http://www.homestead.com/macmillan/files/actuation.pdf
http://www.homestead.com/macmillan/files/antilock.pdf
http://www.homestead.com/macmillan/files/brakes.pdf
2 dead batteries
replaced intermediate steering shaft
replaced crankshaft sensor
fixed migrating door trim
fixed loose shift handle
replaced trunk struts
Only 4 payments left and she's all mine!
Please respond by March 9 to lordusky@aol.com
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
He did find a new problem. By slightly wiggling the ignition key while the car was running it would cause it to stall out. It's possible that this may be connected and they're replacing the ignition switch. I got a call late in the afternoon that they are also replacing the alternator!!! This will be #7 for this car(we took delivery of our new Intrigue exactly one year ago today!). He said that the one they put in last month is the old model.
The representative from GM called today because we contacted BBB about arbitration. He was the rudest, most ineffective person I have ever talked to! He called the dimming problem a "design characteristic". Needless to say we're at an impasse unless we get our car back tomorrow and it's defect free!!
Do all of you Intrigue owners have headlights that dim off intermittently??? Don't think so....
re: Air Dam
Yes, I had wondered how much if a difference it makes. (I pulled the air dam off my Mazda when it was damaged, and the engine temp stayed the same.) I still want to get the redesigned one when I have time.
Dealer immediately changed alternator (p/n 10464395)(test shows not charging at times); said the two could be related?!?
I really went in to get on record in case I buy at end of lease. I didn't think they would change alt. now. I don't know if I'll get to buy; GMAC doesn't seem interested. Buyout is 16.2K, trying to offer less than 10K. GMAC is losing a ton of money on those leases from 1999 with nearly 60% residual.
The good news may be that people who really like the Intrigue will be able to pick up used ones cheap for a long time. Imagine picking up a used PCS 2002 Intrigue in 2010 for $1000. I bet you'll be able to.
jg28 : I have had only slight dimming on cold nights. The lights never went out. My wife noticed it also so it's not my imagination. I will wait till next winter to have it fixed, probably just a month or two before the warranty runs out. Have not seen the problem again since January. February has been a pretty warm month.
headlights failling can cause accidents/deaths. GM should be really concerend about this. And the poor guy comming off the warranty gets the shaft again.
Back in 98 & 99 I was constantly on this site. There were a lot more complaints about warped rotors on Intrigues that didnt have the autobahn package than the ones that did. I have the 98 and they warped at 7500 & 14000. I still say that particular problem was caused by defective rotor casting and the fact that the pads no longer have asbestos. By the way I never saw an offical recall on the autobahn package If you could dig it up I would like to read it. I believe olds stop making it after the 99.
Actually it was the thought of foregoing that sweet 3.5 shortstar that forced this economically questionable decision. Anyway the extended warranty, discounts and terms made it acceptable. Especially when faced with the alternatives.
Was able to buy this vehicle for under 25K out the door and 5 years of payments that approached lease amounts, and we keep the car. It's a rationaliztion, but I could not find a competitive vehicle that was equipped or handled like I know this car would and does..
And although I read the horror stories of Intrigue idiosyncracies here, I have been in one since 1998 and have yet to encounter any of them. The Eagles did wear out in 24,000 miles but That probably is not the cars fault.
Comments on various topics. Have been using synthetic oil exclusively in all my cars for about 10 years. I fudge the cost by extending the change interval to 10K. I replace the filter and add a quart of oil at 5K. This has resulted in no problems, and I believe, superior engine protection, on the 8 vehicles I have owned in that time.
One of the most appealing properties of the synthetic is its resistance to heat and varnish formation. The stuff just doesn't have the chemical composition to turn to sludge. As long as you are getting good filtration to keep particulates out of your system, the stuff should hold up.
I believe this is particularly true with the oversized 6 quart capacity of the shortstar. With that amount of lubricant in this engine, they should have remarkable longevity. Time will tell.
Cracks me up that they removed and replaced the alternator(#7 for this 1 year old car), because "they discovered that the wrong alternator was in the car". I asked about that when they installed it in January because it had the old part #. I'm hoping that this will be the end of this fiasco. We can put up with a mild fluctuation in brightness of the headlights, but dimming nearly totally out intermittantly was unacceptable and dangerous. We'll be taking it out for a couple test drives at night to see if we can totally enjoy our car now! Will report back...
delrick : Congrats on the new 02 Intrigue. While the depreciation is bad, you have to keep in mind what you actually paid not what the list price is. Intrigues sometimes have a few bugs in them, but nothing that will leave you stranded that's for sure.
Do you notice any difference in ride quality between the '99 and the '02? Several have said the '02 rides a little better.
