Visitor Agreement.
Or if thats too much, anyone know which digit in the vin# signifies the PHG package? Not sure if this would work but its worth a shot.
Keith
Roger-Kinda bringing up a little South bashing, aren't you? Bubba and a banjo? If you're bashing Tennessee, then that's OK!! ;-)
More fantastic latex apparel for women, brought to you by CyberHussy
URL: http://www.cyberhussy.com/latex6.html
The link is dead, BTW!
Really, the parts database they use has computerized pics of the parts and he should be able to tell differences in PHG vs non-PHG struts.
Perhaps you need a smarter parts guy?
http://www.dodgertclub.com/ubb/Forum11/HTML/000182.html
http://www.dodgertclub.com/ubb/Forum11/HTML/000194.html
"Roger - I sent you a shirt today as a sample of what I get produced here locally. You should have it in a couple of days."
After all I read one of their messages that said "300M's better look out" ... Can you believe the nerve heheh
I had my M in last week to replace the driver's armrest and interior door weatherstripping. They don't replace the armrest -- they replace the whole door panel. The new panels are different --they have a hole drilled in the rounded portion at the door opening. It looks like a screw should be inserted, but there is nothing inside to screw it to. The dealer is trying to get Chrysler to provide a filler for the hole.
It's not that bad -- its a pretty small hole and you only see it when the door is open, but I thought you should be prepared...
Thanx for the info. Just went to the www.carsdirect.com web site and the rebate shows $1k
with must take delivery before April 30. We got the 1k rebate through a convoluted deal involving a Chrysler dealer in Milwaukie, OR and a dodge delaer in Portland (since I had ordered from them before and have been very happy with Timberline Dodge). We started an invoice price of around 28k as I couldn't get them to take the damn 600 bucks rollback off ....The whole thing after rebate came to 29 and change (luxury pack, 17" rims, PHP, spoiler, bra, side impact a/b, traction control - not sure if that was part of the PHP, cargo liner, cargo net and last but not least those indispensable 4 hooks for the grcery bags
Sounds like I gotta remove the strut tower brace, cowl and wipers to get adequate access to the throttle body for removal and replacement.
Anyone suggest a bit to use on a dremel? I'll check with GR8WHT and see what he used to open his up.
Here's an excerpt from one of his posts from
Well I installed the modified TB today and first impressions are as follows:
Off the line I had no problem laying down a nice black line! (smelled awfull though!) It seem a lot more alive from a stop and pulled strong all the way to 100mph (ran out of clear road).
Ran 3 0-60 times, it was a crude measurment as I had to do it myself so there is a reaction time in my fingers here.
Each run was 8 sec, but acounting for my delay and just using the console timer. I would say its in the 7 to 7.5 sec range. The runs were not in ideal conditions either (very windy)
I also reset the PCM in order for it to learn the new airflow. It will take a while for the pcm to fully adjust to the TB. (a few days of driving)
Seat of the pants, it pulls stronger, sounds better (growls).
Now the fun stuff, the swap!
In order to remove the TB its a detailed operation.
Tools-Good socket set and extension.
Full Torx driver set (TB uses Torx)
** disconnect battery**
1. Remove wiper arms, Socket under plastic caps(yep you have to)
2. Remove plastic cowl, Torx screws ** note where the screws came out off, they are different lengths.
3. Remove Strut Tower brace, 9 bolts, and disconnect washer nozzle hose from brace.
4. Now you can access the TB- remove air hose.
5. Remove TB support bracket bolt on underside of TB and loosen the 2 nuts on the Tranny holding that bracket. The TB is on plastic studs so you have to lossen the bracket.
6. Remove Throttle and Cruise cables, WOT and slide them out of the slot.
7. Remove 3 Torx blots holding the TB on
8. Disconnect TP and AIS connectors.
9. remove TB **its on studs so be carefull and watch the rubber gasket.
Install, reverse above.
Some pics of the TB: just put the url in your browser.
1. Stock TB with sensors
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653114
2.62mm stock bore
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653110
3. WOT stop, prevents 90 degree opening (86degrees)
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653107
4.Lower lip below the throttle plate 70 mm
throttle plate is 68mm dia.
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653103
5.Narrowing of tb to 62 mm (metal to be removed)
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653098
6. TB after removing metal to 67 mm dia
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653095
7.another view of Throttle plate and boring.
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653090
8. WOT stop modified to allow 90 degrees
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653087
9. Lower lip remmoved for smoother flow.
http://albums.photopoint.com/j/View?u=1062358&a=7846180&p=44653084
Rich made this post on DodgeRTclub.com
This is Rich from DreamSpeed. I have been getting tons of emails from Intrepid and 300M owners looking for parts for their cars. I will be starting a few projects with an Intepid very soon but I need some feedback from you guys on what is currently available and who supplies it. I am not sure what there is currently available but I will be making a larger rear sway bar for it, possibly adjustable coilovers, and an air intake system. If there is anything else that you are interested in, let me know.
