-June 2024 Special Lease Deals-
Isuzu Axiom
![drmperalta](https://secure.gravatar.com/avatar/fc1f38d9619037448e7dc53f1a6d0f12/?default=https%3A%2F%2Fvanillicon.com%2F62d5ad0da2729a80d3f737ee2510cfd9_200.png&rating=g&size=200)
in Isuzu
Any info on availability? and any info on road test information?
-mike
Power seats with no up and down adjustment or bottom cushion tilt? That is just plain stupid. Also the was NO room for my right foot (size 12). I could barely fit it inbetween the brake and the accelerator. Stupid, stupid, stupid! Otherwise it was a decent vehicle, but these GLARING shortcomings take it off my list.
GAM
It is curvy than my '99 Passport, nice one-piece rear hatch, I can live with the front grille, bigger wheels with lower profile tires. Looks more modern than my Passport.
Interior.
Ride height, seating position and ergonomics are carry-over of my Passport, everything felt very familiar including the lack of thigh support which I made custom cushion to support my thighs, the power seats had no height adjustment (which I believe should be available for a power operated seat). Front cabin has nice curvy arm rests but the space seemed to be smaller than the angular interior of my Passport. Relocated switches are the following; rear wiper and washer, power and winter mode. The fully automatic HVAC is excellent and the information display center is a nice touch, I believe it can be tweaked to receive navigation upgrade. Sound system are better. Rear seating positions and space seemed similar to my Passport. The rear cargo is narrower but longer.
Under the hood.
Everything is arranged similar to the Passport except that the engine is a little bigger and an additional TOD computer module is located at the place where the clutch master cylinder should have been.
Ride and drive.
I expected the power, esp on starts from stops to be ample but my Passport felt quicker and more rev-happy (a 2001 Rodeo with ISC that I test drove also felt quicker). It may be that the weight increase could have something to do with it or it could be that the engine has not been broken-in. The ride is nice, same as the Rodeo with ISC, soft on the bumps and dips with controled dives and sways. It has a normal and sport mode. I like the normal mode better, less road harshness but still with good dive and sway control. However, when I got back to my Passport with Monroe-matic plus shocks, I could not really tell if the ISC has a definite advantage over the Monroe shocks.
My Passport felt lighter and quicker in comparison but I never noticed from the Axiom any thumping sound when swifting / stopping / accelerating. Such is a welcome surprise and should be.
Inside "plasticy" soft rattles are about the same to my passport. I never thought that I fixed the interior rattles of my Passport to this level.
I believe it will boil down to driver's taste since the Axiom and Rodeo has price overlaps. However, the TOD may be the tie breaker for those who wants a no-brainer drivetrain (esp. female drivers).
My two cents.
-mike
Spokesman for Edmund's Isuzu Owner's Club.
My first impressions were very positive. I did a great deal of research at the Isuzu site were recently were posted relatively good technical information and 2 new independent reviews were also posted.(Interestingly enough, no one has a brochure.)
First the front "cowcatcher" was a bit unusual, but it got friendlier each time I looked at it. The truck (car?) sidelines are eye-catching and Isuzu designers have put a great deal of effort into the rear tailgate. It seams nicely detailed. What was very impressive it's the interior design. Slightly narrower than the similar category, but good architecture made it almost irrelevant. Its hip room is 2" narrower than the JGC, but it felt even "roomier".
The Axiom comes with a lot of features. Even the base model is equipped with accessories than on other models (like JGC, Ford/Mercury) are good for several thousand more on extras, such automatic A/AC, 4-way power seats, I SC, automatic transmission mode selector.
As I mentioned before I would be a first timer for an Isuzu. If some one can share experience about the engine reliability and specially on how efficient is its TOD on off-road and if it the lack of full time 4WD is a disadvantage.
So in conclusion, the full-time 4wd of the TOD coupled with the 4wd-Lo range, should provide excellent on and off road handling.
-mike
If I understood well the TOD can be used as a full time 4WD/AWD even on dry regular surface road without any ill effect on the power train system. That sounds pretty good. What about the V6 engine oil usage? It sounds almost scary that a sophisticated engine as the 3.2/3.5 engine can consume 1 Q/1000 mile. My current car is over 65,000 miles and it goes from one oil change to another without any add-on oil.
