I wonder if anyone else had their airshocks go on them or could it be a malfunction of air compressor.
Will phone the dealer tomorrow and see if I can drive it in. Let them have a look at it.
I had a 1972 El Camino, which had airshocks. They were a pain, replaced them three times. Guess they could not stand the cold. Replaced them with ordinary shocks., end of problem.
This is my first posting.
Been reading this site for over a year now, got alot of good info from all of the members.
I have been overly satisfied with our Envoy, wife would kill me if I traded it in. )))
Chris
Chris
Also, I don't think the tongue weight will be heavy enough to need a weight distributing hitch.
I've owned two travel trailers over the years, one at 26' and the other at 36'. I did use sway control and weight distribution on them, but not with either boat. My first boat was 18' runabout, and the one I tow now is a 21' low profile skier.
Also, I too believe your overestimating the combined boat/trailer weight.
You will not be getting a New unit.You will be getting a Remanufactured unit from an Authorized Delco Repair Center thats why they need the part number off your unit. Remember to take all your Cd's out before you drop off the truck.
I also have the 6 Cd Bose. When playing CDs I have the EQ set to 3(spacious) it always returns to this setting when going from radio to CD. However when I set the radio to EQ 3 and go from radio to CD back to radio the EQ changes back to EQ 2 it doesn't hold EQ 3. I haven't read the manual yet to see if ths is normal operation but honestly it doesn't really bother me and I would rather keep my head unit rather than get a remaned.
I bought and installed a Putco Punch Grill (Denali look). You can put it on without taking the original off but I had to figure out how as the instructions aren't great. It only took me about 15 minutes or so and looks pretty good for the price. There are 4 allen wrench screws that go through the grill and attach to flanges that wrap behind the original grill. I used a screw driver to hold the flanges tight while I screwed in the allen screws to the flange.
Thanks for the Putco Grille advice. Did you install the Putco grille with the cut-out for the GMC logo? Just curious.
Chris
A couple of things that I have noticed: 1. There is no door ajar warning light on the dash. (One door was half-ajar for a day before I noticed it). 2. the 2nd row floor mats do not have the coverage and they are moving around too. Can anyone recommend a better floor mats? 3. reclining 2nd row seat please! 4. the vibration on the gas pedal: I can feel it when going up a small hill on the hiway and trying to maintain the speed. The engine seems to be laboring and the exhaust not venting very well. The speed would still come down as the engine rev come down as I push the gas pedal at little bit. All this is under 2hi. No obvious vibrations at normal cruising on flat road.
For people still sitting on the fence and with reliability concerns: I was in the same situation for a long time and the 3000 rebates and my GM card extra incentive finally got me in. Bought extended warranty and hope for the best. One thing I can say is that wife and son love the smooth ride! (test drove a Tahoe and that 2nd row is a back breaker to me).
BTW, thanks to monstersinc, ndmike88 and others for information on bug-deflectors, mud flaps.
Well - my 2003 Envoy is in the shop today to get its springs replaced due to the vibration and noise at highway speeds. We'll see if it fixes the problem, I'll keep everyone posted. I asked my service advisor a couple of questions about what the fix really is, he went off and asked someone and came back and told me that it is a newly-designed spring that is "springier" than the old one. He said this one is not as stiff but that I should not be able to tell any difference in the ride. He said that GM has found that the engine vibrates and that vibration comes down the drive shaft and goes to the rear springs which is where we feel it. Don't know if I truly believe that but I am hoping for the best!
Those of you that have had the rear springs replaced, have you noticed a difference in the ride after getting the new springs? I am worried because I really love the way it rides and I don't want that to change!
Thanks - Hillary
Hey, report back and let us know your impressions after the springs are replaced.
Michael
Yes, I bought the grill with the cut-out. Without the cut-out, the install would be much more complicated as there did not seem to be an easy way to get the logo off of the original grill without taking the whole grill off. I wanted a quick hassle free add-on so I opted for the grill with the cut-out.
Since the first time I started our '03 Bravada at the dealership, the air suspension "buzzes" (I wouldn't call it a hiss") immediately after startup and again as I back out of the garage (sharp drop-off angle for driveway versus garage floor. Stopping on inclines also kicks in the compressor buzz. If this is the noise being discussed, it is normal. Says so in the manual. If it is something else, you probably have a problem.
Also, had the driver & passenger side doors re-aligned which helped reduce the excessive wind noise I had been experiencing from the top corner of the doors.
A full size van sounds a bit big, but I'll double check. Chevy/GMC has a AWD model this year that has the driver side door like the little vans
The other concern is the turning radius on a van and EXT start to get pretty big.
Maybe a Tahoe or Yukon?
--jay
Help!
A fiend of mine has a durango and got a gift of a "dog matt" that wraps up the sides. That might work but I can't find anyone that sells. them.
I'm looking for something to cover my third row too. I have been trying to call GM parts today to find out if the vinyl liner (part# 12498158) will cover the third row. I have not been able to get through yet. There is also a cargo tray (part# 12498139), but I have a feeling it will only fit behind the third row.
customerservice@gmpartsdirect.com
Also, regardless of the posts here, you also have to realize that large percentage of triplet owners do not come to Edmunds. On the other hand, at every one of my 30+ dealer visits while I had my Bravada, there were other Bravadas and Envoys in for similar problems.
