then select the brand link to the 'Holden' website.
Due to CAFE regulations, we won't see these cars in the US.
teo: I've seen the SE and it is much more to my liking. Probably can't option the supercharged engine though. Still, the 3800 is a darn good engine. Another concern with Bonneville is there is rumor the car will cease production in 2003. Any thoughts?
vocus: Nothing wrong with "boy racer" look, just don't personally like it much for me. Didn't know about the SSE name drop though.
It's probably the air wrench (at the hands of careless techs) that breaks them.
Best to all
Ken
He was in front of the olds booth with all sterling silver oldsmobiles behind him.
He was standing next to a silver intrigue with the dark grey interior. A combination that i really like. Although i know a lot of people don't.
He said at a recent auto auction an a 2001 aurora came up and they couldn't even get people to bid on it at $15,000. Thats about $11,000 depreciation at wholesale level!!! Not good.
I am still trying to see if olds will cancel my lease early and let me buy a 2001 Intrigue, but my dealership has not called me back, so i guess they are not really interested.
I want the same deal that limadelta got.
etharmon/tpken : I would take a 3.5 Aurora over any Bonneville. That being said, the Bonneville is not a bad car at all. I just really like the Aurora's looks inside and out better. It's also more sophisticated mechanically.
Auto show is 2 week and counting!!
One note though, I did notice that the 3.5 does use a little oil between changes. Nothing drastic, but I'm sure it will cause problems for those that never check their oil, antifreeze or tire pressure.
On the lighter side, still winter in Cincinnati, with more car painted a nice shade of salt white a lot of the time. On the other hand, when I do wash it, the silver mist really does shine.
Bryan
Ken
Both are great cars, but wife and liked the max a little better, and better resale -and at this price, was cheaper. The olds is better looking, but hey I can live with the max.
Have fun and thanks for help. That 3.5 is a strong and good running motor, trans works well. It was the ride (about the same it seemed) and road noise (olds silent on smooth roads, but really got pretty noisy on rough roads) that swayed us beyond price.
Slope
Houston, Texas
Q1; Anyone with a similar experience?
Q2: Anyone familiar with NYS Lemon Law?
b4z, I like the Sterling with dark grey combination alot. Midnight Blue is still my first choice and either sterling or black would be my second. With Bronzemist coming in third. I like the Ruby too, but since my 98 is red(Crimson) I want something different. Forest is okay, but I like the Aurora's darker Polo Green better and White and Sandstone just don't attract me. BTW, anyone remember that purple looking color they offered in 98? I remember seeing that in the bochure and on the color charts when I was looking at mine and the dealer said they had never had one in that color or ordered one. I actually saw one on the road the other day. It had chrome wheels and was okay looking I guess, but I don't think I'd want one in that color. Anyone else also think Olds should have offered better interior color choices? Light grey which is what mine has is no longer offered.
slopedirk : Congrats on the new Maxima. I'm sure you will enjoy it. If they fix the back of it and tune if for regular gas for the next generation perhaps I'll get one in a few years also. Won't be any Intrigues left to buy and I don't want a tin can Accord.
etharmon : The big advantage of the silver color is that it doesn't look so bad with winter crap all over it. If I lived in a less snowy climate, I would have gone with the dark blue for sure.
Demand satisfaction and you will get it. If they can't fix it go to arbitration.
This is the first time i have heard of leaks on the 3.5L motor. So it is unusual.
It is probably something minor. But, GM has been known to give people new engines if they can't fix them.
At the auto show here when the Intrigue first came out in the '98 model year, the first one I saw and sat in was a black '98 with a gray interior. It was about as inviting as a concrete block. That alone made me question what GM was thinking. The neutral is better-looking with most colors, though it has a terrible name. The paint colors have been disappointing to me too. I absolutely despise Silver Mist, and no interior color seems to go with it anyway. The '98 Opal Blue wasn't very attractive either. The Midnight Blue is the best of the current colors IMO, and the Sterling would look better with a different interior than the gray. I don't care for the green they're offering, and the sandstone is everywhere on cars these days so I wouldn't want that.
As for exteriors.. what about the dark red color?
Raven's win the Superbowl. Yaa! Anyone but NY was my hope.
