A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Subaru Impreza WRX Wagon
1959698100101115
    I agree - they should have told you if they were going to charge you. Sadly that's all too common now, they just assume you'll pay. Colin can tell you about his BMW service experience. The dealer might even view it as adding value, not hassling the customer with questions, just fixing stuff.
    Of course it costs them time and money just to identify the problem. Would you be willing to pay for an hour of labor for them to diagnose the problem? My dealer's hourly labor rate is $92.
    My suggestions is to diagnose-it-yourself, given it sounds like you want to fix things yourself.
    Why not upgrade the rotors? Get Hawk pads, something like that. You sound like you're totally capable of doing that. There are lots of resources on the web for getting help working on your Rex.
    So I say, change your strategy, stop going to mechanics for these issues.
    -juice
  • kevin111kevin111 Member Posts: 991
    Can understand your frustration. It is a fairly new car ('03?). For things to go wrong this quickly is odd. Especially with more major things like struts, side-mirrors, and brakes. Hopefully this is the end of troubles, and the rest is smooth sailing?
    - In terms of the brake pads, it has been widely known that the brake pads of the WRX do wear down quicker than other car's pads. It might be due to a softer compound that catches quicker to produce a shorter stopping distance over more "conventional" cars (see Camrys and Accords).
    Mine have about 38K miles on them, and I might look to replace them at between 50-60K miles. Most of my miles are highway. A friend of mine is going to replace her pads at 30K miles. When I am ready to replace the pads, I will probably get Hawk pads, since they stop shorter, and do not need the consistant breaking capabilities of track racing that Bremos or Stop-Techs provide.
    - One other thing about your break pads. Since it is known they wear out quicker, could the temperature fluctuation of your area (going from very hot to extremely cold) cause the pads to warp a little? Not saying it is likely, but possible?
    They also chose brake pads that are quiet for the US.
    Europeans are generally more tolerant of noisy brakes and willing to make that trade-off.
    -juice
  • celica115celica115 Member Posts: 169
    When the brake pads are almost gone, dose the brake ALWAYS make the indicating noise? If it dose not scream and you don't know it wears out, is it going to damage the rotors? Thanks for input.
    You should hear the squeelers first, I believe. But if you do change the pads ASAP, I wouldn't even drive it any more except to get it home or to the shop.
    -juice
  • nixomosenixomose Member Posts: 95
    yea, I'm going to do the rotors and pads together, the rotors are really messed up. I'll take a look at the hawks, thanks for the heads up. One other technical question I hope somebody knows. I'm not so keen to buy the shop manual just yet (I usually wait for at least the warantee to go out before I need it anyway).
    Does anybody here know (or know where I can find out) if these calipers cause the ABS to break if you put backpressure on the caliper?
    I remember hearing a long time ago that the early abs systems would brake if you push backpressure on the pad and you had to bleed the brakes instead. My gti, oddly enough does not require this. I was wondering if anybody knew about the wrx. I don't generally have another person around who's willing to spend all afternoon hanging out so they can step on a pedal for me a few times. And I don't particularly trust those little canister one-person-jobbies. It's just a lot simpler if I can do it all myself. (I know, I know you're thinking I should be flushing the brake fluid anyway since it's two years old.)
    Then again, I'm not sure it's such a sin if I do brake the abs system in this car. :-)
    Power bleeder....I need to invest in one also.
    -juice
    Nixomose, the OEM rotor is about $75.00. My mechanic told me not to buy the cheap aftermarket rotors becasue they are thiner.
    Gee, I was hoping for something *better* than the factory rotors...
  • andmoonandmoon Member Posts: 320
    Although it does not affect my braking, the front rotors on my wrx has score lines on them. (15K miles). I was going to point them out at the next service. Anyone else with marked rotors?
    Don
  • pathstar1pathstar1 Member Posts: 1,015
    The Tire Rack has at least 4 different replacement rotors for WRXs, some quite affordable. You can even replace the front rotors and calipers with Brembo large disks, for the small sum of $2500 ;-) .
  • karl1973karl1973 Member Posts: 89
    There has been quite a few broken outside mirrors, and most of them were not caused by being hit.
    I had the passenger side mirror replaced when the ring holding the spring inside the arm broke, and the mirror swung free. The technician came out and took a look and confirmed that there was no paint chip on the surface (not a hit), and everything was covered under warranty.
  • locke2clocke2c Member Posts: 5,038
    Hmm, I'll be damned! If that was the case for you too, nixomose, sorry about that. Seems really odd is all.
    ~colin
    That's exactly what happened.
    And, yeah my rotors are scored badly, both fronts.
    But again, it was so easy to do the pads, I ordered some rotors, and it'll be worth it to take it apart again, probably 10-20 minutes to have the brakes be smooth again.
    Karl: do you have any documentation, website, anything with any information about the broken mirror, or maybe a claim number with a subaru call center?
    Perhaps I can refer it to the dealership and see if they care.
  • prayerforprayerfor Member Posts: 161
    FWIW, a large number of WRX owners have reported having their brake rotors become grooved over time. Although I'd stop short of calling this phenomenon "normal", it is common, and should not adversely impact the car's braking performance.
    If you're getting shuddering up through the steering wheel, then you've probably got what is known as DTV (or Disk Thickness Variation), which is usually attributable to some pad buildup on the rotor itself.
    I had the DTV problem on my WRX's front rotors (self-inflicted BTW, stupid me), and I remedied it by switching out the pads to Carbotech Bobcats, and then bedding in the new pads aggressively to abrade off the residual pad material. My brake problems went right away and have stayed away, despite the still-grooved rotors.
    Maybe too late for nixomose, but hopefully this helps someone else.
    funny my wrx would be doing a lot more than 70 after 3 or so shifts...no blow off hiss from mine either.
    Well, I picked up the rotors today, going to take a long lunch break and put them on in the parking lot. never did car repair at work before, wonder if they'll care.
    Somebody explain blowoff hiss to me? I get the basic idea behind a turbocharger, is there some overpressure valve or something for when you downshift and the turbo hasn't spun down to the lower engine speed or something?
    I do hear some hissing sometimes at full throttle, (like in 3rd or so) which I figure is odd given the amount of wind and engine noise, I figure I shouldn't be able to hear much else.
    is caused by the need to relieve the air produced by the turbo when you close the throttle. If not done, it would "bounce" off the throttle plates and the shock wave would then hit the compressor fan. Not a good thing, as it can cause damage. So the "blowoff" valve is added to relieve the pressure. Usually this exhausting of compressor air is vented into the air filter, to quiet it down. Some like the sound, and vent it into the air (hiss). Some really like the sound and buy aftermarket BOVs that make loud sounds (some call this rice ;-).
  • p0926p0926 Member Posts: 4,423
    It is also possible that a passerby hit the mirror (intentionally or not). I remember long ago when inebriated teens use to break off mirrors of parked cars for fun (Yeah I know, what a warped definition of fun).
    -Frank P.
  • 1hokie1hokie Member Posts: 36
    Are blown speakers covered by warranty? I have a completely stock (for now) 2003 WRX wagon, 16k miles, less than a year old, and I think my passenger side speaker (oddly enough seems to be the "tweeter", though it could be the full range at the bottom of the door) is blown. I don't listen to music all that loud - "7" if I like the song - "8" if I really like it.
    Seemed to have happened in the past couple weeks - too cold for the windows to go down and drive, so my stereo was at "8" tops. I have the upgraded sound system.
    I don't feel I've abused the system, and I find it odd that the speaker would be blown. Should I expect hassle from my dealer, or just spend $40 and get a new speaker myself? (or replace them all before another one goes, with better ones?)
    Not sure but I think speakers should be able to take full volume so the volume you listen to shouldn't even be a factor with the waranty.
    If for sure it's blown (which would be very unusual given the conditions listed), then I think it would be covered under the 3/36 warranty. What do you hear when you adjust the balance all the way to the right and the fade all the way forward?
