and I do think you do a great job... otherwise I wouldn't have become a charter member of your website..
Kevin
I can understand your frustration. Trust me I'm as pessimistic about my windows as any of you are. I figure they'll fail at some point like everyone elses. The only downside of mine failing is that I'm out of warranty already so if they do fail I'm out the cash.
sniemietz: I'm not sure that your window problem is being caused by the window regulator. I agree with stanny1 that something else may be causing it to bind up, which would cause undue stress on the regulator. Maybe you have a bent track. Has the dealer checked that out?
lolaj42: Thanks!
Brian (who is now blushing....)
While reading magazines in Public Library ran across 9/3/01 issue of Fortune. Has a lengthy profile on Gerry McGovern, Irishman who is Lincoln's chief designer. You might find it interesting. I paid attention for hints on Lincoln's future products. He looks like aging bass player from big hair metal band of 1980s. Mentions Ford not liking his Mark IX show car. His first design into production won't be till 2004. Before that Lincoln will introduce a luxury SUV for about $45,000 based on Explorer chassis. No mention of LS or short DEW platfrom. Average age of Town Car buyer is now 71. Estimate Lincoln generated about $7.5 billion in gross revenue last year with an 8.5 percent operating margin; margin is twice Ford's/Mercury's. Lincoln sales slid 14 percent so far this year even with 0.0 percent interest offer. BMW and Lexus sales up 21 and 17 percent respectively this year.
Thursday:
5:00pm-10:00pm Event check-in and Happy hour mixer at the Dearborn Inn Golden Eagle Lounge.
Friday:
7:30am-10:30am Wixom Assembly plant tour
10:30am-11:30am Discussion with plant managers
11:30am-1:00pm Lunch at Henry Ford Museum Pool House with Lincoln folks
1:00pm-4:00pm Engineering facilities tour along with a couple of surprises planned for you!
5:00pm-7:00pm Happy hour mixer at Dearborn Inn
7:00pm-?? Possible dinner with some of the engineers at a local eatery.
Saturday and Sunday
Open timing: Ford Centennial Racing Event at Greenfield Village (about 1/4 mile from the Dearborn Inn)
This will be a very full day for all of us. Pay extra attention on the Wixom plant tour since there will be a contest at lunch for a very special prize
The Lincoln folks are as excited as we are to have us and are very much looking forward to meeting all of us. This promises to be a very memorable event based on what we have discussed.
There is still plenty of room available for people interested in the event, but you must be a member of LLSOC to be able to attend the event. For more details go to the club site at www.llsoc.com
Brian
http://www.fortune.com/indexw.jhtml? channel=artcol.jhtml&doc_id=203722&_DARGS=%2Feditorial%2Fcurrent_issue.html.30_A&_DAV=Home
Brian
"The LSE package includes a new fascia with round fog lamps, a low profile rear decklid spoiler, modified rear valence, dual exhaust with stainless steel tips, and special 17-inch five-spoke aluminum painted Blade Gray. Chrome 17-inch wheels also are available. The vanes on the LSE's signature Lincoln grille are painted Blade Gray. The rear license plate surround and the new rocker moldings are color-keyed to the body. Floor mats and special badging round out the package."
Has anyone seen any more info on this, specifically photos? Must... see... new... LSE...
Because the water pump is the achilles heal of the air-cooled heat engine, the separation of water pump and fan functions relieves the water pump bearing from weight load and imbalance/harmonic problems which are endemic to conventional fan/pump interfaces. Water pump failures are almost always related to bearing and then seal failures. I think water pump bearing stress is highly under appreciated. True, we have more complexity and the possibility of hose, fluid pump, fluid motor and module failure as Wixom recently experienced. But the fact that the LS can be driven in cooling failure mode and driving over 35 mph should replace fan cooling to a large degree should be significant offsets to hydraulic failure modality.
In addition, although I am not sure this is true on the LS, faster warm-up could be accelerated by
applying reverse hydraulic pressure to the extent of "locking-up" the hydraulic motor and causing the fan blade to "stall" and block air flow.
I think we will all enjoy increased water pump life compared with the conventional fan/pump belt driven system with failure-prone silicon-fluid- filled clutch fans or noisy, usually flow and size-limited electric fans.
I agree with slunar that a variable-speed electric motor would seem to achieve the same operational flexibility as the hydraulic motor, but I don't recall seeing any automobile with a variable speed electric fan motor. I often hear quite a lot of noise from electric fans whirring away under the hood of cars sitting at stop lights or even after being turned off in parking lots.
The Lincoln LS fan is very unobtrusive, and I am almost never aware of noise from it. I can't comment on its complexity, cost, or reliability, except when I worked on jet fighter planes in the navy back in the mid-50's I saw applications of hydraulic motors, and they seemed to be totally reliable.
In my other car (Nissan Altima), you can feel the RPM's drop, as well as see it on the tach, when the fan(s) come on & the alternator has to catch up with the load. It even does this to a lesser extent when you turn on the headlights.
René- I don't know about infinitely variable speed electrical fans per se, but some cars do have 2-speed fans.
Brian, Re project GT. The more I stare at the induction system, The more I see a cowl induction ala NASCAR fitting the bill. If you pulled air in on the passenger side cowl it would be a lot shorter and more direct route to the manifold. The only restriciton I see for trial purposes would be extending the wiring for the MAP sensor. Might even be able to fit a cone filter in the cowl plenum. A dyno might not show optimal figures as the car is stationary. A WOT on a back road would prve it out. Compare max MPH before and after. If you don't feel comfortable at MAX speed, I'll pilot it for you.
As far as load goes, turn on all 4 power windows after they are already against their stops after you idle away in drive after you cold start the car and watch the tachometer. That's a load.
With a 42 volt system, power steering units like Magnesteer (GM) will be commonplace. I've heard the A/C compressor will still have to be engine-driven because of the hp required. Variable speed DC motors are rare. I think they take multiple windings, which is expensive. I think it's easier to convert to AC and change frequency or cycle. I think that's one reason for 42 volt. And since Volts X Amps = Watts, changing to a higher voltage will let the manufacturers change to a smaller guage wire (higher EMF). We saw that in the fifties with the change from six to 12 volts. That's one reason planes have higher voltage systems. Actually, it was a mistake for this country to go to the 120 volt standard. Too late to change now.
Banker friend of mine at church had his beloved '88 Volvo 780 Bertone totalled recently. Replaced it with new S80 T-6 Executive. While looking at it after church today (had to check out the TV/DVD/refrigerator which takes up the middle seat in back) he threw me the keys and told me to take her for a good spin. Glad the good deacon trusts me! After about 30 minutes of spirited driving I was sad to have to return it. She rode and handled quite nicely. But talk about mid-range passing power! Slight turbo lag off line but once you hit about 3,000 RPMs that twin-turbo six will throw you back. Before you know it you're gone from 50 to 100 mph. Quality of interior materials impeccable. Too expensive for me; over $45,000 with most options on it.
teenage kid who loves Cadillacs has a nice link today on the Cadillac CTS board (#1584) that gives July 2000/2001 and YTD 2000/2001 sales figures for 53 luxury cars. LS YTD down from 30,400 last year to 26,000 this year. Some AIC outfit.
I am sure all of here wish you were at LS Mania I in Irvine last January 6th. There was this one hairpin turn at the end of the straightaway (no, guys, not on the gymkhana run) I would love to see a FWD execute. On second thought, don't do the off-ramp at 50 mph. I don't want it on my conscience.
Actually, I thought I was being very gentle and conservative in deference to his wife's somewhat unstable stomach. I explained the posted limits seemed to be established for inferior vehicles like covered wagons and SUVs, and for the LS I was actually driving far below the car's actual limits at a very comfortable rate that was designed to get us to our destination and back home again during the same day. But Toronto doesn't have many (read that 'any') mountain roads, and I suppose they had a slightly different calibration about driving around curves with long dropoffs at the edge.
The LS really is (almost) as much fun in the mountains as my BMW motorcycle. In the rain, it is way MORE fun!
Does anybody have experience with this car in the snow. I live in Western Mass. where snow can really build up in the winter. Are snow tires really helpful on this car?
m.rankell
It has been a great car. My lease expires in the spring and I plan to order a 2003.
I have the standard sound system which was OK. I upgraded the speakers myself and find it as good as most I have heard. I'm not into subwoofer envy so go by what my ears tell me, not what the other guy has lurking under his dash. I'm sure the Alpine option sounds even better.
Why not a Maxima? Front wheel drive - pure and simple. My LS is the first rear wheel drive car I have had in 12 years. I've never had a fwd car handle this well. BMW? The 3 series is way too small. The 5 series is a beautiful car but comes at a real $ premium.
As mentioned, the duratec six takes forever to loosen up. With 17,000 miles on mine, I averaged 25 mph on a recent 2,400 mile trip. I could do better around town if I kept my foot off the accelerator. (Like I said, this car is fun.)
I have had one problem with my LS (fogging headlight) which was replaced immediately. My impression is that the early build quality problems have been addressed. Pick your dealer carefully. That will determine quality of service more than anything.
Good luck! Let us know what you end up buying.
V6 auto is not a screamer but isn't a dog either. V6 manual and V8 auto are quick. Off the line acceleration isn't great but passing power is superb. More power is on the way for 2003 via larger displacment (3.3 and 4.3 - or 4.2) engines.
There were a few problems with the first year models but they were almost all fixed before the 2001 model year. The only problem to be concerned about right now are the rear window regulators that are failing frequently, but it's not clear whether this is a problem on new models or not. It seems to be heat related.
The non-audiophile stereo isn't great but a speaker upgrade seems to help a lot. The true audiophile system with subwoofers is great. This wasn't available on Sport models previously but I think it's back for 2002.
Dealers are hit or miss. Some are good, some are bad. Some offer LS loaners, some don't.
Even with a few problems, most owners here love their LS and would buy another one in a heartbeat. We feel it's the best combination of performance, handling and luxury for the money. Test drive one and you'll see for yourself.
You need to drive it. If you like it, buy it.
Happy tire shopping......
When I got my LS, I sold my 92' Continental myself. I got 50% more than the dealer offered. Even after the ten or so test drives I gave to the prosctive buyers, the extra $2000 +/- was worth every penney.
Now if I could just find a Firestone/Michelin store that would give me credit towards a new set of Michelins......
BTW, your current situation is not harmful to the plastic. Unless you have alot of white showing from excessive wax making the car "unsightly" you may want to leave it alone. Most waxes will evaporate from summertime heat in a couple of weeks anyway. E-mail me if you need more information.
A manufacturer's rep, e.g. a Firestone store, might still be the best place to go for help, but your Lincoln dealer now has responsibility, too, if you have an '01 or '02 LS.
On another topic: Has anyone seen an '02 LS on a dealer's lot yet? I saw a bunch of 2002 Town Cars, Continentals, and Navigators yesterday, but no LSs. Are they keeping them all in Michigan due to the cooling system situation?
I found an ad in the back of Car & Driver for the Langka paint chip repair method. I checked out the website at http://www.langka.com & it seems too good to be true. Have you ever had any experience with this?
Keyrow, please tell me it isn't so.
I must add that I really enjoy the opportunity to take the BMW 5 series crowd to task on every major corner I can...I just smile and wave good-bye as I see them shrink in my rear view mirrors!
In spite of the differing opinions that I read every day, I am convinced that this is one excellent group of individuals...I thank you all for the great entertainment, the news, and all of the tips.
gschwartz - NEVER use dawn or any other dishwashing liquid to wash your car. It will strip the wax. I don't recall seeing that recommended here. I do recall someone that was getting ready to put on wax (may have been Zaino) using it to get the old wax off before putting on the new wax. Maybe you got confused by that post. Get a good quality car wash liquid.
Gschartz: YES, I'm sorry to report that Dawn WILL remove wax, both natural and polymers. Start using a product designated as a Car Wash. These are designed to not harm any type of wax.
Amazing stuff!
Anyway, when comparing costs don't forget to factor in the free maintenance on the LS.
The big difference will be RWD (LS) vs FWD (TL-S). The RWD offers acceleration (weight shift is to not away from driving wheels) and braking advantages (more weight stays on back wheels allowing you use brakes/tires). The RWD will also have cornering advantages due near 50/50 weight distribution, and a lighter quicker steering.
The RWD car will have a tendency to drift at the limits not understeer or plough. You will also be able to put the tail out with the throttle and drift, effectively cornering beyond the traction limits. However, within the limits the TL-S might be just as good, plus understeer is usually considered easier to recover from and more predictable.
You can also use the throttle in FWD to prevent understeer to a certain degree, turn the wheel less, and use power (gently) to pull you through.
I think both the V8 and V6 LS will have more low end torque, useful for acceleration off idle in any gear from any speed to any speed. The TL-S has a smaller displacement engine and uses variable valve timing to preserve torque resulting in more high end horsepower.
Regarding the LSV8 vs LSV6, they are both great cars with great engines. The difference isnt the same as the difference between say the BMW 528i (193hp) and the BMW 540i (280hp), but then again the price gap isnt the same either. WHen comparing prices, note that the V8 LS comes with the convenience package as standard. That lessens the perceived gap in price. If you live out west, lots of open highway stretches, I would personally consider the V8. Other than that, I think the 210hp of the V6 is more than adequate. It is for me. It also depends on what you are coming from. Are you coming from a 6 cylinder or a 4 cylinder? The LSV6 will probably be a stepu up for you. Are youcoming from a car with a powerfuly V8? You may want to stay with an 8. Whatever you do, forumulate your own decision, and not that of any magazine critic. Drive them both yourself, and you tell if there is a MAJOR acceleration/power difference. (oh, youve already done that). :-)
The Acura is still FWD while the LS is RWD and handles better. Hit the brakes hard doing 50 mph (safely of course!) - the Acura should nose dive at least a little while the LS will stay perfectly level. Same for launching hard - the Acura should squat a little in the rear while the LS will not. And the LS has a better weight balance which also helps handling. But if you're not impressed by the V8 performance why are you looking at the Type S version?
Acceleration difference between the auto V6 and V8 LS is very noticeable - maybe you just weren't pushing them hard enough to see the difference. But if you like the V6 then you can save some $$. But you don't get the message center on the V6.
The TL has Xenon headlamps.
The LS offers Advance Trak stability control, 17" wheels w/sport package, automatic windshield wipers and full fold down rear seats and six-disc in-dash cd changer. Plus memory seats and electric tilt/telescoping wheel.
The Acura is a nice car and if I were buying a FWD sports sedan it would probably be the choice. Only thing that bothers me is that from the front you can't tell it apart from an Accord (at least I can't). Only you can decide if the extra features are worth the extra $$. We obviously think it was or we would be on the other owner's forum.
