Toyota Tacoma: Problems & Solutions
Please help and how difficult is it to replace. I have done some minor stuff b4. Also cost of replacement.
the tonneau dealer try sealing it by using some kind of tape seal, but that didn't help.
Does any one have the same tonnue cover & same problem?
If so did you guys able to fix it? & how or what did you use to fix that problem?
bob
After the maintanence, all was well except for a distinctive odor that is either front diff fluid or manual transmission fluid. I had my Taco up on the rack with the guy and everything up there is dry as a bone with no visible leaks. I thought it was maybe that he just spilled some fluid and that it was just burning off but it has been 5 weeks and I suspect there is a problem.
The odor started when I rolled out of the driveway after the maintanence. It occurs only when you take off in first gear; it does not occur if you just rev the engine in neutral or at a stop. The odor also occurs if you mash the gas pedal in just about any gear. You can only smell it if you drive with one or both windows down.
My gut feeling is that the shop I took it to disconnected a breather hose or element somewhere but hell if I can see or find it.
Any help?
and second squeak appears when i turn on the fan system in the cab... where can i locate the belt for this?.. is it even a belt to begin with?..
i was planning on taking these problems to my mechanic but he mysteriously closed early today... so i pose them to you all instead...
any ideas?..
Eric
Both of the barings went out in the front. Potentially extrememly dangerous. Cost an arm and a leg. Anyone else with the problem. I bought this truck because my sis had one that lasted forever. Mine only has 117,00 miles on it and I just do not think it should have had that problem with such low miles or really it should have never had it. Anyone else? The pieces could have lodged in and made my tire stop, very dangerous, so keep a watch out for it.
From your post typos, it's difficult to tell, but if what you're saying is you had 117,000 (117 thousand) miles, then it is likely not a vehicle design issue. Bearings likely were repacked (or neglected) in one or more front brake jobs (where the brgs should be inspected, lubed, etc)
Most common failure is due to bad seals, which should have been replaced w/ the brake job. Bad seals allow grease out and water and contaminants in.
I'd look into who/when the brake work was done.
I have noticed that if I put the automatic transmission into neutral before I stop at a light, I get no bump. Does that imply it's a transmission problem, or could this axlewrap still be the issue?
Any help is appreciated. Morgan 5
Many new vehicles of many brands do this. My '05 V6 Toyota, and my neighbor's '05 Hemi Ram have similar startup behavior. The Ram sounds like an F16 when he starts it.
It's something to do with emissions. AFAIK, The goal is to warm up the engine faster.
The delay between shifts is a little strange. I'd give it a few miles into break-in and see if it self corrects.
B
And the funniest part? I was at the starting line of a 10K race on a Saturday morning in August and the truck--parked 100 feet from the starting line--went off! The announcer who was trying to announce the race on the PA stated that someone's truck was "whining for daddy." I didn't move. I had a race to run and I wasn't about to tend to this problem then. The REAL kicker is that the salesman who sold me the truck was in that race too. Everyone saw my TACO with lights flashing and horn blaring. He commented to a friend of mine: "We are going to have to fix that damned thing!"
So now I had a witness. Anyway, this is December and Toyota has finally decided to cut the mustard and install a whole new alarm system and totally disable the one in there now. I should have that work done this week. The service manager has been in a full-court press on Toyota for 6 months as they kept ignoring him by telling him that they have never had this problem before. He persisted by telling them that they weren't helping him any by their inaction and cheap comments. I have to say that I am quite happy with my dealer as they have struggled with the company to do something about this.
B
My 2002 Tacoma PreRunner D Cab 69950 (yes) Miles has started acting bad. The check engine light is on (though sometimes only flashing) and the truck sounds like it wants to explode at 50mph (coughing and poor handling, shaking). My suspicion is Fuel Pump, but I'm no genius, so I'm seeking any reccomendations that I can relay (in very bad Spanish) to a mechanic here, if anyone can help, Please!!!
It's a 98 tacoma 4x4, 3.4v6, TRD. Brakes have always been a bit week even when I bought it stock 3 years ago, so there has always been a problem, now that I have 35" tires obviously that emphasized the problem.
Rear brakes didn't seem to do anything so tried adjusting proportioning valve armiture. No luck, changed proportioning valve since it look pretty beat up from something. Some difference, not much.
Thought it might be the booster, so had a shop replace that. No change in braking power. Shop said because of my supercharger I had a decrease vacuum. Ok, understandable even though I was still pulling 15 (inches??), so to correct that I installed a vacuum canister. No shortage of vacuum now.
Front rotors were warped, so I installed some slotted/drilled baer rotors and high dollar pads. No difference yet. Just changed the master cylinder, still no difference. What the heck am I missing here!
And for those of you that think it is the larger tires, I disagree. My braking power is so bad that even with stock tires I roll right through stop signs in normal braking.
The calipers look fine, no leakage or rust. Before I waste money to replace them with no difference, I was thinking to go to a Big Brake system, but don't want to spend any more money with out some expert advice. Please HELP! Thanks.
I haven't test drove it yet, but it still doesn't feel like there is enough power to the master cylinder. It only takes a very little pressure to the gas pedal to get the rear tires spinning when the brakes are pressed fully.
I couldn't lock up the front tires at all, and definitely no fluid loss. I'll try doing the remote vacume test after this test drive. Thanks for your advice. If you have any more, I'm all ears.
I'm especially curious about piping damage because of your mention of external physical damage to the proportioning valve.
Good luck