    -Frank P.
    and now the shimmy is gone, I guess the rotors were warped too.
    so which roters and pads did you buy? Do you feel any different comparing with the OEM roters?
    Is it worth saving that speaker? I mean, they're basically paper dual-cones. If you have the premium sound then they're still your basic paper two-way speakers. (I did the swap, someone gave me the premium ones for my Forester)
    This is a sign from above to get some real speakers in there. ;-)
    -juice
  • msdannyjmsdannyj Member Posts: 22
    ok, I finally got my car today (left it yesterday morning) after a mega audio upgrade. Installed items -
    Blaupunkt San Francisco CD72 Receiver (this thing is more complicated than the Mars rover)
    Rockford Fosgate 851x 5 channel Amp
    Blaupunkt A08 10-CD changer
    Infinity Kappa 60.5cs comp speakers for front
    Infinity Kappa 42.5i speakers for back
    Two small issues,one, the front speakers came with only one tweeter, so the passenger side is still connected to stock tweeter until i get the other shipped. Two, the 2nd din is now covered with plastic neatly but I would like a spacer that doubles as a compartment. Anyone know where I can get it? The damage for installation - $500. Well, a little more than expected but hopefully worth it. The guys at the shop did a good job as the finish is clean and laughed at Subie's stock speakers.
    Anyway, I am on the NJ turnpike around 9 pm listening to Tom Jones covering Prince's Kiss on my new system and this new Altima blows past me. Hmmm, can't let that happen, can we? So I showed him a little Subie love. The car hit 125 and I was seeing his headlights in the rear view. I dont think those cars do over $115-120 max as I slowed a little and waited for him to catch up. Then I came to my senses and slowed down to speed limit as I knew that my Passport might be useless at that speed.
    Well, any music lover in a WRX still driving with stock speakers should junk it and get something better.
    Well,I am off to play some poker and lose more money. Isn't life great?
    that's really odd, who ever heard of a component set being short a tweeter? did you buy it from the shop that did the installation?
    ~c
    For me, I would like to spend $500 to have a K&N filter and Cobb Stage 1 upgraded.
    you'd get more palpable and measurable results from the carfi gear. :)
    ~colin
    You can certainly say that WRX rocks!
    -juice
  • grosegrose Member Posts: 3
    I just bought my 04 WRX wagon yesterday, and I am pretty fired up for this car. I have never really been a "car person," but I would like to take this opportunity to learn more about my WRX, now that I have a car worth knowing something about. Can anyone recommend some resources for learning about my WRX (and performance cars of its sort) generally, as well as specifically about how best to drive and maintain the WRX to ensure that it continues to perform optimally. Further, is there a good place to find a complete presentation of aftermarket modifications, their effect, and their cost? Thanks for your help.
    I bought my system components from online dealers (hookedontronics mainly). I contacted them about the missing tweeter and they are sending another one.
    I was very close to going for cobb tuning but warranty issues (added security) and the old adage 'if it aint broke, dont fix it' kept me from it. While I do enjoy driving, I am not a typical street racer. I am upgrading my tires but thats as far as I am going at this point.
    Anyway, I am still figuring out my receiver and I can only say that Germans do take their car audio seriously.
  • saintvipersaintviper Member Posts: 177
    Went to the auto show last weekend and they had a Saab 9-2X sitting on the show floor. It wasn't open to sit in, but I looked it over pretty well.
    All of the changes were cosmetic, but overall, looked pretty good. The wheels look better to me than the standard WRX wheels. The dash was about the same with some minor cosmetic changes to the climate controls. I wouldn't say it looked any better, just different. The seats were completely different as far as I could tell. The grey and black two tone leather treatment looked pretty good. I found that some of the other Saab seats I sat in didn't seem especially comfortable though. The steering wheel was different, and smaller than the WRX wheel which I think is too big.
    Other than that, everything else looked the same. I definately got the impression that it was just a rebadged WRX as I looked at it. Luckily for them I suppose, the Subarus where on a different floor. Last year Saab and Subaru were fairly close to each other.
