Now the fuel cap light came on about 8 months ago along with the check engine light. But when I looked it up, the check engine light comes on if the cap is malfunctioned. But it has been running fine since then tell now....Any help would be much appreciated.....
it stopped on the the tail pipe and proceed to cut the tail pipe with a hack saw or saw zaw and you will find the double walled pipe has folded over and partially blocked gases from escaping the engine creating a loss of power.
it stopped on the outside of the tail pipe and proceed to cut the tail pipe with a hack saw or saw zaw and you will find the double walled pipe inside has folded over and partially blocked gases from escaping the engine creating a backpressure toward the engine for a loss of power. Exhaust must escape or the engine will indeed lose power and stumble!
You can also have an assistant rev up your engine and with your hand in front of the tailpipe exit feel the exhuast pressure if it feels weak when it is revved up it may have a clogged pipe or c.c.
Cleaning that little thingy will probably show some improvement.
It has been awhile since I posted Last. I have a Ford Ranger 06 XLT .86,000 miles Recently it has been draining Coolant. I Checked Hoses , Checked oil. etc. Engine light did not Come On. Did not over Heat. Temp gage is in the Middle .
But I smell burnt Coolant off the Engine . Seems to Run OK . Seem is be draining Fluid. I noticed some coolant near the water pump. t-stat area. Hard to see areas. I had a 98 Ranger that had a bad Head Gasket . I know what to Look for. If you have any Ideas . Let me Know. Before I head off to the Ford Garage . Thanks Prayerhiker
But, if you are smelling coolant, you have a leak. Somewhere.
It might be a leaking seal on the water pump.
get out the little mirrors and flashlights to examine those semi-hidden areas.
do carefully check all the hose connections--inexpensive fix if that is the problem.
don't clean anything up on the engine block--if you take it to the repair shop, they will want to inspect it for traces of fluid, etc.
good luck ! let us know the outcome.
Thanks for Your Help this Week. PrayerHiker
if it's below check the brake line to make sure it hasn'worn a pin whole in the line where your clamp goes around it, that would be my guess
i have not seen any master cylinders that the clamp bolt goes into the fluid cavity.
hope this helps!
What was the OEM tire size for a 1998 Ford Ranger, 4x4, 3.0L, Auto Trans with A/C, Supercab, step side?
Bob B.
One source says 215/75R/15 another source says 235/75R/15, I'm wodering which is correct OEM. Need to tell my daughter what size tire would be ok, the 215s would be cheaper than the 235s I'm guessing.
Black Ford Ranger 2004 - Tow Away
Vehicle does not start as is. It needs to be towed away, car was towed to residence in a normal tow truck (flat bed not necessary). We used AAA.
--Vehicle was involved in a rollover accident down a hill.
--Damage to all sides. Doors do not open. Driver's side window broken
--Passenger compartment appears intact. Engine compartment mostly intact, with the exception of some buckling in one corner which has displaced the battery.
--There is a leak (maybe transmission fluid).
--May be useful for parts only (all four tires look good) or as a project for someone who is knowledgeable. Welcome to come by to look at it.
i have owned a few and all of them had a sticker with this size
Any thoughts?
http://www.youtube.com/watch?v=g-36aM360V8
