Go to a hot rod muffler shop. ALL exhaust work is very difficult do-it yourself work but not very expensive to purchase. If it leaks or bangs against the underside, it will not seen like such a bargain. Be advised that any freeing-up of an exhaust system will increase noise (good or bad depending on age, marital status, etc.).
I've got a 2001 LTD...had the vibration since I took delivery. Most noticeable in cold weather (<30 degrees overnight). I'm working on a resolution with Toyota now. I hope to have this resolved soon.
Just wanted to let you know that I have this same problem with the front diff. on my 2002 SR5 Sequoia. Purchased in Aug.2002 I dont think that this problem is only limited to the 2003 models. The noise in mine also stops when 4 wheel drive is engaged or when the fluid warms up.
Toyota told my service manager that if I had the problem Toyonoise had it would be a loud sound and that it wouldn't be a hum. Well I am a bad person for using the wrong descriptive in my inital complaint. The bottom line is I bought this truck for Toyota Quality Control.
I told the dealer that the vibration and "sound" is prevelant at 35-45 and 60-70 mph and has more to do with colder weather.
He is arranging a meeting with Toyota to discuss this matter. The same Toyota Rep who drove my car 4 miles in on a busy street where you know you will get moving along at a turtles pace.
My vehicle will be in for check #2, with only one more to go. I hope Toyota will either truly explain why my Sequoia has this vrbration and sound at certain intervals, why it is doing this on cold days, and admit what has been proven so far. There is a problem. Its going to be in 70's next week.
I also had the squeaky sunroof. The SB fixed it. They said it requires removing the headliner replacing some hinge hardware and installing a rub strip. I will update after the repairs are completed.
-Mike
Also, the lowest quote I've received on an extended Toyota platinum warranty (6 year/80,000 miles) with zero deductible is $1105. Does this sound reasonable? Another dealer quoted $1255. Another didn't offer the Toyota warranty but one from the Southeast distributor that was no where near these amounts (way overpriced).
I've chalked it up to the incline parking letting gas trickle to an area it shouldn't be in... or something like that. I hope I'm right.
Pricing differs depending on the region you're in, but for a 2001 SR5, 2WD, w/33K, I picked these two quotes out: 5yr/80K miles, $973.00 and 5yrs/100K for $1,074. I'm in Florida.
I've also heard that State Farm is quite competitive and offers very comprehensive coverage as well.
So check out your credit union or insurance company, you might be better off there. BTW Toyota does not sell warranties themselves, but authorizes companies to offer the product on their behalf, they get a percentage of whatever the member pays.
Kevin
LEAPplays.com
LEAPplays@aol.com
After further inspection I found that the right rear brake's backing plate was also wet and had small pieces of debris (pebbles an the like) stuck to the plate. Ran the car over to the Toyota dealer and was told that the car was unsafe to drive until the leaky axle seal is repaired confirming the axle seal problem.
My Toyota - I love it but the surprises are coming quicker then with my older Toyotas.
Anybody else had leaking axle seals?
I am wondering if the brakes are the problem to shudder/vibration and read somewhere on this site that there was a TSB brake upgrade for Sequoias that were in the a certain vin# range.
Anyone experience a similar problem?
I have had several cars and drive a police cruiser and have never seen this before. I am very disappointed that Toyota would use an interior plastic that scratches so easily under normal conditions.
jfd3rd- Had the left rear seal on my 02 fail around 12K miles. Tech said a spring that holds the seal in place was omitted during assembly. Wasn't the first one he had seen either.
I hear 2 clicking noises from the center of the dashboard after startup and upon acceleration; first at about 25 mph and the second at about 30-32 mph. Doesn't happen again until I turn off the engine and turn on again. Dealer says its the ABS and it's normal.
Has anyone experienced this? It is annoying if nothing else.
Also, what about breaks? It feels like mine "stick" momentarily when I take my foot off the pedal - sometimes, not every time? Dealer says there's no problem, but....
Thanks for any input.
Has anyone else seen a problem using non Toyota Oil filters?
:-) Let your dealer take a look.
I have really enjoyed my Sequoia, but I also have been disappointed in how easily the interior scratches. I am also a little worried about the AC because the blower seems to almost cut off at times for no reason. Of course, I can't get it to duplicate the problem while at the dealership, so they have been unable to address it. In their favor, they offered to keep it for a day and give me a loaner while they look into it, but I haven't done it yet. After reading about the AC problems here, I may take them up on it before I get out of warranty.
The Crown Toyota serviceman was very helpful and he was aware of the brake vibration problem. It was a good feeling to get it fixed under warranty.
Has anyone else experienced this problem? Toyota tells me to only run the ac on fresh air, which I do the vast majority of the time, but it seems wrong that I have to take special measures to ensure that my car does not stink. After all, I purchased a Toyota because of its reputation for quality and durability.
Go to:
"Mazda Tribute/Ford Escape problems" thread and read posts 1705,06,09,11,13.
