Visitor Agreement.
Because of poor sales the FWD RAV4 was discontinued in Canada. The only reason the Highlander is offered in FWD is because of price. Still, most are opting for the 6 cyl. 4WD.
If your information is accurate, I think Toyota is underestimating the demand for this vehicle to be equipped with AWD (particularly in Canada). The only fly in the ointment is PRICE. Toyota has always priced their vehicles higher than comparably equipped vehicles. If this one is priced too high it may not be as successful as Toyota hopes it will be.
My wife and I will be waiting patiently for its release. The Camry stays. However the RAV may be exchanged for the Matrix or a new RAV. Time will tell.
Preliminary Fuel Economy Estimates:
Base engine, manual (city/hwy): 30 / 36
Base engine, automatic: 27 / 32
Base engine, AWD: 26 / 31
GT engine: 21 / 28
These are fairly good. Better than the Pro-5.
Check out the GM site (click on the Vibe)
http://media.gm.com
to see some different pictures and info on the Vibe/Matrix. To read the site, you would think GM did everything, inc. the engines.
Toyota's VC is similar to Subaru's (on manual tranny cars). I think the RAV4 and Highlander have a 50/50 split, too.
-juice
They are compact and cheap to produce, but not at all an ideal design. You hit a bump and do the back axle boogy.
You sure about that? The Celica and Corolla have fully independent suspensions.
-juice
This design is employed by VW with great success. The Jetta, Golf, Cabrio, Beetle, and non all wheel drive Passats all use this suspension as does the 96-01 Audi A4 without Quattro. As you all know, these cars are known for their good handling, although VW has mastered this design by adding something called "track-correction" (something in the design that counteracts toe-out and thus helps counteract the skittishness of older designs). Mazda uses a torsion beam on their MPV. The Chrysler PT Cruiser also uses it. So you shouldn't worry about owning a car with this suspension.
As for the AWD design, I'm glad it uses only front wheel drive unless slippage occurs. Since you don't really need 4 wheel drive most of the time, the reduced strain on the engine saves gas.
I wonder about the fuel savings on the AWD setup. Honda used this type of AWD (Called Real time 4WD) with the CRV and I know the first model CRV didn't manage to get better fuel mileage than the Subaru Forester we bought (I researched at the time we purchased our 5 speed Forester) and the forester uses 50:50 split. The Honda even had a smaller, less powerful engine.
IT's kinda nice to know the power is always going to the 4 wheels since then you know you are taking advantage of AWD all the time...not just when the front wheels slip.
Full time AWD is nice because it reduces understeer and eliminates torque steer completely. The engines in the Matrix won't be overly torquey, so that is probably less of an issue. But drive a V6 Altima and then a WRX and you'll feel the difference AWD makes.
I've charted my mileage on my Forester and have averaged over 25mpg. Not bad for 165hp and AWD. The Matrix could do better 'cause it's lighter.
-juice
That's great, then, for the Matrix.
-juice
-juice
-juice
http://www.autonet.ca/wow/Stories.cfm?storyID=3913
There's also an article in today's Globe & Mail Megawheels section on the Vibe. It says that the AWD has less hp (123 vs. 130)/torque (118 vs. 130) than the FWD model due to more restrictive exhaust routing to get around the rear suspension.
http://www.globeandmail.com/globemegawheels/20011213/good.html
Maybe not any more?
-juice
I too liked it much better without all the cladding and skirting. I do think however that some details will be different in production. Notice the color coordinated side mirrors and B pillar but black door handles. According to the info I have, the side mirrors will be black in the base (as will the door handles). I also didn't like the black "D" pillar behind the glass but this shouldn't matter since the vehicle we ordered (at $800 under MSRP whatever it is) is a base Matrix in Black (so the D pillar should look ok) also with the B option package (A/C, Keyless, alloy wheels). It is due to be made on January 8. We also plan to tint the windows.
-Andrew L
Could be pretty cool.
-juice
-juice
On a car specific basis, yes Toyota will gain more from the Matrix but it's offset by high volume cars sold at a 1.4 like the Camry (made in U.S.).
I'm thinking most models will sell for $16k-$18k with the basic equipment most people want.
-juice
As I mentioned before, My Matrix is being built on January 8 and it's (hopefully) not the first one they make. In any event, they should be on a similar time line.
I noticed that on the official specs, the Matrix comes in 3 different trim levels. Each trim level comes with 5-9 additional options, plus one or more option packages. Then of course there are both 2wd and 4wd versions. Toyota will probably change the option combinations every few weeks or so, based on market supply/demand, which will make it a nightmare to find the vehicle with the right options. I'm sure the underlying goal is to manage profit by loading up vehicles with useless options, rather than truly meeting the needs of the customer.
As an example of this hassle, let's say I want a Matrix XR with side air bags. I can't. But I can get frills like expensive alloy wheels or a DVD navigation system, or other options. For side air bags I need to step down to the base version or step up to the XRS version. But on the base version, power locks/windows, and AC are optional. Of course Toyota will have the usual disclaimer that their vehicles will be equipped with "popular" (with who?) option combinations. The bottom line is that it will be generally difficult to find the right Matrix, unless one is ready to buy one with some useless, expensive options.
If Toyota plays the same options game that they played with the RAV4, chances are they won't get their target young buyer, who may be turned off by the high price and dealer markup. Based on the complicated options scheme devised for the Matrix, it looks like Toyota hasn't learned that younger buyers prefer simple, straightforward pricing(like Honda).
