1994 Isuzu Truck Rodeo (4WD) V6-3165cc 3.2L SOHC (6VD1)
Vehicle Level Technical Service Bulletins Customer Interest Heater Core - Coolant Leakage
BULLETIN NUMBER:
SB00-12-S003
ISSUE DATE:
JUNE 2000
GROUP:
HEATING AND A/C
HEATER CORE AND CASING LEAKAGE
(SUPERSEDES SB00-12-S001)
NOTE : Shaded information reflects changes from previous service bulletin.
AFFECTED VEHICLES
^ 1997 and prior Rodeo (UC) models
^ All 1995 and prior Pickup (TF) - SIA built models
Condition:
Coolant leakage may be present near the heater core area.
Possible Cause:
Aluminum-type core may have eroded resulting in a leak
Correction:
To correct this condition, install revised (copper) heater core and casing to replace the existing (aluminum) heater core and casing.
SERVICE PROCEDURE
Refer to published procedure in the appropriate Workshop Manual.
Do NOT check resistance on the ECM itself, as it is solid state and damage could result. Good luck
I have replaced brake and turn signal bulbs in the back of my Trooper before with no problem ... there are obvious screws that allow the bulb unit (lenses and all) to be pulled away from the vehicle so the bulbs can be unhooked and replaced.
But the turn signal bulbs in the front of the car seem to be a different story. The plastic lens covers have no visible screws, and the bulbs do not seem to be accessible by hand from the back of the unit by just opening the hood and reaching in (like the headlight bulbs are). I noticed one screw under the hood that looks like it loosens the top of the bulb housing unit, but there is obviously more than thing holdng it in there because it still barely moves when that single screw is taken out.
I'm usually pretty good at figuring out where the other bolts are, unless of course it is designed so that you have to take out lots of other things before you can even see them. Before I go overboard disassembling the front of my Trooper, can someone tell me the correct way to change the front turn signal bulbs? I'm assuming I must just be missing something obvious since the rear is so simple.
Thanks in advance -
Joe
Disconnect the battery ground cable.
Remove the screw at the upper portion of the light bracket, and remove the bracket from the fender.
Remove the front combination light (1).
Remove the turn signal light socket (3) by turning it counterclockwise.
Remove the bulb (2) by turning it counterclockwise while pushing it at the same time.
Installation
To install, follow the removal steps in the reverse order.
I apparently had actually started down the correct path, because I had removed the screw on the upper part of the bracket. But the bracket sure seemed to be still in there pretty tight, and I was worried I would crack the plastic if I tried to force it much harder than I already had. Do you know whether there is any trick to popping it out after the screw is removed ... like grabbing onto a certain part or side of the bracket and/or pulling in some specific direction? Like should it be grabbed on the edge in the front of the vehicle and pulled toward the side of the vehicle, or grab the edge on the side of the vehicle and pulled toward the front? Or some other way?
Or, should it actually just pop out by itself easily after removing the screw, in which case mine might just need a little muscle after such a long time having never been removed?
Thanks -
Joe
I was even thinking of trying to thread a thin wire around the back of the lamp assy. and pulling it forward, like a sling. However, there is a decorative rubber molding on the side of the assy. that would have been damaged.
So, I made a "shadetree modification" to the design.
Obviously Isuzu must have split the workload on the original designs of the front bulb brackets and the rear ones between different engineers .
Thanks again to both you and atfdmike for the helpful info.
Joe
BULLETIN NUMBER:
SB96-01-L004
ISSUE DATE:
APRIL 1996
GROUP:
ENGINE
TROOPER (UX) AND RODEO (UC) 6VD1 SOHC
SPARK PLUG TUBE REPLACEMENT
(Supersedes SB96-01-L001, to include sublet allowance information)
APPLICABLE VEHICLES
Trooper (UX) and Rodeo (UC) models equipped with 6VD1 SOHC engine.
Yesterday, I noticed that the engine was cranking a little slowly, as if the battery were going dead. While driving, I noticed that my iPod, which was plugged into the cigarette lighter, didn't appear to be charging although the light on the charger was on. Later in the day, I stopped to get gas and the engine wouldn't start. It sounded like it didn't have enough power to crank the engine. I got a jump start and the engine started fine. I drove to the store to get a new battery but it turned out that my battery was fully charged and in good shape. I tried jumpstarting the engine again, to no avail.
Before I turned off the engine at the battery store, the engine was running fine. I have driven cars when the alternator went out, leading to a drained or dead battery. You had to rev the engine at stop lights to generate enough power to keep it running. That wasn't the case with the Trooper. It seemed to idle and run fine and the voltage meter was showing the normal reading.
When I try starting the engine I can hear a loud clicking, like the solenoid (starter solenoid?) but so far I haven't been able to find the solenoid.
I'm assuming this could be a problem with A) the solenoid; the starter; C) the alternator or D) a loose connection or wiring problem.
Any thoughts or suggestions on where to start?
I don't have a repair manual for this vehicle. I am considering buying one to diagnose and repair this problem. I also ran across an online site/service called AllData offered by AutoZone. It appears to be an online version of the factory-type repair manual used by mechanics. Does anyone have any experience with this service? Am I better off buying the manual or having a year's worth of access to the online manual for about $25?
Any thoughts, ideas or suggestions would be welcome.
The operating condition of charging system is indicated by the charge warning lamp. The warning lamp comes on when the starter switch is turned to "ON" position. The charging system operates normally if the lamp goes OFF when the engine starts.
If the warning lamp shows abnormality or if undercharged or overcharged battery condition is suspected, perform diagnosis by checking the charging system as follows:
Check visually the belt and wiring connector.
With the engine stopped, turn the switch to "ON" position and observe the warning lamp. If lamp does not comes ON : Disconnect wiring connector from generator, and ground the terminal "L" on connector side. If lamp comes ON : Repair or replace the generator.
Be very careful when working under a running vehicle. You should chock the wheels to insure it will not move while underneath it. I hope this helps you.
1999 Isuzu Truck Trooper V6-3.5L
Vehicle Level Maintenance Fluids Fluid - A/T Testing and Inspection
CHECKING TRANSMISSION FLUID LEVEL AND CONDITION
Checking fluid level and condition (color and odor) at regular intervals will provide early diagnosis information about the transmission. This information may be used to correct a condition that, if not detected early, could result in major transmission repairs.
IMPORTANT.- When new, automatic transmission fluid is red in color. As the vehicle is driven, the transmission fluid will begin to look darker in color. The color may eventually appear light brown.
A dark brown color with burnt odor may indicate excessive fluid deterioration and signal a need for fluid change.
FLUID LEVEL
When adding or changing fluid, use only DEXRON (R) -III.
CAUTION: DO NOT OVERFILL. Overfilling will cause foaming, loss of fluid, abnormal shifting and possible damage to the transmission.
Park the vehicle on level ground and apply the parking brake firmly.
Check fluid level with engine running at idle. NOTE: Be sure that transmission fluid temperature is below 30 °C (86 °F).
Move the selector lever through all gear ranges.
Move the selector lever to "Park".
Let engine idle for 3 minutes and open the overfill screw (1).
Add released ( this means proper grade) transmission fluid until it flows out over the overfill screw opening.
Let engine idle until a fluid temperature between 32 °C (90 °F) and 57 °C (135 °F) is reached, then close the overfill screw (1). Torque: 38 Nm (28 ft. lbs.) NOTE: Check transmission fluid temperature with scan tool. Minimum fluid level 57 °C (135 °F) Maximum fluid level 32 °C (90 °F)
CAUTION: Do not open overfill screw with engine stopped.
CAUTION: DO NOT CHECK FLUID LEVEL UNDER THESE CONDITIONS:
Immediately after driving at sustained highway speeds.
In heavy city traffic during hot weather.
If vehicle is towing a trailer.
If the vehicle has been operated under these conditions, shut the engine off and allow the vehicle to "cool" for thirty (30) minutes. After the cool down period, restart the vehicle and continue from step 2 above.
I have a 2002 Axiom with 49,900 miles. Sunday, while driving to work, temp gauge shot up to beyond hot. I immediately pulled over and shut it down. Smoke coming from under hood and coolant level was near empty.
I had the vehicle towed to the dealership where I purchased it and they found a coolant line, which passes under the intake manifold, had ruptured. The line had eroded from the inside out and was full of "gunk" as they called it. They asked if I used the vehicle for towing, which I did not, and then suggested I probably did not follow the required maintenance schedule.
I have all service records which prove I have done the maintenance, but the 3yr/50k warranty had timed out 6 months before. No problem I thought because at their urging I had purchased an extended warranty through CNA, which I was told would cover everything except normal wear and tear items for 10yr/120k. Wrong. They will not cover this coolant line.
