Visitor Agreement.
I was going to just replace the fluid myself....but read there was no drain plug on the transmission pan. Didn't want to get into siphoning.
That's a bunch of horse hockey.
The filter is a cloth-like fuzzy material somewhat like the engine oil filters. I cut apart my last one I took off the car. One particulates are caught in that mesh nothing is going to back it out and make the filter clean.
You just donated to the company profit plan.
You can jack the car up a little, place stands to support the weight, remove 20 little bolts from around the pan, catch the fluid that drains in an oil drain pan or plastic storage tub, replace the filter, install a new one securely, put pan back on with same old rubber gasket, tighten the little bolts evenly to about 2 lb-ft, refill with 7 quarts of regular trans fluid from PepBoys of a good brand, and have spent about $35.
Put down sheets of plastic to catch splash and oil that misses the catch pan-I use plastic protector they have to Lowes and HomeDepot for you to put in your car to protect the trunk from plants.etc.
You will be surprised what's on the bottom of the pan. If you find metal shavings, save the gunk for a trany guy to look at.
There are some sites that help tell exactly how to do the change. I've done it 5 times on 98 LeSabre in 130K. I don't change filter other than at maybe 70K miles.
LOL. I knew going in that a "small" donation would be required...so that part is fine. But, when I called earlier in the day to talk to the service advisor he answered "yes" when I asked that they could do this(backflush) because it was a metal screen type filter. If I had known it was the cloth type filter you described I probably would have taken it somewhere else to change the filter.
But, whats done is done. Got new trans and coolant fluid so won't have to worry about it again. I will sell the Regal in maybe 5 years.
That dealership did try to sell...sell...sell though. Wanted to change my oil as well as take my car over to their body shop to get an estimate on small dent on front fender. No thanks.
This is true, and I've done it myself twice on Chrysler minivans, but a word of warning on these here Regals. While pulling the filter off might require a good yank, getting the bushing out of the hole that the filter fits into can be a real bear. I've read where some guys just leave it in there and throw out the new one that came with the kit, that is if the old one is still in good shape. GM might sell a special tool for this. Also, be absolutely sure you buy the correct transmission fluid. There are different types and pouring in the wrong one will ruin your transmission. And, yes, this can be a messy job if one isn't careful; but a very satisfying job nonetheless.
For those out there who might be interested in trying this, I highly recommend you invest in a Haynes (or equivalent) manual specifically for your car. It might cost 20 bucks, but can save you hundreds.
At 50,000 I had the tires rotated as I do every 5,000 miles and now there is a noticable shimmy in the steering wheel while traveling at certain speeds.
Also, at 50,000 miles I had the front and rear brake pads replaced. I would like this shimmy to go away but am not sure where to start. Should I have the tires balanced and get an alignment or do you think there is more underlying front suspension issues.
I normally do not keep cars this long, but I really like this one and would like to keep it a while longer.
I balanced my wheels at Firestone when I bought replacement tires from them. I asked if weights are compatible with alloy wheels, and receive a positive answer. A year later the weights started to rust noticeably. Back to Firestone: the managers told that all weights rust and that his shop does not carry other weights.
When changing air filter at dealership several months later, I asked them also about the rusting weights. Turned to be that the dealership uses special coated weights for alloy wheels.
I was pleasantly surprised to learn that even at dealership a full rebalancing, on Road Force machine, costs only about $40. About the same as at Firestone, with bad weights and inferior equipment. Unfortunately, my wheels already corroded where the old weights were. Would I know it before...
As I said, they were good, all around (quiet) tires. If you're looking for tires that will give you super grip taking a sharp turn at 50 MPH, look elsewhere. These tires were a noticeable improvement over the OEM Goodyear LS tires (that only lasted 30,000 miles).
Bought all parts online: the Impala brackets and installation hardware from GMPartsDirect, rotors and pads from TireRack. Dealership installed everything.
The gap between the brackets and wheels is very narrow. I would say, a notch more than 1/4". However, it does not matter as long as the brackets do not rib the rims.
