I am looking for some advise, i have a Jeep Grand Cherokee X reg 4l Petrol. the problem is that when ever i move off from a stationary position the rear wheels make a grindiing noise and then it make a screatching noise. Someone told me it may be the Diff.
Does anyone know what the problem may be?
Cheers --- Clip
Has bought Jeep Grand Cherokee Limited 2000ã. 4,7ë. a box the automatic device.
We in city do not have service on these machines.
At me a problem with a back suspension bracket + with a back reducer.
Very much you I ask give the reference to a site where is detailed instructions and step by step diagrams for all workshop procedures of repair of these units in figures or photos with the description of work.
If you have opportunity I shall be very grateful.
Yours faithfully to you Oleg. e-mail: GELO2006@inbox.ru
Excuse for bad English.
(Çäðàâñòâóéòå! ß èç Ðîññèè (g. Kirov).
Êóïèë Jeep Grand Cherokee Limited 2000ã. 4,7ë. êîðîáêà àâòîìàò.
Ó íàñ â ãîðîäå íåò ñåðâèñà ïî ýòèì ìàøèíàì.
Ó ìåíÿ ïðîáëåìà ñ çàäíåé ïîäâåñêîé + ñ çàäíèì ðåäóêòîðîì.
Î÷åíü âàñ ïðîøó äàéòå ññûëêó íà ñàéò ãäå åñòü ïîäðîáíîå ïîøàãîâîå îïèñàíèå ðåìîíòà ýòèõ óçëîâ â ðèñóíêàõ èëè ôîòîãðàôèÿõ ñ îïèñàíèåì ðàáîòû.
Åñëè ó âàñ åñòü âîçìîæíîñòü ÿ áóäó î÷åíü áëàãîäàðåí.
Ñ óâàæåíèåì ê Âàì Oleg. Ñâîé e-mail: GELO2006@inbox.ru
Èçâèíèòå çà ïëîõîé àíãëèéñêèé.)
My 05 GC with 40K miles. has the same alarm showing on a 65 degree day on dry pavement. Perhaps there is brake dust on something, or worn pads ? Please post what you find out.
Steve
but more than likley it is the 45rfe they used them on the 2000 jgc
1) Cruise Control light appears on dash when I press the on button, but it will not engage.
2) Mode control (recirculation, floor, floor/vent, vent, defrost, etc.) does not work. All heating or air conditioning comes out of the windshield defrost louver.
I checked the fuses in the cab and under the hood, all tested OK.
Could it be the vacuum line?
looks as if hose runes between the battery ans fender would check that area
I really appreciate the help.
Paul
tuggajb
One moth ago I had a problem with the transmission on my 2000 jgc laredo 4x4, I was trying to troubleshoot the problem but that is not easy, I took the car to AAMCO Transmission center and they did a free diagnostic on the trasn, and took the decision to change it. I order a used transmission on the internet, 45k miles on it + 6 months warranty, $850.00 not bad, now is back to the road.
The dealers have a special tool to diagnostic transmission problems, that is the only easy way, good luck.
Greetings, I'm having an issue with my Grand Cherokee's door locks. They are making an awful squeeking sound when locking. They seem to be freezing up. I tried to access the locks to grease them, but gave up when it appeared that I would have to destroy the door panels to get there. My question is whether it is a mechanical or an electrical issue? The car is parked outside in the elements year round if that helps. It's getting more and more difficult getting into the car by either key or remote. It's like the locks are sticking.
Found 1998 4.0, (complete), is the block and head gonna bolt-up under all the 1994 components?
1. It could be an oxygen sensor, throttle control sensor, or some other kind of sensor.
2. It could be the battery (unlikely seeing as it turns on well, and the battery is less then a year old)
3. It could be the PCM (powertrain control module)
any thoughts on this would be helpful. I dont want to pay thousands to fix a 40 dollar problem.
I bought my 5.9 (we call it THE BEAST) w/55k and the only probs. I had were anti-sway bar links both front axles (easy replacements) and the fact it didn't have its original front seats or radio... until the electric fan stopped working 0ne day ( I discovered the temp sensors switches in the radiator hoses were the culprits...$100 ea.) an the beast overheated one too many times...(even though I 've made a manual switch for it) Now I'm trying to figure out if the knock that's developed is a leak in the manifold or something worse...(knock on wood!) Dispite all that...I STILL LOVE MY BEAST!
So, why did you disconnect the battery? Seems like, (more than once), I've opened the 12v. circuit to do some maintenance, installed a battery, dropped it on some wire loom disconnecting, (shearing or breaking), a connector somewhere, left fuses out, etc. The most recent situation I recall - I missed a wire when I installed the starter-motor. Retrace your steps.
also a loose gas cap can cause the check engine light
So I've removed all the old exhaust; catalytic converter, muffler, and exhaust pipe. Then installed the catalytic converter and muffler, however I can't for the life of me coax that exhaust pipe up around what I believe is a sway bar. Do I need to remove the sway bar? If so, I'll have to take it in somewhere. I tried and that torx nut and bolt is rusted on there solid.
Any advice ...other than "take it in"
Thanks in advance.
Currently the headlights don't turn on. The high beams work fine, but there are no regular headlights so she can't drive the car at night. Also, and I'm not sure if this is related, but sometimes when she's driving the locks will start going haywire and just lock/unlock repeatedly for a minute or two.
Should I replace the switch? What else could it be?
I need help with some out of the box thinking. Anyone ever had any problems with this? Does it hot or cold.
Ta
