Used STS would be a nice choice. The new ones are beautiful IMO. Unfortunately I can't afford a car like that yet, but I love my Intrigue!
About Euro this, Euro that, I couldn't care less. I just want the best car my hard-earned money can buy.
seemed like a good deal to me.
In 1984 I paid $505.00 for the H.O. L69 motor in my Z28.
Does the 3.5 use standard GM pumps? That's the most likely thing to replace on an engine. If they're "normal" then there will be aftermarket parts.
We're going to be stuck with GM for things like head gaskets, but at least we can get the parts. Heck, you can get gaskets and other parts for cars which long ago disappeared from our shores, like Renaults and Alpha Romeos. (You might need to wait a few days for it, but you *can* get it!)
I guess the key issue for owners several years from now is: "How much inconvenience will you put up with to drive an Intrigue?" Can you wait a few days for a part? Would you take it to an Oldsmobile specialist 30 miles from you?
Oh wait the Catera was imported.
The Saturn L series is the current generation Vectra. The new one appears to be bigger, hence the perfect replacement for the aging N-body Malibu.
Questions:
What's the deal with the after market Xenon bulbs? Do they really work, and are they street legal?
Would anyone recommend a good source of parts in the central New Jersey area? I'd be happy to go to yards and pull parts, (e.g., climate control, CD player, driving lights) myself.
Also, has anyone had a problem with the color fading on their side view mirrors? If so, have you been able to get a dealership repaint them at little/no charge after warranty. I from a technical service bulletin that I came across that know GM has done this in the past with some other models.
I'd be happy to share info re: my buyout of the car.
Questions:
Also, has anyone had a problem with the color fading on their side view mirrors? If so, have you been able to get a dealership repaint them at little/no charge after warranty. I from a technical service bulletin that I came across I know GM has done extended this service in the past with some other models.
http://members.aol.com/wizbang250/STB_Bracket_Build.htm
BTW, has anyone installed just the rear STB and if so, was it an improvement or did the increased stiffness in the rear "unbalance" the car in some way?
I'm not familiar with the Intrigue engine compartment layout. But, what I can tell you is the brackets I've designed lift the STB 5/8 inches higher than its normal height. This also puts it 1/4 inch from the hood on a Grand Prix. I would not feel comfortable going any closer to the hood. How the hood line of a GP compares to an Intrigue, I don't know. I guess the only way to know for sure whether the brackets in their present configuration would work on an Intrigue is to test fit them out.
If you, or someone you know, own an Intrigue, were willing to get a STB kit and commit to test fitting a set of brackets, I'd send a set out your way. You could reimburse me if you felt they worked to your satisfaction. If they didn't work, I'm sure I could modify the design to have it work just fine. So, I'll leave that ball in your court. If this is something that you might be interested in, email me back your address and I'll get a set of brackets out to you. ;-)
Another thing. In your message, you stated you caught a link on the Edmund's Town Hall Intrigue forum to these brackets. I was not familiar with this forum. It's sure amazing how information travels on the web.
To answer your question you posted on that forum, mounting a STB on the rear only will not throw your car out of balance under normal driving situations. I had my rear on a week and a half before I had my brackets designed, made and the front STB mounted. During that time, my GP's handling was well behaved. I hope this settles any of your concerns.
Look forward to hearing back from you,
Jim
I have a '99 GL w/54k and today the ABS light and brake light illuminated and wont go off. The rear calipers dont appear to be working, as they were cold to the touch after driving. and the fronts were not!! I called the dealer service dept. and its going in tomorrow. Anyone seen anything like this? Thanks, Mark
Hope to hear from you before Feb 22 via the Talk to the Press discussion or at jfallon@edmunds.com with your thoughts and contact information.
Thanks as always,
Jeannine Fallon
PR Director, Edmunds.com
Sometimes a front-strut assembly will correct noise but I don't think you want to go there. Next oil change, have them lube jounce bumps (easy, should be free) but take the mechanic for a ride so he can hear the noise.
Front end noises on Intrigue (especially early ones) are a trademark for this car.
I will wait until next winter to get it fixed. It's not that bad and I want a 1 year warranty on the replacement at the end of the car's warranty.
I just purchased a 2001 used Olds Intrigue with 27,300 miles on it. The car only included the 3 year/36,000 mile GM warranty and the chevrolet dealer added an extra 3 months or 3,000 miles on top of that.
I was trying to find out why this vehicle did not come under the 5 year 60,000 mile warranty and found out that this vehicle was manufactured in August of 2000 and was not part of the revised warranty features. (Is this correct???)
Also, when I was driving the vehicle, there was some clicking that could be felt in the steering wheel and that small bumps in the road could be felt in the steering wheel (Like the front suspension was loose). Also looked as though the power steering fluid is low. I am taking this vehicle to the Oldsmobile dealership tommorrow and am getting this fixed under warranty. I had seen some prior posts about this problem (lubrication problem, steering coupler, etc). Any other info on this problem would be appreciated.
I am also asking them to replace the air filter and cabin air filter as well as making sure all applicable recall notices are taken care of.
