See
http://www.rearseatvideo.com/sienna1.htm
It took me about 2 hours to install the whole thing and looks completely stock. The only hard part about the installation was getting over disassembling the left side trim and dashboard to run the cables and hook-up to the head unit and power supply. My wife was more than a little concerned when she came into the garage and found her beautiful new van in pieces
I purchased this system on eBay for about $900 and it came with 2 sets of wireless headphones. The screen is, I believe, 8" diag., and is a widescreen format (16:9) so you can see DVDs as they're meant to be seen.
The alloy wheel do not have covers of nuts, which came with
Toyota Solara of size 16x7 5 bolt pattern 5 spoke. So I doubt that without special nuts, the existed nut will look ugly on alloy wheel.
Anyone has any idea or comments? The wheel is MHT chrome alloy, and asking price is $325. Do you think what is a reasonable price?
I have one question: when I try to buy aftermarket alloy wheel for my 2004 Sienna LE,
almost all of tire center pick up wheel size 16x7, but OEM steel wheel size is 16x6.5.
1): What is the size effect of this half inch width difference?
2): It will give any trouble to the OEM tire P215/65R16? or I need to buy wider P225/65/R16 tire? Thanks.
I am interested in getting a Sienna XLE Ltd with NAV but will lose the 6 cd changer as a result. If I install a after market cd changer, will it mess up other electronic stuff?
search for toy-aux connectors from PIE
Well, it turns out that Cequent (the makers of the DPS accessories for Toyota) sell a swing-away mount that will allow you to swing the tray/box out of the way to make it easier to access stuff in the rear of the van. You still retain the ability to fold the tray up against the back of the van, but now you can swing the whole thing out of the way if you need something in the trunk. It also comes with the necessary extenders for the wiring for the lights for the tray itself.
I haven't changed out the mount yet, but it looks pretty straight-forward to do so. The part was $150 from an online hitch merchant with no sales tax and no shipping charges. It's too bad that Toyota didn't think to use the swingaway mount in the first place since it seems to make a lot more sense for use on a minivan.
If you are considering getting the DPS cargo tray/box setup, see if your parts department can order the swing-away mount instead of the fold-up mount.
http://tinyurl.com/49fzk
Why Toyota doesn't offer this themselves is beyond me. They design a great van and some great accessories for it (like the DPS cargo tray/carrier), but somehow fall a little short on execution, like needing the swing-away mount for the cargo tray/carrier, or extra lift for towing something.
Is the area exposed big enough to step on as a person exits the van stepping forward?
Thule vs Yakima, size, easy intallation , etc.
any input will be very much appreciated
Thank you in advance for your help.
I have a 2004 Sienna with NAV and want to install a 6 CD changer. Unfortunately, the NAV only comes with one.
Anyone have any experience with this?
We just bought an AWD LE, but I forgot if it needs chain in the snow country...
Trip is tomorrow, but I forgot to buy and stores are out of stock for the tire size :<
Has anyone installed a CD-changer into their 04/05 LE or early year? Does any one know if the LE JBL system can control an aftermarket CD changer w/o using FM Modulator? Or has anyone replaced their JBL unit with an aftermarket MP3/WMA head with a CD changer? Thanks.
where did you buy the color-keyed mud guards? would like to get them for my silver sienna
http://www.trdparts4u.com
I have the same problem......I plugged my XBox into the video/audio source and was able to hear the Audio through the Wireless Headset but couldn't figure out through the remote or Audio system in the front how to pipe the sound from the source into the Car speakers.
Keeping in mind that I have the factory installed DVD system.....has anyone figured it out yet?
I can't find it in the Manual. If its in the manual....its buried deep inside where I can't find it.
Questions: Where is the glass break sensor located if I have one and is it easy to install one if I don't have one? Any suggestions on where to buy one if I need to? Is there someplace to plug it in? I checked the wiring under the driver side dash as described in the Tacoma forum but haven't been able to find a white box with a sensitivity control or any extra connectors. I did find the black sonar module with a volume control. I wouldn't be surprised if I already have it since it seems to have everything else except running boards.
Dave
