Initially - they thought it was the O2 sensor. The MPV has two ... one before the catalytic converter - and one after it. Combined, they cost about <$200.00.
However, further testing and pleading from me showed something else instead.
The MAF - mass air flow sensor was dirty. We thought it needed replacement - which was not too expensive. The tech guy simply cleaned it and the error codes never came back.
About 15-20K miles later, slightly same error codes came back ---
1. The EGR - hose / valve (made of rubber or PVC) was in need of replacement (again). It was initially replaced at 35K due to a recall. It was again worn out - the part was about <$70 but the labor was relatively high.Check the Mazda MPV recall history on this one. I am might be wrong about the exact name.
2. The MAF needed replacement. I cleaned it on more than one occasion but at 120K mileage - I think it was beyond its useful life - so I replaced it.
The problem has not come back since - am now at 132K.
I did notice that all these problems crop up during the cold winter months ...
-Brian
The MAF is just downstream of the air filter. It can get lint and so forth from a new air cleaner.
But, your rough idle could also be due to the PVC hose collapsing and cracking (which creates a vacuum leak, and a lean condition). That hose can be about a $100 item...I've had to do mine twice in 88k miles, once as a dealer recall, once on my own wallet.
John
What plugs are you using? Rock Auto shows a bunch of options, looks like Bosch has an expensive Iridium replacement, super long life, etc...
John
Also might be rain related, it misfired and flashed the code last week during a big rain storm. As I learned, apparently the back coil packs can get wet. It's running fine again now that it has dried out.
John
I made a mistake about 5 years ago, hosed all the dust out of the engine compartment, and lost a coil in the back. That clean engine cost me about $400 I believe. Yikes. It's generally a bad design, I read that the OEM coils have a snorkel out the top for sucking in water...
John
problem . ;/anyone ;have any ideas?
Thanx Butchsan
-Brian
Did anybody experience something like this?
As a matter of fact, I'm currently experiencing the same thing on my 2004. Sounds like the sway bar links. Should be noticeable when turning while going over bumps, or just going over speed bumps etc, sometimes felt thru the steering wheel. There are 2 sway bar links, each attached to a front end tire. They are about $40-$50 a piece. My Mazda dealership quoted me a price of $276 just last week. It is not dangerous to drive on it I am told.
Online Repair Manuals
I have the best luck with the online repair manual through my public library.
Steve, visiting host
Yes - I do have a clicking noise too ... over humps and certain road conditions.
Otherwise, there is no serious driving concerns.
I tried going under - and everything seems fine.
No issues on braking nor turning.
2.5L Engine
Install or connect the following:
Alternator. Tighten the bolts to 29–41 ft. lbs. (40–50 Nm).
Center shaft support bracket. Tighten the bolts to 32–45 ft. lbs. (43–61 Nm).
Alternator harness connectors. Tighten the battery terminal nut to 87–130 inch lbs. (10–15 Nm).
Right axle halfshaft and center shaft assembly
Exhaust front pipe
Subframe transverse section. Tighten the bolts to 69–96 ft. lbs. (94–131 Nm).
Accessory drive belt
Negative battery cable
3.0L Engine
Alternator
Alternator harness connectors. Tighten the battery terminal nut to 44–60 inch lbs. (5–7 Nm).
Power steering pulley. Tighten the nut to 29–43 ft. lbs. (40–58 Nm).
Accessory drive belts. Tighten the alternator lockbolt to 14–18 ft. lbs. (19–25 Nm) and the pivot bolt to 28–38 ft. lbs. (38–51 Nm).
I don't see a pic for the 2.5. Try this for the 3.0 V-belt routing:
Mazda MPV V-belt
Hello Everyone;
This is a great forum and I have been able to get very valuable tips on our Mazda 2003 MPV in the past. Now we have a weird problem:
Whenever the parking break is engaged, the "parking break" sign lights up on the dashboard. In addition, the "door open" sign also lights up on the dashboard and all the interior lights are on (even with all the doors closed!!). When the parking break is disengaged, the "parking break" and the "door open" signs go off in the dashboard and the interior light turn off as well.
Looks like there is a short somewhere in the system. Can someone please help me about the possible causes?
Sri.
Cheers, BK
The front end also was replaced under extended warranty around 95K miles. It was a worn tie rod issue. Yes, you do hold your breath with these things! I also would like to hang onto mine two more years. We'll see.
I removed the MAFS and sprayed it with electronic contact cleaner, but that did not resolve it.
The CE light sometimes turns off by itself, and it is more likely to come back on when the weather is wet. That leads me to think there may be a bad contact somewhere, but if its not the MAFS, what can it be?
The engine runs fine; idling, cold-start, acceleration, etc are fine.
I'm looking for suggestions on what can be causing the codes before I go to the dealer. Thanks!
CE light in wet weather usually means ignition coils. But, you say van runs fine. :confuse:
