As Vinnie Barbarino used to say, "I'm so confused!"
Steve
I have two questions
1. Should I drive the truck to the dealer or should it be towed?
2. What is most likely at fault and what is the fix?
I'm sure they can figure out what the problem, but just in case I thought I'd ask the list. I want to be certain they get it right. Gee whiz - I wonder if this qualifies for a loaner or will they try to send me home in it until Monday!
Thanks in advance for the help.
Bob
I also asked about the 45-55mph vibration and unfortunately I was unable to go on the drive with the Tech, so he was not able to reproduce. I did talk to the Tech for a while and his specialty is transmissions, he said the Torque converter stall related vibration could explain what I've noticed but that it is typical of this type of transmission as opposed to Cadillacs that have a viscous coupling system which allows some slippage and thus no vibration.
I was actually at my dealer for an oil leak that turned out to be a Power Steering Fluid leak. Unfortunately, the schematics were not available so they had to take my rack apart to get the p/n. They kept my TB LTZ overnight and gave me a TB LS to drive for the day. I have to admit that the difference between my LTZ and an LS is amazing (ride, Bose, 3.73 vs 3.42). I also have to admit that I drove this LS, HARD!!! and I'm amazed at what the TB can do with the L6. Really made me happy for choosing an LTZ.
Tim
TB LTZ
You should turn the key to the on position without starting the vehicle. The voltmeter should say 12. If it's below that, the battery isn't fully charged.
On a less important note, I don't understand that last part of your message about the ride being diffent in a LTZ as opposed to an LS. Also, I believe you can get pretty close to everything an LTZ has in an LS.
I had a similar problem with the rear end of my Envoy being very low at the end of December. When I drove it into the dealer, they immediately knew what the problem was because they had had 3 others with the same problem within the week.
To fix the problem, the air compressor was replaced. At the time, the replacement air compressor was on National Back Order so it took a few days to get the part in. Hopefully, they have one in stock for you. There was no question about me getting a loaner, they immediately offered one.
I was able to drive the Envoy to the dealer (although it was a bit bumpy), but I noticed when driving the Envoy at that angle, the headlights were blinding everyone I passed by.
Hope this helps.
Vic
It is hard to believe that anyone could install these bars wrong. Each bar is plainly marked in three different places with arrows and the word "forward" pointing in the right direction .
I am not sure, but I think the wind noise is a little less now. I have the front bar back over the little rear door window.
Carl
Steve
As far as the LS that I drove, I wasn't clear enough. The LS I drove was a stripped down bare bones TB w/ the 16" wheels as opposed to the 17" on LTZ. Maybe its just me but I drove the same road I've driven a 1000 times and there was a noticeable difference. Don't take me wrong I'm not knocking the LS but I was not expecting there to be a noticeable difference in ride, then again since it was a rental maybe someone else did something to it.
Tim
TB LTZ
Thanks for the feedback
Our Triplets have a unique feature that will lower the headrests automatically when the seat is folded. Then when you place it back in normal position you can leave the headrests down. This is the way that I usually keep them since it is rare for me to carry passengers (great visibility).
If I am going to carry passengers, I simply fold them up and they lock in place.
Oh and I solved the problem with the roof rack seal flapping. There are plastic covers on the front of the rack rails. Take off the cover (flat-head screwdriver over the inner notch), torque the nut down a little more, and lok-tite it down. I just think it worked loose, since they didn't use the lok-tite. Either way, no more flapping!
2002 Bravada with 6500 miles. Getting 15-17mpg on combined city highway commute of 28 miles each way. Get 16-19mpg on the few all highway trips depending on wind. Usually travelling 75mph.
Mice. I haven't looked again at the Envoy or Trailblazer to see if they may be susceptible to this problem that I've just invested almost $400 on. I have now had mice crawl into my HVAC fan twice!! The first time they left a bunch of junk in the fan (shaped like a mouse running wheel) and threw it out of balance causing the whole dash to vibrate at high fan speeds. The second time they chewed through the electrical wires inside the fan motor. $125 for an HVAC fan (fyi). The local dealer tried to jimmy some screen in front of the fan to prevent this but not enough room to make it work. Our best guess is that they are coming in at the ends of the wiper area plastic cover (plastic between the hood and the windshield). At the ends are preformed rubber shields to prevent water entering but there is still plenty of gap for a enterprising mouse. I planning to insert some galvanized screen material and possibly seal around it with some epoxy.
I thought I should let the rest of you know in case you park where mice may be nearby. I am also open to other creative suggestions for preventing these unwanted guests in my Bravada.
Otherwise no other problems have arisen with this particular triplet SUV.
Tom
I bought the stainless Manik stepbars at autostyles.com (http://www.autostyles.com/mangmc.htm) and paid just under $400 for them (now they're $400 even).
It took a while for Manik to get the order right (Autostyles did their part just fine), but I ordered them as soon as they were released.
Rick
http://www.zainobros.com
As for washing and drying, 100% Made in USA cotton towels are the best thing to use.
Contact your dealer - a fix may be available.
In addition, all five new TBs on his lot had all seat bracket covers on them.
Just shows what American car makers can do. Only improved engine mounts to reduce vibration and gas mileage complaints to address and GM may actually have a winner.
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=1807507349
2. I read on this forum somewhere that I should try to purchase an Envoy built AFTER WHICH DATE? I thought I'd remembered Oct. 01...but I'm not sure. What was the reason again that I need to check into the date it was built?
3. Is the upgraded Bose system worth the $...or do you think the standard stereo is fine? We are for sure getting the 6 CD changer. For the same $ for the Bose, can I get a higher quality speaker system installed somewhere else?
4. I live in Milwaukee, Wisconsin. Which options would be best for me? I don't plan to off-road. ECS? Locking Differential? I'm not a "car person" so don't understand these too much.
5. Thinking about the Monterey Marroon Metalic color...haven't seen one in person but it looks cool. Hope to see one tomorrow. How would that color hold up in this climate (salt, snow, etc...)?
Think that's about it for now. Many thanks in advance for the help.
Kristin
I've had this happen twice since I've had my bravada.
The fan will come on and sound really really loud untill the car warms up and acceleration, for lack of a better word, sucks. The second time it happend was tonight before I went to dinner. I hadn't used the bravada all day.
2. My Envoy was built 01/02 (label located on the driver's door edge). Knock on wood, but I have not had problems. Personally I would make sure I bought a vehicle built in 2002.
3. I like the Bose system, and others on this forum like the system -- I would venture to say it is worth the money and saves the headaches and expense of adding an after market setup.
4. Get an Envoy with the SH pkg., you get locking differential, Bose, upgrade wheels, HEATED SEATS (a must have in cold climates), air suspension (great over frost heaves), etc. Whether you need it or not, who can say, but it is fun to have!
5. Color is a personal choice, but I think red/black show dirt/salt more than lighter colors -- but get what you like.
Good Luck.
I like the 1 sh package also. The ECS suspension helps give a smooth ride. Everyone agrees the BOSE is worth it. Might be hard to get upgrade later since the OnStar is tied into radio/speakers. The 6 cd changer saves you having to store CD some place else in vehicle.
The "locking diff" will help when you travel through that Wisconsin snow. Keeps both rear wheels turning if one slips.
The heated seats are a must for cold climates and leather. I have used that more than I thought I would. Of course it's been winter the whole time I've had it. The low setting and Back Only sure is comforting even after the car warms up.
You don't hear too much about Rain sense wipers. But I have come to like that feature also. The wipers will automatically adjust speed depending how wet the windshield is. Works great when someone passes you and sprays your windshield, the wipers seem to kick right in.
Be sure to check your roof rack cross bars. There is an arrow on the top of each one that points to "forward". Just checked mine and they are on backwards. Heard others had the same thing. Might just as well have dealer make it right before you take delivery.
The color is your choice. You can't go wrong here. Just pick one you like. All Envoys look good no matter the color....of course Pewter is just a touch better .
Haven't heard about rebates after 2-28-02. Just have to take a chance, but I can't imagine them getting much better.
Good luck,
--Mike
If anyone else has heard of this issue, please post your findings.
Hope this helps everyone. Mine were backward at first, but is very easy to change. Just pop cover off front of each rail and then slide the rack off. Just be sure to put back on the correct way.
--Mike
I think it's been posted here before.
I'd like to have this info before I go in to the dealer. I mentioned the fan issue to them when I had the transmission recall done and they blew me off.
The noisy fan doesn't bother me too much when I first start the truck, as it goes away quikly. However, it sometimes comes on when I'm up in the mountains on the highway. It sounds like a jet engine at 3000 RPM's and it sucks away power which is not what you want at 11000 ft.
Mine buzzes occassionally, and I am wondering if that indicates that something is wrong.
getting the wind (whistling) noise. It is more aerodynamic to have the arrows pointing backwards.
I changed mine and eliminated the wind noise.
I haven't been too concerned with it, because it only happens from a cold start after hours of downtime, and it's happened less than 10 times in total in the nearly a year that I've owned the car. One of these days I may look further into it, but it's not readily reproducible.
