Visitor Agreement.
I think I'll do a live poll tonight at the chat room and that'll be the end of it
although having only one ES sticker is kinda cool... sort of like having the best of both ways...
anyone seen one?
it's all in my hand now, all 3 options DIY-able. What should I do.... hmmm... this should make some interesting chat topic tonight....
I won't be able to do this immediately though, gonna be out of town this weekend, probably gonna do it sometime next week after I wash the car and clean it up a bit.
H
I know I'm probably asking too much. Can I get some suggestions please. Thanks!
Kumho Ecsta
Vredestein (BMW tires)
Looks like the constant nagging by Protege enthusiasts such as people on this board is starting to pay off...
Is there a nice Mazda forum/website out there also? Kind of like the VW forums at www.vwvortex.com by any chance?
comet
-mcomet
http://www.corksport.com/ (under Protege link)
here
http://www.geocities.com/lonestarrd/title.htm (under body kit link)
there are others, but I have to look later today.
1) is it a good idea to tow a small trailer (1000 lbs. - class I) with car ?
2) any pointers as to where i can get a roof carrier for my pro ? again, is it ok/safe to install one, considering the power.
thanks in advance for the info,
-hari
p.s. (i cross-posted this in "care & maint" also, by mistake)
can you tell me what areas have to covered interms of priority. (trunk, front leg space, etc.) i mean, which areas vibrate most ?
also, for chikoo & conheady :
IF you remember (i know it was more than 2 months ago) , how much was the shipping cost ? (they do not mention it on their web-site).
thanks for the info,
-hari
Go for it.
Makes a hell of a difference. Especically the trunk. Noise is reduced by 70% in the trunk.
same goes for the floor.
I just cut the mat int the shape of the floor mats and put it under them.
Shipping + 2 mats cost me 30 buck or so.
I guess the mats were $12 apiece.
thanks for the info, btw.
One thought that came to my mind was to go for a smaller alloy wheel(14") and corresponding tire with a bigger and softer sidewall.
I made a search on tirerack.com for alloywheels for the PRO, but it came up with only 15,16,17 inch wheels.
Any ideas on how to
1. get hold fo 14" wheels that fit the ES
2. trade in the existing 15" wheels
all inputs would be highly appreciated.
regards,
Chikoo
but I'll be the 1st to say you are loco...
You can check the bolt pattern and wheel offset (face of hub to centerplane of wheel) specifications on your Pro and see if the wheel choices match.
Weaknesses: The Avid V4s are very noisy
Compared To: BFG Comp T/A VR4, Bridgestone Potenza RE-92VR
Review Summary:
Bought a set of 215-55VR16 tires for my 99 Maxima. Immediately noticed a tremendous improvement in dry grip and steering response. Also noticed a stiffer ride and a little road noise. After prox 15K miles the tires became unbearable noisy -- lots of rumble at anything above 30mph, especially noticeable in my very quiet Maxima. Too bad, because there was lots of tread left when I replaced them at 24K miles. Maybe this is just the way it is with V-rated tires. I love my new Bridgestone Turanzas H Revos. They are smooth, quiet, and seem to corner and respond every bit as well as the Avid V4s.
any rebuttals?
Just a thought.
And if you wanna replace the potenzas, the kumho ecstas from tirerack are amazing tires for the money; quiet, comfortable, great grip
i would also appreciate any hints/tips/warnings/cautions.
thanks.
You'll want to make sure the mfr. has clips or towers that fit the Pro, due to the curvature of the roof. Most should have something that fits.
I use a Mondial roof rack that fits both my '99 Pro and my '89 323. I actually use it mostly on my 323 since the roof is flatter. Thus, I can maximize the distance between my support bars. The only problem I have with the Mondial rack is that the clips (which are dipped in vinyl) have some surface rust where the vinyl doesn't cover the steel. I hear they now have stainless steel clips. Otherwise, it's pretty easy to install and mount bikes to it (15 minutes to install and mount two bikes). I like it because the support bars don't protrude past the integrated towers and the locks are built into the rack.
Saris also makes a nice roof rack. Thule and Yakima are longer-established brands and are good too.
I think the Pro manual recommends a max roof loading of 150 pounds, including the rack itself.
If you are only carrying 1 or 2 bikes, a trunk-mounted rack might make more sense, and it's easier to put your bikes on it. Look for 6-strap versions as they better resist lateral accelerations. 4-strap trunk racks are getting pretty rare anyway. With trunk or hitch-mount racks, make sure the rack will accomodate the frame of your bicycles. Some rear-suspension frames won't fit on "traditional" rack arms.
I called Shadowtinting again and I asked if they could get the Solargard metallized tint. They said they could. It will cost about $250 CDN (before taxes) and it is guaranteed for life not to fade. The owner said that the metallized stuff will cut out about 20% more heat than the other stuff. I'm still not sure if I'm gonna get the metallized or medium grade (dyed, $179) Solargard tint, but I am fairly certain that I will go to Shadowtinting.
To all others,
I finally decided to go ahead and install the hood deflector, my very first mod!! Installation was simple, but I reccomend NOT doing it at night under a street light....very frustrating then. It looks better than I thought it would, so I'm happy with it. I will be taking a long trip tonight, so we'll see how it actually works.
PF
The cassette is $180 and the CD player is $200 less a $50 discount at 800.com and I figure about $100 installation at Circuit City since I would not attempt it mayself. About $430 for the whole shootin' match.
PF
In my 95DX, I replaced the factory stereo (Damaged when I bought car) with a Pioneer KEH-p2800 cassette player for 100 including installation at Circuit City. It is IP-Bus (Pioneer) CD changer compatible, and I know I'll add that before I move to the East Coast, so would like to hear what combo you go with and how good it sounds.
Also, if you haven't purchased it yet, try crutchfield (.com), they have a wide variety of Pioneer systems, combos are discounted (not 50, but about 20-30, but starting prices are cheaper than 800.com) and (the best part) you get ALL the gear (brackets, wires, connectors etc) and a car-specific installation pamphlet to instruct you on the installation process. Plus free phone assistance and no-questions 30-day prepaid return, should you need it!
I had installed a hood deflector that was sold to me by the dealership. Now, most hood deflectors I've seen come with something to prevent the hood deflector from contacting the hood if it gets hit with something or just from vibrations. These things were usually in the form of little plastic mounds that you would stick onto your hood, thus preventing the hood delflector from hitting the hood. However, the one that the dealership service dept. sold me did not come with these little pieces. When I phoned to ask about them, the parts person did not know what I was talking about. So after about 2/3 weeks now, I have noticed that the paint is scuffed at 2 points; exactly where the hood deflector would come down onto the hood if it moved at all. I have now taken off the hood deflector, but am now out cash and have damage on my hood from this deflector. Is there anything I can/should do?
Thanks in advance.
Protege_fan
On another topic, I wanna stop the problem I am having with my car radio in my 2001 ES. I can't turn it up loud, because the radio "misses" and sounds like it's gonna die. Would another set of speakers cure that or not? Thanks.
Pro_fan
But, it may just be inherent to that radio. I have heard complaints from owners of every Mazda vehicle that uses this new modular system (Protege, Miata-except Bose, Tribute, MPV, Millenia-except Bose, 626-except Bose). But, I really hear complaints about the Protege5. I've listed to it, and it does suck. A far cry from the radio in my '99 ES.
