I experienced similar low RPM non-response with a
California emissions LS-V6 5M. Below 3000 rpm,
punch it and... nothing. Odd part is it doesn't
stall as if too much air or sputter with too much
fuel. It responds as if the throttle body is
electronic and just plain isn't opening. It looks
to be a purely mechanical throttle body to me but
hard to believe given lack of response.
A California emission feature?
Never did find out what the issue is. I'm interested
in hearing what you find out.
Enjoy.
#3203 (low rpm grunt) -- I've written much more than I'm sure anyone wanted to read on this subject. The manual is a dog at low rpm's, especially when it's new. My theory is that the "all-world low emissions" goal for this car severely limited two things. One is low rpm performance for the manual and the other is gas mileage. . .for everyone, I might add. I'm still stunned by the relatively much better gas mileage my Eagle Vision (don't get me started on how bad the car was otherwise) got, both around town (2 mpg better) and on high-speed vacation runs through Nevada (up to 4 mpg better). Hang in there, though. The manual's performance gets much better after everything is run in -- second gear will eventually really make you smile. The gas mileage, however, will still suck.
#3204 (azlels) -- BLESS YOU! You're the only other person on the board that I recall who has pointed out that the turn signal feels like it's off a Yugo (you were somewhat more kind). Since I live in Arizona, I realize that only 3% of the people actually use the turn signal, but those who do must notice that the thing doesn't have the solid feel one would like for a $30 - 40K car. I use mine hundreds of times a day, and every time, I regret not buying a car built by people who paid attention to such details.
For those new to this board, I'm one of the malcontents, and overall still love the LS. Just give it a bettter chip and a solid turn signal stalk. If the turn signal felt half as nice as the steering wheel controls, all would be well. I rent lots of semi-luxury cars for work, and once in a while end up with a Cadillac or equivalent. The LS's steering wheel controls (both radio & cruise) are really fine.
Steve
Tires-
- Firestone Firehawk LH P205/50R17/95V, shot at 35K.
- Guy at Firestone shop said tht this was good mileage for a performance tire ( probably due to lots of hiway miles).
- My set was hurtin' from underinfaltion, and starting to chunk . This made the last 5k noisy and annoying. Firestone guy said conscientious rotation would have helped.
- Firestone Firehawk is currently the only replacement available ($150 each). In the future, if demand for this specific size increases more alternatives may appear.
- My plan is to watch pressures more closely and rotate at every oil change (5k miles)
Talked to LM dealer service dept- they suggested that a wheel sensor could have been affected during tire change.
Firestone said bring it back in in the AM.
Like many of you, I've had the mysterios beeps,and the "change oil soon" message that takes 3-10 tries to reset.
Sure enough. in the AM the lights are off. A test on a gravel road shows that the ABS and Traction contrl are both working.
This car is either not smart enough to know if something is wrong or smart enough to fix itself.
ratio. I hope that when my lease is up in 7/03, LM will get serious with the rear ratio, 6 speed and LSD or I'll look hard at the 5 series or the IS300 six-speed. Six-speed Getrags are going in more models all the time and the LS needs to join the club. Chant VVT, LSD, and Getrag Six-speed. Then the rear ratio will take care of itself. So will the non-competitive 0-60 times which will look even worse in two years. But for now, I will just enjoy my Manual and not plan any major mods that will be worth nothing if I turn the car in. The ball is in LM's court. I'm not saying anything they don't know in the Manual/V-6 Engineering Group. A few little changes with existing hardware....
Besides, I have no life except Real Estate and driving the LS. These 85 hour weeks without a day off. Will the economy end this?..maybe I need a break!
I have over 34,000 miles on mine, and they all appear to still have good tread left, and Im sure I can at least make 40,000 to maybe 45,000 miles on them before hitting the wear bars. I do quite a bit of city driving, and some of its pretty aggressive cornering at times. No jackrabbit starts, but some dicy lane changing when the traffic permits, usually Sunday evenings around these parts. Tires are still quiet, and good traction.
I've never had any trouble resetting the "change oil soon"' light nor do I remember anyone else having problems. Maybe you're not doing it right.
Pat
Sedans and Women's Auto Center Message Boards
My '01 V8 Sport has 10,600 miles. I got my 10000 mile checkup yesterday at Liberty LM in Clifton, NJ. No problems at all. All service done on time and correctly...reset the oil life monitor, rotated tires, and didn't try to charge me for it.
My overall fuel mileage (city/hwy) is at 17.90 mpg as calculated from the pump. The car is reporting an average of 18.0 from the display (I reset at each fillup). Pretty close. The average continues to slowly increase from the day I bought it. No problems to report with the car.
Love this car.
Joe
Steve
Any engineering perspectives on Macpherson struts vs. double wishbones?
My problem was a bad connection between a cable and a connector for the Passive Anti-Theft System (PATS). The connector is under the escutcheon plate around the ignition key, attached to a 4-conductor cable. The connector has a green part on it. The problem was a bad contact between the "crimp-on" connector and the cable. A few hefty tugs on the cable with a pair of needle nose pliers and some contact cleaner spray to boot and the car cranked and started flawlessly. The problem has never recurred.
I've done it several times, on three boards, & found the same thing.