Now this is going to cost me almost $500 to make this repair and I don't have any idea if the overheating may have damaged the engine further. It starts up and idles perfectly, but who knows what might have have been stressed during the overheat.
Has anyone ever heard of corrosion forming that severely after only 3.5 years and 49k miles?
Any thoughts would be appreciated.
Anyway, you're out of warranty so the question is really moot I think, unless you can dig up some kind of recall issued on this problem.
If you shut the engine off in time, you should be okay. Your quick reaction might have paid off. Hope so.
2002 Isuzu Truck Axiom 2WD V6-3.5L
Vehicle Level Maintenance Service Intervals Normal Service 30000 MI or 48000 KM
Check
Battery
Check fluid level replenish if needed. Check at mileage interval or every 12 months whichever occurs first.
Brake Fluid
Check at mileage interval or every 12 months whichever occurs first. Replenish fluid if needed.
Brakes and Traction Control
Perform at mileage interval or every 12 months whichever occurs first.
Fluid - A/T
Check automatic transmission for leaks.
Fluids
Check for fluid leaks at mileage interval or every 12 months whichever occurs first.
Parking Brake System
Steering and Suspension
Clean/Repack
Wheel Bearing
Front wheel bearings
Inspect
Brake Hose/Line (S)
Inspect the vehicles brake lines and hoses. Perform at mileage interval or every 12 months whichever occurs first.
Cooling System (S)
Inspect the cooling system, heater hoses, and connections. Check at mileage interval or every 12 months whichever occurs first.
Cruise Control
Inspect the cruise control linkage and hoses. Perform at mileage interval or every 12 months whichever occurs first.
Exhaust System (B)
Neutral Safety Switch
Steering (S)
Check for looseness, leaks, or damage. Check at mileage interval or every 12 months whichever occurs first.
Inspect/Adjust
Brake Pedal Assy
Inspect brake pedal play and adjust if necessary. Perform at mileage interval or every 12 months whichever occurs first.
Drive Belt
Perform at mileage interval or every 24 months whichever occurs first.
Lubricate
Accelerator Pedal
Lubricate accelerator linkage. Perform at mileage interval or every 6 months whichever occurs first.
Body and Frame (S)
Locks
Throttle Cable/Linkage (S)
Replace
Air Filter Element (B)
Coolant (E)
Engine Oil (E)
Change at mileage interval or every 12 months whichever occurs first.
Fluid - Differential (S)
Oil Filter, Engine (S)
Power Steering Fluid (S)
Rotate
Tires (S)
Check tires and wheels too. Check at mileage interval or every 12 months whichever occurs first.
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
I noticed that it only says check in the service procedure for each interval, but it is at this milestone that it first says change coolant to meet emission warranty requirements. Maybe this info will help you as you deal with it.
As far as the ext warranty company, the mech at the dealer said he called them and they denied the claim saying it is not covered.
I am going to pick it up tomorrow and will have a nice little conversation with the sales manager who said all would be covered except wear and tear items.
Wow what a great forum to find..
Hello Group
I am the proud owner of a 1991 Isuzu Trooper (6cyl). Recently I have smelled gas while driving.Sometimes when i stop i also smell it.It seems to be coming from the rear however..no leaks, and not all the time..i replaced the fuel pump 2 years ago..the smell is quite concerning..
any suggestions? someone told me it could be a faulty gas cap..could this be a cause?
he gas smell comes into the cab..also we can smell it near the rear of the truck
EVAPORATIVE EMISSION CONTROL SYSTEM
A closed fuel tank ventilation system is used to prevent evaporative hydrocarbon emissions from escaping the fuel system into the atmosphere. Fuel tank vapors are stored in an activated carbon (charcoal) canister when the vehicle is off and vented to the intake manifold to be consumed when the engine is running.
Here is a link to a diagram to show what the system looks like under the hood and the fuel tank:
http://www.carspace.com/atfdmike/.59a44ffa!v=
http://www.carspace.com/atfdmike/.59a4501d!v=
Check hoses for kinks, cuts, deterioration.
The ECM controlled canister purge vacuum switching valve (VSV) is in the vacuum line to the purge control valve. Normally closed, the VSV opens when energized by the ECM. During idle or cold operation, the VSV is closed (de-energized), preventing canister purging. The ECM energizes the VSV to permit canister purge only under these conditions:
Engine at operating temperature.
