The covers do exist, mine has all of them.
Thanks for the suggestion, I'll check this fix this weekend.
Just curious...
She was very nice and polite on the phone but useless...she took my name and said she would open a file about the problem. I have already told the dealer I will buy from about the problem and I also went to an Olds dealer and pointed out the problem to the sales guy. Both said they are going to bring this up to their reps...maybe something will eventually get done. For now, I will probably buy the vehicle with the knowledge that I am going to have to create my own fix (probably make a gasket to fit and then fix the chips).
Anyway, sorry to take up so much time, but I will make sure to let you know how things work out for me.
Carl
My Malibu was aful at the beginning, after 3000 miles I was getting 30MPG highway, hoping the TB can stretch to at least 24MPG highway. Is tha not realistic?
I have been able to average 22.5 MPG over a 200 mile trip. That was driving at an average speed of 53 MPH with 2700 miles on the odometer.
That was an extremely rare case for me. I currently average about 15.5 MPG with 4600 miles on the odometer. I believe my low average is because I take many short trips at an average speed of 25 MPH (stop and go traffic 2 miles to work and back everyday).
I NEVER rely on the average MPH in the DIC, though I get my average speed by taking the difference in odometer readings between each fill-up and dividing it by the DIC timer reading which I reset and restart each fill-up.
I have over 4500 miles now and have not noticed an increase in acceleration. I now use 89 octane to reduce pinging.
Thanks for all the info guys. I am really enjoying my Summit White Trailblazer, it just takes getting used to a different fuel economy than my sedan, but I wouldn't trade this TB for the world!
but that is normal if you live in a place that gets cold. That oxygenated fuel they
use in the winter has less energy than normal gas, hence poorer gas mileage.
Since then, I've been in mid 18 range. I commute 32 miles, each way, through Atlanta traffic. I also drive many miles through the midtown areas of Atlanta so I don't think it's doing that bad "around town".
Since I've had the Bravada (May '01) I've never had it on the highway for more than 20 miles or so. I can't wait till I do so I can see what she gets then.
It should be pretty basic that a car that stays in low gear for to long a time is going to get poor gas mileage.
I do not buy the theory that because it is a truck it will shift high, I have a Toyota pickup and a 3/4 ton Suburban that shifts so smooth you are not aware that they have shifted.
Carl
Everything is programmed into the PCM (powertrain control module) including injector duration (how much fuel) spark advance, shift points wheel diameter and so on.
There may be a device where the consumer can modify these settings, but I don't think it's available yet for the triplets.
Shift points are also temperature related, make sure all your evaluations are on a fully warmed up system.
If your dealer cannot reprogram the transmission, tell him you have concerns about the transmission shift points and see if he can reprogram the pcm (not the transmission) or try a different dealer.
My 02 Bravada runs like a top. Dealer fixed misaligned front bumper cover, droopy headliner, and some other fit and finish issues in his excellent body shop.
My car had a problem with the radiator fan comming on even when cold, and he said there was a bulletin on that and reprogrammed the pcm.
If one dealer does not meet your needs, try another. I've found that being rude and gruff to the service writer gets me nowhere, and being polite but firm, and mentioning items I read about on this forum and others does a world of good. A call to the general manager will really wake folks up, but again, be polite, and tell them how much you like their dealership and how you've bought your last five vehicles from them and are expecting a promotion and a raise in a month and will need a new luxo car for the spouse.
My Oldsmobile service writer is Donavon Baker, Davis Moore Oldsmobile, Wichita, KS (316) 618-2092, let it ring, cause he is probably with a customer. He's good.
WichitaGreg
Purchased from Davis/Moore Auto Group, Whicita
I filled at a different station than I usually do and will monitor mileage when getting gas from various stations to see if there is any noticable difference.
Just read the posts about the trannies before heading out, so I watched for them. Mine seem to shift just before 2k, under normal flat conditions. But when going up hill or soemthing, can hit the middle of 2-3 before shifting. As for gas mileage, used about half gallon and only getting 146 miles so far. Will ahve to fill it up and do the math to be sure. Using 87 from mobil right now. What are others using, or suggesting?
I normally don't worry about mileage too much. I have over 5000 miles on my TB. It was only since I filled at a different brand station that I noticed what appeared to be a major drop in my gas guage based on the driving I was doing. I reset the DIC and began watching. It seems that the mileage reduction may be related to the brand rather than any of the other factors.
By posting these things, we can help each otehr out. Some people on this board may decide to try to switch brands and see if it makes a difference in mileage. If it helps, great!
My expectation was to get 15-17 MPG around town. I am disappointed.
I agree...I don't know why someone would waste their time reading this board if they just want to drive and crank up the stereo.
General Motors’ 2002 midsize sport/utility vehicles, hit with an early recall to fix a defective front-suspension lower control arm, are now being recalled to fix a 4wd transfer case control module problem.
About 78,000 Chevrolet TrailBlazers (named North American Truck of the Year) and GMC Envoys are affected by the problem, which can result in the vehicle rolling while in park.
In an unrelated powertrain problem affecting an unspecified number of the same vehicles, GM says a torque converter control module that regulates all-wheel-drive and four-wheel-drive functions is on a national backorder. Once the module fails, the vehicle operates in rear-wheel drive only.
I have been reading these posts since the beginning. They are very informative to read it helped in my decision to purchase last October 2001. However, I have a very noticable scratch on the rear driver side fender/wheel flare.
Does anyone know the "part number" for the metallic pewter paint ? I really want to take care of this soon. your help will be greatly appreciated.
http://media.gm.com/division/powertrain/index.html
1) Front control arm
2) transfer case
3) Some other one ( can't remember_ related th the programming of gears
Those were mostly early production models. no recalls since so if you are considering the Trailblazer it is safe to do so. Mine was built in October 2001 so it's up to date. :-)
Not sure who got that ball rolling on the GM side, but I hope it's an indication that they are fessing up to this problem.
Some of the concerns I had prior to my purchase were
1. which gear ratio to get?
2. Is the load level(air spring) suspension worth it?
3. What the heck are "rain sense" wipers?
4. what king of MPG's to expect.
Well with everyone's help here, I got a pretty good understanding of them all. Thanks and I will keep you posted on my own experiences.
So far, the Envoy is GREAT !! Picked it up last night in the fog and rain. Only drove 50 miles, but what a nice ride.
I got the Pewter w/ dark interior, SLT with professional towing option. Has the running boards and moon roof to boot. The Envoy was built in Dec , 01. Looks like everything but the DVD player. (no kids, so not much use for that.) I got the 4:10 rear axle and the motor runs about 2300 rpms @ 70 mph. A nice smooth ride.
I Will let you know more as "The Odometer Turns"
Personally, I decided to shy away from the rain-sense wipers and the air suspension because I figure that these automatic features will be failure prone if I decide to keep my car longer than five years.
I would also suggest that you get the manual HVAC if that is an option. I find that the automatic HVAC is very irritating.
Things that I really would suggest that you get:
1. Auto-dim mirrors (I don't know if there are packages where you DON'T get them, but they are fabulous)
2. Heated seats. Really, really nice during the winter.
Bear in mind, though, I would much rather drive a manual transmission, and would prefer everything in my car to be of the utmost simplicity so that it is not failure-prone and easy to fix, so this is my bias. I spent the extra money on the extra package becuase I wanted to do something very different from my clunker that I used to own... and now I'm very concerned after having to get everything 'reprogrammed' several times. It scares me to think how much this might cost after the warranty period has passed.
Jeff
Normally I see a rectangular or circular-shaped tube running the length of a car/truck but never before in that odd configuration.
