Thanks, bjh1225
HTH
Dave
Paul
Having an issue with my 99 JGC LTD where the AC is on and is blowing, however, the air is not coming out of the Vents. It is as if there is something restricting the Air flow. I hit the dash once with my fist out of frustration and all of a sudden the AC started working! And the air was cold. But the problem is unpredictable, some times it works, other times it wont. And sometimes, after a half hour of not working, for no apparent reason it will start blowing cold air.
Any idea as to where this problem might be originating?
pleased that worked with the alarm,I wish I could disable mine I even leave the key in it and hope someone will take the POS !
mine does that hesitation a little when first starting off as well,could be lots of things,IAC,Wires,injectors dirty.I think I mine could use some wires and plugs cause it seems to be worse when damp out.Does it doe it all the time on yours?
Thanks in advance.
Thanks to everyone who make this forum work. I almost caved-in and took it to a dealer, who wanted me to have him tow it to his shop. This forum just saved me hundreds of dollars. I'm not saying there's not value in a shop, because there is, I'm just saying that my "little" set of fixes are saving me a ton right now, as I'm between jobs.
Thanks again!
We checked the auto shutdown relay by putting it into the fog light relay socket and turning it on and off. seemed to operate without chattering.
Any suggestions?
In closing good luck but don't expect anything assistance from Jeep.
LET THE BUYER BEWARE!!!!!!!!!!!!!!!!!!!!!!!!!
On an extended test drive, I noticed the following issues:
1) Loud noise when making slow sharp turns (like into a parking space), particularly when turning right.
2) Power door locks unlock, but do not lock, from either the driver's side switch or the passenger side switch.
3) "Service 4WD Switch" and "Rear Light" messages appear on the center dash display panel.
I know that some of these questions have been at least partially addressed in other posts, but I would appreciate new feedback.
I would also appreciate any comments on what else to expect with this vehicle after 125K miles, and whether it's worth buying at this price given this model's below-average reliability rating.
Your loud noise when turning slow could be a Viscous coupling (at least 800 bucks),the power door locks are minor and expected on a Jeep this old,the Service 4wd switch is also very common,you can replace the swithc,the VSS and even the TCM and it may still make that message come up.
Run form the POS and buy a Toyota.
Any help would be great.
HTH