    There was no price on the car, but I think that if it were not that much more than a WRX, I'd consider it. If it's closer to $30,000 which is likely, I can't imagine why anyone would bother with it.
    9-2x also gets the Forester's interior and the STi's steering wheel.
    -juice
  • bluesubiebluesubie Member Posts: 3,497
    I saw it in Philly and thought is was nice, but not $30k nice (which is the number I keep reading).
    Aside from pricing, I think the powertrain warranty on Saab isn't as long. Isn't it 4/50 b to b?
    -Dennis
    Well lets see... Just because there is no mark doesn't mean it wasn't broken by a kid bending it forward snapping it and then putting it back in place so it doesn't look like they did anything to it.... Seen that in parking lots on a few occassions.
    As for the warranty thing. When you sign a document, do you not read it? Or do you sign things blindly? I'm 99% sure that you signed a document when you dropped off the car at the dealer stating you would be willing to pay the XX diagnostic fee if in fact the problem was not under warranty. Most dealers (even the bad ones) will call before proceeding but I guess that yours went by the document you signed. Crappy thing, but 100% dealer fault, not Subaru.
    As for the brakes? 19K miles is not uncommon for brakes on a wrx. 19-30K is the standard brake replacement for the WRX at least here in the NY/NJ/PA area from my experience (I've done at least 30+ brake jobs on WRXs in the past year or so)
    -mike
    Mike,
    I am starting to get a little steering wheel vibration at high speeds when the brakes are applied lightly...maybe time for a brake job.
    What kind of brake jobs have you done? Were they mostly resurfacing the rotors? Popular pads? Aftermarket rotors? I also remember one of the auto magazine long term wrx's having brake problems with the dealer doing a resuface under warranty. My 03 wagon just turned 15K.
    Don
    All the jobs we've done have been either pads, rotors and pads, or Big Brake Kits. For the WRX I'd suggest getting either blank replacement rotors or some upgraded ones like the ones sold at http://RacingBrake.com We actually put together a "kit" for upgrading the brakes on the WRX which includes flush, uprated fluid, Hawk HP+ or HPS Pads, ss lines, upgraded slotted/drilled rotors, speed bleeders etc. :)
    Cutting rotors IMHO is a waste of time since blank replacements are about 4x the cost of cutting them might as well get the replacement rotors rather than pay $10 to get em cut.
    -mike
    Thanks for the info. I didn't know wrx rotors could be bought for $80. a pair. If the dealer doesn't fix them for free then I'll just replace them.
    Don
  • cptpltcptplt Member Posts: 1,075
    well , just got the car back after getting the juddering clutch replaced per TSB. Its a thousand times better but there is still a very slight judder but it may also be me getting used to the lower pedal pressure and sharper take up. See how it goes with more miles.
    I foolishly asked them to fix a squeaky window. They fixed it, now there;s a slight rattle! Its barely noticeable and with the radio even on low volume its imperceptible but OCD me hears it!
    how often should I change the airfilter and PCV? I only drive 7K a year.
    3 years for the air filter, 'cause those get dirty fast. Maybe 6 years for the PCV.
    -juice
    Don --
    My wagon developed a similar problem with the steering wheel vibrating under braking at higher speeds. In my case, however, it was pretty easy to diagnose the cause of the problem -- I went out and did a series of 10-12 "road dyno" runs to ~90 mph, and, like an idiot, kept the brakes depressed between runs as I read and reset my data recorder (incidentally, don't do this).
    With the brakes heated up as much as they were, that left pad deposits/imprints on the rotor surface, resulting in what is known as DTV (or Disk Thickness Variation).
    DTV caused by pad deposits is like 100x more likely to be the cause of your vibration problem than is the disk itself being warped. Under typical (or even very aggressive street) driving conditions, your stock rotors are not going to warp (from stoptech.com):
    http://www.stoptech.com/whitepapers/warped_rotors_myth.htm
    Anyway, the solution I found worked like a charm was to splurge on a new set of front pads (I chose the Carbotech Bobcats, which at least ~6 months ago were pretty widely viewed by the folks at nabisco as the best aftermarket street pad out there), and then I bedded them in pretty aggressively (well on the aggressive side of Carbotech's instructions) to abrade the offending pad deposits right off the disks.