Frank
As for the oil consumtion, it's completely hit or miss. Of all the 3.5l owners I know, about 25% have oil consumption problems. I was burning about 1Q per 1200-1500 miles. After 10K I switched to synthetic and now it goes through a quart every 2500 miles. I just check the oil @ every-other gas fillup and it gives me a good reason to check under the hood. If you fish around the owners area you'll see that most everyone feels that since the other quality attributes of the Isuzus are so great, that the oil consumption isn't really a problem. Compared to say the warped rotors of the JGC and the tranny problems of the Durangos. Most likely you'll get one that doesn't burn oil at all.
-mike
I'll keep posting my impressions on the Axiom.
Frank
-mike
I was somewhat hoping to find an SUV that didn't ride like a Ryder truck and cost more than the house I grew up in. However, the two SUV's that I've really liked, the Axiom and the Highlander have one very big limitation: terrible interior color selection. The leather on the Highlander can only be had in a buttery (shows every piece of dirt) beige and the Axiom can only be had (either cloth or leather) in a color that reminds me of cooked carrots.
Isuzu and Toyota should be given a slap on the wrist for this faux pas. The Axiom looks great in dark grey...until you open the door.
-mike
I am interested in How you customized the thigh support for your Isuzu seat cushions. I am having the same problem in most foreign cars that I test drive. I am very interested in the Axiom, However I am not going to spend $30000 on a vehicle with the same issue as my current car. Mhenson@garycsc.k12.in.us
http://forums.vmag.com/suvrodeo0300/messages/5250.html
Anyway, I took a test drive on a Pathfinder LE with 8-way power seat and the range of adjustability is perfect for me, it also has very nice car-like ride and with very strong engine.
I read somewhere that the 2001 Passport EX-L has power seat and I plan to take a look on it. Maybe I'll order driver power seat for my '99 Passport.
-mike
It will have:
V8 Isuzu Engine
3 Rows of Seats
TOD
Probably other stuff too.
-mike
-mike
It has a good room in front and on the back seat.
It looks like higher class vehicle, with a some expensive features. I liked the drive as well.
It was a pleasant first experience with the new kind of SUV. I will drive the 4WD version next and make my decisions.
Does anybody know if Axiom has the Overdrive system? I couldn't find any switches for it.
Thanks for your attention. Rob
P-R-N-D-3-2-1
When you place the gear shifter in "D" it will be in overdrive mode allowing gear 1-4 to be selected. If you place it in "3" you will only get gear 1-3. Winter mode when engaged will start the car in 3rd gear so as to not cut the wheels loose on take-off from a start on wet or icy pavement, @ 20mph winter mode will kick off. Power mode will move the shift points from about 4500rpms up to close to red-line for perkier shifting, and better acceleration.
-mike
Or, maybe people just really hate the Axiom.
The axiom is getting closer to that car-like ride and they filled it with lots of noise deadening material, which will give it that more solid feel, but it also porked it out a bit weight wise.
If I were shopping for a highlander, Escape, Outback, All-road, X-Country, or Min-van, I'd seriously consider the axiom.
-mike
-mike
You may remember me, I sometimes hang out on the Trooper area.
Here is my depressing Axiom tale.
On the way from work I pass my local Isuzu dealer.
This is back on March 22. What do I spot...the new Axiom. So I park the car and hop out and take a look. Turns out it is the base 2wd model with cloth.A friendly salesman comes to talk to me while I climb all over it as best I could (it was up on ramps and locked). I let him know I was a browser, not a buyer so we made small talk about it and he did not open it for me. It was a very attractive dark blue, and overall I was very impressed with it. I recall back on March 22 I said to him "So do you think it will last the weekend?".....my point is - it was the first one they got, first of a new model, no large dealer markup, and it is still sitting in the same spot today!!!
Oh yeah....and they also have a yellow Vehicross sitting forever with a 0% financing sticker in the window!!!
Why arent people buying these cars? While I admit the Vehicross has limited appeal, it sure should be cool and rare enough for someone to snap up. And I thought the first Axioms would sell immediately.
I am baffled, my '96 Trooper has been PERFECT. Now at 82k miles.
I look at people driving FOrd Explorers like they are lunatics.
FWIW
-Eric
We feel your pain. Maybe it is the Isuzu marketing, or the fact that Americans are generally sheep that follow the pack right to the slaughterhouse! With the Big 3 having a major safety recall on all their trucks last week you'd think that would help!
-mike
The website is http://www.winanaxiom.com/
-mike
http://isuzu-suvs.com
-mike
link
Steve