Realizing the Q is much pricier, does fuel efficiency cost that much to produce? Lincoln cant do better MPG wise, especially compared to the weight/power of the Q?
There are a couple of ways to see if you are still subscribed to something or not - either look at your "Preferences" (follow the link that appears to the right of your personalized "Welcome" message at the top of the page), or check the middle button above the post box in a discussion. If it says "Subscribe" you are not currently subscribed, or if it says "Change Subscripts", you are.
I'll report this to those that be to see if something can be fixed.
Pat
They did have LS's at each of the Hertz locations I went too, but the company won't pay for those. In Vancouver, I saw five LS's in the span of one hour, including the one at Hertz. Had me missing mine even more.
For the person who was asking about cleaning the black trim below the doors and bumpers. I've been using Blue Coral Leather & Vinyl cleaner. It works real well. I just hope the person who has the auto detailing business doesn't burst my bubble and tell me that it contains silicon.
So, it sounds like you got a good deal @ 30% off on the cabin filter.
slunar: How did you get the discount?
Check out this one from ebay. I can't believe they actually make something like this. What's worse it there are people that are buying this.
Brian
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=592658994&r=0&t=0
Isn't the study of genetics fascinating?
Artie
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=592698358
Brian
If you even get the chance, bring your LS6M and LS8 Sports up to the Adirondacks. God's country and some really, really fun roads to drive on. Even the two-lane county roads are a blast. Maybe more so as most are not very heavily used.
When I logged on today I found only the Lincoln LS site had somehow unsubscribed. All my other subscriptions were OK.
If FWD is so much cheaper, where are all the FWD pickup trucks? Full-size pickups & SUVs are considered the cash cows of the auto industry. Now that Toyota is stealing sales from Detroit on full-size pickups & SUVs, Detroit is really, really nervous. Noticed someone mentioned IRS being part of reason for costliness of RWD. Ever notice how almost all those RWD sedans (Crown Vic, Grand Marquis, former Caprice/Roadmaster, etc.) were or still are non-IRS? Not to mention all those 2WD F-150s, Dodge Rams, Blackwoods, etc. Or most 4WD pickups and SUVs? Guess that is why Ford and Merc making such a big deal about '02 IRS in Exploder (oops Explorer) and Mountaineer?
One big down side to having the SS's huge trunk is that my wife is buying too much. When we went to Old Forge and Lake Placid she knew the car would be able to bring back all the crap she had to have!!!
Gotta get back to some more bass and trout fishin'. I'll have another Genny Cream Ale, smoke a fine cigar, and enjoy looking at my SS. Though, in all honesty, I really can't wait to get home and take the LS8 for a serious twisty spin!!!
I understand comparisons between the two may seem ridiculous. However, I want to express some opinions strictly from the "luxury car" point of view - an area in which the TC should more than hold its own.
Seats: The LS seats are soooooo much better. Why shouldn't a luxury car have good lateral support in the seats? I suppose if you are 6' 6" and weigh 250 or more, the TC might be better. For me, the TC requires a firm grip on the wheel because the seats sure don't hold you in place.
Performance: The 4.6 two-valve engine in the TC has good low RPM grunt. However, in the 50 - 80 MPH passing situation, the LS would suck its windshield out. Isn't good passing ability a desirable trait in a luxury car?
Interior: IMHO, the LS interior is every bit as luxurious as the TC. The TC looks just like a Ford Crown Vic - not bad but certainly no better than an LS. I had no idea how much we would miss the telescoping wheel and individual driver/passenger temperature controls, either. Luxuries found on the LS but not the TC.
Driving: (I won't even mention "handling") What is luxurious of having to continually make steering corrections when trying to go straight? The LS tracks better and is so much more communicative and responsive.
Ride: TCs aren't as floaty as they used to be, thank goodness. However, over really bad roads, there are more steering wheel jitters and dash jiggles than the LS ever thought of having!
It is not my intent to condemn TCs or insult their owners. However, unless the huge trunk is needed, I think the LS is a far better luxury car. In my market, TCs go for around $30k and LS V8s around 35. That difference is easy to justify.
By the way, Alaska is awesome - I highly recommend a visit!
Bruce
And one last thing, when heading to the Adirondacks leave the LS home and rent a Town Car because you will need a trunk big enough to hold a dozen cases of Deep Woods Off.
I've had a TC as a loaner before and agree totally with your assesment. I have short arms and couldn't reach the radio from a comfortable driving position without leaning forward away from the seatback. Why is the radio 5 feet from the drivers seat? On a recent trip to Lake Arrowhead in my loaner I30 I really missed the seat bolsters. I was constantly having to right myself in the seat.
I miss my LS. Hopefully today!
Mike-as far as reaching the radio controls, I guess necessity really is the mother of invention-voila!-redundant steering wheel controls.
This discussion has served a real twofold purpose:
-We appreciate our LS's all the more;
-We now know why people (including ourselves) are astounded that the LS was produced by the same division that gave us the TC. We can even further appreciate what a bold step the LS was for Lincoln.
Now for that old oxymoron: a car this size is a TOWN car. How does this differ from a city car- like the ones I saw in Italy that are 2.5 meters long?
Brian
