Does anyone know what oil replaces this and what the fill quantity is? The amount is not in the shop manual and RedLine hasn't responded as to the oil cross over.
If this has been addressed before, I apologize. Man, I wish the forum would get a decent search engine.
Paul P
Here's a link.
Steve
Daytrip -- do you have the TSB #???
But I was in the dealer ship later trying to upgrade the factory system to the Bose system and was told it was not possible to do even on an after market purchase." You should have purchase the LT model" is what I was told. I was shock they were being so blunt. It almost like they force a customer to spend more on a vechiles then you want, to get one or two of the more appealing extra. So you purchase thing on a car that are really just waste money to me but pure profit to them.
the prep before a delivery is going to very, but most will wash, clean inside and what not. this is typically done while you're inside signing the papers.
the half A@# wash you got....well, not acceptable in my eyes, but if you drove it home and took delivery, too late. won't hurt to complain, but they may not do much. approach it as if they just didn't have time, go ask when they are going to clean and prep it to your standards. play it cool and dumb.
tim
The 3 day thing is typically a non-issue even when state laws do allow for it as the buyers are usually approved and financed by the banks or leasing companies within a day or so. Once the financing is done, you own the vehicle and the dealer is out of the picture.
tim
Just curious if anyone knows what the deal is...
-Jason
-mike
However - he had no idea what I was talking about when I asked for the license plate gasket. I had to point one out on the lot. This despite the fact that the part was supposedly ordered for me along with the mirror actuators and I got a post card saying everything was in.
Oh well - looks like another visit to the service department this week.
-Jason
If you go to Crutchfield.com, you can find out exactly what fits and if you buy from them, they send you complete instructions for your car-they tell exactly how to take door panels off, and same for dash panels. They also include wiring harnesses that will plug into your facroy harness. You end up using the factory speaker wires, etc.
I would recommend as mentioned above-for the same money, aftermarket will provide much better performance than unpgrading to the Bose.
The only drawback of installing aftermarket head unit is that you loose door chimes, low gas chime and Onstar audio. Of course, I was one of those saps that wanted a sunroof so bad that I was forced into Onstar. I will not pay to keep onstar active. The aftermarket installer said they could install a different amp and speaker for the onstar so it would still work.
I do think it is total bull that they make you get Onstar just to get the sunroof. I argued for two hours about that. The dealer was recommending an aftermarket sunroof, but the price of aftermarket that was electric, etc, was similar to the cost of factory with Onstar. Of course I did get that fancy mirror that tells me what temperature it is in some other part of the world-it is never correct for where I am!
Did you notice this when the suspension was activated? I have my Envoy in today for an oil change and various other things, one of them being that it feels as if there is 'play' or a clunk in the steering when going over bumps, especially with the steering wheel turned. Does this sound similar to your problem?
If so, did you adjust the stablizer links, or the dealership?
JAW
What was the model number of the Piaa fog lights that you installed in your TB LS? If you could do it again, would there be another brand or model that fits inside further?
Thanks in advance.
#02-08-49-004
Instrument Panel Cluster (IPC) Gauges Read Zero at Times, Gauges Inoperative at Times (Exchange IPC)
2002 Chevrolet TrailBlazer, TrailBlazer EXT
2002 GMC Envoy, Envoy XL
2002 Oldsmobile Bravada
Condition
Some customers may comment that at times all the IPC gauges are inoperative or read zero at times.
Cause
The IPC cluster module receives information to position the gauges when the key is turned from OFF to ON/START. Random electrical interference with this data information on the serial data line may interrupt the receipt of the information by the IPC. When the IPC data information signal is compromised, the IPC will set the gauges to zero for that complete ignition cycle. The gauges may work properly on the next ignition cycle, if the ignition was off for approximately five minutes prior to the next ignition cycle.
AAARRRGGGHHHHH
Patience - they are working on it!
tidester
SUVs; Aftermarket & Accessories
Steve
I sent an email today to get a feel for what they believe the lead time is on Jet Upgrades. I still don't think they will ship until late Aug, but we'll see.
Also note that some of the links/pics for the brush and grill bars are not accurate. If anyone finds a standard Bull Bar for the trailblazer let me know please!!!
not sure if yours is painted or what not. haven't seen it up close to see what the deal is.
tim
Walter
-mike
It explains how they work and why they can create excessive noise.
Open this link:
http://service.gm.com/techlink/html_en/pdf/200207-en.pdf#dst01
-mike
Steve
I was talking about the PIAA replacement headlightbulbs @ $70 Cheesy blue I think was the color.
The XTs and XT Pros are ok, alot of the subie guys buy em to replace their stock fog lights on WRXs and 25RSs. I prefer the Hella 500/550s
-mike
