-Larry
but the theory which I proposed was in consideration that there is ABSOLUTELY NO fluctuation in the temp. needle....just a simple thermostat maintaining such accurate temp.?
makes me wonder.....
Best Regards,
Steve
I have a 95 ES Protege with 87,000 miles. I am on my third transmission. The first went in an accident. Something about a pin breaking. The second failed within 24000 miles after the accident. For the third one the shop rebuilt the transmission. It is working fine for now. Any one else have this many problems?
Also parts are hard to find. I have the first model year of the redesign. An engine fan had to be reorder 5 times. We finally found one in a junk yard. Apparently I have a Protege ES built in the first 6 months of 95. They changed the fan they used for the second 6 months of 95. The dealer missed that.
To clarify what I stated, there are three or more temp sensors/switches and one thermostat.
The thermostat regulates the flow of water from the engine to the radiator. It will only open when the water temp reaches a particular threshold, usually between 190 and 195 degrees for most newer vehicles. if the coolant temp begins to fall below the specified temp, the thermostat(all mechanical) slowly begins to restrict the flow of the coolant until the temp rises again.
Temp sensors/switches:
1) in the radiator to control the fan. Again, the radiator only heats at low/no speed.
2) on the engine to sense engine temp for the PCM(Powertrain Control Module). Senses either oil of water temp depending on the vehicle. Also, the oxygen sensor in the exhaust is a temp sensor. Exhaust temps are relative to air/fuel mixture.
3)A cheesy little sensor for the gauge to give you peace of mind while you drive. The gauge sensor is much less accurate than the sensor for the PCM.
I'm tired of typing but if you want more just ask.
At least I think it's a vent. '01 Protege.
I do have to say... the relatively insane temp gauge in my '82 RX-7 puts on quite a show. Particularly while sitting in line at a drive-thru with the AC on. Then it goes up, up, up... Then it goes down, down, down... Then it goes up, up, up, up, up, up, up, up... Then it goes down.
Let me tell you... even though that little rotary engine has never overheated, it provides quite a scare sometimes. Especially since I know that overheating a rotary is almost certain death for it. But, there's nothing like watching that tach needle swing past 10,000rpm! It's quite exhilarating!
MARTIN
Personally, I would just drive slowly (keep in under 3500RPM) until you see the temp needle go up to the normal operation temperature. I find it only takes 3 minutes of regular driving before you can punch it!
I looked at a 2001 VW Golf the other day. Now THIS is a car! Built like a vault, and extremely safe. It has side airbags, head curtain airbags, all standard. Plus the normal front airbags. Lots of standard features, too. Love the how the keyless entry remote and key are the same thing. Very fun to drive, too.
Now it's not like I hate my Protege, or its a bad car. In fact, I really like it a lot. But I like the VW even more. I'm going down to the VW dealership tomorrow and see about a Golf. I know a few friends and co-workers who'd like to take my Protege off my hands, and if they do, at least I will know where my baby will end up.
Now if I do get the Golf and sell my Protege, don't worry, I'll still be around! My father still has his 2000 Protege DX, only has about 2500 miles on it.
Decisions, decisions...
Nice Car. I thank you folks for the inspiration to look into this little feller.
It's Mica Black w/ Grey Interior, Auto, Comfort Options, Keyless Entry.
I was driving a 1980 Caprice with a bent camshaft. What a difference!
-Larry
Just my .02 worth.
Welcome to the world of ZOOM!
Mark.
good luck
H
reason why I argued was that considering the modern trends towards feedback systems in all aspects of mech. engg., it was natural for a modern feedback system in place for maintaining the engine temp....
If I were an impulse buyer I'd be the owner of a Jetta right now. I really liked the way it drove, standard features, safety stuff, etc. However, after doing the research, here I am in the Protege forum! I know a few people with jetta's that have had a lot of problems with them (like vocus said...2 out of 3 of them had to replace the oxygen sensors). Consumer reports also helped me make up my mind not to buy a VW (however, the Passat rates pretty high).
I really think the protege drives a lot like the jetta. The jetta may be a little more refined, but I like my pro!
Any comments or suggestions as to the performance with auto transmission?
I think Mazda was thinking "automatic" when they decided to upgrade the 1.8 to the 2.0 engine.
And while the 2.0, in my opinion, sounds a bit gruffer going up the tach, it's not the voice of complaint you're hearing. I was easing up one of our overly-short onramps yesterday when a monster van appeared from out of a blind spot and refused to budge. No problemo: push down hard with right foot, zip to 5500 rpm (which is the HP peak in the 626), watch van shrink in rear-view mirror. A practical application of Zoom Zoom.
Frank
My wife really made some interesting comments that I'd like to share with y'all: "Man... this car just doesn't like to sit around at 65MPH; The steering is so responsive, sharp and centered compared to my Camry... now I see why you like to zip around turns 20+ MPH above the posted 'safe' limit !!!!" She even requests to drive it on the weekends! OKAY by me... as long as I'm there for the ride!!!
MARTIN
Same emerald green as ours.. looked sharp.. the slight pangs of jealously started creeping up, but I pushed it down... we all are enjoying our zoom zooming machines!!!!
Has anybody used the S plan lately? We are so...pleased that we looked into that.
In-stock Protege ESs for sale in Maryland: I stopped by Russel Mazda on Route 40 in Maryland. They have one Premium Pkg. automatic ES in Millenium Red, one 5-speed no options in M. Red, one automatic no options in Seabreeze, and one additional automatic no options Millenium Red. Also, there was one LX 2.0 on their lot as well, and I think it was Sunlight Silver. Just wanted to let people in the neighborhood looking for an ES that there were some available.
On another point, I have not seen another ES (or 2001 Protege, to think about it) on the road since I got mine on 2/23/01. I now have 1801 miles on my car and still loving it!
Respectfully;
Larry
Next, I hear its very hard to find an ES without a built-in cassette player - which I also didn't want to pay extra for.
Is anyone else in this bind?
Also, whats some of your choices on the color to pick?
2001 - Time for the Protege to hit the market..I am sure rebates will continue left and right...
2 years down the road....watch out...
I just want to do a quick survey on what people think of the ES interior. I know that a few people have made comments on it already. I've been torn between purchasing an LX with gray interior fabric and normal black gauges and purchasing an ES with the black fabric and the white gauges. I really wish that Mazda offered a choice of ES interior colour.
At this point, I'm not sure if I'd learn to live with the black ES interior. It's too dark, looks like it can get dirty in a hurry, the pattern on the fabric looks cheesy and cheap to me, and I don't like the white gauges either. However, the LX trim level offers far fewer bells and whistles (particularly here in Canada, where you can't even get things like power windows on the LX at all), and I like bells and whistles.
For those of you who are like me and aren't too hot on the ES interior, has it been enough to dissuade you from purchasing the ES model? If not, does the interior grow on you after a while?
pygmalion - the graduate rebate is a Mazda program that should not affect the price you can negotiate at the dealer. Try contacting Mazda Canada directly for information. At the dealer, get the price finalized and then tell them you want the rebate. If they're on the up and up it shouldn't be an issue.