From what I've read it appears there are two ways to do this. One is to remove the tower strut brace that connects the port and starboard front suspension struts. For some with smaller arms and hands this might be all you need to get enough room to access the rear plugs, but you may have to climb over the top of the engine like a monkey to do it.
The other is to rotate the engine forward a little. I know it sounds bizarre, but the technique is actually described in the service manual I have for the car. With the car on a level surface and the wheels chocked, put the transaxle in neutral; disconnect the air duct; then remove the bolts from the front two engine torque strut bolts (commonly called "dogbones") and swing the struts out of the way; replace the strut bolt on the passenger side engine bracket so you can use a pry bar and rotate the engine forward, securing it in place with a ratchet strap connected to the bolt at one end and the frame or radiator core support at the other.
Some guys will rotate the engine by putting the transaxle in park and the parking brake off and pushing the vehicle forward a little, locking it in place by then applying the parking brake. That sounds to me like something that might put undue stress on the transaxle, so I think I'll do it the other way.
The hardest part of the job might be getting the spark plug boots off. When the time comes for me to do the job I'm thinking of buying a really good spark plug puller.
And speaking of spark plug boots, be sure to use dielectric grease on the boots before replacing them on the plugs. Oh, and be sure to use anti seize on the threads of all the new plugs before installing them. It will make the job a lot easier the next time. Finally, remember not to over tighten them.
Anyway, although I've never done the job before, I'm certainly not afraid to try it. Sounds like enough other shade tree mechanics have been successful, so why can't we?
Good luck! Please let us know how it goes, and any tips you might have.
I do get chimes when I turn the key on to start the motor so I guess "some chimes" are working. Could these chimes have been disabled somehow and can they be enabled and if so how.
Has anyone experienced this
Yokohama advertises the tires as performance tires. Tire dealerships I have called say it is a Touring tire...as well as advertisments in the paper have stated they were touring tires. I liken them to a Performance/Touring hybrid.
Only about 15 miles on them...but thus far I am very happy with them.
Good luck!
However, I would not fixate on the 2004 model. We have two Regals in our family, a 2004 GS and a 2000 GS. We found that the 2000 is a much better car. GM deleted a few good things in 2001, and many good things, big and small, during 2003-2004.
Jeannine Fallon
Corporate Communications
Edmunds.com
From there I believe the best course of action is to buy a spark plug boot puller to remove the now exposed boot from the plug itself. The one I'm thinking of reminds me of a pair of tongs. It provides more leverage in a tight spot. You should be able to get one at any of the major auto parts stores, or from your local GM dealer (but that will probably cost more, of course). Open the tongs, align them around the boot, squeeze the handle to close them over the boot, twist slightly and pull.
Inasfar as rotating the engine is concerned, if the 1991 model year allows you to do that, I would recommend it. You will need all the room you can muster back there.
I'd first try using the boot pulling tool to twist the boot sideways (not upwards yet) around the axis of the plug. If successful in busting it lose at this point, you've probably won 80% of the battle.
The reason I mentioned in my earlier post that there might be value to rotating the engine is you will probably need the additional room to initially twist the boot lose. Some people I've read about don't rotate the engine, but instead remove the hoisting brackets around the engine, especially the one in the back.
The boot pulling tool is usually long enough that you can pry against almost anything that isn't prone to breakage, like a valve cover. But I'd be careful of prying at an angle; could bust off the top of the plug. Might (or might not) need the other hand to position a wide blade screwdriver or something to push outwards against the tool to maintain upward (not sideward) force.
If your '91 has a plastic cover over the top of the engine, it would probably help to remove it to find good points for leverage. On my '99, the cylindrical oil filler opening unscrews out of its opening, allowing the cover to be easily lifted off.
By the way, I highly recommend you also replace the plug wires while you're at it. You might end up destroying one or two during the operation anyway.
I was hesitant to reply to your first inquiry because sometimes following advice from someone who hasn't done the job before (like yours truly) can cause more harm than good. I've changed lots of plugs before, and even busted a couple along the way, but not on GM's 3.8L engines.
Anyone else out there who has done this job already? Brian, Yuriy?
Now we're talking. Someone with experience!! Thanks!