Engine must run for a specified length of time.
Vehicle must be operating above a specified road speed.
Throttle must be open more than a specified angle.
1991 Isuzu Truck Trooper II L4-2559cc 2.6L SOHC (4ZE1)
Vehicle Level Powertrain Management Fuel Delivery and Air Induction Fuel Tank Service Precautions
Service Precautions
WARNING: Adhere to the following procedures any time the fuel system is being worked on in order to reduce the risk of fire and personal injury:
Keep a dry chemical (Class fire extinguisher near the work area.
Place a "CAUTION FLAMMABLE" sign in the work area.
Work in a well-ventilated area. Do not smoke, and keep sparks and open flames away.
Wear eye protection.
Use caution when working near the catalytic converter to prevent the possibility of burns or fire. (The temperatures within the converter can exceed 537 degrees C (1000 degrees F).)
Relieve the fuel system pressure prior to disconnecting fuel system components.
Disconnect the negative battery cable except for tests where battery voltage is required.
Use a suitable container to store or catch fuel.
Do not replace fuel pipe with fuel hose.
Plug all disconnected fuel line fittings and hoses.
After making any fuel system repairs ALWAYS inspect for fuel leaks.
Replace all pipes with the same pipe and fittings that were removed. Do not reuse "O" rings. Always replace.
Do not attempt repairs on the fuel system until you have read the instructions and checked the pictures relating to that repair.
Adhere to all Notices and Cautions.
NOTE: If available, use system bleed valve (schrader) to relieve pressure.
NYLON FUEL PIPE CAUTIONS: In order to reduce the risk of fire and personal injury observe the following items:
Replace all nylon fuel pipes that are nicked, scratched or damaged during installation, do not attempt to repair the sections of the nylon fuel pipes
Do not hammer directly on the fuel harness body clips when installing new fuel pipes. Damage to the nylon pipes may result in a fuel leak.
Always cover nylon vapor pipes with a wet towel before using a torch near them. Also, never expose the vehicle to temperatures higher than 115°C (239°F) for more than one hour, or more than 90°C (194°F) for any extended period.
Apply a few drops of clean engine oil to the male pipe ends before connecting fuel pipe fittings. This will ensure proper reconnection and prevent a possible fuel leak. (During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.)
The carb is not leaking and the smell is mainly around the rear of the vehicle
Thanks for the info..i will check out the lines,canister,tank etc
Thanks again
Your model Rodeo does have a fuel tank shield, so a tank leak might now show right away on the ground. Good luck.
1992 Isuzu Truck Rodeo (2WD) L4-2559cc 2.6L SOHC (4ZE1)
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Electrical - Inspect Connectors for Various Malfunctions
Information IB05-04-S005
Inspection Of All Related Wiring Harness Connections
When Diagnosing Miscellaneous DTC's, Intermittent
Driveability Concerns, Hard Start, No Start, Incorrect
Gauges, Inoperative Air Conditioning Systems, Service
Engine Soon Lamps Illuminated, 4WD Lamp Illuminated,
Instrument Panel Gauges Inoperative, Cruise Inoperative
ISSUE DATE: SEPTEMBER 22, 2005
Affected Vehicles
All Isuzu Vehicles
Service Information
When servicing a vehicle for any type of customer concern, the following steps are imperative. Inspect and ensure the integrity of all related wiring harness connectors. If the wiring harness connectors are not properly put together or engaged before they are locked together, numerous types of intermittent conditions may occur, which may include any of the symptoms listed above and possibly others.
The first step in any type of electrical diagnosis is a visual and physical inspection of the wiring harness connectors for integrity. Many times, the vehicle may be repaired just by disconnecting and reconnecting the connectors. As with all repairs to wiring harness connectors and terminals, a pull test of the terminals within the connector should be performed. A pull test is performed by inserting the proper size terminal test tool (not a paper clip) into the terminal to determine whether or not the terminal is making good contact, or whether the terminal has been damaged from the prior improper connection or lack of connection.
NOTE : Most terminals used in current module connectors (ECM, BCM, and the like) are small O~64 mm sq terminals and can be damaged by probing with the wrong tool
For example, if the Connector C2 of the engine wiring harness to the Powertrain Control Module (PCM) is not properly seated into the PCM:
^ The cam lock lever may close improperly.
^ The cam lock lever may even snap out of position.