If you are not familiar with DreamSpeed, here is a little background. We are located in California on the Central coast. I pretty much only deal with the Stratus, cirrus, breeze, avenger and sebring cars at the moment. I own 3 Stratus's personally and I am in the process of building a 500hp Stratus. Most of my parts are simple bolts ons that anyone can install but I do have turbo kits and Superchargers on the way too. So know I would like to expand and start making parts for our big brother the Intrepid and the 300m. Any input will be appreciated.
www.dreamspeed1.com
805-735-8091
ajpiii - I also caught that reference to M owners "watching out". Let me at em..
dustin - The caddy's have any part numbers that look like that? I'm stumped.
Has anyone identified causes and remedies for this? Does it continue to be a problem? If I can resolve this issue, I'm gonna need Ed Hanson to make me some tips. I believe he has set the new standard. Thanks for sharing, Mike.
If the remaining resonance is still to much for your taste (I like it, it's very subtle) there is another small Magnaflow cylindrical muffler that you can add behind the collector that will make the resonance even less, probably close to stock sound if that's what you want.
I have a bit of resonance between 1800 and 2100 RPM, but after the first couple of days, I don't even hear it any more. It is NEVER so loud that it drowns out the stereo, even at very modest volume levels.
Try it. You'll like it.
have you also noticed on the windows and plastic parts of the windows that there are some nasty stuff stuck on there too? i know, this sound so ambiguous, so i'll try and explain. it appears to be salt and dirt mixed and it is stuck on the plastic. i tried washing it off, but no aviail. when it dries, i was able to some what use my fingernails (i know i know) to scrape it off some. but still, it can be noticable.
i'm meeting with russ today, so i'll show that to him, may be he has a clue, as we both live in the buffalo area.
then may be he can describe it for me some more.
ok. off to meet my coffee M-ate.
sleeps
As for an audio recording, I'd have to hear from someone how they would recommend doing it. I would guess that the microphone used would have to be pretty sensitive because we certainly don't sound like downshifting tractor trailers. I'll experiment with my video camera and see if I can get both inside and outside videos/recordings and find a way to digitize them. Roger, if you find a good way to do this let me know.
Mike
At idle I don't hear the exhaust at all inside. I barely hear it outside.
Revving the engine provides an ever-so-slight increase in sound in the interior (to use Roger's 1=stock to 10=harley scale, I'd say it's a 2), and at the rear you get a raspy "rowwwr" that is pretty subtle. It's not the guttural growling you would expect, but more like a bobcat than lion.
Under load you hear a wonderful low growl, ranking about a 3 on the Roger scale) that increases in pitch as you "get on it". It's a beautiful soothing sound, not "headache inducing" like many open exhaust cars that I've been in...or even stock Camaro Z28's or SS's that scramble your brain at highway speeds. I haven't heard the exhaust from the outside during acceleration..
-Mike
Mike
I'm outta here until the weekend, going to Lost Wages to win my down payment on the Hemi C.
Roger
I'm gonna have to try this. I'm off to buy my RotoZip at lunchtime. Mike, do you know what material Ed uses as molding around the cutouts? It looks good, and I'm sure I can benefit from a "fudge factor".
-Russ
Quick trip to the casino Sunday, just trying to win monthly payment on the M. Came up a little short...Drove 80-100mph most of the way down I95. This car is built for high speed cruising. Overall, for the trip (170 miles, 80% highway) I averaged about 25.5 mpg.
Still at least 12 months before I start searching for my next car, I'm going to give the M to my wife to replace her '95 Saab 900 (also a fine car). What will you have for me, Chrysler????
My main concern continues to be the transmission though. The only thing that I have seen in this area is a larger cooler. If we could just cut the paricitic losses on the transmission, say to 20% we would get a large performance increase.
Keep lurking and join in once in a while too.
So many things to do, so little time to do them.
My 300M is comming up on it's three years too. I will be keeping my eye out on the market too, to see if any improvements come up, for the 2002 model year. I do wish Chrysler (Chrysler, Dodge, and Plymounth) had the same after market selection as say Ford, GM and even Honda.
Mike, When you fill up your car what does your trip computer calculate total distance before you need more gas? Just wondering.
Also, anyone notice that the outside rubber trim strips at the base of the side windows is shrinking? Sleepy has gaps at both ends of these strips (2000, 26K miles).
One last thought: Some 2000 Ms, as well as the "00 and '01 Concorde have drain holes in the root area of the outside mirrors. Maybe one of us could make a template to drill holes in the '99-'01 M and the '01 Sebring sedan that uses the same mirrors.
Check out the New Dodge Charger coming out for 2002...'nuff said.
-Mike
Also, yes, my trip computer (the 01) provides me miles to empty, spot MPG, average MPG, and other information.
-Mike
Mike
If it was low, it man say 250 miles to empty on fillup, and if it was all highway miles, at 25 MPG or so, it may show a DTE of about 400 miles.