Also the chevrolet dealer did not have an owners manual to give me so they are going to find me one. In addition, they only provided me with 1 key. I am going to need another one and my father told me that the keys are specially coded and cost around $20-$25 for a replacement.
I had the dealer provide me a carfax report and found that the vehicle was obtained from auction and that it had been leased in Boca Raton Florida.
(In a year and 4 months the car was driven 27,000 miles) Hopefully all highway miles.
Started to worry about salt water and rusting problems but the body looks OK. Small pin rust spots were noticed around the trunk wells when the trunk is open. It appears that water could accumulate here. (Any pointers about removing this?)
Other than that the car has new tires, the brakes appear fine and the overall body is in great condition. Can anyone think of anything else I need to have the dealer service while it is in the shop?
Does this car take normal power steering fluid?
What Oil weight is recommended? 10W 30 (Is synthetic oil better to use than the synthetic blend)?
I currently use Mobil 1 in my minivan but that gets expensive after a while.
Also, this vehicle does not have the keyless entry GX Model. Can this be purchased aftermarket and if so how much does it cost?
Any additional pointers would be appreciated?
I got a replacement key at a locksmith for $2.50 and the dealer paid for it. There's nothing special about it.
5w-30 is the recommended oil weight. I think it says this right on the filler cap. The oil quality sensor will tell you when it needs changing. I wouldn't bother with synthetic.
I purchased a "Viper" keyless entry with trunk release for $150 (installed). It doesn't have an alarm but who's going to steal an Intrigue?
The clicking could be the intermediate steering shaft. My Chevy dealer replaced mine without even being asked to when they noticed the click.
The primary determination between a "new" car and a used one (in legal terms) is whether a title for it exists. Even if the dealer used the car for some reason, and put a couple thousand miles on it, as long as a title has never been created, it's still a "new" car in the eyes of the state.
You could still raise a stink and see if they budge on the warranty. But I wouldn't get my hopes too high.
I have been checking under the car to see where the oil plug is to drain the oil. Is it easy to change the oil yourself on this car???
Also, I noticed that the coolant in the plastic resevoir is Brownish yellow (Orangish). Is this the normal color of the coolant or is it dirty?
(It says the coolant should last 150,000 miles).
great news on the car. While yes it has some reliability issues, overall its an excellent car, and one of the finer sports sedans on the market for the price. Enjoy...just remember to get on it and hear that great LX5 v6 once in awhile!
Lights still have the dimming problem. I supposably already have the new alternator. The dimming seems to be less right now though.
Another new problem that happened to me was that the dash lights quit working automatically when the headlights came on in the evening. The dash lights intensity dial was dialed up to bright too. If I turned the headlights on manually, they worked fine. The dealer said they found nothing wrong but they now work ok. I was told to read the manual. Excuse me, I have to count to ten again..........Ok, I'm better now!
I guess my biggest problem so far has been the Oldsmobile dealership. I go to take my car in...they say I have to have an appointment.....I make one.....I bring it back on the appointment date......the car sits all day without being touched! Car goes back this week hopefully.
Question on the Impalas to everyone....Is it just me or did Chevrolet blow it by not having the three round tail lights in the rear instead of the two that they have? Three rear tail lights always was the quick indicator of the Impala vs the Bel-Air. Plus I think that 3 smaller tail lights would look better than the 2 plate size tail lights they currently have. This is not a flame, I would have probably bought the Impala over the Intrigue if not for the 5/50,000 mile warranty. I bumped that up to 100,000 miles too!
Dealer calls and says intake manifold is warped and needs to be replaced. $620.
Extended warranty covered it all. So 3 weeks into my 4 years of extended warranty and I already got half my money back. It's always a good feeling bringing your car to the dealer knowing someone else is picking up the tab.
I know alot of people see extended warranties as nothing but a money maker for the warranty company. That may be, but it helps me sleep better once the original warranty runs out.
With parts costing what they do and labor at about $80 an hour, it doesn't take much for a $500 dollar repair bill.
I have a 1999 Olds Intrigue GX with the 3.8V6. I am starting to experience intermittent starting problems. The car starts but idles roughly on occaasion. This usually happens when the car has been driven and is warm on restart. Other times it starts fine. Also after the car is put into drive and starts to move the rough idle disappears. Has anyone else experienced this problem and if so what was causing it? Thanks in advance for you help.
I know you do also "1way".
Test drove a Toyota Matrix on Friday also. Really neat little car. Waiting for the Vibe twin as it looks better on the outside.
one2one : I agree, the Impala needs a better interior and rear end before I would look at it again. I think at this point the upcoming 04 Malibu looks like a better bet though it's a bit small.
Can't help you with price in the US, but it sounds like a good deal.
Mine rode hard over small bumps. 2001's and laters might have softer struts which is a real plus.
I think somebody just posted about that on their 3.8L intrigue.
So, my 8 month old 14,000 mile impala finally had its first problem.
I had been to the dealer about 6 times during this time period with the intrigue.
rotors, I've now got 12,000 miles on my 2001 GLS(purchased in July) and no brake problems at all. Stops are smooth and straight.