^ The vehicle may have an intermittent condition with any one of the components which are controlled or monitored by the PCM.
THE CAM LOCK LEVER IS DESIGNED TO PULL (OR ASSIST) THE CONNECTOR INTO ITS FINAL POSITION ONCE IT HAS BEEN PRESSED STRAIGHT INTO THE PCM HEADER PAST THE INITIAL DETENT, ALLOWING THE LEVER TO BE MOVED INTO THE LOCKED POSITION. It is not only a retainer but an assist during the connection process. When the wiring harness connector is properly connected to the PCM, a snap will be heard when the connector is in position to be fully seated. The cam lock lever may then be closed. The cam lock lever will then do its designated job as both an assist and ensuring the connector does not come apart due to vibration or other types of conditions found in vehicles as they travel down the highway.
Remember, if a terminal (metal) or the connector (plastic) is damaged, they should be replaced. DO NOT replace the complete wfring harness assembly. Some harnesses are now on order restriction since most harness damage can be repaired.
Even though this is generic for all Isuzu, Hope this helps.
What are the down sides to this and is it safe?
Question 2....
Also today He took the pozzie rear end out of a trooper pup and just put it in his trooper. His drive line is about 1 inch short (drives now but rattles a bit) he says its safe to cut the drive-line and put a pipe in it to extend it to give him one more inch. To me this sounds like an accident waiting to happen, he is 17 and the shop teacher has no clue I don't think what he is working on in class, I will call the teacher tomorrow however id like to get your idea here in OT first so I have some questions to ask...
he also after this has a loose rattle in the front a noise like I had when I had my 69 Chevy when 2 springs broke and they were dinging around in the break well, his trooper does not have this but sounds bad, I don't even want him to drive it right now...
Thanks for the help in advance, when it comes to Car mechanics I have not a clue, changing filters or Oil is about my limit....
Fuel Control Heated Oxygen Sensors
The fuel control heated oxygen sensors (Bank 1 HO2S 1 and Bank 2 HO2S 1) are mounted in the exhaust stream where they can monitor the oxygen content of the exhaust gas. The oxygen present in the exhaust gas reacts with the sensor to produce a voltage output. This voltage should constantly fluctuate from approximately 100 mV to 900 mV . The heated oxygen sensor voltage can be monitored with a Tech 2. By monitoring the voltage output of the oxygen sensor, the PCM calculates the pulse width command for the injectors to produce the proper combustion chamber mixture.
Low HO2S voltage is a lean mixture which will result in a rich command to compensate.
High HO2S voltage is a rich mixture which will result in a lean command to compensate.
An open Bank 1 HO2S 1 signal circuit will set a DTC P0134 and the Tech 2 will display a constant voltage between 400 - 500 mV . A constant voltage below 300 mV in the sensor circuit (circuit grounded) will set DTC P0131. A constant voltage above 800 mV in the circuit will set DTC P0132. Faults in the Bank 2 HO2S 1 signal circuit will cause DTC P0154 (open circuit), DTC P0151 (grounded circuit), or DTC P0152 (signal voltage high) to set. A fault in the Bank 1 HO2S 1 heater circuit will cause DTC P0135 to set. A fault in the Bank 2 HO2S 1 heater circuit will cause DTC P0155 to set. The PCM can also detect HO2S response problems. If the response time of an HO2S is determined to be too slow, the PCM will store a DTC that indicates degraded HO2S performance.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL "OFF" on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present.
A history DTC P0141 will clear after 40 consecutive warm-up cycles have occurred without a fault.
DTC P0141 can be cleared by using the Tech 2 "Clear Info" function or by disconnecting the PCM battery feed
Finally, I hope this helps. There are more technical checks that can be performed. If you would like to read them, post again and I will try to supply them. They virtually require you to monitor voltages and probe connectors, which can be a tricky business, and something you may not wish to get in to unless replacing the sensor does not work.
Best of luck!
Modifying the driveshaft is not too bad for length, but it must be re-balanced due to the added weight and the alignment checked as well. When the suspension is "exercised" in the real world, the spline could be separated from the spindle of the shaft...dangerous and not a good thing to have happen at speed.
Obviously, rattles are annoying, and commonly, loose shocks, bad control arm bushings and sway bushings are the leading culprits. Again, any suspension item can significantly affect the driveability of the vehicle. Taken all together, I would personally be leery of driving it until a certified mechanic had looked it over. Again, my opinion only.