Given your issues with your late Bravada and the fact that you apparently provided input on the Bravada to the CR survey two times, is it any wonder that CR's predicted reliability for the 2002 Bravada is about as bad as it can get. Without knowing CR's sample size, I could assume that it may have been comprised of only your two inputs, which most would agree is not necessarily representative of the thousands of other '02 Bravada owners. In summary, I think you have demonstrated my issue with the CR auto reliability data quite well, thank you.
Here, you lose me. In Canada, they all come with locking differential, which as far as I understand, give torque to both rear wheel when one starts slipping. What is "limited slip differential"? The one I ordered is also with Auto 4WD.
P.S.
We plan to winter in Victoria when I retire. Its our favorite city. What a jewel. I will however have to keep my guns at home when I do
Good thing Consumers Report didn't use my Bravada in their survey. It would have made things worse.
My '03 Envoy is better in most regards, but has more wind noise than any vehicle I have owned. Maybe I will also have to get the doors realigned. There is an obvious gap between the door and the seal. On the other hand, the transmission is MUCH better than the Bravada's.
GAM
You can let them put it in, or you can put it in yourself--I did it myself for a friend a long while back. It's just a piece of foam encased in a soft rubber cylinder, and it's cost should be negligible. Like I said, I changed one over a year ago (and I'm no "under-the-hood" guy), and it was simple. Unfortunately, about all I can remember about it is that the line is located behind the right side panel in the rear compartment behind the nozzle.
Of course, you may just decide to live with it. The buzz and hiss are normal.
I also had them lubricate the steering column because it squeaks whenever its turned while its cold outside. That fix did not take either. So I'll have to call them and see what else they may be able to do for that. Someone a while back posted that they had to get their entire steering column replaced but that it did fix the problem.
I am now beginning to notice something else that is bothering me - the wind noise. A couple of folks have posted that they had their doors realigned and that helped. Is that something covered under warranty - and did it help a lot? I seem to hear it the most right around the drivers door pillar.
That was me. They replaced the steering shaft from under the hood and that fixed it. It is a known problem that is addressed by TSB #02-02-35-006. They say to lubricate which you have had done. Now call the dealer like I did and demand that "parts be ordered". The best part is this repair is done from under the hood so they wont get grease all over your interior.
My dealer is going to put a probe in my Envoy to measure the frequency of the vibration. This way they might be able to tell where the source is. I would also make this suggestion, have your dealer call GMC for possible solutions. This is what they are suppose to do and will force them to address this problem. The more they hear about it, the better odds we may have at getting to the bottom of this. GMC will also give them permission to search and destroy the problem. This is the procedure the dealer needs to do instead of telling you to just "live with it". Dealers are lazy and need to have their feet held to the fire. Some are better than others. Then finally we can get a TSB to address this issue.
Of course door alignment is covered under warranty. This is a fit and finish issue and should be dealt with a.s.a.p. The Envoy rides like a dream and is whisper quiet when everything is to spec. Go back and demand that it be made right. Fit and finish has come a long way with GM, but they are still years behind the Japanese.
and gmpartsdirect has it for $83 plus shipping
does it actually do any good keeping the rear window and overall rear hatch area clean.
I had a factory rear deflector on my 91 s-10 blazer and it never got dirty. I also took my cross-bars off for the winter.
tim
HILLFA: The door allignment was covered under warranty. The wind noise was occuring on the driver side up near the pillar just like you described. The allignment did the trick!
Thanks to all of you for your posts on what to do next about getting my problems fixed. I just made an appt with the dealer for tomorrow to have them take a look at the vibration again, the steering wheel squeak, and the wind noise. This time they said they would take a drive with me - we had not done that before. So we shall see what they come up with next!
Do folks think it is good enough just to tell them there is wind noise and where it is located or should I specifically ask for the doors to be aligned?
I believe just complaining about the wind noise alone or asking for the doors to be aligned because of wind noise will possibly result in the overly duplicated "cannot duplicate" dealer phrase. To be fair, the dealers can't get reimbursed from GM unless they can duplicate the problem, but I also believe they use this as a crutch when they want to be lazy.
When you talk to the service writer I would complain about the doors alignment, citing uneven resistance when being closed and opened. Then add there's evidence of this misalignment via excessive wind noise at freeway speeds emanating from various points where the doors make contact with the door seals. I could be wrong about this but I believe you would have a better shot at getting the doors realigned this way.
Group members please feel free to add your two cents to this conundrum since I don't want to go spouting off bad advice inadvertently.
Has anyone here had there truck replaced under the lemon law? Is it a long process? I will give them one more attempt at solving it before I do anthing. Thanks!
I also have a squeek eminating from the bottom of the air filter box after the vehicle warms up. I thought it was the dash or glove box. Talk about strange!
GAM
I tend to be guilt of trying to find every mality others claim to experience. So far I can only claim the locking passanger seat belt and wandering mirror.
For those surfing to find those who complain, do not count me in that group. I am please with this product and would buy it again
If you do get an attorney (recommended so you don't get jerked around), get one that won't charge you. The attorney fees should be paid by the manufacturer, if you win. A good attorney will evaluate your case, and decide if he should invest the time if there is a good chance of winning. If you don't win, the attorney should eat the costs. The only thing you should be liable for is the court filing fee and paying for an inspection.
Not bashing the triplets here. I was very happy with the truck the first year. Great power, ride, and comfort. It's still all that, when it doesn't die on me however. Seems like the '03s have fewer bugs. I *might* consider a trade for an '03 if they offered it.
