Visitor Agreement.
Anyway, I don't think I'll upsize since the potholes are kind of rough where I live and most of the paving contractors don't seem to know how to make a road smooth. I'll just have to wait until I upgrade to a P5 for the better handling, but the LX is still fun.
Chow
I have been looking at a few sets of speakers to upgrade to. My primary choices are Infiniti Kappa series 3-way 6x9, Pioneer 3-way 6x9 (with horn tweeter, not dome tweeter), and Boston Acoustic 3-way 6x9. All of them have fairly high tweeter setups and require the use of the provided grill to give enough clearance. It seems that the factory integrated speaker grills in the rear deck won't provide enough height for these speakers. Did you run into that problem?
If I do go for any of these speakers, I will have to customize the rear deck, or have one customized for me. I can't just remove the factory speaker grills and replace them with the provided speaker grills because of the angular shape of the factory grills. Any ideas?
If you have interference between the tweeter and the bottom of the rear deck panel, you have two choices: mount the speakers under the rear deck or cut up your rear deck panel.
Mounting under the deck is easier, but means you'll lose some trunk space and cut down on the height of anything you can stick through the pass-through from the trunk to the cabin. You'll also lose some volume from the speakers as they'll be located about 1 inch lower than being top-mounted. You'll also want to use some lock-tite to keep the speakers from falling out if the screws work themselves loose (you'll hear a lot of rattling before that happens though).
One thing I haven't checked out is how flat the rear deck is underneath. If there are protrusions, then I recommend against mounting them underneath. I don't suggest cutting any metal off the rear deck to make it flat for mounting speakers. I'll take a look after work and let you know. However, I don't have the ISOFIX child seat anchors in my 99, so I can't comment on how they affect this situation.
So far as modifying the rear deck, you can cut out the existing grilles and cover the holes with larger grilles. Maybe you will have a friend who installed really large speakers and isn't using the after-market grilles. You might also ask someone who installs audio systems. Aftermarket speakers usually come with grilles, but these usually aren't used when they fit into factory spots. You can also fashion your own if you have either access to the equipment or are willing to pay someone to make them for you. Make a frame and stretch some fabric over them. If you want to get fancy, you can use perforated metal or wire mesh in place of the fabric.
You can also mount speaker boxes on top of the rear deck panel. You can then pitch them slightly forwards for more sound, but they will cut down on your rearward visibility.
I'd probably go the lazy way and mount them underneath if it's clear.
The only minor issue that came up is that since the stripes have been on the car for a year already, the newly exposed paint is just a tad darker than the rest of the car, but you won't be able to see it unless you know where it is. Hopefully after a couple of years of exposure under the sun it will even out with the rest of the car and disappear for good (if that's possible). Even if it doesn't, it still looks better than the cheesy GOLD(not light tan as i said before) pinstripe that it had on before (car dealers aren't the most aesthetically inclined group of people i guess :P).
and the zoom zoom continues....
I just got a 01 Pro-ES w/out mud flaps, but am interested in installing the mud flaps myself, because I understand it's not terribly difficult to do. Can anyone comment? Is it something you need special tools for? Does the car need to be elevated off the ground? Anything that would prevent an apartment dweller like me with limited tools and work space from installing the flaps myself?
I appreciate the help. Also, what are some recommendations for where to purchase the flaps? I've heard mazdastuff.com referenced--is that the general best option?
I was considering mounting one under the rear deck when I have the $$$. I figure it's easy to get to (other than running the wiring under the carpeting and trim) and will allow it to throw off heat easily.
I'd only get to use it when the wife isn't riding with me though.
Actually, I sometimes leave the stereo off when I'm driving some twisty road because I love the sound of the engine.
Just a thought.
Also, you may want to check www.corksport.com for some Pro/Pro5 mods.
I looked at corksport a while back, but I'll check them out again. Thanks, maltb.
I don't know that much about audio.. if anyone has any ideas I'd apprecaite it
I did not disassemble the rear door trim panels, but I imagine it's pretty similar too, just with a different number of screws and other fasteners.
The front speaker holes are made to fit 6x8s, but 5x7s can fit if they come with mounting holes to fit a 6x8 hole.
I consulted Crutchfield's site for what "drop-in" replacement speakers they have for the Protege. They may already have info on what fits into a P5's rear doors, but if they don't, they will shortly.
The stock Pioneer speakers are OK, but their permament magnets are kind of puny.They also lack a bit in reproducing high-end sounds.They are made of paper (single cone in front, single cone with whizzer cone in back), with rubber-coated fiber surrounds. The ones in my 99Pro were rated for 25W continuous power. I replaced the fronts with Pioneer TA-6865s (3-way), rears with Pioneer TA-6999s (3-way also). Much more punch in the high frequency range, and more boom in the lower range when I crank up the volume (I can feel the door vibrate much more than before...fun).
I have an old box with 10's from my current car I could throw behind the backseat but that would wipeout the main reason why I got the p5 over the mp3.. cargo room..
-AardMark
Let me know how it goes with your P5 when you get it. I'll be quite envious.
I'm also curious in case I do manage to convince my wife to get a P5.
Checked Crutchfield's site. No info on any 2002 Mazda products yet, although they list 5-1/4 speakers in the rear doors of the Protege sedan with "minor" modifications.
Chow
9709T18 - Acoustical Damping Sheet Hi-Temp Mastic, .070"Thk,.7 Lbs/SF, 32" X54", Black.
someone wanted this info. I forget who
Steve
P5 B28V-56-49XE
I think it comes down to color preference.
My question Henry is that are your driving habits such that it would matter much? With the mileage you are getting, your car must rarely see any twists.
I guess I should've sticked with my Civic. NOT!
http://albums.photopoint.com/j/View?u=1630230&a=12462090&p=50575354&Sequence=0&res=high[/
after the intake was changed.
Engine noise, heh, varies. During idle, there is this sucking noise like there is a bad vacuum leak, from 1000-3000 RPM, the noise is minimal, up to around 4500 it says "Hey I've done something to this engine". After 4500 it screams "Watch Out" and sounds so powerful. If you've ever heard a good intake before you know what I'm talking about....it's a powerful sound in it's own class.
I wonder about that super mega-flow intake... since I have the 1.8L, how would that affect performance and would it be legal? Maybe I should e-mail corksport...
It shouldn't be illegal, all cars make noise during throttle up. And unlike and exhaust the noise only occurs when your foot is down, once you let up, it completely disappears. I don't think it would affect emission laws...The Super Mega Flow intake is a great setup, well worth it. Just be sure to get it away from engine heat. You'll see a big difference.
Since the Super Mega Flow intake draws air from well within the engine compartment (and only a few inches away from that hot exhaust manifold!! It looks that way from Corksport's pics), I'm afraid I won't gain any power. Sure, it can draw in a larger volume of air, but it seems hot air! The stock intake draws in cold air from just above the grill. And, I'm afraid any type of ducting from the intake to a cold air source would severely hamper the amount of air the intake can take in... virtually reducing it to pre-modification intake...
Just add a length of PVC and coat it to get it farther from the exhaust manifold. But if you go as low as mine for cold air, you'll want to invest in a bypass filter so you won't ingest any water.
now my dilemma, since one side of my ES decal is gone, there are 3 things I can do:
1. get a new ES decal and put it on
2. remove the decal on the other side
3. leave as is and be the only Protege around here with ONE ES decal on one side of the car
now, I could care less about the decal, I don't think it looks cool nor hideous. So what should I do? any suggestions/comments?
Sorry, I had to get that out of my system.