If it were my kid, I'd suggest going with proper suspension upgrade parts and no body lift (no spacers between body and frame). The OME stuff is quite good and while being as off road ready as any suspension can be, the OME also provides a civilized ride on road with better then stock handling. I have added the OME shocks and matched coil springs to two Troopers 95 & 01, and I have been delighted with both.
http://www.arbusa.com/leaf_springs.htm
http://www.arbusa.com/torsion_bars.htm
http://www.arbusa.com/Nitrocharger.htm
The cost of these parts(~$60 each per wheel)can be low compared to the peace of mind you get(no worry about danger from faulty or inadaquate parts)and the nice ride and handling. The 1984 Trooper will ride better than new and perform off road better than new.
The 1.9L engine and 4 speed manual transmission (the transmission shifted better than any manual I have ever driven) are a great combination. I put over 200K trouble free miles on my 1984 Trooper. The engine can be rebuilt easily if needed and as long as the body is in good shape this Trooper will be ready for another 200K miles.
Downside is no airbags in this old Trooper.
Upside is durability, light weight and huge interior make this a great off road choice.
2001 Isuzu Truck Trooper LTD 4WD V6-3.5L
Vehicle Level Brakes and Traction Control Antilock Brakes / Traction Control Systems Testing and Inspection Torque On Demand (TOD) System Description of On-Board Diagnostics Precautions on Fault Diagnosis
Replacement of Control Unit
The control unit itself rarely fails. In most cases, the harnesses have failed (e.q. short-circuit) to cause secondary troubles. Other cases include that the cause has been unknown due to intermittent occurrence of troubles and the troubles are removed accidentally along with replacement of control unit, resulting in misjudgment of cause. Therefore, before replacing the control unit, check the connector joints and whether the unspecified current flows in the control unit due to short-circuit between harnesses.
Trouble Intermittently Observed
Troubles intermittently observed are mostly attributable to temporary imperfect connection of harnesses and connectors.
When such troubles are found, check the associated circuit according to the following procedure.
Check whether improper connectors are plugged in or connector terminals are completely engaged.
Check whether the terminals are deformed or damaged. If yes, remove the deformation or damage and connect the terminals securely.
It is likely that wires in the harness are falsely broken. Therefore, in examination of failed harness circuit, shake the harness for check to such extent that the harness will not be damaged.
Test Run of Filed TOD Vehicle
If the TOD indicator lamps experienced faulty operation even once in the past, the failed portion can be identified by use of the procedure "Fault Diagnosis from Trouble Codes" or "Fault Diagnosis from Lighting Status of TOD Indicator Lamps". If the troubles that are only recognized as abnormal phenomena of the vehicle by the driver are observed, conduct the test run in the following procedure to reproduce the faulty phenomena and diagnose the fault for each phenomenon.
Start the engine, and check that the TOD indicator lamps are turned on for about two seconds for initial check; the CHECK lamp goes off; and the TOD indicator lamps display the specified drive mode. (If the CHECK lamp starts blinking, read the trouble codes and identify the failed portion. )
While keeping the vehicle standstill, operate the 4WD switch and shift the transfer lever to change the modes: 2H mode; TOD mode; 4L mode; TOD mode; 2H mode. Check that the TOD indicator lamps correctly display the status whenever the mode is changed. If the transition status is displayed during the shift operation, run the vehicle a little to complete shifting.
Slowly start the vehicle in the TOD mode, and add the power to accelerate to at least 40 km/h (25 mph) and maintain the speed for about two minutes. Apply the brake to completely stop the vehicle. Repeat this test pattern at least three times.
Turn the steering to the right end (or left end) in the TOD mode, and slowly start the vehicle and make a circle five times. Next, conduct the same test in the 2H mode.
Slowly start the vehicle in the TOD mode, and accelerate to at least 40 km/h (25 mph) . Keep the established speed, carefully change the mode in the sequence "TOD mode; 2H mode; TOD mode" while checking that the shift is complete in each mode change. After the test, apply the brake to completely stop the vehicle.
Slowly start the vehicle in the TOD mode, and accelerate to at least 40 km/h (25 mph) . Apply the brake strongly so that the ABS works, and completely stop the vehicle.
