Will try to clean first but may have to remove.
Any thoughts on cleaning the sticky buttons?
Anyone know how to remove the unit?
Has anyone been able to get the promised brake override installed? I know some claimed that the 2008 Sequoia came with this already in place but ours definitely does not have it.
Have any of you had any luck getting this repaired by non-toyota franchise mechanics? Is this the whole enchilada or nothing sort of repair or are there various components that can be diagnosed and replaced piecemeal?
I would like to a permanently disengage the VSC. How can I accomplish ?? It gets in the way (by cutting the engine power when needed) in soft sand, mud, snow, slush etc. A REAL nuisance.!!
Thx ..... Chs
Thx ....... harbo
Is there a way to use the Nav. system while driving?? Instead of pulling off the road? Thanks so much for any help.
Also - my power antenna died and Im going to replace it with a fixed mast. That too doesnt not even show up in a repair manual - does anyone know where the access port is for the power antenna - I cannot locate anything in wheel well or door. Glove box maybe? I've had this 2001 Toyota for 220k miles just under 10 years and no regrets. Has saved me bundles vs other big SUVs friends have.
Tks all,
1) Close all doors
2) Insert your MASTER key (BLACK) into the key cylinder
3) Turn the ignition switch from LOCK to ON 5 times within 15 seconds (key end at ON)
4) OPEN then CLOSE the driver's door 6 times within 20 seconds
5) Remove the MASTER key from the ignition switch, insert the blank key in the key cylinder then turn to ON position
6) While the blank key in the ON position, wait 60 seconds or more to allow the blank key register the key code
7) after 60 seconds, remove the key. Open then Close the driver's door to end the process.
Has anyone successfully programmed an additional key/transponder for Sequoia 06?
I am trying to decide whether to get a used Toyota Sequoia or a Volvo xc90. I had a 02 4Runner until I totaled it last week
My wife would like me to throw this in. If you have a dog, you and your dog have probably enjoyed the back window that rolls down on your 4Runner. Sequoia has it, Volvo doesn't. Your dog will miss that feature if you go with the Volvo!
Two rear latch handles (cost about $50). Change Castrol Syntec oil / filter each 10,000 miles. That's about it. Get about 17 mpg around town. 20 /21 on highway mostly in the 70+ mph range. Lots of discounts available through the Toyota dealers for service. Usually 15 to 20 %.
Basically I'd buy another Sequoia in a flash. Bulletproof. Expect this 2002 to go 300,000 unless you would like to buy it now. (-; sorry not for sale.
Grandkids love it ..... family loves it ..... wife loves it ... likes driving and riding the Sequoia over the Audi A8L.. Although the Audi is the "high speed" cross country cruiser.... and the Saturday to dinner with guests ride!! <(-; No Volvo experience.
Our problem is the height my 13 year old Lab has to jump up just to get in. He tries and tries but just can't bring himself to jump up. I think he really misses our Chrysler T&C mini van.
inspected. Got call that it failed. It has a 1 3/4" hole in the frame near the front sway bar bracket/mount. I've got a little over 90K miles. After a quick google search I found that the 2001 tundra and Tacoma had a recall for this exact issue.
I contacted North America Toyota and said no recalls for the Sequoia, you're out of luck.
PLEASE - calling anyone else who has experienced this - I want to make it my business to organize other Sequoia owners with this problem to demand compensation/action from Toyota.
Thanks in advance
Take off the rear wheels. On the back side of the wheel hub, you will see some electrical lines going in to the wheel hub.
Take off the bolt holding in the sensor. If there are metal flakes on the magnetized tips, clean them off and then replace.
You will need to reset your computer by disconnecting the battery wire for a few minutes and then reconnect.
Thx all ..... Chs
I just contacted my Toyota dealer to file a report. They informed me that someone from Toyota would be in touch with me.
The Toyota Sequoia is built on the same frame as the Toyota Tundra that is currently being recalled. Therefore, Toyota needs to add the Sequoia to the same frame recall as the Toyota Tundra.
I'm sure there are many Toyota Sequoia owners out there that are not even aware that their driving an SUV that has a rotting frame and is very unsafe. All Sequoia owners need to have an "independent mechanic" check the undercarriage of their Sequoia for "frame rot", as soon as possible. This is a major safety issue that Toyota needs to address immediately.
