Visitor Agreement.
What could have caused this light to come on and what can I do about it short of taking it to a repair shop? I'd prefer to fix it myself for obvious reasons if at all possible.
I like to work on such things myself (to save the trouble and $) and would appreciate hearing back from some of you about this. Thanks a million. :confuse:
They do this in support of selling you parts to fix it.
I can not lock/unlock my passenger side car door with a key anymore. I opened up the door panel and found that the lock tumbler was not attached to anything and a long metal piece with a plastic and metal clip attached to it fell down. What I need to know is how to reinstall the metal piece so that I can lock/unlock my door from the outside again?
It probably just came loose, or the clip on the end broke.
This happens the moment that I install it and try to start it up.
It will start but it will short out the number 4 cylinder and
get no fire to number 4 and miss-fire on the rest.
Any help would be greatly welcomed.
I last used it about 6 months ago and I tried to use it recently and it just wont turn on. It used to work and there arent any other problems with the truck...I checked all fuses and they all seem to be working fine.I heard about this recall, could it be related to this??? I need some help thanks
I have changed the fuel filter, swapped relays and finally changed the fuel pump,but the trouble remains.
I now believe the problem is in the power distribution box. If the contacts are dirty/corroded or loose changing/swapping the relays won't solve the trouble. Also could be a poor ground to the box.
I'm going to try cleaning the contacts with electrical contact cleaner and oxy-acetylene torch tip cleaners. I will post if this solves the problem.
If any one knows/has any other ideas of possible solutions or problem areas please reply. This seems to be a fairly common problem. Thanks and get dirty.
When functioning correctly, vacuum is applied to the gas tank vent hose, to pull fumes into the charcoal recovery tank. If the vacuum cannot be pulled, it sees 'high pressure'?
Bad gas cap. Bad vent lines. Bad canister. Any or all of the hoses of this system. There may be relays and vacuum switches also in this system that have failed.
P.S. This is another reason to not run the vehicle when you are fueling it, you may set a check engine light. Main reason, is you may blow up.
P.P.S. This also shows that having a code reader, and know the definition of the code set in some cases may not give you much of any hint at all as to what is wrong. You need a factory service manual, which has procedures to run for error codes.
I have replaced the plugs and wires, and the EGR valve. I have cleaned the MAF sensor with MAF sensor cleaner. Nothing has helped. A mechanic buddy of mine told me to change the fuel pump. That is expensive, so I don't want to do that unless I have too. Your thoughts please. Thanks!!!
There can be errors in the parts data bases.
I've never used anti-seize. Are you going to be changing them again when needed in 50/75/100,000 miles?