I am considering a K&N mod. How did yours work out? Any airflow meter problems as a result? (I saw an old posting of yours from April of 2001.)
Also has anyone installed after market strut tower braces? I'd be interested to hear if anyone thought they were worthwhile.
I've got 52K mi. on my '99, and knock on wood, the only problems I've experienced are the migrating front door trim and the loud noises which emanate from the ABS when really hard braking causes it to activate.
I love the way the 3.8 pulls of the line, but it's not smooth or as responsive at highway speeds. Handling is also excellent; worlds better than the Maxima which was the other car I was considering when I leased the Intrigue back in '99.
You could probably get it for less also. Unfortunately I can't get another.
If you look at the K&N thread in the accessories section, you'll read that about 1/2 the people didn't notice anything and the other 1/2 did. I believe those who think they can tell the difference are noticing the placebo effect, i.e., they think performance should increase, so they're sure they feel it.
gunmetal MR7
Recently I threw away $114 on plastic hubcap for 15" wheel.
Had a 45k mile service with my Malibu. Left it at dealership. The service adviser called me at work and told that hubcap is broken and need to be relaced. However, the genuine GM hubcap for 98 Malibu costs $114. Dealership does not store the part, need to order it.
When she called, I was deep into program debugging, absolutely disconnected from the outside word. Additionally I have problem with understanding her diction. Thought that it cost $14, and approved...
Oops!
Perhaps a 5 spoke with rounded spokes and curves where the spokes meet the rim and hub would be better.
Regarding ride difference from the 99, I do not see much diff. Maybe slightly firmer. There seems to be more change as a result of the larger tires/increased ground clearance. The taller final drive ratio and the subleties introduced by the PCS.
Not sure if I a care much for the "improved" Magnasteer. It seems more squirrely to me at all speeds. Maybe just a getting used to isssue.
Was disappointed with the content reduction in the 02. No fuel cover release and the spare tire/trunk treatment. They deleted the carpet overlay and wrapped some material around the spare cover. This looks cheap. Of course they did not get the carpet back in the 99. They did get an 02, carpet covered spare tire opening cover ;=)....
"Apparently prompted by competition in the form of the Grand Marquis-based Mercury Marauder, General Motors has approved importation of a version of the Austrailian-market Holden Commodore SS as the next Impala SS. The rear-drive sedan features a Corvette-spec (350 hp) Gen III 5.7L alloy V-8, six -speed maual gearbox, ABS, limited-slip differential, and 17-in. 235/45 V-rated tires. This would seem to doom plans for an SS based on the current U.S. market front-drive Impala---but that hardly seems like much of a loss."
Interesting...........
"SS" means trim, "Impala" - model. To sell absolutely different model, on the same market, and to name it like just another trim... It would confuse customers. Bad idea marketing-wise.
Personally, I would still get one. The performance increase may not be reflected on the dyno but the pump is another issue. It's a fact that a dirty paper filter will erode gas mileage and performance suffers as well, even if not dramatically. So, with that info, I tend to believe that there is an increase in performance.
Another argument he makes is that the cost of paper filters over 50,000 miles is about the same as one K&N for the same period. True. But that means you don't have to go under the hood or pay someone to go under there to replace it.
So if a dirty paper filter reduces fuel economy, reduces performance and makes me replace it more than twice in the life of the car (under 100,000 miles) and a K&N improves fuel economy (or at the least keeps it at what the EPA says it should be for the car) for 50k miles, assume it doesn't do squat for performance, over the same mileage cost me the same as a paper filter but only have to pop the hood once (which is a big plus if maintaining more than one vehicle), then I think it's worth the money to put one in.
And if after all that the placebo effect kicks in and you enjoy driving your Intrigue more, then I don't see where there is a drawback or waste of money.
Is that Canadian or U.S.? That sounds awful high. The one I got for the Intrigue was only $45. I didn't get the cleaning kit because I wouldn't need it for another 50K. The Bonniville was over $70 (which suprised me) although the airbox is larger.
I agree with one2one. I've enjoyed mine and haven't regretted it for a minute. They're not exactly easy to replace and if I can leave it alone for 50K, I'm all for it. Plus, I happen to think that I'm not just taking a sugar pill and that it does make a difference, even if it's only slight. I don't remember how much mine was but I was thinking around $40 USD. I got it from macromotive.com
Wasn't there someone here who talked about having custom made badging for his Intrigue? I'd pay money to get OLDSMOBILE in the Intrigue font right underneath the license plate on the rear. Then I could take the halfhearted Oldsmobile off the rear end.
As far as badging, I was also thinking of taking the tiny oldsmobile off the rear end. It looks straight out of the eighties.