Slowly start the vehicle in the 4L mode, and accelerate to at least 20 km/h (12 mph) . Apply the brake to completely stop the vehicle. If the CHECK lamp starts blinking during the test run, read the trouble codes and give appropriate maintenance according to the fault diagnostic procedure. If the TOD indicator lamps are lit abnormally during the run, check the lighting condition and give appropriate maintenance according to the fault diagnostic procedure. Even if the phenomena are not observed, try to reproduce the abnormal state reported by the customer to the possible extent.
Post-Repair Check
As long as the starter is not turned off, the TOD indicator lamps continue blinking even after the failed control unit is repaired. Therefore, upon completion of repair, be sure to turn off the starter switch once and then turn on it to conduct the test run sequence specified in steps 1 through 6 above and check that the TOD indicator lamps no longer show any faulty status.
TOD Indicator Control
The TOD indicator on the instrument panel informs the driver of the current working status of the transfer unit. The information consists of two items: the drive mode (2H, TOD, 4L, transition) and the torque split status of the TOD (torque distribution level). The indicator can display occasional errors and corresponding error codes.
To check for codes stored:
The control unit has a function of self-diagnosis. If a trouble occurs in the course of system start-up, the control unit blinks the CHECK lamp and saves the trouble code.
Note: If an intermittent fault occurs, the control unit stops blinking upon removal of the fault. The trouble code is saved to the control unit.
Indication Method of Trouble Code
Short-circuit terminal 8 of the self-diagnostic connector to GND to display the trouble code on the CHECK lamp.
If no trouble codes exist, code "12" is displayed continuously.
If trouble codes exist, code "12" is displayed three times, and the trouble codes, starting from the smaller code number, are displayed three times respectively.
Here is a link to the aldl connector pin locations.
http://www.carspace.com/atfdmike/.59a64997!v=
MrShiftright
Thanks for the help!
Vehicle Level Brakes and Traction Control Antilock Brakes / Traction Control Systems Testing and Inspection Antilock Brake System Trouble Code Diagnostic Procedures By Diagnostic Trouble Code (DTC) Number DTC 14 - B-2 EHCU Abnormality
http://www.carspace.com/atfdmike/.59a65b3a!v=
Vehicle Level Brakes and Traction Control Antilock Brakes / Traction Control Systems Testing and Inspection Antilock Brake System Trouble Code Diagnostic Procedures By Diagnostic Trouble Code (DTC) Number DTC 24 - B7 Transfer Monitor
http://www.carspace.com/atfdmike/.59a65b3b!v=
http://www.carspace.com/atfdmike/.59a65b71!v=
Okay, I found these, hope they help. also, just from experience, I know that your brake light switch is an integral part of the system and is monitored by the powertrain control module. You might check to see if it is adjusted correctly, if it is telling the tod module the brakes are on, it will effect the engagement speeds of the tod significantly. Just a tip that will at least eliminate one possible source of problems, particularly if it is intermittent.The TOD unit is under the passenger seat, might want to check the connector on that. Also, it monitors a speed sensor for the front driveshaft and another on the rear. Those connectors are on the transfer case near the the respective output shaft to the propeller shafts.
To me, it seems as though your TOD ECU is seeing some differences in speed from the front to rear, and applying torque to balance. If you want info on the speed sensors, Post again and I will dig deeper.
Remember to disconnect the battery cable if you are going to disconnect and reconnect any connectors. I think these are pretty easy things to check and then go from there. Good luck.
I'm sure one of the owners will be able to tell you what it does and where to find it.
Electronic Hydraulic Control Unit (EHCU)
The EHCU consists of ABS control circuits, fault detector, and a fail-safe. It drives the hydraulic unit according to the signal from each sensor, canceling ABS to return to normal braking when a malfunction has occurred in the ABS.
The EHCU has a self-diagnosing function which can indicate faulty circuits during diagnosis.
The EHCU is mounted on the engine compartment front right side. It consists of a Motor, Plunger Pump, Solenoid Valves and Check Valve.
On the outside, the relay box containing a motor relay and a valve relay is installed.
Solenoid Valves: Reduces or holds the caliper fluid pressure for each front disc brake or both rear disc brakes according to the signal sent from the EHCU.
Reservoir: Temporarily holds the brake fluid that returns from the front and rear disc brake caliper so that pressure of front disc brake caliper can be reduced smoothly.
Plunger Pump: Feeds the brake fluid held in the reservoir to the master cylinder.
Motor: Drives the pump according to the signal from EHCU.
Check Valve: Controls the brake fluid flow.
Hope this helps.