    That cured the problem right away, without my having to do anything more drastic. So that gives you something you could try anyway, before springing for replacement rotors.
    Dave
    stoptech's personal "disc thickness variation" holywar is semantics.
    is the disc REALLY warped when we've been calling it that all these last 40+ years of disc brakes? no, probably not.
    regardless of the cause, the result is an uneven surface. the long-established methods of resolving this problem, by turning the face of the rotor on a lathe or simply replacing them, will do the trick no matter what.
    semantics. hope they're enjoying their 15 minutes of fame...
    ~c
  • stinstistinsti Member Posts: 3
    I am planning to purchase a sti, but I am really worried about the reliability of this car. I have been driving a european car for several years, and it has been giving me countless amount of problems. Therefore, I am out to get advices from the people who drive and own sti's or wrx's to make this important decision of purchasing one.
    Well, I have already heard that subaru's does have problems, and my friend deals with a problem himself. He experiences the rpm going up and down from 600 to 1500 during startup when it rains. Does any of you guys experience this problem or any other. Honestly speaking, would you guys buy subaru again? Is it reliable?
    How reliable are sti's and wrx's? What is the reliability of subarus?
  • nowakj66nowakj66 Member Posts: 709
    Consumer reports rates the WRX as average reilability and ranks it as one of the best sporty cars out there. I would not hesitate to get one for reliability reasons.
    I do not have a WRX but I do have a 2002 LL Bean which has been very reliable. So far there have been 2 recalls (tranny-park and winterizing rear suspension pieces) on the Bean. All taken care of by the dealer.
    There may be other reasons NOT to get a WRX or STI (like need for a large backseat). But reliability is not one of them in my mind.
  • mikenkmikenk Member Posts: 281
    There is no statistically accurate data on just the STI, or actually on just the WRX. However, in general, as a car brand, Subaru rates very high in long term reliability approaching the levels of Toyota and Honda per CU data.
    I would suspect that the STI would tend not to be as reliable as the typical: more new components; driving style; bred for performance, but still better than similar performance cars. I certainly would not shy away from any Subaru product because of anecdotal reliability concerns.
  • epp1epp1 Member Posts: 48
    ...http://www.grdperformance.com.
    So, finally took my '02 WRX Wagon to NaperThrill, IL from Minneapolis over the holidays for some work - APS Uppipe, APS TBE (sans cats, for now), and Ecutek Reflash.
    Wow. HP and torque at the wheels around 220 each. Loosely translates to about 285-290hp at the crank based on baseline pulls. Sound may not be for everyone, but she purrs like kitten until you climb above 3K (so, like, all the time) and there is drone at high speed cruising (70mph+).
    For the first time ever I got mid-20s+ MPG on the way home with a fully burdened ride (Santa was good to me) and bike racks up top.
    Tuan (tuner) and Chris (wrench) did nice work. Have a low RPM rattle that popped up recently that I need to address - likely loose hanger or 02 sensor cable.
    Power comes on sooner and pulls - hard - all the way to redline in each gear. Can't wait for the snow to be gone and get my Nokian Haaka/OE wheelset off and put the P1/Sumi set back on. The winter tires are just overwhelmed by the power. Somewhat conflicted on the no-cat situation - may opt for APS High Flow Cat this summer.
    E-mail me at sepp at mn dot rr dot com with questions.
    Sean
    Colin -
    Regardless of whether or not the stoptech article I linked to is a "holywar" and/or "semantics", the point I was making is that my car exhibited the exact same symptoms that Don described, and the problem was rectified without having to turn or replace the rotors.
    true... depends on how bad you have warping/deposits/whatever. it has to be pretty mild for the heavy bedding trick to work though.
    ~c
