The engine makes a put put noise and struggles past 25 MPH. :sick:
Trouble codes only tell you which systems or components are in distress--they could be disturbed by an entirely different problem than the component itself.
Jeannine Fallon
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
don't sell if you like your car, i like mine.
:confuse:
Hope you can help.
It says:
Bulb Replacement
HEADLAMP
Disconnect negative battery cable.
Turn the plastic cap counterclockwise to unlock it from the combination lamp.
Turn the bulb socket counterclockwise to unlock it.
Unlock the retaining spring and remove the bulb from the combination lamp.
Installation is in the reverse order of removal.
CAUTION: After installing the bulb, be sure to install the plastic cap securely to ensure watertightness.
Good news was that it was covered (just barely) by 60k powertrain warranty. Bad news was that they had to order the part, and when it arrived it was cracked and I had to take it back a second time. But the dealer was otherwise great and gave me no issues about fixing it.
http://www.courtesyparts.com/31935-sensor-assy-revolution-maxima-a33b-2000-2003-- p-49916.html
I would never buy another one...ever!
Also, it's worth pointing out that the Maxima now uses an entirely different transmission.
Finally, I had the same problem with my 2006, and it ended up being the tranny fluid pump, not the tranny itself. Perhaps the repair didn't address the real problem.
I'm currently looking to replace the 3 motor mounts that have broken on my Nissan Maxima 2000 automatic, including the lower cradle mount (in between the right and left mount), the right passenger side mount, and the left radiator side mount. The older this car gets, the more expensive it's becoming to get it fixed. Rather than take it to a dealership, I would like to buy these parts inexpensively somewhere, and then take it to a repair shop for the labor of installing them. While I've discovered an inexpensive wholesaler to purchase the mounts from, I have yet to locate a reliable and inexpensive place to get the installation done. Would any Nissan Maxima 2000 experts here please give me an idea of how much I should expect to pay on the lower and upper ends to do the installation? I've heard that some places are likely to charge a single price for installing all 3 motor mounts. Help with this will go a long way for me and my pocketbook.
Thank you in advance.
I'm not so sure I agree with the way you are planning to do this, however. Most shops don't take all that kindly to having parts brought in from outside, and even if they are amenable to that, they will not warranty the labor should the part fail---so in other words, if you buy the part from them, and it fails, they replace it for free. If you bring them a part from who knows where, and it fails, YOU pay for the labor again, not them.
So your plan has some risks and although the mounts are somewhat expensive, they aren't *that* expensive. I don't think your $100 or so savings is worth this risk...in my opinion.
What you (or someone) can do would be to locate the ignition switch wire that attaches to the starter solenoid (on the starter). In other words, when you turn the key to start, a signal is sent along that wire to the starter solenoid. So you should be able to read that signal with a simple test light at the starter motor solenoid "tab" (usually a pull-off connector). The test light should come one and off as you turn the key to start, and then release it.
If there IS a signal, then the starter solenoid or starter motor must be at fault. If there is no signal, then the ignition switch, or the wiring or connectors attached to it, must be at fault.
Another idea from left field is something flakey in your anti-theft system.
I have recently replaced a bad battery (it had a small crack in it around the negative terminal). My car sometimes starts automatically and other times takes several cranks to start. The engine has roughly 139000 miles on it. I had the starter tested at the parts store and it passed. I then took a reading when it started it had 12v at the starter and when it didn't it had only 7volts. Any suggestions on what to try next? Thank you!
it was oxygen sensors and Pre Cat ~$1500.00
I have an 1997 Nissan Maxima with 248000 miles on it that has just started having problems starting after the car has reached opp temp. If you shut the car off and restart after a few mins its just fine. If you leave it set over 45min to an hour it will not restart till the car has cooled all the way off.
I just replaced plugs, map sensor, knock sensor and fuel filter. there are no check engine codes at the moment. i have no idea of what could be wrong now. any one have any idea or has had simm. problems
thanks andrew
:sick:
I have a 02' Maxima with AT with a hot engine restart problem. Did your issue ever got resolve? I'm very interested with the fix.
:confuse:
