Visitor Agreement.
http://phases78.homestead.com/300m.html
phases78
Anyway, looks like a good setup for using air from the hood scoop (which really looks cool, BTW). You should probably use the 90 degree nitrile elbow from the Lister setup instead of that over-engineered thing that is attached to the TB (it's a [non-permissible content removed] to get on, though). Are you going to route a 3" tube from your box to the fender hole as well as a tube or whatever to the hood scoop? More air!
www.intenseperformance.com however this is expensive. Since you have taken the facia parts off do you think there is a way to get air right out of the grill ducts? What size airfilter is that in your pictures? I love the part of running part of the cold airconditior pipe inside the airbox. Should really help on hot summerdays.
Looks great.
"Mechanics: Horror Stories." I bet all of you have had at least one bad run in with a dishonest mechanic. Please post your horror story under my new topic. I hope to see this topic in the top ten list with your help to get it going. Here is the link: easyrider300m "Mechanics: Horror Stories" Oct 28, 2001 1:54am ---Ok, Guys--start your postings!
I am using a S&B 7" dual cone (same as an 9" K&N) filter.
I did rework the stock 90 degree bend off the TB to maintain the 3" minimum. Actually it lets more air then the Lister tube.
As for adding the additional pipe back, I am debating it. The new intake offers a minumun of 9 sq inches, plus it is pressurized (with the car moving). I would have to add a valve to prevent the pressurized air going back the orginal stock and out the side fender well. The hood scoop is designed to bleed off any rain water already so unless we get an very heavy snow storm in Phoenix (about the same time hell freezes over) I have nothing to worry about in that department.
"Mechanics: Horror Stories." I bet all of you have had at least one bad run in with a dishonest mechanic. Please post your horror story under my new topic. Here is the link: Easyrider's Mechanics Horror Stories ---Ok, Guys--start your postings!
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55718836&f=0
The stock piece also can be trimmed in the inside to remove further restriction, but that flattened part is gone. Why it is flattened, who knows.
The Lister setup, which is just a 3" 90 degree rubber tube, does not have this restriction. However, stretching the 3" i.d. tube around the 2.75" o.d. TB and its idle intake may result in a shape that affects airflow somewhat, but I doubt that it would affect it more than the chopped off part in the stock piece. The stock piece is much, much easier to attach to the TB, though.
I assume everything that gouged the inside of this ended up passing through my engine. Yikes!:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55718834
I used calipers to check the wall thickness of the stock bend (off the TB) It is surprizing how much you can take off the inner walls, not to mention that huge obstruction at the TB.
More on the flat part later (work).
The wall thickness of the aluminum tubes (http://www.burnsstainless.com/AluminumTube/45o___Straight_Alum/45o___straight_alum.html) is 16 gauge = 0.051" = 1.291mm; 0.102" = 2.582mm total wall thickness is considerably less than 0.250" = 6.350mm. I would have bought a thinner wall tube from a telescopes site, but they had a $75 minimum order.
The box:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55243320&f=0
Final install:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55718914&f=0
Plans:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55785794&f=0
Old v. new:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=54971393&f=0
I have ordered two digital thermometers from JCWhitney so I can compare the temperatures between the inside and the outside of the airbox.
New steering wheel put on (leather 'peeling' problem)
New Body Control module (light show problem)
Driver side seat rail/bracket
So far, no more light show, so far, driver seat no move. Steering wheel?...anyone here get a replacement steering wheel put on? The 'texture/finish' of the new wheel os much smoother than the original. Thr service manager said its a replacemant part-they don't make the 'old' version anymore--perhaps because of the 'peeling' problem? Those of you who have had a replacement installed, what is the 'new' one like?
Doc
Actually, just about everything in there is junky, or at least awkward, looking. Take the TB for instance. It has all of these strange and completely useless things molded and shaped onto it. Like the rectangular tab at the bottom right of this picture. Serves absolutely no purpose, just weighs down the car, but there it is:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13923132&p=55197447&f=0
Fuzzy -- I believe it is you who drilled holes in your stock airbox to let more air in. Unfortunately, you are letting in power-robbing hot air. When I started out with my air source mod, I purchased a new stock airbox that I now have no use for ever since reading up on setups like that. It's yours, if you want it; it's just taking up space for me.
Sheesh
Oh, I got my first scratch on Big Red. Or should I say someone scratched Big Red (since *I* had nothing to do with it). It's about 2 inches long next to my driver's side door handle. I'll have to see what Z5 can do with it.I wish people would be more careful with their car doors.
http://www.ritchiefamily.com/car.htm
http://www.napleton.com/nfg/nfgweb.nsf/VEH/Vehicle.html
scotian - I like the New Yorker, but how does it handle? Also your airbox is definitely a piece of art no matter how utilitarian you proclaim it.
engine cleaning - I can't stand a dirty engine compartment, just a preference. Once a week I spray with simple green. Let sit for 2 minutes then rinse off. Then spray the entire engine bay with tire cleaning foam. Looks like brand new! Then again your talking about somebody who cleans his door jams, trunk and wheel wells every week too. I'm in therapy now.
What's interesting is that while the Simple Green company says that "Simple Green is completely non-toxic for ... your pets," they proudly proclaim that it "Has not been tested on animals" (http://www.simplegreen.co.uk/).
NO! A scratch on BigRed!! See. I bet the van doesn't have any! ;-)))
fastdriver
I'm getting two $15 thermometers from JCWhitney. I hope the remote sensors are on a long enough wire.
How will you insulate your box? From what I read on the net, cold air is very important. Even though you won't be sucking in underhood air, you'll probably want something, even at the risk of it looking junky.
You were going to say something about the flat part of the stock TB bend...
Well, it's official. I'm losing my job next month. Nothing worse than knowing you're leaving but still having to function to "transition" your job. Sheesh. Oh well, every job change has been for the better in my last 20+ years. This should be the same...right?
Looks like we won't be seeing you then in Phoenix. Let me know the total (shipping and shirst) for the shirts and and address to send it to.
Keep an stiff upper lip. (why starching you upper lip, would do anything boggles the mind)
www.lorinser.com