I forgot to mention in my earlier (and rather lengthy) response that we should remember to use Anti-seize on the plug threads before screwing them in, and dielectric grease on the wire ends. If installing new wires, put grease on both ends of each wire.
Actually, even if we don't change the wires, it isn't a bad idea to refresh the grease where they connect at the coil packs, too.
thank you
Replacing the rear struts on these cars is a pain.
These cars use a leaf spring mounted between the two rear wheels instead of coil springs. There is a special tool that you can use to relieve the tension on the spring or you can just put one jack under the center of the spring and another under the side that you are working on to relieve the tension.
The struts have brackets attached to them which bolt up to the wheel hub. The bolts are very tight and usually rusted. The top strut bolts can be reached through the trunk if you pull the carpet back.
The difficult part is that the camber of the rear wheels needs to be set when you tighten the lower strut bolts. The lower strut brackets have slightly oval shaped holes in them and the camber is adjusted by tightening the bolts when the strut bracket and hub are in the proper relation to each other. The problem is that the leaf spring is always trying to push the top of the hub outward while the strut is off and the bolts need to be made very tight (I think factory spec is 125 ft/lb).
I'm not trying to discourage you from doing the work yourself, just if you do replace the struts yourself you will have to bring the car to an alignment shop to have the camber set anyway. You might as well just have the shop install the struts and save yourself the hassle.
79CustomD
I have read several times that fixing the the upper manifold leak costs about $800 at dealerships. However, it looks as the additional $400 is for fixing a separate leak at the water pump.
I'd do just the intake and price shop for somewhere else to do it. Then if the waterpump actually does need replaced I would have it done. It almost sounds like the waterpump is being added to pad the bill while they're in there working.
My dealer put pressure on the system and couldn't get it to leak--leaks will be next to the throttle body connection to the intake manifold plastic. No water runs through the rest of it. We coiuld see orange dust from the DexCool in those areas. They also showed me that under the water pump there was a trail of orange from the wick hold that lets water out that gets past the seal at the bearing.
I see no "color" from coolant anywhere that would indicate a leak. Two suspect areas where "something" has leaked a bit. But, are dried out and haven't gotten worse. At this point in time I don't see myself spending $1,200 on this. Though will continue to keep a close eye on it. Thanks.
The Century was quick off the line, but solely lacked the muscle when it came to highway merging and passing. Anything over 45mph was a chore. The Regal 's 3.8 200 hp engine is much stronger...has all the power I would ever need. That said, it has recently developed a possible slow coolant leak in the lower intake gasket.
One post mentions that there was a recall for all 2000-2003 Regals with the 3800 Series 2 engine. Under the recall GM would replace the engine throttle body fastners with redesigned fastners and add cooling system sealant to the radiator.
A few questions please: Anyone have this done and what was their experience? My 1999 Buick Regal has the same engine as those under recall...any idea why it may not have been included?
Would having new throttle body fastners and adding cooling system sealant be an option for me?(see my above posts on coolant leak) Sounds a lot cheaper than the $1,200 for lower intake and water pump my dealer recently quoted me.
GM had gone away from putting sealant in the motor from the factory because it tended to leave a crud in the overflow tank after a while or early on. People didn't like seeing that in the clear tank so they left it out. But most motors have it in and it seals miniscule leaks from the factory assembly.
I added the sealant, two tablets, to my 03 leSabre each time I've changed the dexcool to refresh that sealing material which plugs cracks that _might_ occur. I do the the same for my 98 leSabre.
If you didn't put a couple of tablets back in you 99 when you changed the antifreeze every two years (I hope you've done that) you should add it now. Buy the packet from your local Buick dealer, take two of the tablets and crush them with a spoon, then add them directly to the warm radiator and take her out of a good run. I drove to Cincinnati one time I did it. I open my hot radiator when it's not over heated but I don't recommend that for others. Do not add the tables to the overflow reservoir; they go directly into the radiator so they can circulate through the motor before they settle out to the bottom.
Go Regal LS, if you don't need supercharger. Reliability has been pretty good. I've owned for 5 years now.
